I deleted the intel-ucode package by mistake and now I cannot boot because I get the error - intel-ucode.img not found.
How do I fix this? ![]()
Boot up from the install medium in live mode. Open up a terminal window and become root…
su -
Now issue the following command…
manjaro-chroot -a
Select the correct root partition if there is more than one ─ enter 1 if you get something like “0/0”.
Now issue the following commands…
pacman -Syyu intel-ucode
update-grub
Let the commands finish, and then it should be safe to reboot.
The system should still be bootable if you edit your Manjaro boot entry in grub (press e in grub menu) and adjust the initrd line from
initrd /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
to
initrd /boot/initramfs-5.4-x86_64.img
and then press f10 to boot this edited entry.
Reinstall the package or at least update-grub to get a bootable system.
