deadbeef seems to have a problem playing FLAC files.
If deadbeef --version reports that you are using v1.9.1, build new version 1.9.2 from AUR
pamac build deadbeef
You’re behind with the pkgbuild updates, also search exists in this forum and AUR maintainers are not obliged to push pkgrel bumps for rebuild
Seems okay here…
pamac install deadbeef
2 aur/deadbeef 1.9.2-2 [+60 ~4.58] [Installed]
Launch from terminal… enter the music folder and do 'deadbeef ` and autocomplete.
deadbeef 101\ -\ Unaccompanied\ Cello\ Suite\
No.\ 1\ in\ G\ major,\ BWV\ 1007_\ I.\ Prélude.flac
