"dbus-org.freedesktop.home1.service not found." - i set "NoExtract = usr/lib/security/pam_systemd_home.so" in pacman.conf
journalctl shown:
dbus-daemon[1108]: [system] Activation via systemd failed for unit ‘dbus-org.freedesktop.home1.service’: Unit dbus-org.freedesktop.home1.service not found.
and was confusing not only to myself, i read that it is not necessary, so my /etc/pacman.conf now contains:
and i reinstalled systemd as suggested on that page:
pamac reinstall systemd
Yep, was an annoyance also for me: Systemd-homed annoyance (when disabled, the journal log is literally spammed)
:+1: Thank you for sharing! :+1:
However, could you do me a favour and:
  • edit your question by pressing the 3 dots and the pencil icon
  • make it into a real question
  • cut and paste the solution into a reply to your own question
  • click the 3 dots below your own answer to mark a solution like this:
    Solution
    so that the next person that has the exact same problem you just had will benefit from your post as your question will now be in the “solved” status.
:crossed_fingers:
