Hi All,
I’m back and asking for help from the best user community on the web.
I was finally able to upgrade from DaVinci Resolve Studio 18 to 18.6.2-2. The upgrade went well, but now the application won’t open at all. Let me know if more information is needed to help correct the issue.
I have already done the following:
Upgraded DRS using Add/Remove Software
Installed the libxcrypt-compat after the upgrade per a previous solution (DaVinci Resolve Does Not Open or Start )
Upgraded my Kernel to 6.5.5-1
Upgraded the entire system with -Syyu
Updated my nVidia driver from 470 to 535.113.01
Ran the DVS build/install one last time
Reboot
Does not open
Current nVidia Driver
workstation ~]$ inxi -G
Device-1: NVIDIA GA102 [GeForce RTX 3080] driver: nvidia v: 535.113.01
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: nvidia
gpu: nvidia resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
API: EGL v: 1.5 drivers: nvidia platforms: gbm
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 renderer: NVIDIA
GeForce RTX 3080/PCIe/SSE2
Best regards,
Gerry
cscs
23 October 2023 21:29
2
Just give us inxi -Fazy
mapman97:
Does not open
It would be much more helpful with some form of log or output ..
For example .. try starting it from terminal.
Also please see how to format code etc:
Difficulty: ★☆☆☆☆
Formatting differences
Discourse – this forum’s engine – uses Markdown to format its posts, and removes “unnecessary” whitespace.
Terminal commands often produce output formatted so that they are better readable by the user, taking advantage of the monospaced font used.
Programming code often rely on indentation to make it more readable.
Using preformatting in Markdown
Markdown includes a pattern to provide preformatting when necessary.
You only need to put the part to form…
Thank you for your reply.
I ran the inxi -Fazy script and see everything about my machine. Is all this information necessary? Will this compromise my security if I post?
Regards,
Gerry
Option -z removes identifiable information
-z, --filter Adds security filters for IP/MAC addresses, serial numbers,
location (-w), user home directory name, host name. Default on
for IRC clients
“For example … try starting it from terminal.”
I have never been able to open DRS from a terminal and I tried everything. If anyone knows, please share.
With and without sudo
resolve
davinci-resolve-studio
/opt/resolve/bin/resolve
/opt/resolve/
Thanks,
Gerry
Thank you for the clarification. inxi looks very handy.
Gerry
I really hope this helps. Thanks again all.
$ inxi -Fazyw
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=168ece4a-e887-4756-8d5b-7cba765e4588 rw quiet apparmor=1
security=apparmor resume=UUID=3152ee28-5b26-46bb-807d-add8c321a811
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Hewlett-Packard product: HP Z820 Workstation v: N/A
serial: <superuser required> Chassis: type: 6 serial: <superuser required>
Mobo: Hewlett-Packard model: 158B v: 1.01 serial: <superuser required>
UEFI: Hewlett-Packard v: J63 v03.96 date: 10/28/2019
Device-1: hidpp_battery_0 model: Logitech K850 Performance Wireless Keyboard
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech M720 Triathlon Multi-Device Mouse
status: discharging
Info: model: Intel Xeon E5-2670 v2 bits: 64 type: MT MCP SMP arch: Ivy Bridge
level: v2 built: 2012-15 process: Intel 22nm family: 6 model-id: 0x3E (62)
stepping: 4 microcode: 0x42E
Topology: cpus: 2x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 2x 640 KiB (1.2 MiB) desc: d-10x32 KiB; i-10x32 KiB
L2: 2x 2.5 MiB (5 MiB) desc: 10x256 KiB L3: 2x 25 MiB (50 MiB)
desc: 1x25 MiB
Speed (MHz): avg: 1212 high: 1700 min/max: 1200/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1200 2: 1200 3: 1197
4: 1200 5: 1200 6: 1197 7: 1700 8: 1200 9: 1197 10: 1200 11: 1200 12: 1200
13: 1200 14: 1200 15: 1200 16: 1200 17: 1200 18: 1197 19: 1200 20: 1200
21: 1200 22: 1200 23: 1200 24: 1200 25: 1200 26: 1200 27: 1200 28: 1200
29: 1200 30: 1200 31: 1200 32: 1200 33: 1200 34: 1200 35: 1200 36: 1200
37: 1200 38: 1200 39: 1200 40: 1200 bogomips: 199639
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.0
chip-ID: 10de:2206 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: DP-1 pos: right res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 93
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB
Device-1: Intel C600/X79 series High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1d20
class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 10de:1aef class-ID: 0403
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: e040 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
Device-2: Intel 82574L Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 01:00.0 chip-ID: 8086:10d3 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
IF-ID-1: br-acc24ced576e state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth311d510 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: veth91d018f state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: vethad665df state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: vethbd71754 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-7: vethca937e4 state: up speed: 10000 Mbps duplex: full mac: <filter>
Hardware-1: Intel C600/X79 series SATA RAID Controller driver: ahci v: 3.0
port: e020 bus-ID: 00:1f.2 chip-ID: 8086:2826 rev: N/A class-ID: 0104
Local Storage: total: 19.1 TiB used: 5.99 TiB (31.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD4005FZBX-00K5WB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Extreme Portable SSD
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 speed: <unknown> tech: SSD
serial: <filter> fw-rev: 1012
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD101FZBX-00ATAA0 size: 9.1 TiB block-size: physical: 4096 B
logical: 512 B tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A01
scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD6003FZBX-00K5WB0 size: 5.46 TiB block-size: physical: 4096 B
scheme: GPT
ID-1: / raw-size: 3.63 TiB size: 3.57 TiB (98.40%) used: 330.92 GiB (9.0%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 8.8 GiB used: 268 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 34.0 C mobo: N/A
Fan Speeds (rpm): N/A
Weather:
Report: temperature: 22.71 C (73 F) conditions: overcast clouds wind: from S
at 5.7 m/s (20 km/h, 13 mph) cloud cover: 100% humidity: 84%
pressure: 1015 mb (34 in)
Locale: <filter> current time: Thu 26 Oct 2023 11:48:33 AM CDT
(America/Chicago) observation time: Thu 26 Oct 2023 11:47:50 AM CDT
sunrise: 07:40:18 sunset: 18:42:27 Source: OpenWeatherMap.org
Processes: 675 Uptime: 3d 3h 25m wakeups: 142 Memory: total: 128 GiB
note: est. available: 125.81 GiB used: 13.12 GiB (10.4%) Init: systemd v: 254
Packages: 1613 pm: pacman pkgs: 1592 libs: 437 tools: pamac pm: flatpak
pkgs: 17 pm: snap pkgs: 4 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.30
nikgnomic: post edited to show data in preformatted text format
Thanks to all who replied although none of the suggestions worked for me. The issue was solved by waiting for the next version. I do remember in an earlier post someone suggested I wait for the next version. I waited and now it works and works well.
Regards,
Gerry
system
Closed
19 November 2023 12:06
9
