Hi guys. Just today i installed Majaro on my Hp laptop 4530s with Intel graphics card. All was working fine but after few latest updates when i boot from shutdown. The boot screen goes black and nothing happens. It’s my first try at Linux and i would appreciate of someone kind can guide me to a solution.
If the output is cut with “>” on the right side, then please expand the window of the terminal or CTRL + - for decreasing the font size and CTRL + + for increasing.
Hi Megavolt.
Thanks for the reply. I couldn’t hold myself and did a fresh install. I have done few updates yesterday and will try to be careful with the ones for intel display driver. If anything i will update you hear and post the results of command at the top.
