I updated everything using the “install/remove apps” GUI, and after a reboot, I cannot start kde anymore. On SDDM I get this error:
And if I enter my password, I get returnen to this screen instead of logging in.
I tried everything from this thread: The current theme cannot be loaded after update + Unable to access TTY - #6 by fhafha
But it didn’t work
you have broken kitemviews:
sudo pacman -S kitemviews --overwrite '*'
reboot
I just figure this out myself, but thanks! I was looking where the “.so” file belonged to and found it from de Ian packages.
But thanks!
