zirafin
January 19, 2023, 6:35pm
#1
Hello, after the update I noticed that I can’t play CSGO, the fps dropped from 180 to 80. I’m trying to find what was wrong, I just installed fresh steam and csgo - it didn’t help. then a new manjaro - did not help. whenever i find that my nvidia card fan doesn’t spin automatically if you start the game and if i want to play the game and have 180 fps i have to open the nvdia program and turn it on and manually set the fan speed to 70%. then start cs go and play like old times,
can it be fixed?
kisun
January 19, 2023, 6:47pm
#2
Hello @zirafin and welcome to the manjaro forum!
zirafin:
can it be fixed?
… possibly yes.
First we need more information about your system. Could you provide the output of these commands:
inxi -Fxzc0
mhwd -li
mhwd -l
Also take a look in these posts, to get better help further :
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to this tutorial, so if you’re reading this in response to a question, please click the link above this text to bring you to the full and unabridged text of the tutorial…
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links when…
zirafin
January 19, 2023, 6:56pm
#3
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
[ss@ss ~]$ mhwd -l
0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
0000:01:00.0 (0300:10de:13c2) Display controller nVidia Corporation:
video-nvidia-470xx 2021.11.04 false PCI
video-nvidia-390xx 2021.11.26 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
zirafin
January 19, 2023, 7:01pm
#4
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: Xfce v: 4.18.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: H81M-VG4 R2.0 serial:
BIOS: American Megatrends v: P1.30 date: 04/24/2015
Info: quad core model: Intel Core i7-4770K bits: 64 type: MT MCP
arch: Haswell rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 2825 high: 3502 min/max: 800/3500 cores: 1: 3499 2: 3501
3: 3499 4: 800 5: 3502 6: 800 7: 3502 8: 3500 bogomips: 56014
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: ASUSTeK driver: nvidia
v: 525.60.11 arch: Maxwell bus-ID: 01:00.0
Display: x11 server: X…Org v: 21.1.6 driver: N/A
resolution: 1920x1080~60Hz
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GM204 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: ASRock driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac:
Local Storage: total: 342.81 GiB used: 139.96 GiB (40.8%)
ID-1: /dev/sda vendor: Gigabyte model: GP-GSTFS31240GNTD size: 223.57 GiB
ID-2: /dev/sdb vendor: Samsung model: SSD SM841 2.5 7mm 128GB
ID-1: / size: 116.81 GiB used: 12.23 GiB (10.5%) fs: ext4 dev: /dev/sdb1
System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 40 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 75%
Processes: 248 Uptime: 2h 3m Memory: 11.63 GiB used: 2.91 GiB (25.0%)
Init: systemd Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1054
Shell: Bash v: 5.1.16 inxi: 3.3.24
kisun
January 19, 2023, 7:27pm
#5
Hm, looks for melike it should.
could you also post the output from this:
cat /etc/X11/xorg.conf.d/90-mhwd.conf
If there is NO output please the output from this:
ls -la /etc/X11/xorg.conf.d
And please use the “formated text”-button ( </> ) for your command output, so it looks more clear.
zirafin
January 19, 2023, 7:30pm
#6
[ss@ss ~]$ cat /etc/X11/xorg.conf.d/90-mhwd.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 525.60.11
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "NoLogo" "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
