Creative Sound Blaster Recon3D Fatal1ty Professional 3D - Switch between Headphones and Speakers
Hello,
Im new to Manjaro and would like to set up my sound card. I got the Creative Sound Blaster Recon3D Fatal1ty Professional 3D. This one got a link for speakers and an extra link for headphones. In Windows i had a software where i could change between speakers and headphones. Looks like this:
How can I switch between headphones and speakers in Manjaro like this? The sound settings tell me that headphones are disconnected, so I cant switch to them.
Greetings
:+1: Welcome to Manjaro! :+1:
Under Linux, this is a feature of the hardware or firmware.
  • If your hardware supports automatic speaker mute when plugging in your headphones, it’ll just work.
  • If the hardware doesn’t support it, the (UEFI) firmware has to support it and it’ll just work
  • If neither do support this, we’ll have to do some hacking so please provide more hardware info:
inxi --full --system --verbosity=7 --filter --no-host --admin
would be a good start!
:innocent:
Hello,
thank you for your reply! I dont know if my hardware supports this. I got my speakers and headphones connected parallel. I just want to switch between them like i did in windows.
I got a legacy installation.
Here is my hardware info:
System: Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=042e01da-0267-46ea-a260-d253937020d1 rw quiet
cryptdevice=UUID=58273342-cfca-44ac-8784-a81cc5a702ae:luks-58273342-cfca-44ac-8784-a81cc5a702ae
root=/dev/mapper/luks-58273342-cfca-44ac-8784-a81cc5a702ae apparmor=1 security=apparmor udev.log_priority=3
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop System: Acer product: AG3-605 v: N/A serial: Chassis: type: 3 serial:
Mobo: Acer model: Predator G3-605 serial: BIOS: American Megatrends v: P11-B4 date: 01/03/2014
Memory: RAM: total: 11.62 GiB used: 2.03 GiB (17.5%)
CPU: Topology: Quad Core model: Intel Core i7-4770 bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 3C (60)
stepping: 3 microcode: 28 L2 cache: 8192 KiB bogomips: 54300
Speed: 1896 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 1896 2: 1896 3: 1896 4: 1896 5: 1896 6: 1896 7: 1898
8: 1899
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 440.100 alternate: nouveau,nvidia_drm
bus ID: 01:00.0 chip ID: 10de:1c82
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9") s-diag: 610mm (24")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100 direct render: Yes
Audio: Device-1: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
Device-2: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series] driver: snd_hda_intel v: kernel
bus ID: 03:00.0 chip ID: 1102:0012
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus ID: 2-3:3 chip ID: 046d:0825
serial:
Sound Server: ALSA v: k5.7.15-1-MANJARO
Network: Device-1: Intel Ethernet I217-V vendor: Acer Incorporated ALI driver: e1000e v: 3.2.6-k port: f040 bus ID: 00:19.0
chip ID: 8086:153b
IF: eno1 state: up speed: 1000 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global broadcast:
IP v6: type: noprefixroute scope: link
Device-2: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Lite-On driver: ath9k v: kernel port: e000
bus ID: 04:00.0 chip ID: 168c:0034
IF: wlp4s0 state: down mac:
WAN IP:
Drives: Local Storage: total: 2.31 TiB used: 888.90 GiB (37.6%)
ID-1: /dev/sda vendor: Toshiba model: THNSNH060GMCT size: 55.90 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: rev: N102 scheme: GPT
ID-2: /dev/sdb vendor: SanDisk model: Ultra II 480GB size: 447.13 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: rev: 20RL scheme: MBR
ID-3: /dev/sdc vendor: Western Digital model: WD10EZEX-00WN4A0 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: rev: 1A01 scheme: GPT
ID-4: /dev/sdd vendor: Western Digital model: WD10EZEX-22RKKA0 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s serial: rev: 0A80 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GT90N rev: 1.00 dev-links: cdrom
Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 447.13 GiB size: 439.09 GiB (98.20%) used: 69.39 GiB (15.8%) fs: ext4 dev: /dev/dm-0 label: N/A
uuid: 042e01da-0267-46ea-a260-d253937020d1
ID-2: /run/media/jaro/Aufnahmen raw size: 931.39 GiB size: 931.39 GiB (100.00%) used: 819.51 GiB (88.0%) fs: ntfs
dev: /dev/sdc2 label: Aufnahmen uuid: 9C8C0B748C0B47EA
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/sda1 size: 400.0 MiB fs: ntfs label: Recovery uuid: 2F5E53C7E6C61409
ID-2: /dev/sda2 size: 100.0 MiB fs: vfat label: ESP uuid: C8C6-3D87
ID-3: /dev/sda3 size: 128.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-4: /dev/sda4 size: 55.28 GiB fs: ntfs label: Sicherung uuid: C2B4D8B9B4D8B161
ID-5: /dev/sdb1 size: 447.13 GiB fs: crypto_luks label: N/A uuid: 58273342-cfca-44ac-8784-a81cc5a702ae
ID-6: /dev/sdc1 size: 128.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-7: /dev/sdd1 size: 927.51 GiB fs: ntfs label: N/A uuid: AC8CBF918CBF5514
ID-8: /dev/sdd10 size: 450.0 MiB fs: ntfs label: N/A uuid: 72F25816F257DCC3
ID-9: /dev/sdd2 size: 486.0 MiB fs: ntfs label: N/A uuid: 54205A5D205A4660
ID-10: /dev/sdd3 size: 450.0 MiB fs: ntfs label: N/A uuid: C66A31BC6A31AA57
ID-11: /dev/sdd4 size: 452.0 MiB fs: ntfs label: N/A uuid: C482391E82391700
ID-12: /dev/sdd5 size: 450.0 MiB fs: ntfs label: N/A uuid: C48EF0778EF0637A
ID-13: /dev/sdd6 size: 450.0 MiB fs: ntfs label: N/A uuid: C25A1B3E5A1B2F23
ID-14: /dev/sdd7 size: 452.0 MiB fs: ntfs label: N/A uuid: F27E8CDA7E8C98CD
ID-15: /dev/sdd8 size: 452.0 MiB fs: ntfs label: N/A uuid: 2A0C86110C85D7E9
ID-16: /dev/sdd9 size: 450.0 MiB fs: ntfs label: N/A uuid: 4682CC1282CC07FF
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 8087:8008
Device-1: 1-1.5:4 info: Lite-On type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 04ca:3006
Hub: 2-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 2-1:2 info: Sunplus Innovation Optical Mouse type: Mouse driver: hid-generic,usbhid interfaces: 1
rev: 2.0 speed: 1.5 Mb/s chip ID: 1bcf:0005
Device-2: 2-3:3 info: Logitech Webcam C270 type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s chip ID: 046d:0825 serial:
Device-3: 2-4:4 info: Lite-On USB Multimedia Keyboard type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2
rev: 1.1 speed: 1.5 Mb/s chip ID: 04ca:0050
Device-4: 2-5:5 info: Realtek USB 2.0 multicard reader type: Mass Storage driver: ums-realtek interfaces: 1
rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0158 serial:
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 8087:8000
Hub: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 20%
Info: Processes: 266 Uptime: 11m Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: 1289 pacman: 1285 lib: 361
flatpak: 0 snap: 4 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
If its from interest: I got a Y-Cable conntected to the soundcard (one plug from my headphones goes to a microphone and to a headphones plug). Looks like this:
https://static.bax-shop.es/image/product/175332/351871/7ade7417/410x410/beyerdynamic_headset_gear_image01.jpg
that looks good, so from a driver POV you’re OK:
So what do you see then when you plug in the microphone into the SoundBlaster?
this is what I get when plugging in my headphones:
Headphones
Hello,
thank you for your reply! I had to switch from Manjaro KDE to Manjaro Gnome because i had some issues with my nvidia card.
Now i got no sound, neither on headphones nor on speakers. Yesterday it worked, after I plugged speakers out and in. But that doesnt work now.
Headphones appear in settings when i connected then over front port, but also no sound.
Here is my new hardware info:
root=UUID=5adc06f6-b0e9-45f9-b84b-ff640d811716 rw quiet
cryptdevice=UUID=227af659-12ef-48a7-8041-d91c05af4db6:luks-227af659-12ef-48a7-8041-d91c05af4db6
root=/dev/mapper/luks-227af659-12ef-48a7-8041-d91c05af4db6 apparmor=1
Desktop: GNOME 3.36.5 tk: GTK 3.24.22 wm: gnome-shell dm: GDM 3.36.3
RAM: total: 11.62 GiB used: 1.55 GiB (13.4%)
RAM Report:
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28
L2 cache: 8192 KiB bogomips: 54296
Speed: 798 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 798 2: 798
3: 798 4: 798 5: 798 6: 798 7: 799 8: 798
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
Type: l1tf
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 450.57
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c82
Display: x11 server: X.org 1.20.8 compositor: gnome-shell driver: nvidia
resolution:
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 450.57
direct render: Yes
driver: snd_hda_intel v: kernel bus ID: 03:00.0 chip ID: 1102:0012
bus ID: 2-3:3 chip ID: 046d:0825 serial:
driver: e1000e v: 3.2.6-k port: f040 bus ID: 00:19.0 chip ID: 8086:153b
broadcast:
driver: ath9k v: kernel port: e000 bus ID: 04:00.0 chip ID: 168c:0034
WAN IP:
Local Storage: total: 5.95 TiB used: 2.36 TiB (39.6%)
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
size: 931.51 GiB block size: physical: 4096 B logical: 512 B
ID-5: /dev/sdf type: USB vendor: Western Digital model: WD Elements 25A1
size: 3.64 TiB block size: physical: 4096 B logical: 512 B
serial: rev: 1018 scheme: GPT
dev-links: cdrom
used: 61.00 GiB (13.9%) fs: ext4 dev: /dev/dm-0 label: N/A
uuid: 5adc06f6-b0e9-45f9-b84b-ff640d811716
ID-2: /run/media/jaro/Elements raw size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 2.30 TiB (63.2%) fs: ntfs dev: /dev/sdf1 label: Elements
uuid: DC7237FA7237D84A
uuid: N/A
uuid: 227af659-12ef-48a7-8041-d91c05af4db6
uuid: N/A
ID-7: /dev/sdc2 size: 931.39 GiB fs: ntfs label: Aufnahmen
ID-8: /dev/sdd1 size: 927.51 GiB fs: ntfs label: N/A
ID-9: /dev/sdd10 size: 450.0 MiB fs: ntfs label: N/A
ID-10: /dev/sdd2 size: 486.0 MiB fs: ntfs label: N/A
ID-11: /dev/sdd3 size: 450.0 MiB fs: ntfs label: N/A
ID-12: /dev/sdd4 size: 452.0 MiB fs: ntfs label: N/A
ID-13: /dev/sdd5 size: 450.0 MiB fs: ntfs label: N/A
ID-14: /dev/sdd6 size: 450.0 MiB fs: ntfs label: N/A
ID-15: /dev/sdd7 size: 452.0 MiB fs: ntfs label: N/A
ID-16: /dev/sdd8 size: 452.0 MiB fs: ntfs label: N/A
ID-17: /dev/sdd9 size: 450.0 MiB fs: ntfs label: N/A
Device-1: 1-1.5:3 info: Lite-On type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s chip ID: 04ca:3006
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 1bcf:0005
chip ID: 04ca:0050
driver: ums-realtek interfaces: 1 rev: 2.0 speed: 480 Mb/s
Device-5: 2-7:6 info: Western Digital Elements / My Passport
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s chip ID: 1058:25a1 serial:
chip ID: 1d6b:0003
System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 33 C
Processes: 254 Uptime: 5m Init: systemd v: 245 Compilers: gcc: N/A
Packages: pacman: 1197 lib: 349 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.05
I’m on KDE and haven’t used Gnome like… ever… a very long time ago…
Sorry! :sob:
No problem, Gnome works fine for me so far but i got no sound :frowning:
@nikgnomic As you seem to be working on a similar issue here, could you have a look here too?
@Ancrion
Could you provide the output to aplay --list-devices and please enclose the output in 3 backticks ``` at the start and end so the output looks like this:
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC255 Analog [ALC255 Analog]
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
  Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
  Subdevices: 1/1
Thank you, sorry didnt know that. Seems that my soundcard doesnt work. I get sound over onboard, but not over the soundcard.
Karte 0: NVidia [HDA NVidia], Gerät 3: HDMI 0 [HDMI 0]
 Sub-Geräte: 1/1
 Sub-Gerät #0: subdevice #0
Karte 0: NVidia [HDA NVidia], Gerät 7: HDMI 1 [HDMI 1]
 Sub-Geräte: 1/1
Karte 0: NVidia [HDA NVidia], Gerät 8: HDMI 2 [HDMI 2]
 Sub-Geräte: 1/1
Karte 0: NVidia [HDA NVidia], Gerät 9: HDMI 3 [HDMI 3]
 Sub-Geräte: 1/1
Karte 0: NVidia [HDA NVidia], Gerät 10: HDMI 4 [HDMI 4]
 Sub-Geräte: 1/1
Karte 0: NVidia [HDA NVidia], Gerät 11: HDMI 5 [HDMI 5]
 Sub-Geräte: 1/1
Karte 1: Creative [HDA Creative], Gerät 0: CA0132 Analog [CA0132 Analog]
 Sub-Geräte: 0/1
Karte 1: Creative [HDA Creative], Gerät 1: CA0132 Digital [CA0132 Digital]
 Sub-Geräte: 1/1
[@ fabby - I was on a coffee break pondering this discussion so far
now on 2nd cup in case of possible strangeness from Creative device ]
Pulseaudio should handle switching between headphones and speakers
but Pulseaudio will not switch to an output that is detected as ‘unplugged’ or ‘not available’
If an audio device is not correctly detecting headphones being plugged in, it would usually require a change in ALSA configuration of hardware device to get Pulseaudio to work as intended
please post response to
amixer --card=1
hoping to see a control for Auto Mute-Mode on this audio device
this card is using standard snd_hda_intel and not a specific Creative driver, so the tools for onboard HDA hardware should work
suggest installing alsa-tools package (assuming it is not already installed)
and check if headphone jack is correctly detected
sudo hdajacksensetest --card=1
Thank you!
I have removed and installed the soundcard and now i get sound again.
I got the headphones working over front, but the microphone doesnt work. Maybe the microphone front connection of my PC is dead? The problem is, that it doesnt detect headphones when i connect them directly to the soundcard. Maybe because of the missing Creative driver?
hdajacksensetest: No pins found for card 1 codec 0, did you pick the right one?
Here are the results of amixer:
Simple mixer control 'Master',0
  Capabilities: pvolume pswitch
  Limits: Playback 0 - 99
  Mono:
  Front Left: Playback 90 [91%] [0.00dB] [on]
  Front Right: Playback 90 [91%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 255 [100%] [0.00dB]
  Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Surround',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'Mic SVM',0
  Capabilities: cswitch cswitch-joined
  Capture channels: Mono
  Mono: Capture [on]
Simple mixer control 'Mic1-Boost (30dB)',0
  Mono: Capture [off]
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined cswitch cswitch-joined
  Mono: Playback [off] Capture [off]
Simple mixer control 'IEC958 Default PCM',0
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 99
  Front Left: Capture 90 [91%] [0.00dB] [on]
  Front Right: Capture 90 [91%] [0.00dB] [on]
Simple mixer control 'AMic1/DMic',0
  Mono: Capture [off]
Simple mixer control 'AMic1/DMic Auto Detect',0
  Mono: Capture [off]
Simple mixer control 'Analog-Mic2',0
Simple mixer control 'CrystalVoice',0
  Mono: Capture [off]
Simple mixer control 'Crystalizer',0
  Mono: Playback [on]
Simple mixer control 'Dialog Plus',0
  Mono: Playback [on]
Simple mixer control 'Echo Cancellation',0
  Mono: Capture [off]
Simple mixer control 'Equalizer',0
  Mono: Playback [on]
Simple mixer control 'HP/Speaker',0
  Mono: Playback [on]
Simple mixer control 'HP/Speaker Auto Detect',0
  Mono: Playback [on]
Simple mixer control 'Noise Reduction',0
  Mono: Capture [on]
Simple mixer control 'PlayEnhancement',0
  Mono: Playback [on]
Simple mixer control 'Smart Volume',0
  Mono: Playback [on]
Simple mixer control 'Voice Focus',0
  Mono: Capture [on]
Simple mixer control 'VoiceFX',0
  Capabilities: cenum
  Items: 'Neutral' 'Female2Male' 'Male2Female' 'ScrappyKid' 'Elderly' 'Orc' 'Elf' 'Dwarf' 'AlienBrute' 'Robot' 'Marine' 'Emo' 'DeepVoice' 'Munchkin'
  Item0: 'Neutral'
Simple mixer control 'What U Hear',0
Simple mixer control 'X-Bass',0
  Mono: Playback [on]
amixer --card=1 response confirms this is the Creative card
(as far as I know only Creative has a control called `What U Hear’, i think they have a trademark for this)
the controls for jack-detection in amixer are not like other HDA audio devices
so I am not too surprised that hdajacksensetest does not work
HP/Speaker Auto Detect is [on] so headphones should work for audio playback
but controls for audio capture are turned off
suggest you go to
alsamixer --card=1 --view All
use arrow keys to locate these two controls
  • AMic1/DMic
  • AMic1/DMic Auto Detect
and either or or Spacebar to turn both controls ON
to capture audio
also suggest turn OFF these audio effects until audio capture and playback is working
(may need to use M key to mute and unmute playback controls)
  • Crystalizer
  • Dialog Plus
  • Equalizer
  • Noise Reduction
  • PlayEnhancement
  • Smart Volume
  • Voice Focus
  • X-Bass
and save any changes made to ALSA controls so they are restored when booting system
sudo alsactl store
Thank you very much.
Even if i conntected headphones at my soundcard and autodetect is on, it says, they were not connected. At the Front just headphones are working. Enabling AMic1/Dmic, AMic1/DMic Auto Detect and disabling the others didnt change anything.
Greetings
My microphone is now working on my soundcard, but my headphones arent.
It says my headphones are not connected., but they are. They are not detected.
