Trying to launch Manjaro KDE/GNOME with live cd in a XPS 9520. Version = 21.3.0-220617
Intel i7 12700H
Nvidia 3050 ti
4k screen
I’m getting a crash when I just move the pointer with touchpad or mouse and after that I can’t do anything but shut down holding power button. Screen goes black when I move the pointer but it works when I use just the keyboard.
I tried minimal and full version, with open and proprietary drivers with always the same result. Ubuntu/Kubuntu 22.04 works out of the box.
Cheers!
Welcome to Manjaro!
Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
Please press the three dots … below your post and then press the
If you give us information about your system, we can see what we’re talking about and make better suggestions.
You can do this by using inxi
in a terminal or in console.
Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
Copy the output from inxi (including the command) and paste it into your post.
To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
akiss
July 22, 2022, 6:09am
3
Same problem here, I managed to get the infos needed:
Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=de_DE keytable=de tz=UTC
misobasedir=manjaro misolabel=MANJARO_GNOME_2135 quiet
systemd.show_status=1 driver=nonfree nouveau.modeset=0 i915.modeset=1
radeon.modeset=1
Console: tty 3 DM: GDM v: 42.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: XPS 15 9520 v: N/A
Mobo: Dell model: 0YD3W1 v: A00 serial: <superuser required> UEFI: Dell
v: 1.4.0 date: 06/09/2022
ID-1: BAT0 charge: 82.6 Wh (100.0%) condition: 82.6/84.3 Wh (98.0%)
volts: 13.1 min: 11.4 model: BYD DELL M59JH21 type: Li-poly serial: <filter>
status: full
RAM: total: 31.03 GiB used: 3.95 GiB (12.7%)
RAM Report:
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 built: 2021 process: Intel 7 (10nm ESF)
family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x41B
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 414 high: 481 min/max: 400/4679:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 445 2: 421 3: 436 4: 424
5: 400 6: 401 7: 401 8: 401 9: 424 10: 427 11: 481 12: 427 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 107560
arch_capabilities arch_lbr arch_perfmon art avx avx2 avx_vnni bmi1 bmi2 bts
cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault
cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:4626 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: Dell
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:25a0 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:2 chip-ID: 0c45:6732 class-ID: 0e02
Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa gpu: i915 tty: 240x75
Monitor-1: eDP-1 model: Sharp 0x1516 built: 2021 res: 3840x2400 dpi: 290
gamma: 1.2 size: 336x210mm (13.23x8.27") diag: 396mm (15.6") ratio: 16:10
modes: 3840x2400
Message: GL data unavailable in console. Try -G --display
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 983.29 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 3400 NVMe 1024GB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 34000050 temp: 26.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Transcend
model: JetFlash 32GB size: 29.42 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
Message: No partition data found.
ID-1: /dev/dm-0 maj-min: 254:0 mapped: ventoy size: 3.29 GiB fs: iso9660
ID-2: /dev/nvme0n1p1 maj-min: 259:1 size: 240 MiB fs: vfat label: ESP
uuid: 1636-F0CB
ID-3: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme0n1p3 maj-min: 259:3 size: 469 GiB fs: ntfs label: OS
uuid: 01D89CC8EE2EB3E0
ID-5: /dev/nvme0n1p4 maj-min: 259:4 size: 465.56 GiB fs: ext4 label: N/A
uuid: 8796c906-bb48-43ca-85f2-35262bb64747
ID-6: /dev/nvme0n1p5 maj-min: 259:5 size: 1.01 GiB fs: ntfs
label: WINRETOOLS uuid: F476A3CF76A39142
ID-7: /dev/nvme0n1p6 maj-min: 259:6 size: 16.5 GiB fs: ntfs label: Image
uuid: E0ACA3FCACA3CAFC
ID-8: /dev/nvme0n1p7 maj-min: 259:7 size: 1.43 GiB fs: ntfs
label: DELLSUPPORT uuid: 8414620C14620212
ID-9: /dev/sda1 maj-min: 8:1 size: 29.39 GiB fs: exfat label: Ventoy
uuid: F45D-E35D
ID-10: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 75B8-7B4D
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-6:2 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 3-9:3 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
Device-3: 3-10:4 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 4-1:2 info: Transcend Information JetFlash type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 304mA
chip-ID: 8564:1000 class-ID: 0806 serial: <filter>
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 42 C
Processes: 496 Uptime: 15m wakeups: 805 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: pacman: 1263 lib: 296 flatpak: 0 Shell: Zsh (login) v: 5.9
running-in: tty 3 inxi: 3.3.19
Command used as described in the post before.
It doesn’t matter which desktop env you are using, I’ve tried KDE, xfce and GNOME Live USB, as soon as I start using the touchpad the screens starts flickering and turns black. Using only the keyboard this problem wont’ arise.
Thx, Andreas
@panabuntu @akiss
Could be an issue with the latest gpu and the power management.
Add this:
i915.enable_psr=0 i915.enable_fbc=0
to to the kernel parameter.
I experienced the same issues that panabuntu and akiss see. I attempted these kernel parameters in the installer and while the experience is marginally more stable (I previously found that the screen would just go blank unrecoverably after moving the mouse for too long), there is still extreme flickering/video corruption/tearing present when the mouse is moved, making the system unusable.
Laptop is Dell XPS 15 9520 (2022), same as panabuntu and akiss. Installer is manjaro-gnome-21.3.6-minimal-220729-linux515.iso.
Olli
August 6, 2022, 3:52am
6
Hi,
Is there anything specific I should be looking for there? The only thing that looks potentially relevant is the i915.edp_vswing=2 boot parameter, which a) doesn’t seem to help, and b) is advice for a model from 2016.
Thanks.
Olli
August 6, 2022, 4:11am
8
without any information from your side it’s almost impossible to give better advice. please open your own thread, give a detailed information of the problem and provide us with basic information as the inxi that has been a basic info for everybody !
Hi,
I have exactly the same problem as the previous two commenters and exactly the same laptop . There’s nothing to add, except that the mitigations suggested by @megavolt —whilst preventing the system from locking up outright—provide only a marginal fix.
Thanks.
klim
December 16, 2022, 11:48am
10
@panabuntu @akiss hey! anyone found a solution to this problem?
@klim This bug is resolved in the current installer (2022-12-24) however I required the following kernel parameters to boot with linux61-nvidia
drivers:
ibt=off nvidia.modeset=0
No other issues detected thus far.
