cat /var/log/Xorg.0.log
[ 16.427] (--) Log file renamed from "/var/log/Xorg.pid-1476.log" to "/var/log/Xorg.0.log"
[ 16.427]
X.Org X Server 1.21.1.2
[ 16.427] Current Operating System: Linux Manjaro 5.15.12-1-MANJARO #1 SMP PREEMPT Wed Dec 29 18:08:07 UTC 2021 x86_64
[ 16.427] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64 root=UUID=6ec72a2d-aff9-4765-b73e-12bdbfb631df rw rootflags=subvol=@ quiet apparmor=1 security=apparmor intel_iommu=on iommu=pt video=vesafb:off vga=off udev.log_priority=3
[ 16.427]
[ 16.427] Current version of pixman: 0.40.0
[ 16.427] Before reporting problems, check http://wiki.x.org
[ 16.427] Markers: (--) probed, (**) from config file, (==) default setting,
[ 16.427] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 6 10:49:56 2022
[ 16.428] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 16.428] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 16.428] (==) ServerLayout "layout"
[ 16.428] (**) |-->Screen "Screen0" (0)
[ 16.428] (**) | |-->Monitor "Monitor0"
[ 16.429] (**) | |-->Device "Device0"
[ 16.429] (==) Automatically adding devices
[ 16.429] (==) Automatically enabling devices
[ 16.429] (==) Automatically adding GPU devices
[ 16.429] (==) Automatically binding GPU devices
[ 16.429] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 16.429] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 16.430] Entry deleted from font path.
[ 16.430] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 16.430] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 16.430] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 16.430] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 16.430] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 16.430] (**) Extension "COMPOSITE" is enabled
[ 16.430] (II) The server relies on udev to provide the list of input devices.
[ 16.430] (II) Module ABI versions:
[ 16.430] X.Org ANSI C Emulation: 0.4
[ 16.430] X.Org Video Driver: 25.2
[ 16.430] X.Org XInput driver : 24.4
[ 16.430] X.Org Server Extension : 10.0
[ 16.430] (++) using VT number 1
[ 16.430] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 16.430] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 16.430] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.2/0000:07:00.0/drm/card0
[ 16.434] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 16.434] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 16.437] (--) PCI:*(7@0:0:0) 10de:17c2:10de:1132 rev 161, Mem @ 0xf9000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 16.437] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 16.437] (II) LoadModule: "glx"
[ 16.437] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 16.441] (II) Module glx: vendor="X.Org Foundation"
[ 16.441] compiled for 1.21.1.2, module version = 1.0.0
[ 16.441] ABI class: X.Org Server Extension, version 10.0
[ 16.441] (II) LoadModule: "nvidia"
[ 16.441] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 16.446] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 16.446] compiled for 1.6.99.901, module version = 1.0.0
[ 16.446] Module class: X.Org Video Driver
[ 16.446] (II) NVIDIA dlloader X Driver 495.44 Fri Oct 22 06:11:21 UTC 2021
[ 16.446] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 16.447] (II) Loading sub module "fb"
[ 16.447] (II) LoadModule: "fb"
[ 16.447] (II) Module "fb" already built-in
[ 16.447] (II) Loading sub module "wfb"
[ 16.447] (II) LoadModule: "wfb"
[ 16.447] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 16.448] (II) Module wfb: vendor="X.Org Foundation"
[ 16.448] compiled for 1.21.1.2, module version = 1.0.0
[ 16.448] ABI class: X.Org ANSI C Emulation, version 0.4
[ 16.448] (II) Loading sub module "ramdac"
[ 16.448] (II) LoadModule: "ramdac"
[ 16.448] (II) Module "ramdac" already built-in
[ 16.513] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 16.513] (==) NVIDIA(0): RGB weight 888
[ 16.513] (==) NVIDIA(0): Default visual is TrueColor
[ 16.513] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 16.513] (**) Option "AllowNVIDIAGpuScreens"
[ 16.514] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 16.514] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 16.514] (**) NVIDIA(0): Enabling 2D acceleration
[ 16.514] (II) Loading sub module "glxserver_nvidia"
[ 16.514] (II) LoadModule: "glxserver_nvidia"
[ 16.514] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 16.560] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 16.560] compiled for 1.6.99.901, module version = 1.0.0
[ 16.560] Module class: X.Org Server Extension
[ 16.560] (II) NVIDIA GLX Module 495.44 Fri Oct 22 06:08:29 UTC 2021
[ 16.561] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 17.497] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:7:0:0
[ 17.497] (--) NVIDIA(0): CRT-0
[ 17.497] (--) NVIDIA(0): DFP-0
[ 17.497] (--) NVIDIA(0): DFP-1
[ 17.497] (--) NVIDIA(0): DFP-2
[ 17.497] (--) NVIDIA(0): DFP-3
[ 17.497] (--) NVIDIA(0): DFP-4 (boot)
[ 17.497] (--) NVIDIA(0): DFP-5
[ 17.497] (--) NVIDIA(0): DFP-6
[ 17.497] (--) NVIDIA(0): DFP-7
[ 17.497] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX TITAN X (GM200-A) at PCI:7:0:0
[ 17.497] (II) NVIDIA(0): (GPU-0)
[ 17.497] (--) NVIDIA(0): Memory: 12582912 kBytes
[ 17.497] (--) NVIDIA(0): VideoBIOS: 84.00.45.00.03
[ 17.497] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 17.501] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 17.501] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 17.504] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 17.504] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 17.504] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 17.551] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): connected
[ 17.551] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): Internal TMDS
[ 17.551] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): 600.0 MHz maximum pixel clock
[ 17.551] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 17.551] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 17.551] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 17.648] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): connected
[ 17.648] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): Internal TMDS
[ 17.648] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): 300.0 MHz maximum pixel clock
[ 17.648] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): connected
[ 17.648] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): Internal DisplayPort
[ 17.648] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): 960.0 MHz maximum pixel clock
[ 17.650] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 17.650] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 17.650] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 17.650] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 17.650] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 17.650] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 17.650] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 17.650] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 17.650] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 17.658] (==) NVIDIA(0):
[ 17.658] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 17.658] (==) NVIDIA(0): will be used as the requested mode.
[ 17.658] (II) NVIDIA(0): Validated MetaModes:
[ 17.658] (II) NVIDIA(0): "DFP-4:nvidia-auto-select,DFP-1:nvidia-auto-select,DFP-3:nvidia-auto-select"
[ 17.658] (II) NVIDIA(0): Virtual screen size determined to be 6400 x 1080
[ 17.664] (--) NVIDIA(0): DPI set to (81, 80); computed from "UseEdidDpi" X config
[ 17.664] (--) NVIDIA(0): option
[ 17.664] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[ 17.664] (II) NVIDIA: access.
[ 17.667] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 17.667] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 17.667] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 17.667] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 17.667] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 17.667] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 17.667] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 17.667] (II) NVIDIA(0): Config Options in the README.
[ 17.689] (II) NVIDIA(0): Setting mode "DFP-4:nvidia-auto-select,DFP-1:nvidia-auto-select,DFP-3:nvidia-auto-select"
[ 17.762] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 17.762] (==) NVIDIA(0): Backing store enabled
[ 17.762] (==) NVIDIA(0): Silken mouse enabled
[ 17.763] (**) NVIDIA(0): DPMS enabled
[ 17.763] (WW) NVIDIA(0): Option "NoLogo" is not used
[ 17.763] (II) Loading sub module "dri2"
[ 17.763] (II) LoadModule: "dri2"
[ 17.763] (II) Module "dri2" already built-in
[ 17.763] (II) NVIDIA(0): [DRI2] Setup complete
[ 17.763] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 17.763] (II) Initializing extension Generic Event Extension
[ 17.763] (II) Initializing extension SHAPE
[ 17.763] (II) Initializing extension MIT-SHM
[ 17.763] (II) Initializing extension XInputExtension
[ 17.763] (II) Initializing extension XTEST
[ 17.763] (II) Initializing extension BIG-REQUESTS
[ 17.763] (II) Initializing extension SYNC
[ 17.764] (II) Initializing extension XKEYBOARD
[ 17.764] (II) Initializing extension XC-MISC
[ 17.764] (II) Initializing extension SECURITY
[ 17.764] (II) Initializing extension XFIXES
[ 17.764] (II) Initializing extension RENDER
[ 17.764] (II) Initializing extension RANDR
[ 17.764] (II) Initializing extension COMPOSITE
[ 17.764] (II) Initializing extension DAMAGE
[ 17.764] (II) Initializing extension MIT-SCREEN-SAVER
[ 17.764] (II) Initializing extension DOUBLE-BUFFER
[ 17.764] (II) Initializing extension RECORD
[ 17.765] (II) Initializing extension DPMS
[ 17.765] (II) Initializing extension Present
[ 17.765] (II) Initializing extension DRI3
[ 17.765] (II) Initializing extension X-Resource
[ 17.765] (II) Initializing extension XVideo
[ 17.765] (II) Initializing extension XVideo-MotionCompensation
[ 17.765] (II) Initializing extension GLX
[ 17.765] (II) Indirect GLX disabled.
[ 17.765] (II) GLX: Another vendor is already registered for screen 0
[ 17.765] (II) Initializing extension XFree86-VidModeExtension
[ 17.765] (II) Initializing extension XFree86-DGA
[ 17.765] (II) Initializing extension XFree86-DRI
[ 17.765] (II) Initializing extension DRI2
[ 17.765] (II) Initializing extension NV-GLX
[ 17.765] (II) Initializing extension NV-CONTROL
[ 17.766] (II) Initializing extension XINERAMA
[ 17.835] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 17.835] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 17.835] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 17.835] (**) Power Button: Applying InputClass "system-keyboard"
[ 17.835] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 17.835] (II) LoadModule: "libinput"
[ 17.835] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 17.839] (II) Module libinput: vendor="X.Org Foundation"
[ 17.840] compiled for 1.21.1, module version = 1.2.0
[ 17.840] Module class: X.Org XInput Driver
[ 17.840] ABI class: X.Org XInput driver, version 24.4
[ 17.840] (II) Using input driver 'libinput' for 'Power Button'
[ 17.840] (**) Power Button: always reports core events
[ 17.840] (**) Option "Device" "/dev/input/event1"
[ 17.840] (**) Option "_source" "server/udev"
[ 17.842] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 17.842] (II) event1 - Power Button: device is a keyboard
[ 17.843] (II) event1 - Power Button: device removed
[ 17.871] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 17.871] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 17.871] (**) Option "xkb_layout" "gb"
[ 17.871] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 17.892] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 17.892] (II) event1 - Power Button: device is a keyboard
[ 17.893] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 17.893] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 17.893] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 17.893] (**) Power Button: Applying InputClass "system-keyboard"
[ 17.893] (**) Power Button: Applying InputClass "Keyboard Defaults"
[ 17.893] (II) Using input driver 'libinput' for 'Power Button'
[ 17.893] (**) Power Button: always reports core events
[ 17.893] (**) Option "Device" "/dev/input/event0"
[ 17.893] (**) Option "_source" "server/udev"
[ 17.893] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 17.894] (II) event0 - Power Button: device is a keyboard
[ 17.894] (II) event0 - Power Button: device removed
[ 17.938] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 17.938] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 17.938] (**) Option "xkb_layout" "gb"
[ 17.938] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 17.940] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 17.940] (II) event0 - Power Button: device is a keyboard
[ 17.941] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event12)
[ 17.941] (II) No input driver specified, ignoring this device.
[ 17.941] (II) This device may have been added with another device file.
[ 17.942] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event13)
[ 17.942] (II) No input driver specified, ignoring this device.
[ 17.942] (II) This device may have been added with another device file.
[ 17.943] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event14)
[ 17.943] (II) No input driver specified, ignoring this device.
[ 17.943] (II) This device may have been added with another device file.
[ 17.943] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event15)
[ 17.944] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event16)
[ 17.944] (II) No input driver specified, ignoring this device.
[ 17.944] (II) This device may have been added with another device file.
[ 17.944] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event17)
[ 17.945] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event18)
[ 17.945] (II) No input driver specified, ignoring this device.
[ 17.945] (II) This device may have been added with another device file.
[ 17.945] (II) config/udev: Adding input device Razer Inc Razer Seiren X Consumer Control (/dev/input/event2)
[ 17.945] (**) Razer Inc Razer Seiren X Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 17.945] (**) Razer Inc Razer Seiren X Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 17.945] (**) Razer Inc Razer Seiren X Consumer Control: Applying InputClass "system-keyboard"
[ 17.945] (**) Razer Inc Razer Seiren X Consumer Control: Applying InputClass "Keyboard Defaults"
[ 17.945] (II) Using input driver 'libinput' for 'Razer Inc Razer Seiren X Consumer Control'
[ 17.945] (**) Razer Inc Razer Seiren X Consumer Control: always reports core events
[ 17.946] (**) Option "Device" "/dev/input/event2"
[ 17.946] (**) Option "_source" "server/udev"
[ 17.947] (II) event2 - Razer Inc Razer Seiren X Consumer Control: is tagged by udev as: Keyboard
[ 17.947] (II) event2 - Razer Inc Razer Seiren X Consumer Control: device is a keyboard
[ 17.947] (II) event2 - Razer Inc Razer Seiren X Consumer Control: device removed
[ 18.031] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.3/0003:1532:0511.0001/input/input4/event2"
[ 18.031] (II) XINPUT: Adding extended input device "Razer Inc Razer Seiren X Consumer Control" (type: KEYBOARD, id 8)
[ 18.031] (**) Option "xkb_layout" "gb"
[ 18.032] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 18.034] (II) event2 - Razer Inc Razer Seiren X Consumer Control: is tagged by udev as: Keyboard
[ 18.034] (II) event2 - Razer Inc Razer Seiren X Consumer Control: device is a keyboard
[ 18.036] (II) config/udev: Adding input device Razer Razer BlackShark V2 Pro Consumer Control (/dev/input/event9)
[ 18.036] (**) Razer Razer BlackShark V2 Pro Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 18.036] (**) Razer Razer BlackShark V2 Pro Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 18.036] (**) Razer Razer BlackShark V2 Pro Consumer Control: Applying InputClass "system-keyboard"
[ 18.036] (**) Razer Razer BlackShark V2 Pro Consumer Control: Applying InputClass "Keyboard Defaults"
[ 18.036] (II) Using input driver 'libinput' for 'Razer Razer BlackShark V2 Pro Consumer Control'
[ 18.036] (**) Razer Razer BlackShark V2 Pro Consumer Control: always reports core events
[ 18.036] (**) Option "Device" "/dev/input/event9"
[ 18.036] (**) Option "_source" "server/udev"
[ 18.038] (II) event9 - Razer Razer BlackShark V2 Pro Consumer Control: is tagged by udev as: Keyboard
[ 18.039] (II) event9 - Razer Razer BlackShark V2 Pro Consumer Control: device is a keyboard
[ 18.039] (II) event9 - Razer Razer BlackShark V2 Pro Consumer Control: device removed
[ 18.085] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-11/3-11:1.3/0003:1532:0528.0007/input/input13/event9"
[ 18.085] (II) XINPUT: Adding extended input device "Razer Razer BlackShark V2 Pro Consumer Control" (type: KEYBOARD, id 9)
[ 18.085] (**) Option "xkb_layout" "gb"
[ 18.085] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 18.088] (II) event9 - Razer Razer BlackShark V2 Pro Consumer Control: is tagged by udev as: Keyboard
[ 18.088] (II) event9 - Razer Razer BlackShark V2 Pro Consumer Control: device is a keyboard
[ 18.090] (II) config/udev: Adding input device Razer Razer BlackShark V2 Pro (/dev/input/event10)
[ 18.090] (II) No input driver specified, ignoring this device.
[ 18.090] (II) This device may have been added with another device file.
[ 18.091] (II) config/udev: Adding input device Razer Razer BlackShark V2 Pro (/dev/input/event11)
[ 18.091] (II) No input driver specified, ignoring this device.
[ 18.091] (II) This device may have been added with another device file.
[ 18.092] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event19)
[ 18.092] (II) No input driver specified, ignoring this device.
[ 18.092] (II) This device may have been added with another device file.
[ 18.093] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event20)
[ 18.093] (II) No input driver specified, ignoring this device.
[ 18.093] (II) This device may have been added with another device file.
[ 18.093] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event21)
[ 18.094] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event22)
[ 18.094] (II) No input driver specified, ignoring this device.
[ 18.094] (II) This device may have been added with another device file.
[ 18.095] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event23)
[ 18.095] (II) No input driver specified, ignoring this device.
[ 18.095] (II) This device may have been added with another device file.
[ 18.096] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event24)
[ 18.096] (II) No input driver specified, ignoring this device.
[ 18.096] (II) This device may have been added with another device file.
[ 18.096] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event25)
[ 18.097] (II) No input driver specified, ignoring this device.
[ 18.097] (II) This device may have been added with another device file.
[ 18.098] (II) config/udev: Adding input device ROCCAT ROCCAT Skeltr (/dev/input/event3)
[ 18.098] (**) ROCCAT ROCCAT Skeltr: Applying InputClass "evdev keyboard catchall"
[ 18.098] (**) ROCCAT ROCCAT Skeltr: Applying InputClass "libinput keyboard catchall"
[ 18.098] (**) ROCCAT ROCCAT Skeltr: Applying InputClass "system-keyboard"
[ 18.098] (**) ROCCAT ROCCAT Skeltr: Applying InputClass "Keyboard Defaults"
[ 18.098] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Skeltr'
[ 18.098] (**) ROCCAT ROCCAT Skeltr: always reports core events
[ 18.098] (**) Option "Device" "/dev/input/event3"
[ 18.098] (**) Option "_source" "server/udev"
[ 18.101] (II) event3 - ROCCAT ROCCAT Skeltr: is tagged by udev as: Keyboard
[ 18.101] (II) event3 - ROCCAT ROCCAT Skeltr: device is a keyboard
[ 18.102] (II) event3 - ROCCAT ROCCAT Skeltr: device removed
[ 18.138] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:09:00.0/usb5/5-1/5-1:1.0/0003:1E7D:2FC6.0002/input/input6/event3"
[ 18.138] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Skeltr" (type: KEYBOARD, id 10)
[ 18.138] (**) Option "xkb_layout" "gb"
[ 18.138] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 18.141] (II) event3 - ROCCAT ROCCAT Skeltr: is tagged by udev as: Keyboard
[ 18.142] (II) event3 - ROCCAT ROCCAT Skeltr: device is a keyboard
[ 18.144] (II) config/udev: Adding input device ROCCAT ROCCAT Skeltr (/dev/input/event4)
[ 18.144] (**) ROCCAT ROCCAT Skeltr: Applying InputClass "evdev pointer catchall"
[ 18.144] (**) ROCCAT ROCCAT Skeltr: Applying InputClass "libinput pointer catchall"
[ 18.144] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Skeltr'
[ 18.144] (**) ROCCAT ROCCAT Skeltr: always reports core events
[ 18.144] (**) Option "Device" "/dev/input/event4"
[ 18.144] (**) Option "_source" "server/udev"
[ 18.146] (II) event4 - ROCCAT ROCCAT Skeltr: is tagged by udev as: Mouse
[ 18.147] (II) event4 - ROCCAT ROCCAT Skeltr: device is a pointer
[ 18.147] (II) event4 - ROCCAT ROCCAT Skeltr: device removed
[ 18.231] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:09:00.0/usb5/5-1/5-1:1.1/0003:1E7D:2FC6.0003/input/input7/event4"
[ 18.231] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Skeltr" (type: MOUSE, id 11)
[ 18.232] (**) Option "AccelerationScheme" "none"
[ 18.232] (**) ROCCAT ROCCAT Skeltr: (accel) selected scheme none/0
[ 18.232] (**) ROCCAT ROCCAT Skeltr: (accel) acceleration factor: 2.000
[ 18.232] (**) ROCCAT ROCCAT Skeltr: (accel) acceleration threshold: 4
[ 18.234] (II) event4 - ROCCAT ROCCAT Skeltr: is tagged by udev as: Mouse
[ 18.235] (II) event4 - ROCCAT ROCCAT Skeltr: device is a pointer
[ 18.237] (II) config/udev: Adding input device ROCCAT ROCCAT Skeltr (/dev/input/mouse0)
[ 18.237] (II) No input driver specified, ignoring this device.
[ 18.237] (II) This device may have been added with another device file.
[ 18.238] (II) config/udev: Adding input device ROCCAT ROCCAT Skeltr Consumer Control (/dev/input/event5)
[ 18.238] (**) ROCCAT ROCCAT Skeltr Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 18.238] (**) ROCCAT ROCCAT Skeltr Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 18.238] (**) ROCCAT ROCCAT Skeltr Consumer Control: Applying InputClass "system-keyboard"
[ 18.238] (**) ROCCAT ROCCAT Skeltr Consumer Control: Applying InputClass "Keyboard Defaults"
[ 18.238] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Skeltr Consumer Control'
[ 18.238] (**) ROCCAT ROCCAT Skeltr Consumer Control: always reports core events
[ 18.238] (**) Option "Device" "/dev/input/event5"
[ 18.238] (**) Option "_source" "server/udev"
[ 18.241] (II) event5 - ROCCAT ROCCAT Skeltr Consumer Control: is tagged by udev as: Keyboard
[ 18.241] (II) event5 - ROCCAT ROCCAT Skeltr Consumer Control: device is a keyboard
[ 18.242] (II) event5 - ROCCAT ROCCAT Skeltr Consumer Control: device removed
[ 18.298] (II) libinput: ROCCAT ROCCAT Skeltr Consumer Control: needs a virtual subdevice
[ 18.298] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:09:00.0/usb5/5-1/5-1:1.1/0003:1E7D:2FC6.0003/input/input8/event5"
[ 18.298] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Skeltr Consumer Control" (type: MOUSE, id 12)
[ 18.298] (**) Option "AccelerationScheme" "none"
[ 18.298] (**) ROCCAT ROCCAT Skeltr Consumer Control: (accel) selected scheme none/0
[ 18.298] (**) ROCCAT ROCCAT Skeltr Consumer Control: (accel) acceleration factor: 2.000
[ 18.298] (**) ROCCAT ROCCAT Skeltr Consumer Control: (accel) acceleration threshold: 4
[ 18.301] (II) event5 - ROCCAT ROCCAT Skeltr Consumer Control: is tagged by udev as: Keyboard
[ 18.301] (II) event5 - ROCCAT ROCCAT Skeltr Consumer Control: device is a keyboard
[ 18.303] (II) config/udev: Adding input device ROCCAT ROCCAT Skeltr System Control (/dev/input/event6)
[ 18.303] (**) ROCCAT ROCCAT Skeltr System Control: Applying InputClass "evdev keyboard catchall"
[ 18.303] (**) ROCCAT ROCCAT Skeltr System Control: Applying InputClass "libinput keyboard catchall"
[ 18.303] (**) ROCCAT ROCCAT Skeltr System Control: Applying InputClass "system-keyboard"
[ 18.303] (**) ROCCAT ROCCAT Skeltr System Control: Applying InputClass "Keyboard Defaults"
[ 18.303] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Skeltr System Control'
[ 18.303] (**) ROCCAT ROCCAT Skeltr System Control: always reports core events
[ 18.303] (**) Option "Device" "/dev/input/event6"
[ 18.303] (**) Option "_source" "server/udev"
[ 18.306] (II) event6 - ROCCAT ROCCAT Skeltr System Control: is tagged by udev as: Keyboard
[ 18.306] (II) event6 - ROCCAT ROCCAT Skeltr System Control: device is a keyboard
[ 18.307] (II) event6 - ROCCAT ROCCAT Skeltr System Control: device removed
[ 18.338] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:09:00.0/usb5/5-1/5-1:1.1/0003:1E7D:2FC6.0003/input/input9/event6"
[ 18.338] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Skeltr System Control" (type: KEYBOARD, id 13)
[ 18.338] (**) Option "xkb_layout" "gb"
[ 18.338] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 18.341] (II) event6 - ROCCAT ROCCAT Skeltr System Control: is tagged by udev as: Keyboard
[ 18.341] (II) event6 - ROCCAT ROCCAT Skeltr System Control: device is a keyboard
[ 18.343] (II) config/udev: Adding input device ROCCAT ROCCAT Skeltr (/dev/input/event7)
[ 18.343] (**) ROCCAT ROCCAT Skeltr: Applying InputClass "evdev keyboard catchall"
[ 18.343] (**) ROCCAT ROCCAT Skeltr: Applying InputClass "libinput keyboard catchall"
[ 18.343] (**) ROCCAT ROCCAT Skeltr: Applying InputClass "system-keyboard"
[ 18.343] (**) ROCCAT ROCCAT Skeltr: Applying InputClass "Keyboard Defaults"
[ 18.343] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Skeltr'
[ 18.343] (**) ROCCAT ROCCAT Skeltr: always reports core events
[ 18.343] (**) Option "Device" "/dev/input/event7"
[ 18.344] (**) Option "_source" "server/udev"
[ 18.346] (II) event7 - ROCCAT ROCCAT Skeltr: is tagged by udev as: Keyboard
[ 18.346] (II) event7 - ROCCAT ROCCAT Skeltr: device is a keyboard
[ 18.347] (II) event7 - ROCCAT ROCCAT Skeltr: device removed
[ 18.378] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:09:00.0/usb5/5-1/5-1:1.2/0003:1E7D:2FC6.0004/input/input11/event7"
[ 18.378] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Skeltr" (type: KEYBOARD, id 14)
[ 18.378] (**) Option "xkb_layout" "gb"
[ 18.378] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 18.381] (II) event7 - ROCCAT ROCCAT Skeltr: is tagged by udev as: Keyboard
[ 18.382] (II) event7 - ROCCAT ROCCAT Skeltr: device is a keyboard
[ 18.384] (II) config/udev: Adding input device SteelSeries SteelSeries Kinzu V3 Gaming Mouse (/dev/input/event8)
[ 18.384] (**) SteelSeries SteelSeries Kinzu V3 Gaming Mouse: Applying InputClass "evdev pointer catchall"
[ 18.384] (**) SteelSeries SteelSeries Kinzu V3 Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 18.384] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries Kinzu V3 Gaming Mouse'
[ 18.384] (**) SteelSeries SteelSeries Kinzu V3 Gaming Mouse: always reports core events
[ 18.384] (**) Option "Device" "/dev/input/event8"
[ 18.384] (**) Option "_source" "server/udev"
[ 18.440] (II) event8 - SteelSeries SteelSeries Kinzu V3 Gaming Mouse: is tagged by udev as: Mouse
[ 18.441] (II) event8 - SteelSeries SteelSeries Kinzu V3 Gaming Mouse: device is a pointer
[ 18.441] (II) event8 - SteelSeries SteelSeries Kinzu V3 Gaming Mouse: device removed
[ 18.511] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:09:00.0/usb5/5-2/5-2:1.1/0003:1038:1388.0006/input/input12/event8"
[ 18.511] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries Kinzu V3 Gaming Mouse" (type: MOUSE, id 15)
[ 18.512] (**) Option "AccelerationScheme" "none"
[ 18.512] (**) SteelSeries SteelSeries Kinzu V3 Gaming Mouse: (accel) selected scheme none/0
[ 18.512] (**) SteelSeries SteelSeries Kinzu V3 Gaming Mouse: (accel) acceleration factor: 2.000
[ 18.512] (**) SteelSeries SteelSeries Kinzu V3 Gaming Mouse: (accel) acceleration threshold: 4
[ 18.570] (II) event8 - SteelSeries SteelSeries Kinzu V3 Gaming Mouse: is tagged by udev as: Mouse
[ 18.571] (II) event8 - SteelSeries SteelSeries Kinzu V3 Gaming Mouse: device is a pointer
[ 18.573] (II) config/udev: Adding input device SteelSeries SteelSeries Kinzu V3 Gaming Mouse (/dev/input/mouse1)
[ 18.573] (II) No input driver specified, ignoring this device.
[ 18.573] (II) This device may have been added with another device file.
[ 18.573] (II) config/udev: Adding input device PC Speaker (/dev/input/event26)
[ 18.587] (**) ROCCAT ROCCAT Skeltr Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 18.587] (**) ROCCAT ROCCAT Skeltr Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 18.587] (**) ROCCAT ROCCAT Skeltr Consumer Control: Applying InputClass "system-keyboard"
[ 18.587] (**) ROCCAT ROCCAT Skeltr Consumer Control: Applying InputClass "Keyboard Defaults"
[ 18.588] (II) Using input driver 'libinput' for 'ROCCAT ROCCAT Skeltr Consumer Control'
[ 18.588] (**) ROCCAT ROCCAT Skeltr Consumer Control: always reports core events
[ 18.588] (**) Option "Device" "/dev/input/event5"
[ 18.588] (**) Option "_source" "_driver/libinput"
[ 18.588] (II) libinput: ROCCAT ROCCAT Skeltr Consumer Control: is a virtual subdevice
[ 18.588] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:09:00.0/usb5/5-1/5-1:1.1/0003:1E7D:2FC6.0003/input/input8/event5"
[ 18.588] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Skeltr Consumer Control" (type: KEYBOARD, id 16)
[ 18.588] (**) Option "xkb_layout" "gb"
[ 18.588] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 18.589] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event13)
[ 18.589] (II) No input driver specified, ignoring this device.
[ 18.589] (II) This device may have been added with another device file.
[ 18.589] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event17)
[ 18.590] (II) No input driver specified, ignoring this device.
[ 18.590] (II) This device may have been added with another device file.
[ 18.590] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event16)
[ 18.591] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event12)
[ 18.591] (II) No input driver specified, ignoring this device.
[ 18.591] (II) This device may have been added with another device file.
[ 18.591] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event15)
[ 18.592] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event14)
[ 18.592] (II) No input driver specified, ignoring this device.
[ 18.592] (II) This device may have been added with another device file.
[ 18.593] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=12 (/dev/input/event18)
[ 18.593] (II) No input driver specified, ignoring this device.
[ 18.593] (II) This device may have been added with another device file.
[ 18.594] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event25)
[ 18.594] (II) No input driver specified, ignoring this device.
[ 18.594] (II) This device may have been added with another device file.
[ 18.595] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event19)
[ 18.595] (II) No input driver specified, ignoring this device.
[ 18.595] (II) This device may have been added with another device file.
[ 18.595] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event20)
[ 18.596] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event22)
[ 18.596] (II) No input driver specified, ignoring this device.
[ 18.596] (II) This device may have been added with another device file.
[ 18.596] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event21)
[ 18.597] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event24)
[ 18.597] (II) No input driver specified, ignoring this device.
[ 18.597] (II) This device may have been added with another device file.
[ 18.598] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event23)
[ 18.598] (II) No input driver specified, ignoring this device.
[ 18.598] (II) This device may have been added with another device file.
[ 18.599] (II) config/udev: Adding input device PC Speaker (/dev/input/event26)
[ 18.599] (II) No input driver specified, ignoring this device.
[ 18.599] (II) This device may have been added with another device file.
[ 18.600] (II) config/udev: Adding input device SteelSeries SteelSeries Kinzu V3 Gaming Mouse (/dev/input/mouse1)
[ 18.600] (II) No input driver specified, ignoring this device.
[ 18.600] (II) This device may have been added with another device file.
[ 18.601] (II) config/udev: Adding input device ROCCAT ROCCAT Skeltr (/dev/input/mouse0)
[ 18.601] (II) No input driver specified, ignoring this device.
[ 18.601] (II) This device may have been added with another device file.
[ 539.506] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 539.506] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 539.509] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 539.509] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 539.509] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 539.555] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): connected
[ 539.555] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): Internal TMDS
[ 539.555] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): 600.0 MHz maximum pixel clock
[ 539.555] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 539.555] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 539.555] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 539.652] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): connected
[ 539.652] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): Internal TMDS
[ 539.652] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): 300.0 MHz maximum pixel clock
[ 539.652] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): connected
[ 539.652] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): Internal DisplayPort
[ 539.652] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): 960.0 MHz maximum pixel clock
[ 539.654] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 539.654] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 539.654] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 539.654] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 539.654] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 539.654] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 539.655] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 539.655] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 539.655] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 540.048] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 540.048] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 540.052] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 540.052] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 540.052] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 540.098] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): connected
[ 540.098] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): Internal TMDS
[ 540.098] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): 600.0 MHz maximum pixel clock
[ 540.098] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 540.098] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 540.098] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 540.196] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): connected
[ 540.196] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): Internal TMDS
[ 540.196] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): 300.0 MHz maximum pixel clock
[ 540.196] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): connected
[ 540.196] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): Internal DisplayPort
[ 540.196] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): 960.0 MHz maximum pixel clock
[ 540.198] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 540.198] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 540.198] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 540.198] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 540.198] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 540.198] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 540.198] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 540.198] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 540.198] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 540.283] (II) NVIDIA(0): Setting mode "DP-2: nvidia-auto-select @2560x1080 +0+0 {ViewPortIn=2560x1080, ViewPortOut=2560x1080+0+0}, HDMI-0: nvidia-auto-select @1080x1920 +0+0 {ViewPortIn=1080x1920, ViewPortOut=1920x1080+0+0, Rotation=270}, DP-1: nvidia-auto-select @1920x1080 +4480+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[ 540.371] (EE) event8 - SteelSeries SteelSeries Kinzu V3 Gaming Mouse: client bug: event processing lagging behind by 49ms, your system is too slow
[ 540.424] (II) NVIDIA(0): Setting mode "DP-2: nvidia-auto-select @2560x1080 +0+0 {ViewPortIn=2560x1080, ViewPortOut=2560x1080+0+0}, HDMI-0: nvidia-auto-select @1080x1920 +0+0 {ViewPortIn=1080x1920, ViewPortOut=1920x1080+0+0, Rotation=270}, DP-1: nvidia-auto-select @1080x1920 +3640+0 {ViewPortIn=1080x1920, ViewPortOut=1920x1080+0+0, Rotation=90}"
[ 540.538] (II) event8 - SteelSeries SteelSeries Kinzu V3 Gaming Mouse: SYN_DROPPED event - some input events have been lost.
[ 540.590] (II) NVIDIA(0): Setting mode "DP-2: 2560x1080_144 @2560x1080 +1080+679 {ViewPortIn=2560x1080, ViewPortOut=2560x1080+0+0}, HDMI-0: nvidia-auto-select @1080x1920 +0+0 {ViewPortIn=1080x1920, ViewPortOut=1920x1080+0+0, Rotation=270}, DP-1: nvidia-auto-select @1080x1920 +3640+0 {ViewPortIn=1080x1920, ViewPortOut=1920x1080+0+0, Rotation=90}"
[ 5154.011] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 5154.011] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 5154.015] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 5154.015] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 5154.015] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 5154.061] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): connected
[ 5154.061] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): Internal TMDS
[ 5154.061] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): 600.0 MHz maximum pixel clock
[ 5154.061] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 5154.061] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 5154.061] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 5154.159] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): connected
[ 5154.159] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): Internal TMDS
[ 5154.159] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): 300.0 MHz maximum pixel clock
[ 5154.159] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): connected
[ 5154.159] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): Internal DisplayPort
[ 5154.159] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): 960.0 MHz maximum pixel clock
[ 5154.162] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 5154.162] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 5154.162] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 5154.162] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 5154.162] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 5154.162] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 5154.162] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 5154.162] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 5154.162] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 5161.510] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 5161.511] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 5161.514] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 5161.515] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 5161.515] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 5161.561] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): connected
[ 5161.561] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): Internal TMDS
[ 5161.561] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): 600.0 MHz maximum pixel clock
[ 5161.561] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 5161.561] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 5161.561] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 5161.658] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): connected
[ 5161.658] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): Internal TMDS
[ 5161.658] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): 300.0 MHz maximum pixel clock
[ 5161.658] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): connected
[ 5161.658] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): Internal DisplayPort
[ 5161.658] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): 960.0 MHz maximum pixel clock
[ 5161.660] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 5161.661] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 5161.661] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 5161.661] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 5161.661] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 5161.661] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 5161.661] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 5161.661] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 5161.661] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 10483.617] (EE) event3 - ROCCAT ROCCAT Skeltr: client bug: event processing lagging behind by 20ms, your system is too slow
[ 10768.240] (EE) event3 - ROCCAT ROCCAT Skeltr: client bug: event processing lagging behind by 13ms, your system is too slow
[ 12990.269] (EE) event3 - ROCCAT ROCCAT Skeltr: client bug: event processing lagging behind by 31ms, your system is too slow
[ 13773.200] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 13773.200] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 13773.204] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 13773.204] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 13773.204] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 13773.251] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): connected
[ 13773.251] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): Internal TMDS
[ 13773.251] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): 600.0 MHz maximum pixel clock
[ 13773.251] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 13773.251] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 13773.251] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 13773.349] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): connected
[ 13773.349] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): Internal TMDS
[ 13773.349] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): 300.0 MHz maximum pixel clock
[ 13773.349] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): connected
[ 13773.349] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): Internal DisplayPort
[ 13773.349] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): 960.0 MHz maximum pixel clock
[ 13773.351] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 13773.351] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 13773.351] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 13773.351] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 13773.351] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 13773.351] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 13773.351] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 13773.351] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 13773.351] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[ 14188.553] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 14188.553] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 14188.557] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 14188.557] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 14188.557] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[ 14188.602] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): connected
[ 14188.602] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): Internal TMDS
[ 14188.602] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-1): 600.0 MHz maximum pixel clock
[ 14188.602] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 14188.602] (--) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 14188.602] (--) NVIDIA(GPU-0): DFP-2: 960.0 MHz maximum pixel clock
[ 14188.701] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): connected
[ 14188.701] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): Internal TMDS
[ 14188.701] (--) NVIDIA(GPU-0): BenQ ZOWIE RL LCD (DFP-3): 300.0 MHz maximum pixel clock
[ 14188.701] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): connected
[ 14188.701] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): Internal DisplayPort
[ 14188.701] (--) NVIDIA(GPU-0): LG Electronics LG ULTRAWIDE (DFP-4): 960.0 MHz maximum pixel clock
[ 14188.703] (--) NVIDIA(GPU-0): DFP-5: disconnected
[ 14188.703] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[ 14188.703] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[ 14188.703] (--) NVIDIA(GPU-0): DFP-6: disconnected
[ 14188.703] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[ 14188.703] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[ 14188.703] (--) NVIDIA(GPU-0): DFP-7: disconnected
[ 14188.703] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[ 14188.703] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: MSI model: X99A RAIDER (MS-7885) v: 5.0
serial: <superuser required> UEFI: American Megatrends v: P.10
date: 11/02/2015
RAM: total: 46.95 GiB used: 5.83 GiB (12.4%)
RAM Report:
Info: model: Intel Core i7-5820K bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x3F (63) stepping: 2 microcode: 0x46
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 15 MiB desc: 1x15 MiB
Speed (MHz): avg: 2511 high: 3433 min/max: 1200/3600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2352 2: 1200 3: 3433
4: 3400 5: 3400 6: 1200 7: 2533 8: 1200 9: 3403 10: 3418 11: 3400 12: 1200
bogomips: 79235
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cqm cqm_llc cqm_occup_llc
cx16 cx8 dca de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_ppin
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Type: l1tf
Device-1: NVIDIA GM200 [GeForce GTX TITAN X] driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 07:00.0 chip-ID: 10de:17c2
class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 4720x1920 s-dpi: 80 s-size: 1499x609mm (59.0x24.0")
s-diag: 1618mm (63.7")
Monitor-1: HDMI-0 res: 1080x1920 hz: 60
Monitor-2: DP-1 res: 1080x1920 hz: 60
Monitor-3: DP-2 res: 2560x1080 dpi: 81 size: 798x334mm (31.4x13.1")
diag: 865mm (34.1")
OpenGL: renderer: NVIDIA GeForce GTX TITAN X/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: Intel C610/X99 series HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20
class-ID: 0403
Device-2: NVIDIA GM200 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 07:00.1 chip-ID: 10de:0fb0 class-ID: 0403
Device-3: Razer USA RZ19-0229 Gaming Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 1532:0511
class-ID: 0300 serial: <filter>
Device-4: Razer USA Razer BlackShark V2 Pro type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-11:6 chip-ID: 1532:0528
class-ID: 0300
Device-5: Astro Gaming A50 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-8.2:7 chip-ID: 9886:0015
class-ID: 0300
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel Ethernet I218-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: f000 bus-ID: 00:19.0 chip-ID: 8086:15a1 class-ID: 0200
Device-2: Realtek RTL8192CU 802.11n WLAN Adapter type: USB
driver: rtl8192cu bus-ID: 3-4:4 chip-ID: 0bda:8178 class-ID: 0000
serial: <filter>
IF: wlp0s20u4 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-2:3 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage: total: 4.09 TiB used: 241.32 GiB (5.8%)
model: WD BLACK SN750 2TB size: 1.82 TiB block-size: physical: 512 B
rev: 112000WD temp: 42.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Crucial model: CT2000P2SSD8
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P2CR033 temp: 32.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9500325AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: DEM1 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 194.52 GiB (10.4%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 6ec72a2d-aff9-4765-b73e-12bdbfb631df
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: FA9A-7079
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 194.52 GiB (10.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 6ec72a2d-aff9-4765-b73e-12bdbfb631df
ID-4: /run/media/yathu/Software raw-size: 465.76 GiB
size: 465.76 GiB (100.00%) used: 46.8 GiB (10.0%) fs: ntfs dev: /dev/sda1
maj-min: 8:1 label: Software uuid: 1FD86E3A09E8FFC1
ID-5: /run/timeshift/backup raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
ID-6: /var/cache raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
ID-7: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 480 MiB fs: vfat label: N/A
uuid: 1F74-88D2
ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 2 GiB fs: swap label: N/A
uuid: c1fb8957-690e-4726-86f0-faf49d8ddd13
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Hub ports: 6 rev: 2.0 speed: 480 Mb/s
chip-ID: 8087:800a class-ID: 0900
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel 8 channel internal hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8002 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 15 rev: 2.0
Device-1: 3-1:2 info: Razer USA RZ19-0229 Gaming Microphone
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 1532:0511 class-ID: 0300
serial: <filter>
Device-2: 3-2:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Device-3: 3-4:4 info: Realtek RTL8192CU 802.11n WLAN Adapter type: Network
driver: rtl8192cu interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 0bda:8178 class-ID: 0000 serial: <filter>
Hub-6: 3-8:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-8.2:7 info: Astro Gaming A50 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 7 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 9886:0015 class-ID: 0300
Device-2: 3-8.4:8 info: Corsair iCUE H150i RGB PRO XT Liquid CPU Cooler
type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1b1c:0c22 class-ID: 0300
Device-3: 3-11:6 info: Razer USA Razer BlackShark V2 Pro type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1532:0528 class-ID: 0300
Hub-7: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-8: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 5-1:2 info: ROCCAT Skeltr Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1e7d:2fc6 class-ID: 0300
Device-2: 5-2:3 info: SteelSeries ApS SteelSeries Kinzu V3 Gaming Mouse
type: HID,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1038:1388 class-ID: 0301
Hub-9: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 67 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 27%
Processes: 359 Uptime: 3h 49m wakeups: 0 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1390
pacman: 1383 lib: 404 flatpak: 0 snap: 7 Shell: Zsh v: 5.8 default: Bash
v: 5.1.12 running-in: konsole inxi: 3.3.11
