I have a ryzen 1800x and it should be able to go to ~4GHz, but the max speed that is reported by the system is 3.6GHz, I am not sure whether I have to enable something in the UEFI screen, but I tried setting
sudo cpupower frequency-set -u 4Ghz
and it didn’t move over 3.6 GHz ?
inxi
Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=528f8171-7936-4019-9382-d327f9354b32 rw quiet apparmor=1
security=apparmor resume=UUID=4b0f0b7e-6616-4a9b-a7e2-5bedfd0afcd8
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7A37 v: 2.0 serial: <filter>
Mobo: MSI model: B350M MORTAR ARCTIC (MS-7A37) v: 2.0 serial: <filter>
UEFI: American Megatrends v: A.K1 date: 05/15/2019
ID-1: hidpp_battery_0 charge: N/A condition: N/A volts: 4.2 min: N/A
model: Logitech G403 Prodigy Wired/Wireless Gaming Mouse type: N/A
serial: <filter> status: Full
RAM: total: 62.82 GiB used: 7.51 GiB (12.0%)
Info: 8-Core model: AMD Ryzen 7 1800X bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 1 stepping: 1 microcode: 8001138 cache: L2: 4 MiB
bogomips: 115252
Speed: 2457 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2457 2: 2167 3: 2168 4: 2153 5: 2672 6: 2079 7: 3414 8: 2107 9: 2135
10: 2114 11: 2345 12: 2118 13: 3056 14: 2097 15: 2468 16: 2177
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: ASUSTeK driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 26:00.0
chip-ID: 10de:13c2 class-ID: 0300
Screen-1: 0 s-res: 3840x1080 s-dpi: 143 s-size: 682x191mm (26.9x7.5")
s-diag: 708mm (27.9")
Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-2: HDMI-0 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: NVIDIA GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes
Device-1: NVIDIA GM204 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 26:00.1 chip-ID: 10de:0fbb
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 28:00.3 chip-ID: 1022:1457
class-ID: 0403
Device-3: C-Media Auna Mic CM900 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:3 chip-ID: 0d8c:0134
class-ID: 0300
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 22:00.0
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-1507b64ec0dd state: down mac: <filter>
IF-ID-2: br-b54611bb19d1 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
Local Storage: total: 1.82 TiB used: 776.85 GiB (41.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-60M2NA0
type: HDD rpm: 7200 serial: <filter> rev: 1A03 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A750 scheme: MBR
ID-1: / raw-size: 260.24 GiB size: 255.16 GiB (98.05%)
used: 85.7 GiB (33.6%) fs: ext4 dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: 528f8171-7936-4019-9382-d327f9354b32
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 308 KiB (0.1%) fs: vfat dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 10CE-D0D1
ID-3: /mnt/Storage raw-size: 930.56 GiB size: 930.56 GiB (100.00%)
used: 691.15 GiB (74.3%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 9202BE5402BE3CD3
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 4b0f0b7e-6616-4a9b-a7e2-5bedfd0afcd8
ID-1: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: ntfs label: Recovery
uuid: 18623B94623B759A
ID-2: /dev/sda2 maj-min: 8:2 size: 99 MiB fs: vfat label: N/A
uuid: 22CA-C366
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 196.09 GiB fs: ntfs label: N/A
uuid: F01A3D101A3CD4F6
ID-5: /dev/sda5 maj-min: 8:5 size: 530 MiB fs: ntfs label: N/A
uuid: E67CFFD97CFFA30B
ID-6: /dev/sdc1 maj-min: 8:33 size: 464.94 GiB fs: ntfs label: Backup
uuid: 0A7E277B7E275EA7
Device-1: 1-4:2 info: Logitech G403 Prodigy Wired/Wireless Gaming Mouse
type: Mouse,HID driver: logitech-hidpp-device,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 498mA chip-ID: 046d:c082 class-ID: 0300
serial: <filter>
Device-2: 1-7:3 info: Cherry Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046a:b090 class-ID: 0300
Device-3: 1-10:4 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c539 class-ID: 0300
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-1:2 info: Wacom Cintiq 16 type: HID driver: usbhid,wacom
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip-ID: 056a:03ae class-ID: 0300
serial: <filter>
Device-2: 3-2:3 info: C-Media Auna Mic CM900 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0134 class-ID: 0300
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 38.6 C mobo: N/A gpu: nvidia temp: 59 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 22%
Processes: 372 Uptime: 51m wakeups: 3 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1617 nix-default: 0
nix-sys: 0 nix-usr: 36 lib: 6 pacman: 1581 lib: 440 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: konsole inxi: 3.3.06
