Corrupted package(s) - but pacman cache is empty
I installed the recent [Stable Update] 2025-12-15 and [Stable Update] 2025-12-08 updates (since I had missed the 2025-12-08 release).
Now sudo pacman -Syu gets a message that the local btrfsmaintenance is newer than the repo package:
sudo pacman -Syu
 core is up to date
 extra is up to date
 multilib is up to date
warning: btrfsmaintenance: local (1:0.5.2-1) is newer than extra (0.5.2-2)
 there is nothing to do
I tried reinstalling it but keep getting this corruption error:
sudo pacman -Syu btrfsmaintenance
 core is up to date
 extra is up to date
warning: downgrading package btrfsmaintenance (1:0.5.2-1 => 0.5.2-2)
resolving dependencies...
Packages (1) btrfsmaintenance-0.5.2-2
Total Download Size:   0.02 MiB
Total Installed Size:  0.06 MiB
Net Upgrade Size:      0.02 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 btrfsmaintenance...    19.1 KiB   340 KiB/s 00:00 [----------------------] 100%
(1/1) checking keys in keyring                     [----------------------] 100%
(1/1) checking package integrity                   [----------------------] 100%
error: btrfsmaintenance: signature from "George Hu <integral@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/btrfsmaintenance-0.5.2-2-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: failed to commit transaction (invalid or corrupted package (PGP signature))
I tried sudo pacman -Syyuu btrfsmaintenance but still getting the same result. I even tried n for the Do you want to delete it? [Y/n] but still the same result.
I also cleaned my local caches with sudo pacman -Scc and verified that /var/cache/pacman/pkg/ is empty, yet still have the same issue.
Not sure this could have something to do with it, but I had this error which appeared benign while upgrading to this release (2025-12-15):
[2025-12-15T14:41:38-0500] [ALPM] upgraded manjaro-keyring (20230719-3 -> 20251003-1)
[2025-12-15T14:41:39-0500] [ALPM-SCRIPTLET] ==> Appending keys from manjaro.gpg...
[2025-12-15T14:41:40-0500] [ALPM-SCRIPTLET] ==> Locally signing trusted keys in keyring...
[2025-12-15T14:41:42-0500] [ALPM-SCRIPTLET] ==> ERROR: F66AD0FF0E57C561615A0901CEE477135C5872B0 could not be locally signed.
Additionally, I am now getting this error:
sudo pacman -Syu
 core is up to date
 extra                   8.7 MiB  10.8 MiB/s 00:01 [----------------------] 100%
Packages (1) gnome-shell-extension-forge-89-1
Total Download Size:   0.09 MiB
Total Installed Size:  0.32 MiB
Net Upgrade Size:      0.00 MiB
 gnome-shell-exte...    93.9 KiB  1342 KiB/s 00:00 [----------------------] 100%
error: gnome-shell-extension-forge: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/gnome-shell-extension-forge-89-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Once again, trying n yields the same results.
Any ideas what is causing this?
I got that too. Just install the update with… :backhand_index_pointing_down:
sudo pacman -Syuu
That worked for me, and I got no complaints about it when I ran pacman again tonight to update both chromium and kdenlive.
Did you update your mirrors first?
Either way, given that it’s Mark’s signature that seems to be the problem, pingelinging @Yochanan. :stuck_out_tongue:
Same issue appears…
sudo pacman -Syuu
 core is up to date
 extra is up to date
warning: btrfsmaintenance: downgrading from version 1:0.5.2-1 to version 0.5.2-2
Packages (2) btrfsmaintenance-0.5.2-2  gnome-shell-extension-forge-89-1
Total Download Size:   0.11 MiB
Total Installed Size:  0.38 MiB
 btrfsmaintenance...    19.1 KiB   178 KiB/s 00:00 [----------------------] 100%
 gnome-shell-exte...    93.9 KiB   531 KiB/s 00:00 [----------------------] 100%
 Total (2/2)           113.0 KiB   565 KiB/s 00:00 [----------------------] 100%
(2/2) checking keys in keyring                     [----------------------] 100%
(2/2) checking package integrity                   [----------------------] 100%
Because of the gnome-shell-extension-forgepackage. Answering "n there interrupts the update process.
Just did followed with forced sync—still appears to be the same.
I did answer y but later tried with n to rule anything out. Didn’t help, of course.
My understanding is pacman thinks there are corrupted packages in /var/cache/pacman/pkg/. But as I wrote in the post, I cleaned it out and then ran the commands again…but nada.
No, it only looks at the packages on the mirrors.
I see.
I tried installing a random package from the extra repository and got the exact same issue.
sudo pacman -S fastfetch
Packages (2) yyjson-0.12.0-1  fastfetch-2.56.0-1
Total Download Size:   0.65 MiB
Total Installed Size:  2.23 MiB
 yyjson-0.12.0-1-...   154.0 KiB  1048 KiB/s 00:00 [----------------------] 100%
 fastfetch-2.56.0...   515.7 KiB  2.85 MiB/s 00:00 [----------------------] 100%
 Total (2/2)           669.8 KiB  3.50 MiB/s 00:00 [----------------------] 100%
error: yyjson: signature from "Robin Candau <antiz@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/yyjson-0.12.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: fastfetch: signature from "Robin Candau <antiz@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/fastfetch-2.56.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
I then tried installing something from the core repo:
sudo pacman -S links
Packages (1) links-2.30-1
Total Download Size:   3.11 MiB
Total Installed Size:  6.23 MiB
 links-2.30-1-x86_64     2.9 MiB  5.81 MiB/s 00:01 [----------------------] 100%
error: failed retrieving file 'links-2.30-1-x86_64.pkg.tar.zst' from mirror.xenyth.net : OpenSSL SSL_read: OpenSSL/3.6.0: error:0A000126:SSL routines::unexpected eof while reading, errno 0
downloading required keys...
:: Import PGP key 6D42BDD116E0068F, "Christian Hesse <eworm@archlinux.org>"? [Y/n] y
error: links: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/links-2.30-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Perhaps this mirror is faulty?
Edit: removed the mirror and forced sync but to no avail…
Maybe you are having GPG issues due to having missed the previous update. Shouldn’t be happening, but never say “never”. :thinking:
Try this… :backhand_index_pointing_down:
Thank you but that didn’t work either. I’ll give this a try: [HowTo] Solve Keyring Related Issues in Manjaro
Edit: This link worked! Here’s what I did (taken from the link) :backhand_index_pointing_down:
Resynchronise with the Manjaro repository servers to ensure that everything is up to date - by entering the command:
sudo pacman -Syy
Remove all keys
sudo rm -rf /etc/pacman.d/gnupg
Reinitialize files & folders for keys
sudo pacman-key --init
Repopulate keys
sudo pacman-key --populate archlinux manjaro
Reinstall latest keyrings
sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring
Refresh the signature keys
sudo pacman-key --refresh-keys
Clear out the software packages downloaded during aborted installations (optional):
sudo pacman -Sc
Then:
sudo pacman -Syyu
…and everything is in good order.
Lesson learned: keep updating regularly
Perhaps another lesson to learn: In normal circumstances, only sudo pacman -Syu is required to perfom an update, – note the single y.
Note:- this is really intended for passers-by who copy/paste everything they see, without question; in this particular case, the double yy was arguably acceptable.
