Hello everyone,
I’ve been using manjaro for a few months now and when I first switched over I had no problem plugging any of my controllers and having them work right away however, I hadn’t tried to use one in a month or so and now when I plug in my Xbox One controller it will vibrate once to indicate it’s charging, and then will never connect. The same goes for other Xbox controllers as well as Playstation controllers so I know it’s not a controller issue.
My controllers also no longer show up in lsusb so I’m not really sure where to even start other than just reinstalling my OS. Any help would be appreciated! Here’s my lsusb in case i just missed it.
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 002: ID 2109:0812 VIA Labs, Inc. VL812 Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 1b1c:0a14 Corsair Corsair VOID PRO Wireless Gaming Headset
Bus 003 Device 003: ID 0a5c:21e8 Broadcom Corp. BCM20702A0 Bluetooth 4.0
Bus 003 Device 002: ID 2109:2812 VIA Labs, Inc. VL812 Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 2433:b200 ASETEK [NZXT Kraken X60]
Bus 001 Device 003: ID 260d:1014 E-Signal USB Gaming Mouse
Bus 001 Device 002: ID 1b1c:1b73 Corsair CORSAIR K70 RGB TKL CHAMPION SERIES Mechanical Gaming Keyboard
omano
2 August 2022 23:40
2
Try from a live USB environment from a fresh ISO and see if controllers work there. Try from another computer/OS to make sure the hardware is not faulty if you can.
Also follow the guidelines to post support request so people can help
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL2 (Trust Level 2) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to…
Sorry! I’m gonna go ahead and include the system information at the bottom of this reply in the hopes someone can tell me what happened. I tried the controller in my windows partition and (unsurprisingly) it worked just fine; now when I boot into manjaro the controller also works just fine again! I had already tried upgrading and downgrading kernels without effect, but whatever! It works! Thanks for the help omano
Kernel: 5.18.14-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=bb324553-ce60-44eb-ac58-c5713f2dac39 rw quiet splash apparmor=1
Desktop: GNOME v: 42.3.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM
v: 42.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3604
date: 02/25/2022
RAM: total: 23.38 GiB used: 3.47 GiB (14.8%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
stepping: 2 microcode: 0xA201205
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3584 high: 3595 min/max: 2200/4936 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3592 2: 3587
3: 3595 4: 3568 5: 3576 6: 3593 7: 3587 8: 3582 9: 3587 10: 3589 11: 3573
12: 3592 13: 3589 14: 3593 15: 3560 16: 3592 bogomips: 115035
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling
Device-1: AMD Vega 10 XTX [Radeon Frontier Edition] driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-1,DP-2,HDMI-A-1 empty: DP-3
bus-ID: 0b:00.0 chip-ID: 1002:6863 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: Acer ED270R serial: <filter> built: 2021
res: 1920x1080 dpi: 81 gamma: 1.2 size: 609x348mm (23.98x13.7")
diag: 690mm (27.2") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: DP-2 model: SCEI MONITOR serial: <filter> built: 2011
res: 1920x1080 dpi: 94 gamma: 1.2 size: 522x294mm (20.55x11.57")
diag: 600mm (23.6") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-3: HDMI-A-1 model: M551d-A2R serial: <filter> built: 2013
res: 1920x1080 dpi: 30 gamma: 1.2 size: 1430x800mm (56.3x31.5")
diag: 1836mm (72.3") ratio: 16:9 modes: max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon Vega Frontier Edition (vega10 LLVM 14.0.6 DRM
3.46 5.18.14-1-MANJARO) v: 4.6 Mesa 22.1.4 direct render: Yes
Device-1: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
v: kernel bus-ID: 3-3.4:4 pcie: chip-ID: 1b1c:0a14 gen: 3 speed: 8 GT/s
class-ID: 0300 lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:aaf8 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Corsair VOID PRO Wireless Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.18.14-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: yes
Sound Server-5: PipeWire v: 0.3.56 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8168 v: 8.049.02-NAPI modules: r8169
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 3-3.1:3 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Local Storage: total: 6.5 TiB used: 1.21 TiB (18.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU010TZ
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 002C temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000VM003-1ET164
type: HDD rpm: 5900 serial: <filter> rev: SC11 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: TR150 size: 111.79 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 12.3 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST4000DM000-1F2168
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5900 serial: <filter> rev: CC54 scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 327.82 GiB
(35.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: bb324553-ce60-44eb-ac58-c5713f2dac39
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 25.6 MiB
(8.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: 8664-D337
ID-3: /mnt raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 915.3 GiB
(49.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 60740ac0-0b94-4994-9262-c98056517905
ID-1: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sdb2 maj-min: 8:18 size: 111.27 GiB fs: ntfs label: N/A
uuid: B826F38126F33F46
ID-3: /dev/sdb3 maj-min: 8:19 size: 517 MiB fs: ntfs label: N/A
uuid: 86D2E85CD2E851CB
ID-4: /dev/sdc1 maj-min: 8:33 size: 16 MiB fs: <superuser required>
ID-5: /dev/sdc2 maj-min: 8:34 size: 3.64 TiB fs: ntfs label: 4tbHDD
uuid: 4ED05620D0560E99
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-1:2 info: Corsair K70 RGB TKL CHAMPION SERIES Mechanical
Gaming Keyboard type: Keyboard,HID driver: hid-generic,usbhid
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 1b1c:1b73
class-ID: 0300 serial: <filter>
Device-2: 1-2:3 info: E-Signal USB Gaming Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 260d:1014 class-ID: 0300
Device-3: 1-3:4 info: Microsoft Xbox One Controller (Firmware 2015)
type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 045e:02dd class-ID: ff00 serial: <filter>
Device-4: 1-8:5 info: ASETEK [NZXT Kraken X60] type: <vendor specific>
driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 50mA
chip-ID: 2433:b200 class-ID: 0000 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 3-3:2 info: VIA Labs VL812 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2812 class-ID: 0900
Device-1: 3-3.1:3 info: Broadcom BCM20702A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:21e8
Device-2: 3-3.4:4 info: Corsair VOID PRO Wireless Gaming Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 1b1c:0a14 class-ID: 0300
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-6: 4-3:2 info: VIA Labs VL812 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0812 class-ID: 0900
Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-8: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 44.1 C mobo: N/A gpu: amdgpu temp: 39.0 C
mem: 38.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 698
Processes: 393 Uptime: 2m wakeups: 0 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 alt: 11 clang: 14.0.6 Packages: 1880
pacman: 1868 lib: 465 flatpak: 5 snap: 7 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.20
omano
3 August 2022 01:42
4
Did you disable Fast Startup , and Hibernation on Windows, so it does not create issues?
PS: make sure you have three backticks ``` before and after your terminal output, you can see what you did is broken currently. Edit your post to fix it.
I had not disabled those, I’ve hardly touched the windows partition since I set it up so if it’s been causing problems I hadn’t put the two together yet.
Thank you so much for the help omano, it’s people like you that make this community so great
Also I fixed my last post and am incredibly embarrassed to say I hadn’t realized a “single quote” and a “back tick” were two different things
omano
3 August 2022 03:47
6
Jordshire:
Then try to disable them and see if you get a normal behavior back after in different scenarios (reboot, cold boot, and so on).
Hii, Jordshire…
continues even if the plugin is installed immediately, the controller does not detect it, The OS may have generated that plugging setting to enable, then you can try to reset the controller once or try changing the plugin setting.
