[Continuation] from how to install huion driver
Mate, I was having problems to install this AUR package but with your answer I was able to solve this. I would like to know if this package provides a graphic tool for configuring the tablet and the pen, as in the gnome-control-center the tablet and the pen are not recognized:
The pen responds to my command, the cursor moves as I move the pen, but I would like to configure its speed and the buttons on the left side of the tablet.
In gnome-control-center it says: “No pens found please move the pen to the proximity of the tablet to set up”
In principle, once you did all the steps and rebooted the system, it should facilitate to set the buttons and tweak some settings from UI.
Is this after, or was previous situation?
A previous situation, when I had not installed anything yet, this was the message that appeared to me, when no graphics tablet was connected. After I installed the drivers, the tablet started to function normally, but the message on the gnome-control-center remains the same: “No pens found please move the pen to the proximity of the tablet to set up.” I move the pen, the cursor responds to my movements but there is no possibility of configuration.
I’m trying to upload a print but I can’t upload images, I put it on imgur but I can’t post links too :frowning:
Let me move this to a new topic, so we can try to see if there is indeed an issue or just Gnome is not dealing with it.
Are you on wayland session or X11?
Install xorg-xinput package and provide the output of
xinput
Use ``` above and bellow it for proper formatting. For image/links, till you gain more trust on the forum, use this workaround :slight_smile:
I am on X11.
$ xinput
⎡ Virtual core pointer                    	id=2	[master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              	id=4	[slave  pointer  (2)]
⎜   ↳ SINO WEALTH USB KEYBOARD Consumer Control	id=10	[slave  pointer  (2)]
⎜   ↳ USB OPTICAL MOUSE                       	id=12	[slave  pointer  (2)]
⎜   ↳ USB OPTICAL MOUSE  Consumer Control     	id=14	[slave  pointer  (2)]
⎜   ↳ HID 256c:006d Pad                       	id=18	[slave  pointer  (2)]
⎜   ↳ HID 256c:006d Pen (0)                   	id=20	[slave  pointer  (2)]
⎣ Virtual core keyboard                   	id=3	[master keyboard (2)]
    ↳ Virtual core XTEST keyboard             	id=5	[slave  keyboard (3)]
    ↳ Power Button                            	id=6	[slave  keyboard (3)]
    ↳ Power Button                            	id=7	[slave  keyboard (3)]
    ↳ SINO WEALTH USB KEYBOARD                	id=8	[slave  keyboard (3)]
    ↳ SINO WEALTH USB KEYBOARD System Control 	id=9	[slave  keyboard (3)]
    ↳ SINO WEALTH USB KEYBOARD Keyboard       	id=11	[slave  keyboard (3)]
    ↳ USB OPTICAL MOUSE  Keyboard             	id=13	[slave  keyboard (3)]
    ↳ Eee PC WMI hotkeys                      	id=15	[slave  keyboard (3)]
    ↳ SINO WEALTH USB KEYBOARD Consumer Control	id=16	[slave  keyboard (3)]
    ↳ USB OPTICAL MOUSE  Consumer Control     	id=17	[slave  keyboard (3)]
    ↳ HID 256c:006d                           	id=19	[slave  keyboard (3)]
and here’s a print of my gnome-control-center in the Tablet Wacom session: https://paste.pics/32c4a2af349244d1dc662172c894c2a6
This is the ID of your device. Pad and Pen. There should be something like this in configs
Section "InputClass"
	Identifier "Huion tablets with Wacom driver"
	MatchUSBID "5543:006e|256c:006e|256c:006d"
	MatchDevicePath "/dev/input/event*"
	MatchIsKeyboard "false"
	Driver "wacom"
EndSection
but then i saw this that it seems the issue is here for quite some time
and according to this
you will be able to set the buttons only trough xsetwacom commands … all this with the v8
Better to use the release v10 from a week ago
http://aur.archlinux.org/packages/digimend-drivers-git-dkms
So instead of the digimend-kernel-drivers-dkms-git as was the case in the other topic, you use this new package, so you will have to do this:
pamac remove digimend-kernel-drivers-dkms-git
then
sudo rm /etc/x11/xorg.conf.d/11-huion-tablet.conf
pamac build digimend-drivers-git-dkms
Reboot your system after that and try again the settings in Gnome.
Mate, what should I do here?
$ pamac build digimend-drivers-git-dkms
Preparing...
Cloning digimend-drivers-git-dkms files to compile...
Veryfying 1digimend-drivers-git-dkms dependencies...
Resolving dependencies...
Checking package conflict...
To create (1):
  digimend-drivers-git-dkms  10.r0.gec5c16d-1      AUR
Edit build files ? [y/N]
You don’t want to edit the file, so you press N for no
Well… the problem persist, is there anything else that we can do? ps: /etc/x11/xorg.conf.d/00-keyboard.conf is the only file that I have in xorg.conf.d
Their digimend configs are elsewhere … i’ll try to check
For now you can only use
xsetwacom list dev
and then for each dev to set the button … something like this
xsetwacom --set 'HUION Huion Tablet Pen stylus' Button 1 "button +1"
where the HUION Huion Tablet Pen stylus is actually given by the dev above. Each can be Stylus or Pad, but without the device at hand i need to read more from other users, other sources.
Edit:
Ok, so their config is in /usr/share/X11/xorg.conf.d/50-digimend.conf
Then you can try to create again the /etc/x11/xorg.conf.d/11-huion-tablet.conf as mentioned in the other topic, and add that content to it. Still can’t asure it will work with the Gnome Settings.
Then see if by installing xf86-input-wacom things change with the detection of the stylus in GS.
So, let me see if I understand: I have to copy all the content present in /usr/share/X11/xorg.conf.d/50-digimend.conf and put into this new file: /etc/x11/xorg.conf.d/11-huion-tablet.conf if it doesn’t work I can try to install xf86-input-wacom. Did I get it right?
No, because in that case you could just make a symlink.
You copy the content from here for that config.
To try to trick the Gnome Settings to see the tablet and be able to set the buttons.
The one installed remains untouched.
