Hi All,
What are some of the popular applications for containerization for Manjaro? I have never used one before and I would like too learn but I am sure some work better than others (Docker, Kubernetes, etc)
Wollie
29 January 2022 14:48
2
There is a tutorial for docker:
Difficulty: β
β
βββ
This tutorial will help you set up a pacman mirror using a Synology Diskstation, which will allow you to minimize Internet traffic when deploying to multiple Manjaro Workstations / Servers on your LAN.
1. the docker image:
A small alpine image has been used with rsync and nginx included. The details can be found here on on GitHub
When starting the container, two simple things happen:
nginx is started
An rsync script runs in an infinite loop with configurable sleep (defauβ¦
Also Arch wiki has some advice:
https://wiki.archlinux.org/title/Docker
