Hi, with the latest update of Manjaro KDE (stable branch) my conky manager widget disappeared.
I decided to try copy the theme from /.conky/theme folder to /.config/conky
but it seems conky config file uses different “indentation?” than conky manager.
This is my conky manager theme file. I made it by trial and error by looking at the other themes.
background yes
double_buffer yes
alignment top_right
border_width 1
cpu_avg_samples 2
default_color white
default_outline_color white
default_shade_color white
draw_borders no
draw_graph_borders yes
draw_outline no
draw_shades no
gap_x 50
gap_y 20
net_avg_samples 2
no_buffers yes
out_to_console no
out_to_stderr no
extra_newline no
own_window yes
own_window_type normal
own_window_transparent yes
own_window_colour 000000
own_window_argb_visual yes
own_window_argb_value 0
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
minimum_size 220 0
stippled_borders 0
update_interval 2.0
uppercase no
use_spacer none
show_graph_scale no
show_graph_range no
use_xft yes
xftalpha 0.1
xftfont Droid Sans:size=10
color0 white
color1 EAEAEA
color2 FFA300
color3 grey
TEXT
${color 9AB7DC}Kernel:${color a4a4a4}${alignr}$kernel
${color 9AB7DC}UpTime:${color a4a4a4}${alignr}$uptime
${color2}CPU ${color0}${alignr}${cpu cpu0}%
${color2}Frequency:${color0}${alignr}$freq MHz
${color2}Temperature ${color0}${alignr}${execi 10 sensors | grep 'Core 10' | cut -c14-17}°C
${cpubar cpu0 6,}
${cpugraph cpu0 50,220}${voffset 2}
${top name 1} $alignr ${top cpu 1}%
${top name 2} $alignr ${top cpu 2}%
${top name 3} $alignr ${top cpu 3}%
${top name 4} $alignr ${top cpu 4}%
${top name 5} $alignr ${top cpu 5}%
${top name 6} $alignr ${top cpu 6}%
${top name 7} $alignr ${top cpu 7}%
${top name 8} $alignr ${top cpu 8}%
${top name 9} $alignr ${top cpu 9}%
${top name 10} $alignr ${top cpu 10}%
${color2}RAM ${color0}${alignr}${offset 2}$mem / $memmax${offset 30}
${membar 7,}
${color2}SWAP ${color0}${alignr}${offset 2}$swap / $swapmax${offset 30}
${swapbar 7,}
${memgraph 50,220}${voffset 2}
${top_mem name 1} $alignr ${top_mem mem_res 1}
${top_mem name 2} $alignr ${top_mem mem_res 2}
${top_mem name 3} $alignr ${top_mem mem_res 3}
${top_mem name 4} $alignr ${top_mem mem_res 4}
${top_mem name 5} $alignr ${top_mem mem_res 5}
${top_mem name 6} $alignr ${top_mem mem_res 6}
${top_mem name 7} $alignr ${top_mem mem_res 7}
${top_mem name 8} $alignr ${top_mem mem_res 8}
${top_mem name 9} $alignr ${top_mem mem_res 9}
${top_mem name 10} $alignr ${top_mem mem_res 10}
I copied it into the /.config/conky/conky.conf but it wouldn’t work so I looked up the github page conky config file and tried to fix it. This is the result.
background = true
double_buffer = true
alignment = top_right
border_width = 1
cpu_avg_samples = 2
default_color = white
default_outline_color = white
default_shade_color = white
draw_borders = false
draw_graph_borders = true
draw_outline = false
draw_shades = false
gap_x = 50
gap_y = 20
net_avg_samples = 2
no_buffers = true
out_to_console = false
out_to_stderr = false
extra_newline = false
own_window = true
own_window_type = normal
own_window_transparent = true
own_window_colour = 000000
own_window_argb_visual = true
own_window_argb_value = 0
own_window_hints = undecorated,below,sticky,skip_taskbar,skip_pager
minimum_size = 220 0
stippled_borders = 0
update_interval = 2.0
uppercase = false
use_spacer = none
show_graph_scale = false
show_graph_range = false
use_xft = true
xftalpha = 0.1
xftfont 'Droid Sans:size=10'
color0 = white
color1 = EAEAEA
color2 = FFA300
color3 = grey
TEXT
${cpubar cpu0 6,}
${membar 7,}
${swapbar 7,}
Could someone help I don’t know how to make my theme file for conky.
I could just wait for the conky manager fix, but I don’t know when that will happen so…
