Ben
25 January 2023 01:56
1
When performing today’s update, I had to make extra space for it to complete.
The problem is that I don’t know why it’s full - I’m seeing 12.7GiB available on my 250GiB SSD.
Yet filelight looks like this:
Showing only 47.5GiB (which seems reasonable).
So why isn’t there 200GiB free???
I ran my cleanup:
sudo pacman -Sc && pamac clean --build-files && paccache
-rvuk0 && paru --clean && flatpak uninstall --unused && sudo journa
lctl --vacuum-time=3h && sudo journalctl --flush --rotate
~ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sda2 233G 183G 41G 82% /
❯ \df -h -hT /home
Filesystem Type Size Used Avail Use% Mounted on
/dev/sda2 btrfs 233G 183G 41G 82% /home
ncdu / --exclude /mnt for the local disk:
Total disk usage is reported as 41.0 GiB… but there’s only 40 GiB free from 250 GiB
Help!!!
Hello @Ben
What about your snapshots/subvolumes since you use btrfs?
Maybe that help you to get the size of each subvolume:
If the snapshot take space, you can check them like that:
export UUID=$(findmnt -n -o UUID /)
export MNTPNT=$(mktemp -d -t "btrfs.XXX")
sudo mount -m -U "$UUID" "$MNTPNT"
for x in $(sudo btrfs subvolume list "$MNTPNT" | cut -d' ' -f9); do
echo ">>> Subvolume: $x"
sudo btrfs filesystem du -s "$MNTPNT/$x"
done
sudo umount "$MNTPNT"
And a one-liner:
export UUID=$(findmnt -n -o UUID /); export MNTPNT=$(mktemp -d -t "btrfs.XXX"); sudo mount -m -U "$UUID" "$MNTPNT"; sleep 3 && for x in…
Please do use btrfs-command when using btrfs
Please post
sudo btrfs filesystem usage -h /
like:
sudo btrfs filesystem usage -h / ✔
[sudo] Passwort für andreas:
Overall:
Device size: 1.76TiB
Device allocated: 1.33TiB
Device unallocated: 441.94GiB
Device missing: 0.00B
Device slack: 0.00B
Used: 1.12TiB
Free (estimated): 323.62GiB (min: 323.62GiB)
Free (statfs, df): 323.62GiB
Data ratio: 2.00
Metadata ratio: 2.00
Global reserve: 512.00MiB (used: 0.00B)
Multiple profiles: no
Data,RAID1: Size:671.00GiB, Used:568.35GiB (84.70%)
/dev/sda2 671.00GiB
/dev/nvme0n1p3 671.00GiB
Metadata,RAID1: Size:8.00GiB, Used:6.38GiB (79.71%)
/dev/sda2 8.00GiB
/dev/nvme0n1p3 8.00GiB
System,RAID1: Size:32.00MiB, Used:128.00KiB (0.39%)
/dev/sda2 32.00MiB
/dev/nvme0n1p3 32.00MiB
Unallocated:
/dev/sda2 220.97GiB
/dev/nvme0n1p3 220.97GiB
Please have a special look at Unallocated:
du only shows what you have in your active subvolume !
But if you took snapshots, they are not acounted by du
Please use
btrfs subvolume list --help
You can find good Information about Btrfs in the wiki
Zesko
25 January 2023 06:58
4
See here:
I am running out of disk space (the symptom being that virsh won’t create a new vm with an error indicating lack of space.
So I am trying to make space but can not see any difference even after removing quite large items.
1. checking usage
$ sudo df -h /
/dev/sda1 443G 436G 4,6G 99% /
2. identifying a large file
$ sudo find /var/lib/libvirt -name WS19.qcow2 -exec ls -lh {} \;
-rw------- 1 root kvm 41G 7. Okt 2020 /var/lib/libvirt/i…
You need to create multiple separate subvolumes: Downloads, VM images, Games, multiple media and some unnecessary data (It exists everywhere in Internet). You do not need to take snapshots for them.
This cannot be the solution. You can use one volume as root and everything should work.
Ben
25 January 2023 07:14
6
I really should look to ditch Timeshift and set up Snapper properly.
For now, I simply deleted all the snapshots (previously I deleted 3, leaving 3 - it didn’t make much of a dent probably because the content of my root is fairly stable).
Anyway, I’m now seeing 114GiB free which seems okay.
I’ve also downloaded this thread as a MarkText, so I’ll edit and pare it down and start learning more.
Overall:
Device size: 232.59GiB
Device allocated: 228.02GiB
Device unallocated: 4.56GiB
Device slack: 512.00B
Used: 105.34GiB
Free (estimated): 114.12GiB (min: 111.84GiB)
Free (statfs, df): 114.12GiB
Data ratio: 1.00
Global reserve: 351.75MiB (used: 0.00B)
Data,single: Size:210.01GiB, Used:100.45GiB (47.83%)
/dev/sda2 210.01GiB
Metadata,DUP: Size:9.00GiB, Used:2.44GiB (27.17%)
/dev/sda2 18.00GiB
System,DUP: Size:8.00MiB, Used:48.00KiB (0.59%)
/dev/sda2 16.00MiB
Unallocated:
/dev/sda2 4.56GiB
A special shoutout to @andreas85 who pretty much found my ‘Error 40’ moment.
So the confusion arises from the subvolume structures and filesystem reporting which excludes snapshots.
This is quite a hideous issue, that subvolumes that take physical space aren’t listed or referred to.
Thanks for that information, I remember the last time I met this issue I also cured it by basically purging them all and taking a fresh one.
I’m determined to stay on top of it, I couldn’t imagine giving up BTRFS.
Thanks for the input. Any additional comments are welcome, I’m starting a new notebook for this - it’s hard for my brain to adjust and wrap around it.
Be careful! Only unallocated counts !!!
(forget about “free”)
after deleting some snapshots this will rise
After removing snapshots i often do as root:
watch btrfs filesystem usage -h /
Then after a while i do:
btrfs balance start -musage=50 -dusage=50 /
Then after a while :
btrfs balance start -musage=70 -dusage=70 /
btrfs balance start -musage=90 -dusage=90 /
A healthy btrfs needs to have 10% unallocated at least !
Ben
25 January 2023 23:37
8
Sweet - so I get a live view in the top window - good because balance has no output or indication.
Live view also of unallocated, which just went past 70GiB after 3-4 minutes…
Time enough, perhaps to
RTFM about Balance Filters.
Okay, so the musage/dusage 50 pass is complete.
had to relocate 84 out of 221 chunks
Unallocated: 92.52 GiB
Data: 132 GiB, used 103.04 GiB (78%)
Metadata, DUP: 4 GiB used 2.59 GiB (64.81%)
System, DUP: Size 32 GiB used 48kib (0.15%)
So that looks nice - back to the RTFM link now for a while.
Cheers guys - adding this to my notebook for sure
Also, for now, I’ll get information conky panel pop up for 15 seconds after launching conky to keep an eye on things… this seems an important aspect to monitor - and look at schedule checks/warnings/maintenance.
I am writing a new page in the wiki
If you have wishes, what to place there …
