Good evening everyone
i use manjaro kde and i have a problem
how do i disable the internal speakers of my new BMAX b2 plus pc?
I would like the audio to be connected to the monitor speakers by default, without touching anything.
Instead, every time I start the PC, the audio comes from the internal speakers of the PC.
thanks to who helps me.
what kind of answer is this?
You can disable the internal speaker with pavucontrol β Configuration and select Profile: Off of Built-in Audio.
OP would need to install PulseAudio Volume Control on KDE
pamac install pavucontrol-qt
Suggestion to Change profile for Built-in Audio to Off would ensure audio only uses HDMI/DP Controller
I tried but the problem remains
thanks anyway
