Conflict while installing emacs
Hi,
I had the 29 version of emacs installed, I removed it and want to install version 28, however I get the below conflict when trying to install -
$ sudo pacman -S emacs
[sudo] password for murtaza:
resolving dependencies…
:: installing libtiff (4.5.0-3) breaks dependency ‘libtiff.so=5-64’ required by sane
Considering I just installed it with no problems:
$ pamac install emacs        Preparing...
Authenticating as: Mirdarthos (mirdarthos)
Password:
Resolving dependencies...
Checking inter-conflicts...
To install (4):
libotf    0.9.16-4  (Required By: emacs)  extra  85.9 kB
m17n-db   1.8.0-4   (Required By: emacs)  extra  1.5 MB
m17n-lib  1.8.0-13  (Required By: emacs)  extra  327.2 kB
emacs     28.2-2                          extra  42.6 MB
Total download size: 44.5 MB
Total installed size: 124.5 MB
Apply transaction ? [y/N] y
Download of m17n-db (1.8.0-4) started
Download of m17n-lib (1.8.0-13) started
Download of m17n-lib (1.8.0-13) finished
Download of emacs (28.2-2) started
Download of m17n-db (1.8.0-4) finished
Download of libotf (0.9.16-4) started
Download of libotf (0.9.16-4) finished
Download of emacs (28.2-2) finished
Checking keyring...        [4/4]
Checking integrity...        [4/4]
Loading packages files...        [4/4]
Checking file conflicts...        [4/4]
Checking available disk space...        [4/4]
Installing libotf (0.9.16-4)...        [1/4]
Installing m17n-db (1.8.0-4)...        [2/4]
Installing m17n-lib (1.8.0-13)...        [3/4]
Installing emacs (28.2-2)...        [4/4]
Arming ConditionNeedsUpdate...        [1/7]
Refreshing PackageKit...        [2/7]
Updating icon theme caches...        [3/7]
pacman-backup.hook        [4/7]
Checking for .pacnew and .pacsave files...        [5/7]
Updating the info directory file...        [6/7]
Updating the desktop file MIME type cache...        [7/7]
I think your system and/or mirrors are of sync and not updated. So resync you mirrors:
sudo pacman-mirrors -f 5
And update your system:
pamac upgrade && pamac upgrade --aur --devel || echo -e '\033[0;91mThere was an error upgrading the system. AUR packages not upgraded.\e[0m'
Reboot, and try to install emacs again:
pamac install emacs
Hope this helps!
:bangbang: Tip: :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
The correct command would be pamac install emacs
(or sudo pacman -Syu emacs)
Otherwise, you’ll end up in a Partial Upgrade state.
I get the below error while installing emacs -
$ pamac -S emacs
pamac: error while loading shared libraries: libtiff.so.5: cannot open shared object file: No such file or directory
Have you done the update that I mentioned? And @mithrial and me gave you more correct commands to install stuff.
And besides, you’re not very clear on what happens and how you’re going about things. Please see:
Okay, so if you duplicate your question, I’ll duplicate my answer:
I tried the below command and I get the same error as above.
pamac install emacs
I am now doing sudo pacman -Syu emacs, its not complete yet.
Well then, wait for it to complete.
