Computer doesn't boot at first try and freezes randomly
Hi There,
My computer doesn’t boot at first try. It freezes on black screen before splash logo, freezes at splash or after login to my account with black screen with cursor. Also when I boot success, sometimes randomly became unresponsive with moving cursor before completely freeezes in 1 minute. This is why I did force shutdown occasionally. Sometimes I need to boot Live usb to run fsck, e2fsck in order to repair my file system.
inxi -Fza                                                        ✔
  Kernel: 5.4.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
  root=UUID=c0ffb714-92e7-d601-c095-b61492e7d601 ro quiet splash apparmor=1
  Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
  Distro: Manjaro Linux
  Type: Laptop System: LENOVO product: 20RBS1L200 v: ThinkPad E14
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: LENOVO model: 20RBS1L200 serial: <filter> UEFI: LENOVO
  v: R16ET28W (1.14 ) date: 09/14/2020
  ID-1: BAT0 charge: 35.8 Wh condition: 45.0/45.0 Wh (100%) volts: 12.4/11.1
  model: LGC 5B10W138 type: Li-poly serial: <filter> status: Charging
  cycles: 21
  Device-1: hidpp_battery_0
  model: Logitech Marathon Mouse/Performance Plus M705 serial: <filter>
  charge: 55% (should be ignored) rechargeable: yes status: Discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K270
  serial: <filter> charge: 100% (should be ignored) rechargeable: yes
  status: Discharging
  Info: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
  microcode: DE L2 cache: 6 MiB
  bogomips: 33615
  Speed: 3881 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 3881 2: 3952
  3: 3991 4: 3887 5: 3810 6: 3793 7: 3961 8: 3758
  Type: srbds mitigation: TSX disabled
  Device-1: Intel UHD Graphics vendor: Lenovo driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:9b41
  Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
  bus ID: 1-8:4 chip ID: 13d3:5415
  Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa display ID: :1
  screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
  s-diag: 1055mm (41.6")
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 163 size: 300x170mm (11.8x6.7")
  diag: 345mm (13.6")
  Monitor-2: HDMI2 res: 1920x1080 hz: 60 dpi: 96
  size: 510x290mm (20.1x11.4") diag: 587mm (23.1")
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.3.3
  direct render: Yes
  Device-1: Intel vendor: Lenovo driver: snd_hda_intel v: kernel
  alternate: snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:02c8
  Sound Server: ALSA v: k5.4.89-1-MANJARO
  Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 3000
  bus ID: 00:14.3 chip ID: 8086:02f0
  vendor: Lenovo driver: r8169 v: kernel port: 2000 bus ID: 04:00.0
  chip ID: 10ec:8168
  IF: enp4s0 state: down mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Local Storage: total: 491.85 GiB used: 42.66 GiB (8.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FP6512G
  size: 476.94 GiB block size: physical: 512 B logical: 512 B
  speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: V1.0
  ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Glide
  size: 14.91 GiB block size: physical: 512 B logical: 512 B
  serial: <filter> rev: 1.27
  ID-1: / raw size: 41.02 GiB size: 38.43 GiB (93.70%)
  used: 18.37 GiB (47.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw size: 100 MiB size: 98.4 MiB (98.42%)
  used: 298 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw size: 435.83 GiB size: 408.52 GiB (93.74%)
  used: 24.29 GiB (5.9%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 68.0 C mobo: 0.0 C
  Fan Speeds (RPM): cpu: 3400
  Processes: 317 Uptime: 31m wakeups: 9 Memory: 15.45 GiB
  used: 5.43 GiB (35.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0
  Packages: 1334 pacman: 1320 lib: 380 flatpak: 6 snap: 8 Shell: Zsh v: 5.8
  running in: gnome-terminal inxi: 3.2.02
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
loop0         7:0    0  97.9M  1 loop /var/lib/snapd/snap/core/10583
loop1         7:1    0   173M  1 loop /var/lib/snapd/snap/spotify/43
loop2         7:2    0  64.8M  1 loop /var/lib/snapd/snap/gtk-common-themes/1514
loop3         7:3    0  31.1M  1 loop /var/lib/snapd/snap/snapd/10707
loop4         7:4    0 162.9M  1 loop /var/lib/snapd/snap/gnome-3-28-1804/145
loop5         7:5    0  55.4M  1 loop /var/lib/snapd/snap/core18/1944
loop6         7:6    0   6.3M  1 loop /var/lib/snapd/snap/rclone/466
sda           8:0    1  14.9G  0 disk
├─sda1        8:1    1   2.8G  0 part /run/media/ercan/MANJARO_GNOME_2021
└─sda2        8:2    1     4M  0 part
nvme0n1     259:0    0 476.9G  0 disk
├─nvme0n1p1 259:1    0   100M  0 part /boot/efi
├─nvme0n1p2 259:2    0    41G  0 part /
└─nvme0n1p3 259:3    0 435.8G  0 part /home
sudo efibootmgr                                           ✔  7s 
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 0000,0010,0011,0012,0013,0014,0018,0019,001A,001B,001C,001D,001E,001F,0020
Boot0000* manjaro
Boot0010  Setup
Boot0011  Boot Menu
Boot0012  Diagnostic Splash Screen
Boot0013  Lenovo Diagnostics
Boot0014  Regulatory Information
Boot0015  Startup Interrupt Menu
Boot0016  Rescue and Recovery
Boot0017  MEBx Hot Key
Boot0018* USB CD
Boot0019* USB FDD
Boot001A* NVMe0
Boot001B* NVMe1
Boot001C* ATA HDD0
Boot001D* ATA HDD1
Boot001E* ATA HDD2
Boot001F* USB HDD
Boot0020* PXE BOOT
Boot0021* IDER BOOT CDROM
Boot0022* IDER BOOT Floppy
Boot0023* ATA HDD
Boot0024* ATAPI CD
I little swap is always better than none.
I’ve enabled the swap. At the moment shutdown and boot proccess is very slow. I saw a stop job is running for 6 minutes while shutdown in progress.
systemd-analyze blame  :heavy_check_mark:  5m 16s 
2min 4.150s systemd-random-seed.service
1min 30.228s systemd-journal-flush.service
1min 1.476s plymouth-read-write.service
33.925s systemd-tmpfiles-setup.service
17.088s NetworkManager-wait-online.service
6.644s docker.service
4.909s plymouth-quit-wait.service
2.465s systemd-backlight@backlight:intel_backlight.service
627ms lvm2-monitor.service
578ms home-swapfile.swap
519ms dev-nvme0n1p2.device
412ms var-lib-snapd-snap-core18-1944.mount
408ms var-lib-snapd-snap-core-10583.mount
407ms var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1514.mount
402ms var-lib-snapd-snap-spotify-43.mount
398ms var-lib-snapd-snap-snapd-10707.mount
347ms var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount
343ms var-lib-snapd-snap-rclone-466.mount
336ms apparmor.service
227ms snapd.service
214ms dev-loop4.device
197ms dev-loop1.device
193ms dev-loop2.device
186ms dev-loop3.device
165ms dev-loop5.device
162ms dev-loop6.device
137ms upower.service
127ms polkit.service
111ms systemd-rfkill.service
101ms systemd-udevd.service
87ms dev-loop0.device
82ms udisks2.service
82ms boot-efi.mount
80ms systemd-udev-trigger.service
77ms user@1000.service
69ms systemd-journald.service
65ms bluetooth.service
63ms NetworkManager.service
62ms cups.service
56ms systemd-logind.service
54ms systemd-tmpfiles-clean.service
When you run the filesystem checks, do you see errors being reported/corrected?
yes I see errors and they got fixed after filesystemchecks.
Based on what you shared, I am tempted to believe that you have a dying hard drive.
Maybe you can enable SMART monitoring to confirm.
It seems like healty to me.
    ~  sudo smartctl --all /dev/nvme0                            ✔  6s 
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.4.89-1-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number:                       TEAM TM8FP6512G
Serial Number:                      TPBF2007240040600332
Firmware Version:                   V1.0
PCI Vendor ID:                      0x10ee
PCI Vendor Subsystem ID:            0x501a
IEEE OUI Identifier:                0x000000
Controller ID:                      1
NVMe Version:                       1.3
Number of Namespaces:               1
Namespace 1 Size/Capacity:          512,110,190,592 [512 GB]
Namespace 1 Formatted LBA Size:     512
Local Time is:                      Thu Feb  4 17:37:03 2021 +03
Firmware Updates (0x02):            1 Slot
Optional Admin Commands (0x0007):   Security Format Frmw_DL
Optional NVM Commands (0x001d):     Comp DS_Mngmt Wr_Zero Sav/Sel_Feat
Log Page Attributes (0x0a):         Cmd_Eff_Lg Telmtry_Lg
Maximum Data Transfer Size:         32 Pages
Warning  Comp. Temp. Threshold:     85 Celsius
Critical Comp. Temp. Threshold:     90 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +     5.00W       -        -    0  0  0  0        0       0
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning:                   0x00
Temperature:                        44 Celsius
Available Spare:                    100%
Available Spare Threshold:          10%
Percentage Used:                    1%
Data Units Read:                    3,432,996 [1.75 TB]
Data Units Written:                 1,545,498 [791 GB]
Host Read Commands:                 26,016,283
Host Write Commands:                18,381,471
Controller Busy Time:               0
Power Cycles:                       284
Power On Hours:                     179
Unsafe Shutdowns:                   232
Media and Data Integrity Errors:    0
Error Information Log Entries:      0
Warning  Comp. Temperature Time:    1
Critical Comp. Temperature Time:    0
Temperature Sensor 1:               44 Celsius
Thermal Temp. 1 Transition Count:   5
Thermal Temp. 1 Total Time:         395
Error Information (NVMe Log 0x01, 16 of 64 entries)
No Errors Logged
Don’t know what to do about :point_up: but I would be worried.
It’s just force shutdown count which is I did when computer freezes. My drive seems healty.
Drives: Local Storage: total: 476.94 GiB used: 59.59 GiB (12.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FP6512G size: 476.94 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: rev: V1.0
temp: 43 Celsius C
SMART: yes health: PASSED on: 7d 11h cycles: 284 read-units: 3,433,075 [1.75 TB]
written-units: 1,546,228 [791 GB]
Oke, so you have forced the shutdown 232 times and it freezes ranomly :thinking:. I’ve had a nvme drive give all OK’s and still lock up in a state where nothing would be writen to disk, no errors reported does not mean no errors. It might be difficult to replace the drive but if there is nothing else wrong that you can find… What can you find in the journal?
Here are some more things you can do to check your drive:
https://bbs.archlinux.org/viewtopic.php?id=248157
I’ve started nvme-self-test with nvmecli I’ll post when it finish. here is my other logs.
journalctl
    ~  journalctl -x -p3 -b1         ✔  4s 
-- Journal begins at Tue 2021-02-02 17:29:23 +03, ends at Thu 2021-02-04 20:53:34 +03. --
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: Loaded firmware version: 50.3e391d3e.0
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00003208 | ADVANCED_SYSASSERT
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x0000A200 | trm_hw_status0
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x004C9534 | branchlink2
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000E56 | interruptlink1
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000E56 | interruptlink2
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | data1
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | data2
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | data3
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x3D403D63 | beacon time
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0xFAAA729B | tsf low
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x0000096D | tsf hi
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | time gp1
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0xB796DE53 | time gp2
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000032 | uCode version major
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x3E391D3E | uCode version minor
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000351 | hw version
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00C89004 | board version
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x80C5FC0B | hcmd
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x24020000 | isr0
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00400000 | isr1
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x08F00002 | isr2
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00C35A4C | isr3
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr4
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x0203001C | last cmd Id
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00016988 | wait_event
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x000000D4 | l2p_control
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00018034 | l2p_duration
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000007 | l2p_mhvalid
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000081 | l2p_addr_match
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | timestamp
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x000040B8 | flow_handler
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x20000070 | NMI_INTERRUPT_LMAC_FATAL
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x80465E6A | umac branchlink2
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x80483754 | umac interruptlink1
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x80483754 | umac interruptlink2
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000400 | umac data1
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x80483754 | umac data2
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | umac data3
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000032 | umac major
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x3E391D3E | umac minor
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0xB796DE67 | frame pointer
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0xC0886284 | stack pointer
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x006E01A9 | last host cmd
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: Fseq Registers:
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x20000021 | FSEQ_ERROR_CODE
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x80290033 | FSEQ_TOP_INIT_VERSION
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00070043 | FSEQ_CNVIO_INIT_VERSION
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x0000A481 | FSEQ_OTP_VERSION
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x01300504 | FSEQ_CNVR_ID
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x01300504 | CNVR_AUX_MISC_CHIP
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: FW error in SYNC CMD REPLY_BEACON_FILTERING_CMD
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: failed to update power mode
Feb 02 17:29:23 manjaro kernel: iwlwifi 0000:00:14.3: PHY ctxt cmd error. ret=-5
lines 34-71/71 (END)
dmesg output:
sudo dmesg -l emerg,alert,crit,err,warn                                                    127 ✘
[sudo] password for ercan:
[  143.917376] kauditd_printk_skb: 4 callbacks suppressed
[  148.520037] iwlwifi 0000:00:14.3: Unhandled alg: 0x707
[  155.035147] kauditd_printk_skb: 33 callbacks suppressed
[  177.813219] proc: Bad value for 'hidepid'
[  332.183754] mce: CPU5: Core temperature above threshold, cpu clock throttled (total events = 510)
[  332.183754] mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 510)
[  332.183756] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 1734)
[  332.183756] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 1734)
[  332.183791] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 1734)
[  332.183792] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 1734)
[  332.183793] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 1734)
[  332.183794] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 1734)
[  332.183795] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 1734)
[  332.183796] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 1734)
[  452.117572] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 399)
[  452.117599] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 399)
[  632.423718] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 1980)
[  632.423718] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 1980)
[  632.423752] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 1980)
[  632.423752] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 1980)
[  632.423753] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 1980)
[  632.423754] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 1980)
[  632.423755] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 1980)
[  632.423756] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 1980)
[  752.514843] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 468)
[  752.514843] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 468)
[  765.397483] proc: Bad value for 'hidepid'
[  932.649049] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 2165)
[  932.649050] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 2165)
[  932.649051] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 2165)
[  932.649052] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 2165)
[  932.649080] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 2165)
[  932.649081] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 2165)
[  932.649082] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 2165)
[  932.649083] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 2165)
[ 1233.746320] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 3432)
[ 1233.746344] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 3432)
[ 1233.746345] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 3432)
[ 1233.746346] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 3432)
[ 1233.746349] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 3432)
[ 1233.746349] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 3432)
[ 1233.746350] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 3432)
[ 1233.746351] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 3432)
[ 1262.433903] proc: Bad value for 'hidepid'
[ 1277.748345] mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 1049)
[ 1277.748346] mce: CPU5: Core temperature above threshold, cpu clock throttled (total events = 1049)
[ 1358.017412] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 784)
[ 1358.017412] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 784)
[ 1534.002594] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 3943)
[ 1534.002594] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 3943)
[ 1534.002628] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 3943)
[ 1534.002629] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 3943)
[ 1534.002630] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 3943)
[ 1534.002631] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 3943)
[ 1534.002632] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 3943)
[ 1534.002633] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 3943)
[ 1709.298138] proc: Bad value for 'hidepid'
[ 1834.490906] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 6165)
[ 1834.490908] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 6165)
[ 1834.490909] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 6165)
[ 1834.490910] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 6165)
[ 1834.490911] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 6165)
[ 1834.490912] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 6165)
[ 1834.490938] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 6165)
[ 1834.490939] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 6165)
[ 1891.105940] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 1993)
[ 1891.105941] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 1993)
[ 2136.902161] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 7702)
[ 2136.902161] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 7702)
[ 2136.902162] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 7702)
[ 2136.902163] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 7702)
[ 2136.902193] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 7702)
[ 2136.902193] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 7702)
[ 2136.902195] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 7702)
[ 2136.902195] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 7702)
[ 2438.933427] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 8479)
[ 2438.933427] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 8479)
[ 2438.933461] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 8479)
[ 2438.933462] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 8479)
[ 2438.933463] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 8479)
[ 2438.933464] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 8479)
[ 2438.933464] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 8479)
[ 2438.933465] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 8479)
[ 2622.075638] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 2449)
[ 2622.075639] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 2450)
[ 2853.667840] mce: CPU5: Core temperature above threshold, cpu clock throttled (total events = 2631)
[ 2853.667841] mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 2631)
[ 2922.133876] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 2746)
[ 2922.133877] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 2747)
[ 3081.543047] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 10746)
[ 3081.543048] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 10746)
[ 3081.543085] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 10746)
[ 3081.543087] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 10746)
[ 3081.543089] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 10746)
[ 3081.543090] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 10745)
[ 3081.543091] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 10746)
[ 3081.543091] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 10745)
[ 3383.549360] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 12183)
[ 3383.549360] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 12182)
[ 3383.549400] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 12183)
[ 3383.549401] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 12183)
[ 3383.549402] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 12183)
[ 3383.549403] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 12183)
[ 3383.549404] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 12182)
[ 3383.549405] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 12183)
[ 3758.688685] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 12466)
[ 3758.688685] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 12466)
[ 3758.688686] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 12465)
[ 3758.688687] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 12466)
[ 3758.688688] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 12466)
[ 3758.688689] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 12466)
[ 3758.688690] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 12465)
[ 3758.688690] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 12466)
[ 3791.729076] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 4009)
[ 3791.729077] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 4009)
[ 3927.761884] mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 3352)
[ 3927.761885] mce: CPU5: Core temperature above threshold, cpu clock throttled (total events = 3352)
[ 4058.863011] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 12663)
[ 4058.863012] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 12662)
[ 4058.863045] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 12663)
[ 4058.863046] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 12663)
[ 4058.863047] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 12663)
[ 4058.863048] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 12663)
[ 4058.863049] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 12662)
[ 4058.863050] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 12663)
[ 4244.371472] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 3311)
[ 4244.371473] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 3310)
[ 4406.552332] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 12733)
[ 4406.552332] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 12733)
[ 4406.552367] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 12733)
[ 4406.552367] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 12733)
[ 4406.552368] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 12732)
[ 4406.552370] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 12733)
[ 4406.552370] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 12732)
[ 4406.552371] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 12733)
[ 4715.969604] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 13056)
[ 4715.969604] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 13056)
[ 4715.969638] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 13055)
[ 4715.969639] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 13056)
[ 4715.969640] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 13056)
[ 4715.969640] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 13056)
[ 4715.969641] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 13055)
[ 4715.969642] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 13056)
[ 4782.896253] proc: Bad value for 'hidepid'
[ 4820.565311] proc: Bad value for 'hidepid'
[ 5020.170917] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 13745)
[ 5020.170918] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 13744)
[ 5020.170919] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 13745)
[ 5020.170920] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 13745)
[ 5020.170921] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 13745)
[ 5020.170922] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 13744)
[ 5020.170922] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 13745)
[ 5020.170923] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 13745)
[ 5326.076218] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 3613)
[ 5326.076219] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 3613)
[ 5326.076220] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 14205)
[ 5326.076220] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 14205)
[ 5326.076253] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 14205)
[ 5326.076254] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 14203)
[ 5326.076255] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 14206)
[ 5326.076255] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 14206)
[ 5326.076256] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 14204)
[ 5326.076257] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 14206)
[ 5626.163495] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 14628)
[ 5626.163495] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 14627)
[ 5626.163541] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 14627)
[ 5626.163541] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 14627)
[ 5626.163542] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 14628)
[ 5626.163543] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 14626)
[ 5626.163544] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 14625)
[ 5626.163545] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 14628)
[ 5926.497782] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 15320)
[ 5926.497783] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 15321)
[ 5926.497783] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 15319)
[ 5926.497784] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 15320)
[ 5926.497842] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 15321)
[ 5926.497843] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 15320)
[ 5926.497844] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 15318)
[ 5926.497845] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 15321)
[ 6107.209896] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 5111)
[ 6107.209897] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 5111)
[ 6227.503054] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 15937)
[ 6227.503055] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 15934)
[ 6227.503090] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 15937)
[ 6227.503091] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 15936)
[ 6227.503091] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 15935)
[ 6227.503092] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 15936)
[ 6227.503093] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 15937)
[ 6227.503094] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 15936)
[ 6249.148068] mce: CPU3: Core temperature above threshold, cpu clock throttled (total events = 3142)
[ 6249.148069] mce: CPU7: Core temperature above threshold, cpu clock throttled (total events = 3142)
[ 6416.358237] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 5461)
[ 6416.358238] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 5461)
[ 6528.297333] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 18740)
[ 6528.297335] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 18737)
[ 6528.297335] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 18738)
[ 6528.297336] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 18739)
[ 6528.297337] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 18739)
[ 6528.297360] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 18740)
[ 6528.297365] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 18739)
[ 6528.297366] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 18739)
[ 6829.430632] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 19346)
[ 6829.430633] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 19345)
[ 6829.430634] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 19344)
[ 6829.430635] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 19345)
[ 6829.430663] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 19345)
[ 6829.430664] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 19346)
[ 6829.430665] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 19343)
[ 6829.430666] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 19345)
[ 6888.486671] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 5422)
[ 6888.486672] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 5422)
[ 7071.062201] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 5917)
[ 7071.062202] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 5917)
[ 7130.402185] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 19853)
[ 7130.402186] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 19851)
[ 7130.402228] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 19852)
[ 7130.402229] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 19853)
[ 7130.402230] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 19852)
[ 7130.402231] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 19852)
[ 7130.402232] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 19852)
[ 7130.402233] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 19850)
[ 7490.668567] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 5930)
[ 7490.668567] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 5930)
[ 7490.668569] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 19873)
[ 7490.668569] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 19874)
[ 7490.668610] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 19874)
[ 7490.668611] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 19872)
[ 7490.668612] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 19873)
[ 7490.668612] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 19873)
[ 7490.668614] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 19873)
[ 7490.668615] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 19871)
[ 7790.913517] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 5847)
[ 7790.913518] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 5847)
[ 7790.913520] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 21369)
[ 7790.913520] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 21369)
[ 7790.913552] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 21370)
[ 7790.913553] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 21369)
[ 7790.913554] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 21370)
[ 7790.913555] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 21368)
[ 7790.913556] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 21367)
[ 7790.913557] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 21369)
[ 8091.268787] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 22874)
[ 8091.268788] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 22876)
[ 8091.268822] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 22876)
[ 8091.268822] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 22874)
[ 8091.268824] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 22873)
[ 8091.268825] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 22874)
[ 8091.268825] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 22875)
[ 8091.268826] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 22875)
[ 8133.286813] mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 5838)
[ 8133.286813] mce: CPU5: Core temperature above threshold, cpu clock throttled (total events = 5838)
[ 8392.292075] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 23972)
[ 8392.292075] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 23973)
[ 8392.292109] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 23974)
[ 8392.292110] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 23972)
[ 8392.292111] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 23974)
[ 8392.292112] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 23972)
[ 8392.292113] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 23973)
[ 8392.292114] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 23971)
[ 8435.305100] mce: CPU5: Core temperature above threshold, cpu clock throttled (total events = 6239)
[ 8435.305101] mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 6239)
[ 8439.693116] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 7343)
[ 8439.693117] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 7344)
[ 8692.358358] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 24890)
[ 8692.358358] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 24892)
[ 8692.358403] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 24890)
[ 8692.358404] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 24890)
[ 8692.358405] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 24891)
[ 8692.358406] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 24892)
[ 8692.358407] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 24889)
[ 8692.358407] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 24891)
[ 8742.249400] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 7634)
[ 8742.249424] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 7633)
[ 8992.806654] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 25305)
[ 8992.806655] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 25306)
[ 8992.806656] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 25305)
[ 8992.806656] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 25307)
[ 8992.806657] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 25304)
[ 8992.806680] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 25306)
[ 8992.806685] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 25305)
[ 8992.806685] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 25307)
[ 9050.007750] mce: CPU3: Core temperature above threshold, cpu clock throttled (total events = 5016)
[ 9050.007751] mce: CPU7: Core temperature above threshold, cpu clock throttled (total events = 5016)
[ 9300.249970] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 25818)
[ 9300.249970] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 25816)
[ 9300.250003] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 25816)
[ 9300.250004] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 25818)
[ 9300.250005] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 25816)
[ 9300.250006] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 25817)
[ 9300.250007] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 25815)
[ 9300.250008] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 25817)
[ 9381.167050] mce: CPU7: Core temperature above threshold, cpu clock throttled (total events = 5095)
[ 9381.167051] mce: CPU3: Core temperature above threshold, cpu clock throttled (total events = 5095)
[ 9603.642245] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 26367)
[ 9603.642247] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 26369)
[ 9603.642247] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 26368)
[ 9603.642248] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 26367)
[ 9603.642278] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 26369)
[ 9603.642279] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 26367)
[ 9603.642280] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 26366)
[ 9603.642280] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 26368)
[ 9686.399329] mce: CPU5: Core temperature above threshold, cpu clock throttled (total events = 6741)
[ 9686.399329] mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 6741)
[ 9906.965536] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 27398)
[ 9906.965537] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 27400)
[ 9906.965538] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 27398)
[ 9906.965539] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 27399)
[ 9906.965540] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 27399)
[ 9906.965541] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 27398)
[ 9906.965541] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 27400)
[ 9906.965542] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 27397)
[ 9988.477631] mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 6987)
[ 9988.477631] mce: CPU5: Core temperature above threshold, cpu clock throttled (total events = 6987)
[10004.748632] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 8642)
[10004.748633] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 8641)
[10206.974839] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 28108)
[10206.974840] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 28109)
[10206.974841] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 28110)
[10206.974842] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 28109)
[10206.974843] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 28109)
[10206.974844] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 28111)
[10206.974845] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 28110)
[10206.974846] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 28111)
[10302.129939] mce: CPU5: Core temperature above threshold, cpu clock throttled (total events = 7201)
[10302.129940] mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 7201)
[10521.851117] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 28801)
[10521.851118] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 28800)
[10521.851118] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 28799)
[10521.851119] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 28798)
[10521.851149] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 28801)
[10521.851149] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 28799)
[10521.851150] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 28800)
[10521.851151] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 28799)
[10823.342380] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 29150)
[10823.342381] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 29150)
[10823.342381] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 29149)
[10823.342382] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 29148)
[10823.342411] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 29151)
[10823.342412] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 29149)
[10823.342413] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 29149)
[10823.342414] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 29151)
[11123.355695] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 29589)
[11123.355696] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 29588)
[11123.355697] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 29589)
[11123.355698] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 29590)
[11123.355699] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 29587)
[11123.355700] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 29588)
[11123.355701] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 29590)
[11123.355702] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 29588)
[11124.111045] proc: Bad value for 'hidepid'
[11239.317773] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 9413)
[11239.317774] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 9414)
[11474.242296] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 30140)
[11474.242296] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 30141)
[11474.242338] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 30142)
[11474.242339] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 30140)
[11474.242340] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 30139)
[11474.242341] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 30140)
[11474.242342] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 30141)
[11474.242343] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 30142)
[11775.155264] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 31318)
[11775.155265] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 31319)
[11775.155298] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 31320)
[11775.155300] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 31318)
[11775.155300] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 31320)
[11775.155301] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 31318)
[11775.155302] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 31319)
[11775.155303] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 31317)
[11858.774363] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 10016)
[11858.774364] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 10017)
[11951.057491] mce: CPU7: Core temperature above threshold, cpu clock throttled (total events = 6344)
[11951.057492] mce: CPU3: Core temperature above threshold, cpu clock throttled (total events = 6344)
[12076.213588] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 32579)
[12076.213589] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 32579)
[12076.213589] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 32581)
[12076.213590] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 32581)
[12076.213612] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 32578)
[12076.213612] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 32580)
[12076.213617] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 32580)
[12076.213617] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 32579)
[12379.026870] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 33497)
[12379.026870] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 33498)
[12379.026904] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 33499)
[12379.026905] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 33499)
[12379.026906] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 33497)
[12379.026907] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 33497)
[12379.026908] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 33498)
[12379.026909] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 33496)
[12580.214090] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 9137)
[12580.214091] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 9137)
[12597.512127] proc: Bad value for 'hidepid'
[12979.890425] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 37410)
[12979.890426] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 37407)
[12979.890426] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 37408)
[12979.890427] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 37409)
[12979.890458] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 37410)
[12979.890459] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 37408)
[12979.890460] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 37409)
[12979.890461] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 37408)
[13090.285550] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 11966)
[13090.285550] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 11967)
[13225.937633] mce: CPU3: Core temperature above threshold, cpu clock throttled (total events = 7747)
[13225.937633] mce: CPU7: Core temperature above threshold, cpu clock throttled (total events = 7747)
[13289.481694] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 38701)
[13289.481695] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 38698)
[13289.481696] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 38700)
[13289.481697] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 38699)
[13289.481698] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 38701)
[13289.481699] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 38700)
[13289.481699] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 38699)
[13289.481700] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 38699)
[13589.766002] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 38961)
[13589.766003] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 38959)
[13589.766037] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 38961)
[13589.766037] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 38959)
[13589.766039] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 38959)
[13589.766039] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 38960)
[13589.766040] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 38958)
[13589.766041] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 38960)
[13890.251299] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 40983)
[13890.251300] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 40981)
[13890.251337] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 40981)
[13890.251338] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 40982)
[13890.251339] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 40981)
[13890.251339] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 40983)
[13890.251341] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 40980)
[13890.251341] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 40982)
[14169.628606] mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 10966)
[14169.628607] mce: CPU5: Core temperature above threshold, cpu clock throttled (total events = 10966)
[14190.452560] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 42461)
[14190.452561] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 42464)
[14190.452562] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 42463)
[14190.452562] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 42462)
[14190.452563] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 42462)
[14190.452564] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 42463)
[14190.452571] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 42462)
[14190.452572] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 42464)
[14331.129676] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 13419)
[14331.129676] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 13418)
[14512.832884] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 42733)
[14512.832886] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 42731)
[14512.832886] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 42733)
[14512.832887] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 42731)
[14512.832909] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 42732)
[14512.832909] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 42731)
[14512.832914] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 42730)
[14512.832914] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 42732)
[14815.641184] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 11157)
[14815.641184] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 11157)
[14815.641186] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 43514)
[14815.641186] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 43515)
[14815.641229] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 43516)
[14815.641230] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 43516)
[14815.641231] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 43513)
[14815.641232] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 43514)
[14815.641233] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 43515)
[14815.641233] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 43514)
[14939.840251] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 13754)
[14939.840252] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 13755)
[15045.582325] nvme nvme0: I/O 431 QID 3 timeout, aborting
[15045.582500] nvme nvme0: Abort status: 0x0
[15075.662457] nvme nvme0: I/O 431 QID 3 timeout, reset controller
[15128.355488] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 43963)
[15128.355488] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 43965)
[15128.355521] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 43962)
[15128.355522] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 43964)
[15128.355551] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 43963)
[15128.355551] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 43964)
[15128.355552] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 43965)
[15128.355553] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 43963)
[15255.135594] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 13860)
[15255.135595] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 13859)
[15474.017874] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 11272)
[15474.017874] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 11272)
[15474.017875] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 44056)
[15474.017876] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 44057)
[15474.017917] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 44056)
[15474.017917] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 44058)
[15474.017919] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 44056)
[15474.017919] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 44058)
[15474.017921] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 44055)
[15474.017921] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 44057)
[15555.626887] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 13924)
[15555.626888] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 13925)
[15701.438633] proc: Bad value for 'hidepid'
[15784.028058] mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 11601)
[15784.028058] mce: CPU5: Core temperature above threshold, cpu clock throttled (total events = 11601)
[15784.028059] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 44899)
[15784.028060] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 44897)
[15784.028088] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 44899)
[15784.028089] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 44897)
[15784.028090] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 44897)
[15784.028091] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 44898)
[15784.028093] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 44896)
[15784.028093] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 44898)
[16087.546354] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 45727)
[16087.546354] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 45728)
[16087.546394] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 45727)
[16087.546395] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 45729)
[16087.546396] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 45727)
[16087.546397] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 45729)
[16087.546398] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 45726)
[16087.546399] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 45728)
[16394.355692] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 46383)
[16394.355693] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 46385)
[16394.355694] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 46383)
[16394.355695] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 46385)
[16394.355696] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 46384)
[16394.355696] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 46382)
[16394.355726] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 46383)
[16394.355726] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 46384)
[16397.552639] mce: CPU3: Core temperature above threshold, cpu clock throttled (total events = 9440)
[16397.552640] mce: CPU7: Core temperature above threshold, cpu clock throttled (total events = 9440)
[16423.485708] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 11830)
[16423.485709] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 11830)
[16488.634719] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 14636)
[16488.634719] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 14635)
[16698.702009] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 46564)
[16698.702010] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 46566)
[16698.702052] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 46566)
[16698.702053] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 46564)
[16698.702054] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 46565)
[16698.702055] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 46563)
[16698.702056] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 46565)
[16698.702057] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 46564)
[16706.412972] mce: CPU5: Core temperature above threshold, cpu clock throttled (total events = 12031)
[16706.412973] mce: CPU1: Core temperature above threshold, cpu clock throttled (total events = 12031)
[16729.746961] mce: CPU2: Core temperature above threshold, cpu clock throttled (total events = 11862)
[16729.746961] mce: CPU6: Core temperature above threshold, cpu clock throttled (total events = 11862)
[16791.812044] mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 15020)
[16791.812044] mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 15021)
[16806.746218] iwlwifi 0000:00:14.3: FW already configured (0) - re-configuring
[16806.928756] iwlwifi 0000:00:14.3: FW already configured (0) - re-configuring
[16810.785500] IRQ 138: no longer affine to CPU1
[16810.788389] IRQ 139: no longer affine to CPU2
[16810.791468] IRQ 140: no longer affine to CPU3
[16810.794510] IRQ 141: no longer affine to CPU4
[16810.797562] IRQ 142: no longer affine to CPU5
[16810.800515] IRQ 143: no longer affine to CPU6
[16810.803506] IRQ 144: no longer affine to CPU7
[16810.889742] iwlwifi 0000:00:14.3: RF_KILL bit toggled to enable radio.
[16811.051126] iwlwifi 0000:00:14.3: FW already configured (0) - re-configuring
[16811.564894] done.
[16812.065233] iwlwifi 0000:00:14.3: FW already configured (0) - re-configuring
[16818.176072] iwlwifi 0000:00:14.3: FW already configured (0) - re-configuring
[17000.877404] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 47474)
[17000.877405] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 47472)
[17000.877429] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 47473)
[17000.877430] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 47472)
[17000.877433] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 47472)
[17000.877434] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 47473)
[17000.877434] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 47474)
[17000.877435] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 47471)
[17301.388731] mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 49089)
[17301.388731] mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 49090)
[17301.388764] mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 49091)
[17301.388764] mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 49089)
[17301.388765] mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 49089)
[17301.388766] mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 49091)
[17301.388767] mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 49090)
[17301.388768] mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 49088)
    ~          ✔  3s 
all log about nvme
Summary
sudo journalctl | grep nvme  :heavy_check_mark:
Jan 10 21:07:00 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 10 21:07:00 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 10 21:07:00 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 10 21:07:00 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 10 21:07:00 manjaro kernel: nvme0n1: p1 p2 p3
Jan 10 21:07:00 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 10 21:07:00 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 10 21:07:01 manjaro systemd-fsck[372]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 10 21:07:01 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 10 21:14:18 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 10 21:14:18 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 10 21:14:18 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 10 21:14:18 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 10 21:14:18 manjaro kernel: nvme0n1: p1 p2 p3
Jan 10 21:14:18 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 10 21:14:18 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 10 21:14:19 manjaro systemd-fsck[385]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 10 21:14:57 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 10 22:51:44 manjaro timeshift-gtk.desktop[136797]: Mounted ‘/dev/nvme0n1p3’ at ‘/run/timeshift/backup’
Jan 10 22:51:44 manjaro timeshift-gtk.desktop[136797]: Selected default snapshot device: /dev/nvme0n1p3
Jan 10 23:45:03 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 10 23:45:03 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 10 23:45:03 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 10 23:45:03 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 10 23:45:03 manjaro kernel: nvme0n1: p1 p2 p3
Jan 10 23:45:03 manjaro kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Jan 10 23:45:03 manjaro kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Jan 10 23:45:03 manjaro kernel: EXT4-fs (nvme0n1p2): recovery complete
Jan 10 23:45:03 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 10 23:45:03 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 10 23:45:04 manjaro systemd-fsck[422]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 10 23:45:06 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 10 23:50:27 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 10 23:50:27 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 10 23:50:27 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 10 23:50:27 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 10 23:50:27 manjaro kernel: nvme0n1: p1 p2 p3
Jan 10 23:50:27 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 10 23:50:27 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 10 23:51:28 manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_find_extent:886: inode #328837: comm systemd-journal: pblk 657929 bad header/extent: invalid magic - magic 0, entries 0, max 0(0), depth 0(0)
Jan 10 23:51:28 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 10 23:51:28 manjaro kernel: nvme nvme0: I/O 281 QID 5 timeout, aborting
Jan 10 23:51:28 manjaro kernel: nvme nvme0: Abort status: 0x0
Jan 10 23:51:28 manjaro kernel: nvme nvme0: I/O 281 QID 5 timeout, reset controller
Jan 10 23:51:28 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 10 23:51:28 manjaro systemd-fsck[420]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 10 23:53:04 manjaro kernel: nvme_process_cq+0x18e/0x220
Jan 10 23:53:04 manjaro kernel: nvme_irq+0x10/0x20
Jan 10 23:53:04 manjaro kernel: nvme nvme0: I/O 90 QID 2 timeout, aborting
Jan 10 23:53:04 manjaro kernel: nvme nvme0: Abort status: 0x0
Jan 10 23:53:04 manjaro kernel: nvme nvme0: I/O 90 QID 2 timeout, reset controller
Jan 10 23:53:04 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 10 23:53:04 manjaro kernel: EXT4-fs error (device nvme0n1p2): ext4_find_extent:886: inode #328837: comm systemd-journal: pblk 657929 bad header/extent: invalid magic - magic 0, entries 0, max 0(0), depth 0(0)
Jan 10 23:53:41 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 10 23:53:41 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 10 23:53:41 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 10 23:53:41 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 10 23:53:41 manjaro kernel: nvme0n1: p1 p2 p3
Jan 10 23:53:41 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 10 23:53:46 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 10 23:54:47 manjaro kernel: nvme_process_cq+0x18e/0x220
Jan 10 23:54:47 manjaro kernel: nvme_irq+0x10/0x20
Jan 10 23:54:47 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 10 23:54:47 manjaro kernel: nvme nvme0: I/O 94 QID 8 timeout, aborting
Jan 10 23:54:47 manjaro kernel: nvme nvme0: Abort status: 0x0
Jan 10 23:54:47 manjaro kernel: nvme nvme0: I/O 94 QID 8 timeout, reset controller
Jan 10 23:54:47 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 10 23:54:47 manjaro systemd-fsck[417]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 10 23:56:16 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 10 23:56:16 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 10 23:56:16 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 10 23:56:16 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 10 23:56:16 manjaro kernel: nvme0n1: p1 p2 p3
Jan 10 23:56:16 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 10 23:56:16 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 10 23:57:17 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 10 23:57:17 manjaro kernel: nvme nvme0: I/O 494 QID 1 timeout, aborting
Jan 10 23:57:17 manjaro kernel: nvme nvme0: Abort status: 0x0
Jan 10 23:57:17 manjaro kernel: nvme nvme0: I/O 494 QID 1 timeout, reset controller
Jan 10 23:57:17 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 10 23:57:17 manjaro systemd-fsck[412]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 11 09:31:09 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 11 09:31:09 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 11 09:31:09 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 11 09:31:09 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 11 09:31:09 manjaro kernel: nvme0n1: p1 p2 p3
Jan 11 09:31:09 manjaro kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Jan 11 09:31:09 manjaro kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Jan 11 09:31:09 manjaro kernel: EXT4-fs (nvme0n1p2): recovery complete
Jan 11 09:31:09 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 11 09:31:09 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 11 09:31:10 manjaro systemd-fsck[414]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 11 09:31:10 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 11 12:04:34 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 11 13:37:18 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 12 09:29:31 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 12 10:17:01 manjaro timeshift-gtk.desktop[269076]: Mounted ‘/dev/nvme0n1p3’ at ‘/run/timeshift/backup’
Jan 12 10:17:05 manjaro timeshift-gtk.desktop[269076]: Saving to device: /dev/nvme0n1p3, mounted at path: /run/timeshift/backup
Jan 12 13:13:54 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 12 13:13:54 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 12 13:13:54 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 12 13:13:54 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 12 13:13:54 manjaro kernel: nvme0n1: p1 p2 p3
Jan 12 13:13:54 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 12 13:13:54 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 12 13:13:55 manjaro systemd-fsck[406]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 12 13:13:55 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 12 13:14:57 manjaro kernel: nvme_process_cq+0x18e/0x220
Jan 12 13:14:57 manjaro kernel: nvme_irq+0x10/0x20
Jan 12 13:14:57 manjaro kernel: nvme nvme0: I/O 186 QID 3 timeout, aborting
Jan 12 13:14:57 manjaro kernel: nvme nvme0: Abort status: 0x0
Jan 12 13:14:57 manjaro kernel: nvme nvme0: I/O 186 QID 3 timeout, reset controller
Jan 12 13:14:57 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 12 21:20:56 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 13 09:29:31 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 13 23:34:38 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 13 23:34:38 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 13 23:34:38 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 13 23:34:38 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 13 23:34:38 manjaro kernel: nvme0n1: p1 p2 p3
Jan 13 23:34:38 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 13 23:34:38 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 13 23:36:13 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 13 23:36:13 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 13 23:36:13 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 13 23:36:13 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 13 23:36:13 manjaro kernel: nvme0n1: p1 p2 p3
Jan 13 23:36:13 manjaro kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Jan 13 23:36:13 manjaro kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Jan 13 23:36:13 manjaro kernel: EXT4-fs (nvme0n1p2): recovery complete
Jan 13 23:36:13 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 13 23:36:13 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 13 23:36:14 manjaro systemd-fsck[395]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 13 23:36:14 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 14 00:07:45 manjaro timeshift-gtk.desktop[7228]: Mounted ‘/dev/nvme0n1p3’ at ‘/run/timeshift/backup’
Jan 14 00:08:06 manjaro timeshift-gtk.desktop[7339]: /dev/nvme0n1p3 is mounted at: /run/timeshift/backup, options: rw,relatime
Jan 14 00:08:07 manjaro timeshift-gtk.desktop[7339]: Saving to device: /dev/nvme0n1p3, mounted at path: /run/timeshift/backup
Jan 14 00:25:56 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 14 00:25:56 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 14 00:25:56 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 14 00:25:56 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 14 00:25:56 manjaro kernel: nvme0n1: p1 p2 p3
Jan 14 00:25:56 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 14 00:25:56 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 14 00:25:57 manjaro systemd-fsck[410]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 14 00:25:57 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 14 09:14:37 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 14 09:14:37 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 14 09:14:37 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 14 09:14:37 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 14 09:14:37 manjaro kernel: nvme0n1: p1 p2 p3
Jan 14 09:14:37 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 14 09:14:37 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 14 09:14:38 manjaro systemd-fsck[420]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 14 09:14:38 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 14 09:14:38 manjaro kernel: nvme_process_cq+0x18e/0x220
Jan 14 09:14:38 manjaro kernel: nvme_irq+0x10/0x20
Jan 14 09:15:40 manjaro kernel: nvme nvme0: I/O 456 QID 2 timeout, aborting
Jan 14 09:15:40 manjaro kernel: nvme nvme0: Abort status: 0x0
Jan 14 09:15:40 manjaro kernel: nvme nvme0: I/O 456 QID 2 timeout, reset controller
Jan 14 09:15:40 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 14 13:09:11 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 14 13:09:11 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 14 13:09:11 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 14 13:09:11 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 14 13:09:11 manjaro kernel: nvme0n1: p1 p2 p3
Jan 14 13:09:11 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 14 13:09:11 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 14 13:09:12 manjaro systemd-fsck[419]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 14 13:09:12 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 14 17:57:47 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 15 09:43:50 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 15 17:51:37 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 15 17:52:29 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 16 14:21:01 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 16 15:24:45 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 16 21:39:51 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 16 21:40:33 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 17 22:09:05 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 18 08:55:51 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 18 13:27:39 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 18 22:16:21 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 18 22:41:13 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 19 09:28:19 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 20 09:14:13 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 21 09:25:55 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 21 09:50:00 manjaro kernel: nvme_process_cq+0x18e/0x220
Jan 21 09:50:00 manjaro kernel: nvme_irq+0x10/0x20
Jan 21 09:50:00 manjaro kernel: nvme nvme0: I/O 190 QID 4 timeout, aborting
Jan 21 09:50:00 manjaro kernel: nvme nvme0: Abort status: 0x0
Jan 21 09:50:00 manjaro kernel: nvme nvme0: I/O 190 QID 4 timeout, reset controller
Jan 21 09:50:00 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 21 09:50:27 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 21 09:50:27 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 21 09:50:27 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 21 09:50:27 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 21 09:50:27 manjaro kernel: nvme0n1: p1 p2 p3
Jan 21 09:50:27 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 21 09:50:27 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 21 09:50:28 manjaro systemd-fsck[438]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 21 09:50:28 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 22 09:00:45 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 24 22:08:41 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 25 09:27:41 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 25 22:26:24 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 25 22:37:29 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 25 22:37:29 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 25 22:37:29 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 25 22:37:29 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 25 22:37:29 manjaro kernel: nvme0n1: p1 p2 p3
Jan 25 22:37:29 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 25 22:37:29 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 25 22:37:30 manjaro systemd-fsck[435]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 25 22:37:30 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 26 09:21:10 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 26 09:21:10 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 26 09:21:10 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 26 09:21:10 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 26 09:21:10 manjaro kernel: nvme0n1: p1 p2 p3
Jan 26 09:21:10 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 26 09:21:10 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 26 09:21:11 manjaro systemd-fsck[438]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 26 09:21:11 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 26 10:14:01 manjaro timeshift-gtk.desktop[105890]: Mounted ‘/dev/nvme0n1p3’ at ‘/run/timeshift/backup’
Jan 26 10:14:08 manjaro timeshift-gtk.desktop[105890]: Saving to device: /dev/nvme0n1p3, mounted at path: /run/timeshift/backup
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/nvme0n1p1
Jan 27 21:33:36 manjaro root[1474]: 05efi: debug: /dev/nvme0n1p1 is a FAT32 partition
Jan 27 21:33:36 manjaro root[1474]: 05efi: debug: /dev/nvme0n1p1 partition scheme is gpt
Jan 27 21:33:36 manjaro root[1474]: 05efi: debug: /dev/nvme0n1p1 partition type is c12a7328-f81f-11d2-ba4b-00a0c93ec93b
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/nvme0n1p1
Jan 27 21:33:36 manjaro root[1474]: 10freedos: debug: /dev/nvme0n1p1 is a FAT32 partition
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/nvme0n1p1
Jan 27 21:33:36 manjaro root[1474]: 10qnx: debug: /dev/nvme0n1p1 is not a QNX4 partition: exiting
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/nvme0n1p1
Jan 27 21:33:36 manjaro macosx-prober[1544]: debug: /dev/nvme0n1p1 is not an HFS+ partition: exiting
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/nvme0n1p1
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/nvme0n1p1
Jan 27 21:33:36 manjaro root[1474]: 30utility: debug: /dev/nvme0n1p1 is a FAT32 partition
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/nvme0n1p1
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/nvme0n1p1
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/nvme0n1p1
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/nvme0n1p1
Jan 27 21:33:36 manjaro root[1474]: 83haiku: debug: /dev/nvme0n1p1 is not a BeFS partition: exiting
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/nvme0n1p1
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/nvme0n1p1
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/nvme0n1p1
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/nvme0n1p3
Jan 27 21:33:36 manjaro root[1474]: 05efi: debug: /dev/nvme0n1p3 is ext4 partition: exiting
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/nvme0n1p3
Jan 27 21:33:36 manjaro root[1474]: 10freedos: debug: /dev/nvme0n1p3 is not a FAT partition: exiting
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/nvme0n1p3
Jan 27 21:33:36 manjaro root[1474]: 10qnx: debug: /dev/nvme0n1p3 is not a QNX4 partition: exiting
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/nvme0n1p3
Jan 27 21:33:36 manjaro macosx-prober[1611]: debug: /dev/nvme0n1p3 is not an HFS+ partition: exiting
Jan 27 21:33:36 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/nvme0n1p3
Jan 27 21:33:37 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/nvme0n1p3
Jan 27 21:33:37 manjaro root[1474]: 30utility: debug: /dev/nvme0n1p3 is not a FAT partition: exiting
Jan 27 21:33:37 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/nvme0n1p3
Jan 27 21:33:37 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/nvme0n1p3
Jan 27 21:33:37 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/nvme0n1p3
Jan 27 21:33:37 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/nvme0n1p3
Jan 27 21:33:37 manjaro root[1474]: 83haiku: debug: /dev/nvme0n1p3 is not a BeFS partition: exiting
Jan 27 21:33:37 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/nvme0n1p3
Jan 27 21:33:37 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/nvme0n1p3
Jan 27 21:33:37 manjaro root[1474]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/nvme0n1p3
Jan 27 21:34:14 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 27 21:34:14 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 27 21:34:14 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 27 21:34:14 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 27 21:34:14 manjaro kernel: nvme0n1: p1 p2 p3
Jan 27 21:34:14 manjaro kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Jan 27 21:34:14 manjaro kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Jan 27 21:34:14 manjaro kernel: EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
Jan 27 21:34:14 manjaro kernel: EXT4-fs (nvme0n1p2): 2 orphan inodes deleted
Jan 27 21:34:14 manjaro kernel: EXT4-fs (nvme0n1p2): recovery complete
Jan 27 21:34:14 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 27 21:34:14 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 27 21:34:15 manjaro systemd-fsck[435]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 27 21:41:49 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 27 21:41:49 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 27 21:41:49 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 27 21:41:49 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 27 21:41:49 manjaro kernel: nvme0n1: p1 p2 p3
Jan 27 21:41:49 manjaro kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Jan 27 21:41:49 manjaro kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Jan 27 21:41:49 manjaro kernel: EXT4-fs (nvme0n1p2): recovery complete
Jan 27 21:41:49 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 27 21:41:49 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 27 21:41:50 manjaro systemd-fsck[429]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 27 22:17:04 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 27 22:17:04 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 27 22:17:04 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 27 22:17:04 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 27 22:17:04 manjaro kernel: nvme0n1: p1 p2 p3
Jan 27 22:17:04 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 27 22:17:10 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 27 22:17:11 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 27 22:17:11 manjaro systemd-fsck[436]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Jan 27 22:43:15 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 27 22:43:15 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 27 22:43:15 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 27 22:43:15 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 27 22:43:15 manjaro kernel: nvme0n1: p1 p2 p3
Jan 27 22:43:15 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 27 22:43:15 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 27 22:43:16 manjaro systemd-fsck[407]: /dev/nvme0n1p1: 6 files, 604/201568 clusters
Jan 27 22:43:16 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 27 22:46:04 manjaro timeshift-gtk.desktop[3044]: Mounted ‘/dev/nvme0n1p3’ at ‘/run/timeshift/backup’
Jan 27 22:46:08 manjaro timeshift-gtk.desktop[3044]: Saving to device: /dev/nvme0n1p3, mounted at path: /run/timeshift/backup
Jan 27 22:48:27 manjaro kernel: EXT4-fs (nvme0n1p2): error count since last fsck: 1
Jan 27 22:48:27 manjaro kernel: EXT4-fs (nvme0n1p2): initial error at time 1611775389: ext4_lookup:1709: inode 4374560
Jan 27 22:48:27 manjaro kernel: EXT4-fs (nvme0n1p2): last error at time 1611775389: ext4_lookup:1709: inode 4374560
Jan 27 22:59:10 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 27 22:59:10 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 27 22:59:10 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 27 22:59:10 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 27 22:59:10 manjaro kernel: nvme0n1: p1 p2 p3
Jan 27 22:59:10 manjaro kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Jan 27 22:59:10 manjaro kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Jan 27 22:59:10 manjaro kernel: EXT4-fs (nvme0n1p2): recovery complete
Jan 27 22:59:10 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 27 22:59:10 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 27 23:02:46 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Jan 27 23:02:46 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Jan 27 23:02:46 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Jan 27 23:02:46 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jan 27 23:02:46 manjaro kernel: nvme0n1: p1 p2 p3
Jan 27 23:02:46 manjaro kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Jan 27 23:02:46 manjaro kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Jan 27 23:02:46 manjaro kernel: EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
Jan 27 23:02:46 manjaro kernel: EXT4-fs (nvme0n1p2): 1 orphan inode deleted
Jan 27 23:02:46 manjaro kernel: EXT4-fs (nvme0n1p2): recovery complete
Jan 27 23:02:46 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Jan 27 23:02:46 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Jan 27 23:02:47 manjaro systemd-fsck[430]: /dev/nvme0n1p1: 6 files, 604/201568 clusters
Jan 27 23:02:47 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Jan 27 23:07:58 manjaro kernel: EXT4-fs (nvme0n1p2): error count since last fsck: 1
Jan 27 23:07:58 manjaro kernel: EXT4-fs (nvme0n1p2): initial error at time 1611775389: ext4_lookup:1709: inode 4374560
Jan 27 23:07:58 manjaro kernel: EXT4-fs (nvme0n1p2): last error at time 1611775389: ext4_lookup:1709: inode 4374560
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/nvme0n1p1
Jan 27 23:10:37 manjaro ercan[3936]: 05efi: debug: /dev/nvme0n1p1 is a FAT32 partition
Jan 27 23:10:37 manjaro ercan[3936]: 05efi: debug: /dev/nvme0n1p1 partition scheme is gpt
Jan 27 23:10:37 manjaro ercan[3936]: 05efi: debug: /dev/nvme0n1p1 partition type is c12a7328-f81f-11d2-ba4b-00a0c93ec93b
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/nvme0n1p1
Jan 27 23:10:37 manjaro ercan[3936]: 10freedos: debug: /dev/nvme0n1p1 is a FAT32 partition
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/nvme0n1p1
Jan 27 23:10:37 manjaro ercan[3936]: 10qnx: debug: /dev/nvme0n1p1 is not a QNX4 partition: exiting
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/nvme0n1p1
Jan 27 23:10:37 manjaro macosx-prober[4005]: debug: /dev/nvme0n1p1 is not an HFS+ partition: exiting
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/nvme0n1p1
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/nvme0n1p1
Jan 27 23:10:37 manjaro ercan[3936]: 30utility: debug: /dev/nvme0n1p1 is a FAT32 partition
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/nvme0n1p1
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/nvme0n1p1
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/nvme0n1p1
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/nvme0n1p1
Jan 27 23:10:37 manjaro ercan[3936]: 83haiku: debug: /dev/nvme0n1p1 is not a BeFS partition: exiting
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/nvme0n1p1
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/nvme0n1p1
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/nvme0n1p1
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/nvme0n1p3
Jan 27 23:10:37 manjaro ercan[3936]: 05efi: debug: /dev/nvme0n1p3 is ext4 partition: exiting
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/nvme0n1p3
Jan 27 23:10:37 manjaro ercan[3936]: 10freedos: debug: /dev/nvme0n1p3 is not a FAT partition: exiting
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/nvme0n1p3
Jan 27 23:10:37 manjaro ercan[3936]: 10qnx: debug: /dev/nvme0n1p3 is not a QNX4 partition: exiting
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/nvme0n1p3
Jan 27 23:10:37 manjaro macosx-prober[4072]: debug: /dev/nvme0n1p3 is not an HFS+ partition: exiting
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/nvme0n1p3
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/nvme0n1p3
Jan 27 23:10:37 manjaro ercan[3936]: 30utility: debug: /dev/nvme0n1p3 is not a FAT partition: exiting
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/nvme0n1p3
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/nvme0n1p3
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/nvme0n1p3
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/nvme0n1p3
Jan 27 23:10:37 manjaro ercan[3936]: 83haiku: debug: /dev/nvme0n1p3 is not a BeFS partition: exiting
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/nvme0n1p3
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/nvme0n1p3
Jan 27 23:10:37 manjaro ercan[3936]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/nvme0n1p3
Jan 27 23:16:01 manjaro timeshift-gtk.desktop[4713]: Mounted ‘/dev/nvme0n1p3’ at ‘/run/timeshift/backup’
Jan 27 23:16:05 manjaro timeshift-gtk.desktop[4713]: Saving to device: /dev/nvme0n1p3, mounted at path: /run/timeshift/backup
Feb 02 17:29:55 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/nvme0n1p1
Feb 02 17:29:55 manjaro ercan[18019]: 05efi: debug: /dev/nvme0n1p1 is a FAT32 partition
Feb 02 17:29:55 manjaro ercan[18019]: 05efi: debug: /dev/nvme0n1p1 partition scheme is gpt
Feb 02 17:29:55 manjaro ercan[18019]: 05efi: debug: /dev/nvme0n1p1 partition type is c12a7328-f81f-11d2-ba4b-00a0c93ec93b
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/nvme0n1p1
Feb 02 17:29:56 manjaro ercan[18019]: 10freedos: debug: /dev/nvme0n1p1 is a FAT32 partition
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/nvme0n1p1
Feb 02 17:29:56 manjaro ercan[18019]: 10qnx: debug: /dev/nvme0n1p1 is not a QNX4 partition: exiting
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/nvme0n1p1
Feb 02 17:29:56 manjaro macosx-prober[18088]: debug: /dev/nvme0n1p1 is not an HFS+ partition: exiting
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/nvme0n1p1
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/nvme0n1p1
Feb 02 17:29:56 manjaro ercan[18019]: 30utility: debug: /dev/nvme0n1p1 is a FAT32 partition
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/nvme0n1p1
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/nvme0n1p1
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/nvme0n1p1
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/nvme0n1p1
Feb 02 17:29:56 manjaro ercan[18019]: 83haiku: debug: /dev/nvme0n1p1 is not a BeFS partition: exiting
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/nvme0n1p1
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/nvme0n1p1
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/nvme0n1p1
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/nvme0n1p3
Feb 02 17:29:56 manjaro ercan[18019]: 05efi: debug: /dev/nvme0n1p3 is ext4 partition: exiting
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/nvme0n1p3
Feb 02 17:29:56 manjaro ercan[18019]: 10freedos: debug: /dev/nvme0n1p3 is not a FAT partition: exiting
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/nvme0n1p3
Feb 02 17:29:56 manjaro ercan[18019]: 10qnx: debug: /dev/nvme0n1p3 is not a QNX4 partition: exiting
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/nvme0n1p3
Feb 02 17:29:56 manjaro macosx-prober[18155]: debug: /dev/nvme0n1p3 is not an HFS+ partition: exiting
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/nvme0n1p3
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/nvme0n1p3
Feb 02 17:29:56 manjaro ercan[18019]: 30utility: debug: /dev/nvme0n1p3 is not a FAT partition: exiting
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/nvme0n1p3
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/nvme0n1p3
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/nvme0n1p3
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/nvme0n1p3
Feb 02 17:29:56 manjaro ercan[18019]: 83haiku: debug: /dev/nvme0n1p3 is not a BeFS partition: exiting
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/nvme0n1p3
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/nvme0n1p3
Feb 02 17:29:56 manjaro ercan[18019]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/nvme0n1p3
Feb 02 17:30:34 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Feb 02 17:30:34 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 02 17:30:34 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 02 17:30:34 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 02 17:30:34 manjaro kernel: nvme0n1: p1 p2 p3
Feb 02 17:30:34 manjaro kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Feb 02 17:30:34 manjaro kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Feb 02 17:30:34 manjaro kernel: EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
Feb 02 17:30:34 manjaro kernel: EXT4-fs (nvme0n1p2): 17 orphan inodes deleted
Feb 02 17:30:34 manjaro kernel: EXT4-fs (nvme0n1p2): recovery complete
Feb 02 17:30:34 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 02 17:30:34 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 02 17:30:35 manjaro systemd-fsck[438]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 02 17:30:37 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Feb 02 17:33:09 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/nvme0n1p1
Feb 02 17:33:09 manjaro root[6438]: 05efi: debug: /dev/nvme0n1p1 is a FAT32 partition
Feb 02 17:33:10 manjaro root[6438]: 05efi: debug: /dev/nvme0n1p1 partition scheme is gpt
Feb 02 17:33:10 manjaro root[6438]: 05efi: debug: /dev/nvme0n1p1 partition type is c12a7328-f81f-11d2-ba4b-00a0c93ec93b
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/nvme0n1p1
Feb 02 17:33:10 manjaro root[6438]: 10freedos: debug: /dev/nvme0n1p1 is a FAT32 partition
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/nvme0n1p1
Feb 02 17:33:10 manjaro root[6438]: 10qnx: debug: /dev/nvme0n1p1 is not a QNX4 partition: exiting
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/nvme0n1p1
Feb 02 17:33:10 manjaro macosx-prober[6507]: debug: /dev/nvme0n1p1 is not an HFS+ partition: exiting
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/nvme0n1p1
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/nvme0n1p1
Feb 02 17:33:10 manjaro root[6438]: 30utility: debug: /dev/nvme0n1p1 is a FAT32 partition
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/nvme0n1p1
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/nvme0n1p1
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/nvme0n1p1
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/nvme0n1p1
Feb 02 17:33:10 manjaro root[6438]: 83haiku: debug: /dev/nvme0n1p1 is not a BeFS partition: exiting
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/nvme0n1p1
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/nvme0n1p1
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/nvme0n1p1
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/nvme0n1p3
Feb 02 17:33:10 manjaro root[6438]: 05efi: debug: /dev/nvme0n1p3 is ext4 partition: exiting
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/nvme0n1p3
Feb 02 17:33:10 manjaro root[6438]: 10freedos: debug: /dev/nvme0n1p3 is not a FAT partition: exiting
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/nvme0n1p3
Feb 02 17:33:10 manjaro root[6438]: 10qnx: debug: /dev/nvme0n1p3 is not a QNX4 partition: exiting
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/nvme0n1p3
Feb 02 17:33:10 manjaro macosx-prober[6574]: debug: /dev/nvme0n1p3 is not an HFS+ partition: exiting
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/nvme0n1p3
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/nvme0n1p3
Feb 02 17:33:10 manjaro root[6438]: 30utility: debug: /dev/nvme0n1p3 is not a FAT partition: exiting
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/nvme0n1p3
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/nvme0n1p3
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/nvme0n1p3
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/nvme0n1p3
Feb 02 17:33:10 manjaro root[6438]: 83haiku: debug: /dev/nvme0n1p3 is not a BeFS partition: exiting
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/nvme0n1p3
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/nvme0n1p3
Feb 02 17:33:10 manjaro root[6438]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/nvme0n1p3
Feb 02 17:37:03 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Feb 02 17:37:03 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 02 17:37:03 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 02 17:37:03 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 02 17:37:03 manjaro kernel: nvme0n1: p1 p2 p3
Feb 02 17:37:03 manjaro kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Feb 02 17:37:03 manjaro kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Feb 02 17:37:03 manjaro kernel: EXT4-fs (nvme0n1p2): recovery complete
Feb 02 17:37:03 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 02 17:37:03 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 02 17:37:04 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Feb 02 17:37:04 manjaro systemd-fsck[445]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/nvme0n1p1
Feb 02 17:38:31 manjaro root[3542]: 05efi: debug: /dev/nvme0n1p1 is a FAT32 partition
Feb 02 17:38:31 manjaro root[3542]: 05efi: debug: /dev/nvme0n1p1 partition scheme is gpt
Feb 02 17:38:31 manjaro root[3542]: 05efi: debug: /dev/nvme0n1p1 partition type is c12a7328-f81f-11d2-ba4b-00a0c93ec93b
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/nvme0n1p1
Feb 02 17:38:31 manjaro root[3542]: 10freedos: debug: /dev/nvme0n1p1 is a FAT32 partition
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/nvme0n1p1
Feb 02 17:38:31 manjaro root[3542]: 10qnx: debug: /dev/nvme0n1p1 is not a QNX4 partition: exiting
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/nvme0n1p1
Feb 02 17:38:31 manjaro macosx-prober[3611]: debug: /dev/nvme0n1p1 is not an HFS+ partition: exiting
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/nvme0n1p1
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/nvme0n1p1
Feb 02 17:38:31 manjaro root[3542]: 30utility: debug: /dev/nvme0n1p1 is a FAT32 partition
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/nvme0n1p1
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/nvme0n1p1
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/nvme0n1p1
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/nvme0n1p1
Feb 02 17:38:31 manjaro root[3542]: 83haiku: debug: /dev/nvme0n1p1 is not a BeFS partition: exiting
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/nvme0n1p1
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/nvme0n1p1
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/nvme0n1p1
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/nvme0n1p3
Feb 02 17:38:31 manjaro root[3542]: 05efi: debug: /dev/nvme0n1p3 is ext4 partition: exiting
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/nvme0n1p3
Feb 02 17:38:31 manjaro root[3542]: 10freedos: debug: /dev/nvme0n1p3 is not a FAT partition: exiting
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/nvme0n1p3
Feb 02 17:38:31 manjaro root[3542]: 10qnx: debug: /dev/nvme0n1p3 is not a QNX4 partition: exiting
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/nvme0n1p3
Feb 02 17:38:31 manjaro macosx-prober[3678]: debug: /dev/nvme0n1p3 is not an HFS+ partition: exiting
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/nvme0n1p3
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/nvme0n1p3
Feb 02 17:38:31 manjaro root[3542]: 30utility: debug: /dev/nvme0n1p3 is not a FAT partition: exiting
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/nvme0n1p3
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/nvme0n1p3
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/nvme0n1p3
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/nvme0n1p3
Feb 02 17:38:31 manjaro root[3542]: 83haiku: debug: /dev/nvme0n1p3 is not a BeFS partition: exiting
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/nvme0n1p3
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/nvme0n1p3
Feb 02 17:38:31 manjaro root[3542]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/nvme0n1p3
Feb 02 17:41:38 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Feb 02 17:41:38 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 02 17:41:38 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 02 17:41:38 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 02 17:41:38 manjaro kernel: nvme0n1: p1 p2 p3
Feb 02 17:41:38 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 02 17:41:38 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 02 17:41:39 manjaro systemd-fsck[437]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 02 17:41:39 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Feb 02 17:43:01 manjaro kernel: nvme nvme0: I/O 134 QID 6 timeout, aborting
Feb 02 17:43:01 manjaro kernel: nvme nvme0: Abort status: 0x0
Feb 02 17:43:01 manjaro kernel: nvme nvme0: I/O 134 QID 6 timeout, reset controller
Feb 02 17:43:01 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 02 17:46:38 manjaro timeshift-gtk.desktop[3313]: Mounted ‘/dev/nvme0n1p3’ at ‘/run/timeshift/backup’
Feb 02 17:46:41 manjaro timeshift-gtk.desktop[3313]: Saving to device: /dev/nvme0n1p3, mounted at path: /run/timeshift/backup
Feb 02 21:58:38 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 03 09:10:15 manjaro kernel: nvme nvme0: pci function 0000:07:00.0
Feb 03 09:10:15 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 03 09:10:15 manjaro kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 03 09:10:15 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 03 09:10:15 manjaro kernel: nvme0n1: p1 p2 p3
Feb 03 09:10:15 manjaro kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 03 09:10:15 manjaro kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 03 09:10:16 manjaro systemd-fsck[451]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 03 09:10:16 manjaro kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Feb 03 09:13:45 manjaro kernel: nvme nvme0: I/O 66 QID 5 timeout, aborting
Feb 03 09:13:45 manjaro kernel: nvme nvme0: Abort status: 0x0
Feb 03 09:14:15 manjaro kernel: nvme nvme0: I/O 66 QID 5 timeout, reset controller
Feb 03 09:14:15 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 03 11:34:46 manjaro timeshift-gtk.desktop[14238]: Mounted ‘/dev/nvme0n1p3’ at ‘/run/timeshift/backup’
Feb 03 11:34:49 manjaro timeshift-gtk.desktop[14238]: Saving to device: /dev/nvme0n1p3, mounted at path: /run/timeshift/backup
Feb 03 12:36:22 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 03 13:09:18 manjaro kernel: nvme nvme0: I/O 81 QID 6 timeout, aborting
Feb 03 13:09:18 manjaro kernel: nvme nvme0: Abort status: 0x0
Feb 03 13:09:18 manjaro kernel: nvme nvme0: I/O 81 QID 6 timeout, reset controller
Feb 03 13:09:18 manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 03 13:24:27 manjaro timeshift-gtk.desktop[14238]: Saving to device: /dev/nvme0n1p3, mounted at path: /run/timeshift/backup
Feb 03 17:22:15 se-ekoc kernel: nvme nvme0: pci function 0000:07:00.0
Feb 03 17:22:15 se-ekoc kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 03 17:22:15 se-ekoc kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 03 17:22:15 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 03 17:22:15 se-ekoc kernel: nvme0n1: p1 p2 p3
Feb 03 17:22:15 se-ekoc kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Feb 03 17:22:15 se-ekoc kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Feb 03 17:22:15 se-ekoc kernel: EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
Feb 03 17:22:15 se-ekoc kernel: EXT4-fs (nvme0n1p2): 1 orphan inode deleted
Feb 03 17:22:15 se-ekoc kernel: EXT4-fs (nvme0n1p2): recovery complete
Feb 03 17:22:15 se-ekoc kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 03 17:22:22 se-ekoc kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 03 17:22:22 se-ekoc systemd-fsck[428]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 03 17:22:24 se-ekoc kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 09:14:00 se-ekoc kernel: nvme nvme0: pci function 0000:07:00.0
Feb 04 09:14:00 se-ekoc kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 04 09:14:00 se-ekoc kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 04 09:14:00 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 09:14:00 se-ekoc kernel: nvme0n1: p1 p2 p3
Feb 04 09:14:00 se-ekoc kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 09:14:00 se-ekoc kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 04 09:14:01 se-ekoc systemd-fsck[429]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 04 09:14:01 se-ekoc kernel: EXT4-fs (nvme0n1p3): warning: maximal mount count reached, running e2fsck is recommended
Feb 04 09:14:01 se-ekoc kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 09:24:14 se-ekoc timeshift-gtk.desktop[3927]: Mounted ‘/dev/nvme0n1p3’ at ‘/run/timeshift/backup’
Feb 04 09:24:56 se-ekoc timeshift-gtk.desktop[3927]: Saving to device: /dev/nvme0n1p3, mounted at path: /run/timeshift/backup
Feb 04 11:03:19 se-ekoc kernel: nvme nvme0: pci function 0000:07:00.0
Feb 04 11:03:19 se-ekoc kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 04 11:03:19 se-ekoc kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 04 11:03:19 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 11:03:19 se-ekoc kernel: nvme0n1: p1 p2 p3
Feb 04 11:03:19 se-ekoc kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 11:03:19 se-ekoc kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 04 11:06:06 se-ekoc kernel: nvme nvme0: pci function 0000:07:00.0
Feb 04 11:06:06 se-ekoc kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 04 11:06:06 se-ekoc kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 04 11:06:06 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 11:06:06 se-ekoc kernel: nvme0n1: p1 p2 p3
Feb 04 11:06:06 se-ekoc kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Feb 04 11:06:06 se-ekoc kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Feb 04 11:06:06 se-ekoc kernel: EXT4-fs (nvme0n1p2): recovery complete
Feb 04 11:06:06 se-ekoc kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 11:06:06 se-ekoc kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 04 11:06:07 se-ekoc systemd-fsck[437]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 04 11:06:07 se-ekoc kernel: EXT4-fs (nvme0n1p3): warning: maximal mount count reached, running e2fsck is recommended
Feb 04 11:06:07 se-ekoc kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 11:09:56 se-ekoc kernel: nvme nvme0: pci function 0000:07:00.0
Feb 04 11:09:56 se-ekoc kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 04 11:09:56 se-ekoc kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 04 11:09:56 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 11:09:56 se-ekoc kernel: nvme0n1: p1 p2 p3
Feb 04 11:09:56 se-ekoc kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Feb 04 11:09:56 se-ekoc kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Feb 04 11:09:56 se-ekoc kernel: EXT4-fs (nvme0n1p2): recovery complete
Feb 04 11:09:56 se-ekoc kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 11:09:56 se-ekoc kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 04 11:09:57 se-ekoc systemd-fsck[441]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 04 11:11:36 se-ekoc kernel: nvme nvme0: pci function 0000:07:00.0
Feb 04 11:11:36 se-ekoc kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 04 11:11:36 se-ekoc kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 04 11:11:36 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 11:11:36 se-ekoc kernel: nvme0n1: p1 p2 p3
Feb 04 11:11:36 se-ekoc kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Feb 04 11:11:36 se-ekoc kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Feb 04 11:11:36 se-ekoc kernel: EXT4-fs (nvme0n1p2): recovery complete
Feb 04 11:11:36 se-ekoc kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 11:11:36 se-ekoc kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 04 11:11:37 se-ekoc systemd-fsck[425]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 04 11:13:07 se-ekoc kernel: nvme nvme0: pci function 0000:07:00.0
Feb 04 11:13:07 se-ekoc kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 04 11:13:07 se-ekoc kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 04 11:13:07 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 11:13:07 se-ekoc kernel: nvme0n1: p1 p2 p3
Feb 04 11:13:07 se-ekoc kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Feb 04 11:13:07 se-ekoc kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Feb 04 11:13:07 se-ekoc kernel: EXT4-fs (nvme0n1p2): recovery complete
Feb 04 11:13:07 se-ekoc kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 11:13:07 se-ekoc kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 04 11:13:08 se-ekoc systemd-fsck[435]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 04 11:14:35 se-ekoc kernel: nvme nvme0: pci function 0000:07:00.0
Feb 04 11:14:35 se-ekoc kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 04 11:14:35 se-ekoc kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 04 11:14:35 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 11:14:35 se-ekoc kernel: nvme0n1: p1 p2 p3
Feb 04 11:14:35 se-ekoc kernel: EXT4-fs (nvme0n1p2): INFO: recovery required on readonly filesystem
Feb 04 11:14:35 se-ekoc kernel: EXT4-fs (nvme0n1p2): write access will be enabled during recovery
Feb 04 11:14:35 se-ekoc kernel: EXT4-fs (nvme0n1p2): recovery complete
Feb 04 11:14:35 se-ekoc kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 11:14:35 se-ekoc kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 04 11:14:36 se-ekoc systemd-fsck[431]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 04 11:22:30 se-ekoc kernel: nvme nvme0: pci function 0000:07:00.0
Feb 04 11:22:30 se-ekoc kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 04 11:22:30 se-ekoc kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 04 11:22:30 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 11:22:30 se-ekoc kernel: nvme0n1: p1 p2 p3
Feb 04 11:22:30 se-ekoc kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 11:22:30 se-ekoc kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 04 11:22:31 se-ekoc kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 11:22:31 se-ekoc systemd-fsck[455]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 04 13:03:09 se-ekoc kernel: nvme nvme0: pci function 0000:07:00.0
Feb 04 13:03:09 se-ekoc kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 04 13:03:09 se-ekoc kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 04 13:03:09 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 13:03:09 se-ekoc kernel: nvme0n1: p1 p2 p3
Feb 04 13:03:09 se-ekoc kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 13:03:09 se-ekoc kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 04 13:04:10 se-ekoc kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 13:04:10 se-ekoc kernel: nvme nvme0: I/O 172 QID 5 timeout, aborting
Feb 04 13:04:10 se-ekoc kernel: nvme nvme0: Abort status: 0x0
Feb 04 13:04:10 se-ekoc kernel: nvme nvme0: I/O 172 QID 5 timeout, reset controller
Feb 04 13:04:10 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 13:04:10 se-ekoc systemd-fsck[425]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 04 13:05:26 se-ekoc kernel: nvme nvme0: I/O 278 QID 4 timeout, aborting
Feb 04 13:05:26 se-ekoc kernel: nvme nvme0: Abort status: 0x0
Feb 04 13:05:26 se-ekoc kernel: nvme nvme0: I/O 278 QID 4 timeout, reset controller
Feb 04 13:05:26 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 13:06:29 se-ekoc kernel: nvme nvme0: I/O 159 QID 5 timeout, aborting
Feb 04 13:06:29 se-ekoc kernel: nvme nvme0: Abort status: 0x0
Feb 04 13:06:29 se-ekoc kernel: nvme nvme0: I/O 159 QID 5 timeout, reset controller
Feb 04 13:06:29 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 13:07:30 se-ekoc kernel: nvme nvme0: I/O 334 QID 7 timeout, aborting
Feb 04 13:07:30 se-ekoc kernel: nvme nvme0: Abort status: 0x0
Feb 04 13:07:30 se-ekoc kernel: nvme nvme0: I/O 334 QID 7 timeout, reset controller
Feb 04 13:07:30 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 336 QID 7 timeout, aborting
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: Abort status: 0x0
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 336 QID 7 timeout, reset controller
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 182 QID 8 timeout, aborting
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 182 QID 8 timeout, reset controller
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 226 QID 1 timeout, aborting
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 226 QID 1 timeout, reset controller
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 228 QID 1 timeout, aborting
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 228 QID 1 timeout, reset controller
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 230 QID 1 timeout, aborting
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 230 QID 1 timeout, reset controller
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 236 QID 1 timeout, aborting
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 236 QID 1 timeout, reset controller
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 422 QID 2 timeout, aborting
Feb 04 13:14:40 se-ekoc kernel: nvme nvme0: I/O 422 QID 2 timeout, reset controller
Feb 04 13:15:10 se-ekoc kernel: nvme nvme0: pci function 0000:07:00.0
Feb 04 13:15:10 se-ekoc kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 04 13:15:10 se-ekoc kernel: nvme nvme0: allocated 64 MiB host memory buffer.
Feb 04 13:15:10 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 13:15:10 se-ekoc kernel: nvme0n1: p1 p2 p3
Feb 04 13:15:10 se-ekoc kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 13:15:10 se-ekoc kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null)
Feb 04 13:17:15 se-ekoc kernel: EXT4-fs (nvme0n1p3): mounted filesystem with ordered data mode. Opts: (null)
Feb 04 13:17:15 se-ekoc kernel: nvme nvme0: I/O 424 QID 4 timeout, aborting
Feb 04 13:17:15 se-ekoc kernel: nvme nvme0: Abort status: 0x0
Feb 04 13:17:15 se-ekoc kernel: nvme nvme0: I/O 424 QID 4 timeout, reset controller
Feb 04 13:17:15 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues
Feb 04 13:17:15 se-ekoc kernel: nvme nvme0: I/O 57 QID 8 timeout, aborting
Feb 04 13:17:15 se-ekoc kernel: nvme nvme0: I/O 57 QID 8 timeout, reset controller
Feb 04 13:17:15 se-ekoc systemd-fsck[437]: /dev/nvme0n1p1: 6 files, 596/201568 clusters
Feb 04 13:42:18 se-ekoc timeshift-gtk.desktop[4788]: Mounted ‘/dev/nvme0n1p3’ at ‘/run/timeshift/backup’
Feb 04 13:42:20 se-ekoc timeshift-gtk.desktop[4788]: Saving to device: /dev/nvme0n1p3, mounted at path: /run/timeshift/backup
Feb 04 17:26:23 se-ekoc kernel: nvme nvme0: I/O 431 QID 3 timeout, aborting
Feb 04 17:26:23 se-ekoc kernel: nvme nvme0: Abort status: 0x0
Feb 04 17:26:23 se-ekoc kernel: nvme nvme0: I/O 431 QID 3 timeout, reset controller
Feb 04 17:26:23 se-ekoc kernel: nvme nvme0: 8/0/0 default/read/poll queues’
nvme self test stucked at %5
   ~  sudo nvme self-test-log /dev/nvme0n1  :heavy_check_mark:
[sudo] password for ercan:
Device Self Test Log for NVME device:nvme0n1
Current operation : 0x1
Current Completion : 5%
Self Test Result[0]:
Operation Result : 0xf
Self Test Result[1]:
Self Test Result[2]:
Self Test Result[3]:
Self Test Result[4]:
Self Test Result[5]:
Self Test Result[6]:
Self Test Result[7]:
Self Test Result[8]:
Self Test Result[9]:
Self Test Result[10]:
Self Test Result[11]:
Self Test Result[12]:
Self Test Result[13]:
Self Test Result[14]:
Self Test Result[15]:
Self Test Result[16]:
Self Test Result[17]:
Self Test Result[18]:
Self Test Result[19]:
:point_up: does not seem good, report it to the supplier/dealer, I’ve had this with 2 drives in a row and had them replaced. Or the drive gets to hot?
:point_down: seems something is hotter then a threshold, check the temperature settings / clean out the dust / repair fans ?
It’s a brand new computer, I only used for one month. I don’t think there is a dust on cooling system. I’m not sure dealer will replace drive because smart reports seems ok. I saw a firmware upgrade for nvme which is critical and released ten days ago. I’ll give ot a try to firmware update and keep eye on logs.
That seems a good idea :slight_smile:
The firmware of nvme was already latest. Unfortunately I had switch to another distro. So far I haven’t got any freezes or boot, shutdown hangs. Journalctl and dmesg logs are clear.
