After the update of the 8th March, my computer crashed when the battery had 11% of its capacity. Before that, it could shut down and crash suddenly when the battery was around 4% of its capacity. How can one explain that? Is it linked by an upgrade of xfce4-power-manager? I would be glad if someone could explain this. Here some more information:
inxi -Fxz --no-host
System: Kernel: 5.4.105-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Xfce 4.16.0 Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: Notebook product: N650DU v: N/A serial:
Mobo: Notebook model: N650DU serial: UEFI: American Megatrends v: 5.12 date: 02/26/2018
Battery: ID-1: BAT0 charge: 42.7 Wh (100.0%) condition: 42.7/62.2 Wh (68.8%) volts: 12.8 min: 11.1 model: Notebook BAT
status: Full
CPU: Info: Quad Core model: Intel Core i5-7500T bits: 64 type: MCP arch: Kaby Lake rev: 9 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21607
Speed: 1585 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 1585 2: 1600 3: 1600 4: 1593
Graphics: Device-1: Intel HD Graphics 630 vendor: CLEVO/KAPOK driver: i915 v: kernel bus-ID: 00:02.0
Device-2: Chicony Chicony USB2.0 Camera type: USB driver: uvcvideo bus-ID: 1-6:2
Display: x11 server: X.org 1.20.10 driver: loaded: intel unloaded: modesetting resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.4.105-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Network: Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: f040 bus-ID: 01:00.0
IF: wlp1s0 state: down mac:
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: CLEVO/KAPOK driver: r8168
v: 8.048.03-NAPI port: e000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac:
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-10:3
Drives: Local Storage: total: 1.14 TiB used: 728.27 GiB (62.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 960 EVO 250GB size: 232.89 GiB
ID-2: /dev/sda vendor: Seagate model: ST1000LM048-2E7172 size: 931.51 GiB
ID-3: /dev/sdb type: USB model: 0930 USB Flash Memory size: 983 MiB
Partition: ID-1: / size: 227.24 GiB used: 39.76 GiB (17.5%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 1022 MiB used: 288 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1
ID-3: /home size: 911.95 GiB used: 688.5 GiB (75.5%) fs: ext4 dev: /dev/sda2
Swap: ID-1: swap-1 type: file size: 8 GiB used: 1.06 GiB (13.3%) file: /swapfile
Sensors: System Temperatures: cpu: 68.0 C mobo: N/A
Info: Processes: 195 Uptime: 21h 16m Memory: 7.7 GiB used: 4.77 GiB (62.0%) Init: systemd Compilers: gcc: 10.2.0
clang: 11.1.0 Packages: 1636 Shell: Bash v: 5.1.0 inxi: 3.3.03
Thanks for your attention!
