For an UEFI boot you don’t need to flag any partition as “boot” because the UEFI bios will check all drives and partitions and use the first (or configured in bios) ESP partition to boot from.
ESP partitions have an unique GUID…
Flagging a partition as “boot” is only needed for Legacy/MBR boot’s.
That’s a point that needs a change actually, because it is much more workable if one could use /efi as the mount point in that case and bind-mount a subdirectory of it as /boot (eg. /efi/Manjaro -> /boot)
But yes that’s the starting point with which i had a working encrypted root also…
If you use that bind-mount “trick” i wrote, you will end-up with all needed files (to boot) in the ESP and that setup will work for any bootloader plus keep kernels+ramdisks separated from other distro installs…
I would be trying in due time to do that, but at moment im still too new to be familiar enough with the Manjaro installer to fiddle with it to accomplish that…
Plus i would not know where to head to to get started with contributing at source level…
This placeholder file system shall be determined during installation time , and an fstab entry may be created. It should be mounted to either /boot/ or /efi/ . Additional locations like /boot/efi/ , with /boot/ being a separate file system, might be supported by implementations. This is not recommended because the mounting of $BOOT is then dependent on and requires the mounting of the intermediate file system.
This is the function to install systemd-boot. Current implementation uses sdboot-manage, so you can also contribute there if you want.
This is where efi partition is mounted.
It’s just bash, if you can do a cli-installation, then this is easy to hack. And it is easy to test changes since you don’t need to compile it between tests.
less than a minute of looking over and i already spot some wrong things…ahh well i’ll sure try to contribute in due time…
Will take some time for me to familiarize with the code base first…
PS: @Chrysostomus, Until the author of sdboot-manage changes his standpoint wrt. wiping old boot entries as default, it will be very hard for me to try fiddling with this all.
I would have to create a VM to make sure it does not render my whole system useless, because that behaviour eliminates the possibility of installing alongside other installs…
As you can notice, that issue is only flagged as RFE eg. as a feature request so others who are willing to implement it could provide a PR for it
(Dated June 8, with no change or reply)
Ok i stand corrected and pleased to hear that you know of other binary types of it.
See the answer of poettering is equal to mine also
Plus it has been 2 years with no actual implementation by anyone.
Network boot (eg. PXE boot) is another type of booting using as the name says another boot loader, hence not the duty of sd-boot but more of the image loaded using the PXE server and or the kernel+ramdisk image that is used by sd-boot like poettering answered.
When it comes to “mixed efi” you mentioned, seems like that discussion is ongoing who knows what the final result will become…
Any reference to that claim?
I know they use an OID from RH wrt “kernel-module-signing only” permission for the Mok-Key.
Because they (RH) came up with the idea of that flag, which can/will be replaced by a general one (and more standard wrt OID’s) in due time i’m sure…
It’s only a binary number afterall and only used by the Linux kernel, it has nothing todo with being big or small enough, it all boils down to who came up with an idea first.
Going by that last part, you should have mentioned the Author of that OID instead of RH
(Nevermind me i have an antipathy vs RH similar to M$)
Besides in that quote im talking about the solution as a whole, not the separate utils used in that solution
These are shim’s sources.
If you are a small distro, you can have “transparent” booting with no action required for free, by asking to them to chainload your signature.
Otherwise you either request to the users to manage themselves their keys (or disable SB altogether), or you have to buy an EV certificate and ask microsoft.
Thanks for the link to the shim source.
For the rest its easier to just use the signed shim binary (no matter which) to start chainloading instead of asking for approval by any commercial company.
(Seems that chainloading of certificate idea bleed to death reading that link)
But now i at least understand why shim is so slow in fixing it’s bugs, it’s the price the community pays when interacting with commercial parties…
(Fast innovation vs power of hard-headed-ness)
No, he is not. Please read the thread. Both bootloaders are currently supported under manjaro-architect. Calamares will default to grub for the foreseeable future. For a change like this, systemd-boot would first require an infrastructure or ecosystem around it, similar to what grub has.
