Hi everyone!
I would like to know if I could make the KDE Konsole look like the Manjaro-Gnome Terminal?
I think it looked quite nice with the colour coding and the ~ >>>
command starting point.
Is it also possible to make the output text also colour coded like this ?
Thanks
omano
24 November 2020 11:40
2
I think you need to customize/change the shell.
//EDIT: yep, quick google for âkde konsole change shellâ yields some interesting results I think you can go from there
That just looks like zsh
to meâŚ
Falav
24 November 2020 12:59
4
You can check whatâs inside your ~/.zshrc in Gnome, copy/adapt it to your KDE system, install if not already done zsh and set is as default shell.
omano
24 November 2020 13:35
5
I think zsh is part of a default KDE installation. I changed the âcommandâ in Konsole preference from bash to zsh and it works after restarting Konsole, and I donât remember installing it myself.
440Hz
24 November 2020 13:58
6
zsh with powerlevel10k most likely
Itâs in the official repo
Falav
24 November 2020 14:37
7
Gnome for sure, not the case from not too recent KDE isos (if I remember well), I didnât check the latest available.
I was wondering, does it exist, a list of all default applications by DE iso?
omano
24 November 2020 15:09
8
Yes you can download the ISO profiles and check the packages list.
//EDIT: from a quick look it seems manjaro-zsh-config is part of Packages-Root which seems to be common for all DE.
Right, so I changed the profile command from /bin/bash to /bin/zsh and it looks perfect, thanks guys!!!
I just tried this and worked like a charm. Thanks man.
omano
25 November 2020 17:21
11
Then you have in your home folder the file .zshrc to customize it.
system
Closed
10 December 2020 17:21
12
