i have no problems with chrome but when I pull up some of the websites that have no problem loading up in chrome on firefox I get those half-cut codeblocks, not sure how to fix this, any advice would be deeply appreciated!
these are my font settings in firefox
Hi @Mmshukla21 ,
I use Firefox, that’s all I use, and I have no such problems. The are my Firefox font settings if you wish to try:
I tried those settings, made everything default but have a look at this, this is how it renders codeblocks for me
And yet, mine is perfectly fine.
just created this new profile. have no extra plugins installed other than the default ones!
Ergh.
The last thing I can recommend is that you check your system fonts:
If it’s not that, I am all out of ideas.
they’re already set to their default settings I didn’t touch em
I’m thinking of reinstalling firefox by completely deleting any leftover config files, if would be great if you guide me through the first few steps, I don’t know exactly where all those files are located.
AFAIK it’ll be the following:
pamac remove firefox
Move the Mozilla configuration files in your home directory:
mv ~/.mozilla ~/.mozilla.backup
Reinstall Firefox, overwriting any conflicts:
pamac install firefox --overwrite='*'
And set everything up again.
You could also just exit Firefox, (re)move tyhe config, and restart Firefox. Should have the same effect.
If you encounter any problems, you can just restore the backup:
cp ~/.mozilla.backup ~/.mozilla
If not, feel free to delete the old, faulty directory:
rm -fr ~/.~/.mozilla.backup
Note:
This is going to cause your Firefox to be completely reset, so no auto-logins, extensions, themes, saved passwords, or anything else custom will be kept.
I have backed up passwords and bookmarks
it’s already in the home directory
[sudo] password for manmohan:
/home/manmohan/.mozilla
/home/manmohan/.local/share/torbrowser/tbb/x86_64/tor-browser_en-US/Browser/TorBrowser/Data/Browser/.mozilla
find: ‘/run/user/1000/doc’: Permission denied
find: ‘/run/user/1000/gvfs’: Permission denied
reinstalled firefox still getting the same error
qruqs
1 July 2022 15:26
10
Just a few ideas that popped up in my head while reading the thread.
From the world of typography, I would call this error wrong font size for the desired line spacing, almost as if there was a setting to, e.g. like in LibreOffice Writer, adjust line spacing to be smaller than the font size used, at which time the letters will interfere with the line above them. They sort of clash into one another, or, as in this case, they get cut off. Is there such a setting in Firefox, maybe? (Which, by the way, used to be abbreviated Fx, is it still?) Perhaps under the infamous about:config. In there is a setting “dom.textMetrics.fontBoundingBox.enabled”, mine says “false”, could be worth a try checking in there, not sure it’ll change anything for you, but perhaps you will find other, more useful things. Be careful, though! Don’t willy nilly double-click on things, the settings may change if you do.
Either that, or if some plug-in has done something with CSS/JavaScript (Tampermonkey/Stylus, etc.), or is there a default CSS document which is always loaded? Not sure if that’s even a thing.
BTW, you have tried changing to a different font, right?
Good luck!
Post scriptum
Have you tried zooming out?
didn’t work, I don’t wanna wipe my entire operating system just for this
Are you using any type of scaling in KDE’s display settings?
posted this everywhere, haven’t got any reasonable answer yet
So to summarize so far:
Fresh Firefox profile (default settings, no extensions)
No scaling or DPI settings configured in KDE
Only happens with Firefox (no other browser)
Changing the fonts makes no difference
Zooming in and out makes no difference
Is that correct?
You’re using an Intel GPU? Can you post the system specs?
Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=6c041c4e-e9ca-4e70-9edc-6656731e29bd rw quiet apparmor=1
security=apparmor resume=UUID=2ba2089c-de98-4caf-9c87-b60340f023ae
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X512FAC_X512FA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X512FAC v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X512FAC.304 date: 01/26/2021
ID-1: BAT0 charge: 8.0 Wh (25.6%) condition: 31.3/37.1 Wh (84.4%) volts: 7.8
min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging cycles: 180
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K230
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: discharging
RAM: total: 11.55 GiB used: 6.09 GiB (52.8%)
RAM Report:
Info: model: Intel Core i3-10110U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 built: 2018
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xC (12)
microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 900 min/max: 400/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 bogomips: 20810
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-1 off: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9b41
class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 13d3:56dd class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: Dell P2419H
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 note: disabled model: BOE Display 0x07f1 built: 2018
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:5 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Hardware-1: Intel Device driver: ahci v: 3.0 port: 3060 bus-ID: 00:17.0
chip-ID: 8086:02d7 rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 76.12 GiB (16.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 type: SSD serial: <filter> rev: 004C temp: 33.9 C scheme: GPT
ID-1: / raw-size: 467.84 GiB size: 459.43 GiB (98.20%)
used: 76.12 GiB (16.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 6c041c4e-e9ca-4e70-9edc-6656731e29bd
label: NO_LABEL uuid: 19F0-F078
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 2ba2089c-de98-4caf-9c87-b60340f023ae
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-4:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
Device-3: 1-6:4 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Device-4: 1-10:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 59.0 C pch: 48.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3100
Processes: 280 Uptime: 1h 12m wakeups: 11 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: 1375 pacman: 1361 lib: 367 flatpak: 7 snap: 7 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.19
yes you’re correct, im using an intel gpu
I doubt this will work (but it should be done regardless for performance and stability):
Remove the package xf86-video-intel
and install the package intel-media-sdk
, then reboot.
Also, can you post the contents of /etc/X11/
before you do anything else?
ls -lR /etc/X11/
After rebooting, if it still has the same issue with Firefox, there might be a particular setting in Firefox that is the culprit, even on a fresh profile.
/etc/X11/:
total 12
drwxr-xr-x 2 root root 4096 Dec 18 2021 mhwd.d
drwxr-xr-x 3 root root 4096 Apr 16 10:47 xinit
drwxr-xr-x 2 root root 4096 Apr 23 15:47 xorg.conf.d
/etc/X11/mhwd.d:
total 0
/etc/X11/xinit:
total 12
-rw-r--r-- 1 root root 739 Oct 10 2020 xinitrc
drwxr-xr-x 2 root root 4096 Jun 25 20:36 xinitrc.d
-rw-r--r-- 1 root root 45 Oct 10 2020 xserverrc
/etc/X11/xinit/xinitrc.d:
total 12
-rwxr-xr-x 1 root root 318 Apr 2 00:32 40-libcanberra-gtk-module.sh
-rwxr-xr-x 1 root root 538 Jun 8 19:28 50-systemd-user.sh
-rwxr-xr-x 1 root root 243 Jun 18 16:38 80xapp-gtk3-module.sh
/etc/X11/xorg.conf.d:
total 8
-rw-r--r-- 1 root root 232 Apr 23 15:47 00-keyboard.conf
-rw-r--r-- 1 root root 131 Apr 16 10:47 30-touchpad.conf
