[closed] NTFS, fstab, and mounting with read, write, and executable permissions
I checked all the articles I could find on the Manjaro forums related to my issue, but no luck.
I am trying to mount a Windows drive with read, write, and executable permissions in fstab. It was working before with my fstab entry as such:
UUID=43FBFFD71AD3FC68 			  /home/USERNAME/d_drive ntfs defaults,noatime 0 0
All that does now is give me read permissions.
I have tried several different fstab ntfs and ntfs-3g options, such as uid=1000, gid=1000,dmask=022,fmask=133,windows_names etc. Nothing is even given me read write access, let alone executable.
Suggestions are appreciated. Thanks.
Try changing the ownership with:
sudo chown -R $USER:$USER /home/USERNAME/d_drive
I tried that before, but I keep getting that it is a read-only file system.
Also, I have already ensured that ‘‘fastboot’’ is disabled in Windows.
Unless USERNAME is your real username you have to replace that in fstab… :rofl:
Also the directory
/home/$USER/d_drive
needs to be created with mkdir.
Furthermore, install ntfs-3g
Then replace ntfs with ntfs-3g in your fstab entry and use the right options:
UUID=43FBFFD71AD3FC68 /home/{username}/d_drive ntfs-3g uid=userid,gid=groupid,dmask=022,fmask=133 0 0
Haha, yes. I replaced my actual username for privacy reasons. I have already made the d_drive using mkdir, and have ntfs-3g installed. The drive has worked fine for the past month or so (which is how long I have had windows installed). It just recently became read-only for some reason.
How have you switched-off “Fast Startup” in Windoze? Better double-check if this has been done right.
I’ll double-check. I usually disable it by going to power options and unchecking it from there. Also, I tried replacing ntfs with ** ntfs-3g** and still have the same issue.
I forgot to update this. For whatever reason, rebooting Windows fixed the problem. No other changes were made.
