Did anyone manage to get WiFi working on that Laptop? I am on the latest kernel, but still seeing unknown intel devices.
Wifi Chipset is Intel Wifi 6 AX101.
Please share your system info.
Kernel: 6.4.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64
root=UUID=758a94cf-88b9-47d6-9352-f7e2c986a504 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
Type: Laptop System: CHUWI Innovation And (ShenZhen) product: GemiBook XPro
v: N/A serial: <superuser required>
Mobo: N/A model: N/A serial: <superuser required> UEFI: American
Megatrends LLC. v: EM_IDL8329_SUB1_V2.0.14 date: 03/17/2023
ID-1: BAT0 charge: 34.6 Wh (91.1%) condition: 38.0/38.0 Wh (100.0%)
volts: 7.6 min: N/A model: Intel SR 1 SR Real Battery type: Unknown
serial: <filter> status: discharging
System RAM: available: 7.51 GiB used: 2.55 GiB (33.9%)
Info: model: Intel N100 bits: 64 type: MCP arch: Alder Lake level: v3
note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0xBE (190) stepping: 0 microcode: 0x10
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1904 high: 3016 min/max: 700/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 3000 2: 800 3: 3016 4: 800
bogomips: 6452
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Alder Lake-N [UHD Graphics] vendor: nCipher Security
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46d1 class-ID: 0300
Device-2: Tripath USB Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 058e:3864
class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Graphics (ADL-N)
direct-render: Yes
Device-1: Intel vendor: Emdoor Digital driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:54c8
class-ID: 0401
API: ALSA v: k6.4.0-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 00:14.3
chip-ID: 8086:54f0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.4:3
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp0s20f0u2u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 238.47 GiB used: 9.54 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 model: G521N256GB size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 227R scheme: GPT
ID-1: / raw-size: 118.69 GiB size: 116.27 GiB (97.96%) used: 9.46 GiB (8.1%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 758a94cf-88b9-47d6-9352-f7e2c986a504
used: 76.9 MiB (80.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM
uuid: 325D-25BD
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 118.69 GiB fs: ntfs label: Local Disk
uuid: 3A9260E39260A4DB
ID-3: /dev/sda4 maj-min: 8:4 size: 1000 MiB fs: ntfs label: Recovery
uuid: 14BC6148BC612608
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-6:3 info: Tripath USB Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 058e:3864 class-ID: 0e02
Device-2: 1-10:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-4: 2-2:2 info: Genesys Logic Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0612
Device-1: 2-2.4:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
System Temperatures: cpu: 64.0 C mobo: N/A
Processes: 178 Uptime: 5m wakeups: 1 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1148 libs: 341 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27```
No matter if using kernel 6.4, 6.3, 6.2 same problem ![]()
Dirver is loaded. Probably an issue with the firmware or the UEFI did not probably initialize it (fastboot)?
Please share the kernel messages:
journalctl --boot 0 --dmesg --grep "iwlwifi" --no-hostname
~ journalctl --boot 0 --dmesg --grep “iwlwifi” --no-hostname ![]()
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: enabling device (0000 → 0002)
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: Detected crf-id 0x501, cnv-id 0x80400 wfpm id 0x80000030
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: PCI dev 54f0/0244, rev=0x370, rfid=0x10c000
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-78.ucode failed w>
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: loaded firmware version 77.f92b5fed.0 so-a0-hr-b0-77.ucode op_>
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX101, REV=0x370
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x10
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: Detected RF HR1 B3, rfid=0x10c000
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3: base HW address: 64:49:7d:f5:a8:02
Jun 17 00:27:18 kernel: iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
Jun 17 00:27:19 kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Jun 17 00:27:19 kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
Jun 17 00:27:19 kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Jun 17 00:27:19 kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
Jun 17 00:27:19 kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x10
Jun 17 00:27:19 kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
Jun 17 00:27:19 kernel: iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 0
Jun 17 00:27:19 kernel: iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
Damn, looks like firmware error, does it?
btw. fastboot is disabled.
Probably an issue where the module triggers functions, which are not available in the firmware? Means the kernel module needs a newer firmware? No idea… At least here is a thread with module options you can try: [SOLVED] iwlwifi: Microcode SW error detected. Restarting 0x0. / Kernel & Hardware / Arch Linux Forums
Note that kernel 6.4 is the mainline kernel, which means: the development kernel with new untested features which includes iwlwifi.
thanks for your time, unfortunately it seems to be the firmware, the linked solution does not work.
Hi all! On my Chuwi gemebook X (but not PRO) after the purchase, with Linux installed, the wifi touch and lan did not work. I read on one of the forums that you need Disable “acpi d3cold support” in BIOS (BIOS-> advanced → ASPI d3cloud setting )… And, miraculously, it worked. At once, both wifi and touch and lan port began to work.
