Chromium based browsers take 30s to start up
Hello Manjaro Forum Members,
for a while I have not posted but this one is quite annoying and I can’t find a fix myself. Chromium and Brave both take about 30s to start up. The only errors I see when it has finished starting up is this
[4825:4825:0908/092000.308878:ERROR:chrome_browser_cloud_management_controller.cc(163)] Cloud management controller initialization aborted as CBCM is not enabled.
[4825:4825:0908/092000.688614:ERROR:network_service_instance_impl.cc(625)] Network service crashed, restarting service.
[4825:4825:0908/092001.190821:ERROR:CONSOLE(2061)] "[Brave Settings Overrides] Appearance Page cannot find use default theme button template", source: chrome://settings/settings.js (2061)
…though I can’t find solutions related to this problem. I disabled HW acceleration, tried to change the used DNS and disabled secure DNS (for testing).
This is the machine I’ve problems with.
  Kernel: 6.1.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    root=UUID=6d3b06b6-82e6-45ce-ad6f-4d26809184e1 rw quiet
    udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 1 dm: startx Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ASRock model: A300M-STX serial: <superuser required>
    UEFI: American Megatrends v: P3.60 date: 10/28/2019
  Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
    arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
    process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
    microcode: 0x8108102
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
    desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 2520 high: 2956 min/max: 1400/3600 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1233 2: 2956
    3: 2951 4: 2942 bogomips: 28812
  Type: spec_rstack_overflow mitigation: SMT disabled
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
    built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1
    empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300
    temp: 47.0 C
  Display: server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
    loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung serial: <filter>
    built: 2012 res: 1920x1080 hz: 60 dpi: 46 gamma: 1.2
    size: 1060x626mm (41.73x24.65") diag: 1168mm (46") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
    chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Device-3: Corsair HS70 Pro Wireless Gaming Headset
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-2.4.1:6 chip-ID: 1b1c:0a4f class-ID: 0300
  Device-4: Creative SB X-Fi Surround 5.1 Pro driver: snd-usb-audio type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.2:5 chip-ID: 041e:30df
    class-ID: 0102 serial: <filter>
  API: ALSA v: k6.1.49-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.78 status: off tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 465.76 GiB used: 357.97 GiB (76.9%)
    model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
    fw-rev: 211070WD temp: 45.9 C scheme: GPT
  ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
    used: 357.97 GiB (78.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 64.5 C mobo: N/A gpu: amdgpu temp: 47.0 C
  Fan Speeds (rpm): fan-2: 1244
  Processes: 226 Uptime: 1h 7m wakeups: 6 Memory: total: 6 GiB
  available: 5.72 GiB used: 2.84 GiB (49.7%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1329 libs: 438 tools: pamac,yay Shell: Zsh v: 5.9
  running-in: alacritty inxi: 3.3.29
I couldn’t find any related entries in the journal. I deleted the config but the problem persists.
Any hints where I could go on searching? If any logs or journals are required please let me know.
Hi @mielouk,
It might be related to this, mentioned in a previous Update Announcement:
Which you would have seen if you worked through it before updating…
This was the first one I checked. Had this issue on several other machines but it is not a problem with this machine. With this xdg problem the first one I noticed was that firefox took a very long time, but firefox works like a charm.
In that case, see:
https://stackoverflow.com/questions/76297624/chrome-browser-cloud-management-controller-cc162-cloud-management-controller/76297692#76297692
Also:
–disable-extensions
–gtk-version=3
–disable-features=AllowQt
don’t speed up the start.
BTW thank you for helping. Is there a verbose mode to start chromium based browsers so I can see more of its own log?
Indeed there is a verbose mode and this is the output
▶ brave --enable-logging=stderr --v=1
[10436:10436:0908/102821.628541:WARNING:chrome_main_delegate.cc(596)] This is Chrome version 116.1.57.62 (not a warning)
[10436:10436:0908/102821.628678:VERBOSE1:chrome_crash_reporter_client.cc(195)] GetCollectStatsConsent(): settings_consent: 0 so returning that
[10436:10436:0908/102821.633953:VERBOSE1:chrome_crash_reporter_client.cc(195)] GetCollectStatsConsent(): settings_consent: 0 so returning that
[10446:10446:0908/102821.663614:VERBOSE1:cdm_registration.cc(208)] Widevine enabled but no library found
[1:1:0908/102821.663614:VERBOSE1:cdm_registration.cc(208)] Widevine enabled but no library found
[1:1:0908/102821.663683:INFO:cpu_info.cc(53)] Available number of cores: 4
[10446:10446:0908/102821.663683:INFO:cpu_info.cc(53)] Available number of cores: 4
[10446:10446:0908/102821.663872:VERBOSE1:zygote_main_linux.cc(201)] ZygoteMain: initializing 0 fork delegates
[1:1:0908/102821.663892:VERBOSE1:zygote_main_linux.cc(201)] ZygoteMain: initializing 0 fork delegates
[10436:10436:0908/102821.666947:WARNING:chrome_browser_cloud_management_controller.cc(88)] Could not create policy manager as CBCM is not enabled.
[10436:10436:0908/102821.670899:VERBOSE1:variations_field_trial_creator.cc(87)] VariationsSeedUsage:0
[10436:10436:0908/102821.671120:VERBOSE1:variations_field_trial_creator.cc(694)] CreateTrialsFromSeed complete with seed.version='1'
[10436:10436:0908/102821.671215:VERBOSE1:variations_field_trial_creator.cc(336)] VariationsSetupComplete
[10436:10456:0908/102821.673980:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
interface: org.freedesktop.DBus
member: GetNameOwner
signature: s
string "org.freedesktop.login1"
[10436:10436:0908/102821.789330:VERBOSE1:webrtc_event_log_manager.cc(97)] WebRTC remote-bound event logging enabled.
[10436:10436:0908/102821.789514:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0x268800199280: set chrome proxy config service to 0x2688000cc920
[10436:10436:0908/102821.789642:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_MAIN
[10436:10436:0908/102821.789656:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_MAIN
[10436:10436:0908/102821.789662:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING
[10436:10436:0908/102821.789669:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING
[10436:10436:0908/102821.789675:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING_HOST
[10436:10436:0908/102821.789682:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING_HOST
[10436:10436:0908/102821.792011:VERBOSE1:cdm_registration.cc(208)] Widevine enabled but no library found
[10436:10458:0908/102821.794985:VERBOSE1:media_stream_manager.cc(1450)] MSM::InitializeMaybeAsync([this=0x268800624a40])
[10436:10458:0908/102821.795022:VERBOSE1:media_stream_manager.cc(1450)] MDM::MediaDevicesManager()
[10436:10458:0908/102821.795048:VERBOSE1:media_stream_manager.cc(1450)] MSM::MediaStreamManager([this=0x268800624a40]))
[10436:10436:0908/102821.796470:VERBOSE1:key_storage_util_linux.cc(50)] Password storage detected desktop environment: XFCE
[10436:10436:0908/102821.796498:VERBOSE1:key_storage_linux.cc(117)] Selected backend for OSCrypt: GNOME_LIBSECRET
[10436:10456:0908/102821.797127:VERBOSE1:select_file_dialog_linux_portal.cc(280)] File chooser portal available: no
[10472:10472:0908/102821.865258:WARNING:sandbox_linux.cc(393)] InitializeSandbox() called with multiple threads in process gpu-process.
[10473:10473:0908/102836.833073:INFO:child_thread_impl.cc(927)] ChildThreadImpl::EnsureConnected()
[10436:10436:0908/102846.827787:WARNING:key_storage_linux.cc(167)] OSCrypt tried Libsecret but couldn't initialise.
[10436:10436:0908/102846.827864:VERBOSE1:key_storage_linux.cc(136)] OSCrypt did not initialize a backend.
[10436:10436:0908/102846.828350:ERROR:chrome_browser_cloud_management_controller.cc(163)] Cloud management controller initialization aborted as CBCM is not enabled.
[10436:10457:0908/102846.835689:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave Ad Block List Catalog
[10436:10466:0908/102846.835697:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave Ad Block Updater
[10436:10454:0908/102846.835689:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave Ad Block Resources Library
[10436:10436:0908/102846.835945:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0x26880019ae00: set chrome proxy config service to 0x2688000d18c0
[10436:10467:0908/102846.836046:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave Ad Block First Party Filters
[10542:1:0908/102846.841397:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: utility.
[10436:10456:0908/102846.842143:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
string "org.freedesktop.Notifications"
[10436:10456:0908/102846.842666:VERBOSE1:bus.cc(687)] Filter function already exists: 1 with associated data: 0x268800fadc00
[10436:10456:0908/102846.842686:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[10436:10456:0908/102846.842837:VERBOSE1:bus.cc(687)] Filter function already exists: 1 with associated data: 0x268800fadc00
[10436:10436:0908/102846.842934:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0x26880019b900: set chrome proxy config service to 0x268800f913e0
[10436:10456:0908/102846.843109:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[10436:10436:0908/102846.843881:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[10436:10436:0908/102846.844119:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[10436:10436:0908/102846.844403:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(217)] MutablePO2TS::MutablePO2TS
[10436:10436:0908/102846.844467:VERBOSE1:gaia_auth_util.cc(48)] Canonicalized @gmail.com to @gmail.com
[10436:10436:0908/102846.844482:VERBOSE1:gaia_auth_util.cc(48)] Canonicalized @gmail.com to @gmail.com
[10436:10436:0908/102846.844527:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[10436:10436:0908/102846.844569:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[10436:10436:0908/102846.845370:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[10436:10436:0908/102846.845401:VERBOSE1:account_reconcilor.cc(167)] AccountReconcilor::AccountReconcilor
[10436:10436:0908/102846.845410:VERBOSE1:account_reconcilor.cc(197)] AccountReconcilor::Initialize
[10436:10436:0908/102846.845585:VERBOSE1:brave_sync_auth_manager.cc(36)] DeriveSigningKeys
[10436:10436:0908/102846.847892:VERBOSE1:device_event_log_impl.cc(224)] [10:28:46.847] Bluetooth: EVENT: bluetooth_api.cc:82 BluetoothAPI: 0x2688001d4600
[10436:10436:0908/102846.848008:VERBOSE1:gaia_auth_util.cc(48)] Canonicalized @gmail.com to @gmail.com
[10436:10436:0908/102846.848017:VERBOSE1:gaia_auth_util.cc(48)] Canonicalized @gmail.com to @gmail.com
[10436:10436:0908/102846.848621:VERBOSE1:bluetooth_low_energy_event_router.cc(276)] Initializing BluetoothLowEnergyEventRouter.
[10436:10454:0908/102846.852191:VERBOSE1:component_installer.cc(428)] StartRegistration for NTP Background Images
[10436:10453:0908/102846.852428:VERBOSE1:component_installer.cc(428)] StartRegistration for NTP Sponsored Images (DE)
[10436:10436:0908/102846.853102:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Webshop
[10436:10458:0908/102846.853398:VERBOSE1:content_verifier.cc(630)] OnFetchComplete ahfgeienlihckogmohjhadlkjgocpleb success:0
[10436:10436:0908/102846.853527:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Chrome PDF Viewer
[10436:10458:0908/102846.853746:VERBOSE1:content_verifier.cc(630)] OnFetchComplete mhjfbmdgcfjbbpaeojofohoefgiehjai success:0
[10436:10436:0908/102846.853884:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Google Hangouts
[10436:10458:0908/102846.854071:VERBOSE1:content_verifier.cc(630)] OnFetchComplete nkeimhogjdpnpccoofpliimaahmaaome success:0
[10436:10436:0908/102846.854415:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Brave
[10436:10458:0908/102846.854825:VERBOSE1:content_verifier.cc(630)] OnFetchComplete mnojpmjdmbbfmejpflffifhffcmidifd success:0
[10436:10436:0908/102846.855536:WARNING:external_provider_impl.cc(513)] Malformed extension dictionary for extension: odbfpeeihdkbihmopkbjmoonfanlbfcl.  Key external_update_url has value "", which is not a valid URL.
[10436:10436:0908/102846.856572:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[10436:10436:0908/102846.856939:VERBOSE1:brave_wallet_p3a.cc(121)] Wallet P3A: starting report
[10436:10436:0908/102846.857160:VERBOSE1:brave_news_p3a.cc(132)] NewsP3A: total card views update: total = 0 count delta = 0
[10436:10436:0908/102846.857184:VERBOSE1:brave_news_controller.cc(667)] STOPPING TIMERS
[10436:10436:0908/102846.857190:VERBOSE1:brave_news_controller.cc(671)] REMOVING DATA FROM MEMORY
[10436:10436:0908/102846.857221:VERBOSE1:profile_manager.cc(1922)] ForceSigninCheck: 0, 0, 1
[10436:10436:0908/102846.858788:VERBOSE1:component_installer.cc(53)] Skipping registration of Brave-unsupported component gcmjkmgdlgnkkcocmoeiminaijmmjnii.
[10436:10436:0908/102846.858915:VERBOSE1:on_device_head_suggest_component_installer.cc(58)] On Device Head Component will fetch model for locale: DE500000
[10436:10454:0908/102846.858993:VERBOSE1:component_installer.cc(428)] StartRegistration for OnDeviceHeadSuggest
[10436:10454:0908/102846.859192:VERBOSE1:on_device_head_suggest_component_installer.cc(81)] On Device head model is successfully installed at directory: /home/schnucky/.config/BraveSoftware/Brave-Browser/OnDeviceHeadSuggestModel/20230815.558564245.14
[10436:10436:0908/102846.859251:VERBOSE1:first_party_sets_component_installer.cc(214)] Registering First-Party Sets component.
[10436:10436:0908/102846.859332:VERBOSE1:component_installer.cc(53)] Skipping registration of Brave-unsupported component gonpemdgkjcecdgbnaabipppbmgfggbe.
[10436:10454:0908/102846.859512:VERBOSE1:component_installer.cc(428)] StartRegistration for Certificate Error Assistant
[10436:10454:0908/102846.859822:VERBOSE1:component_installer.cc(428)] StartRegistration for File Type Policies
[10436:10454:0908/102846.860044:VERBOSE1:component_installer.cc(428)] StartRegistration for CRLSet
[10436:10436:0908/102846.860193:VERBOSE1:component_installer.cc(53)] Skipping registration of Brave-unsupported component llkgjffcdpffmhiakmfcdcblohccpfmo.
[10436:10454:0908/102846.860289:VERBOSE1:component_installer.cc(428)] StartRegistration for MEI Preload
[10436:10454:0908/102846.860392:VERBOSE1:component_installer.cc(273)] Preinstalled component found for MEI Preload at /usr/lib/brave-browser/MEIPreload with version 1.0.7.1652906823.
[10436:10454:0908/102846.860510:VERBOSE1:component_installer.cc(428)] StartRegistration for PKI Metadata
[10436:10454:0908/102846.860695:VERBOSE1:component_installer.cc(428)] StartRegistration for Safety Tips
[10436:10454:0908/102846.860930:VERBOSE1:component_installer.cc(428)] StartRegistration for Crowd Deny
[10436:10436:0908/102846.861132:VERBOSE1:hyphenation_component_installer.cc(150)] Registering Hyphenation component.
[10436:10454:0908/102846.861222:VERBOSE1:component_installer.cc(428)] StartRegistration for Hyphenation
[10436:10436:0908/102846.861401:VERBOSE1:component_installer.cc(53)] Skipping registration of Brave-unsupported component ojhpjlocmbogdgmfpkhlaaeamibhnphh.
[10436:10436:0908/102846.861438:VERBOSE1:component_installer.cc(53)] Skipping registration of Brave-unsupported component eeigpngbgcognadeebkilcpcaedhellh.
[10436:10436:0908/102846.861505:VERBOSE1:component_installer.cc(53)] Skipping registration of Brave-unsupported component imefjhfbkmcmebodilednhmaccmincoa.
[10436:10454:0908/102846.861669:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave Wallet data files
[10436:10454:0908/102846.861914:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave HTTPS Everywhere Updater
[10436:10436:0908/102846.865711:VERBOSE1:profile_manager.cc(1290)] AddKeepAlive(Default, kBrowserWindow). keep_alives=[kWaitingForFirstBrowserWindow (1), kBrowserWindow (1)]
[10436:10436:0908/102846.865781:VERBOSE1:profile_manager.cc(1363)] ClearFirstBrowserWindowKeepAlive(Default). keep_alives=[kBrowserWindow (1)]
[10436:10454:0908/102846.866329:VERBOSE1:command_storage_backend.cc(591)] CommandStorageBackend::ReadLastSessionCommands, reading commands from: /home/schnucky/.config/BraveSoftware/Brave-Browser/Default/Sessions/Session_13338634770682826
[10436:10436:0908/102846.867021:WARNING:bluez_dbus_manager.cc(247)] Floss manager not present, cannot set Floss enable/disable.
[10436:10436:0908/102846.870969:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave Ad Block List Catalog
[10436:10436:0908/102846.871099:VERBOSE1:component_updater_service.cc(151)] CrxUpdateService starting up. First update attempt will take place in 60 s seconds. Next update attempt will take place in 18000 s seconds.
[10436:10436:0908/102846.871163:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.43 in /home/schnucky/.config/BraveSoftware/Brave-Browser/gkboaolpopklhgplhaaiboijnklogmbc/1.0.43
[10436:10436:0908/102846.871501:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave Ad Block First Party Filters
[10436:10436:0908/102846.871555:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.27 in /home/schnucky/.config/BraveSoftware/Brave-Browser/adcocjohghhfpidemphmcmlmhnfgikei/1.0.27
[10436:10436:0908/102846.871658:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave Ad Block Resources Library
[10436:10436:0908/102846.871720:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.62 in /home/schnucky/.config/BraveSoftware/Brave-Browser/mfddibmblmbccpadfndgakiopmmhebop/1.0.62
[10436:10436:0908/102846.872252:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave Ad Block Updater
[10436:10436:0908/102846.872303:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.984 in /home/schnucky/.config/BraveSoftware/Brave-Browser/iodkpdagapdfkphljnddpjlldadblomo/1.0.984
[10436:10436:0908/102846.876622:VERBOSE1:component_installer.cc(499)] FinishRegistration for NTP Background Images
[10436:10436:0908/102846.876701:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.11 in /home/schnucky/.config/BraveSoftware/Brave-Browser/aoojcmojmmcbpfgoecoadbdpnagfchel/1.0.11
[10436:10436:0908/102846.876782:VERBOSE1:component_installer.cc(499)] FinishRegistration for NTP Sponsored Images (DE)
[10436:10436:0908/102846.876800:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.1277 in /home/schnucky/.config/BraveSoftware/Brave-Browser/obbokncgfcbepeipkhpdepjjoncelefj/1.0.1277
[10436:10436:0908/102846.889918:VERBOSE1:component_installer.cc(499)] FinishRegistration for OnDeviceHeadSuggest
[10436:10436:0908/102846.890025:VERBOSE1:component_installer.cc(536)] Component ready, version 20230815.558564245.14 in /home/schnucky/.config/BraveSoftware/Brave-Browser/OnDeviceHeadSuggestModel/20230815.558564245.14
[10436:10436:0908/102846.890145:VERBOSE1:component_installer.cc(499)] FinishRegistration for Certificate Error Assistant
[10436:10436:0908/102846.890210:VERBOSE1:component_installer.cc(536)] Component ready, version 7 in /home/schnucky/.config/BraveSoftware/Brave-Browser/SSLErrorAssistant/7
[10436:10436:0908/102846.890290:VERBOSE1:component_installer.cc(499)] FinishRegistration for File Type Policies
[10550:1:0908/102846.889797:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: renderer.
[10436:10436:0908/102846.890333:VERBOSE1:component_installer.cc(536)] Component ready, version 62 in /home/schnucky/.config/BraveSoftware/Brave-Browser/FileTypePolicies/62
[10436:10436:0908/102846.890420:VERBOSE1:file_type_policies_component_installer.cc(90)] Component ready, version 62 in /home/schnucky/.config/BraveSoftware/Brave-Browser/FileTypePolicies/62
[10436:10436:0908/102846.890525:VERBOSE1:component_installer.cc(499)] FinishRegistration for CRLSet
[10436:10436:0908/102846.890577:VERBOSE1:component_installer.cc(536)] Component ready, version 8226 in /home/schnucky/.config/BraveSoftware/Brave-Browser/CertificateRevocation/8226
[10436:10436:0908/102846.890802:VERBOSE1:component_installer.cc(499)] FinishRegistration for MEI Preload
[10436:10436:0908/102846.890868:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.7.1652906823 in /usr/lib/brave-browser/MEIPreload
[10436:10436:0908/102846.890939:VERBOSE1:component_installer.cc(499)] FinishRegistration for PKI Metadata
[10436:10436:0908/102846.890971:VERBOSE1:component_installer.cc(536)] Component ready, version 700 in /home/schnucky/.config/BraveSoftware/Brave-Browser/PKIMetadata/700
[10436:10436:0908/102846.891042:VERBOSE1:component_installer.cc(499)] FinishRegistration for Safety Tips
[10436:10436:0908/102846.891072:VERBOSE1:component_installer.cc(536)] Component ready, version 2992 in /home/schnucky/.config/BraveSoftware/Brave-Browser/SafetyTips/2992
[10436:10436:0908/102846.891136:VERBOSE1:component_installer.cc(499)] FinishRegistration for Crowd Deny
[10436:10436:0908/102846.891170:VERBOSE1:component_installer.cc(536)] Component ready, version 2022.12.16.779 in /home/schnucky/.config/BraveSoftware/Brave-Browser/Crowd Deny/2022.12.16.779
[10436:10436:0908/102846.891248:VERBOSE1:component_installer.cc(499)] FinishRegistration for Hyphenation
[10436:10436:0908/102846.891279:VERBOSE1:component_installer.cc(536)] Component ready, version 118.0.5990.0 in /home/schnucky/.config/BraveSoftware/Brave-Browser/hyphen-data/118.0.5990.0
[10436:10436:0908/102846.891303:VERBOSE1:hyphenation_component_installer.cc(108)] Hyphenation Component ready, version 118.0.5990.0 in /home/schnucky/.config/BraveSoftware/Brave-Browser/hyphen-data/118.0.5990.0
[10436:10436:0908/102846.891365:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave Wallet data files
[10436:10436:0908/102846.891571:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.65 in /home/schnucky/.config/BraveSoftware/Brave-Browser/BraveWallet/1.0.65
[10551:1:0908/102846.891509:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: renderer.
[10436:10436:0908/102846.891659:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave HTTPS Everywhere Updater
[10436:10436:0908/102846.891685:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.163 in /home/schnucky/.config/BraveSoftware/Brave-Browser/oofiananboodjbbmdelgdommihjbkfag/1.0.163
[10436:10436:0908/102846.892549:VERBOSE1:profile_manager.cc(1290)] AddKeepAlive(Default, kBrowserWindow). keep_alives=[kBrowserWindow (2)]
[10436:10466:0908/102846.893309:VERBOSE1:command_storage_backend.cc(591)] CommandStorageBackend::ReadLastSessionCommands, reading commands from: /home/schnucky/.config/BraveSoftware/Brave-Browser/Default/Sessions/Tabs_13338634770834825
[10436:10456:0908/102846.904360:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
string "com.canonical.AppMenu.Registrar"
[10436:10436:0908/102846.968410:VERBOSE1:sidebar_service.cc(138)] Not migrating built-in items, pref is still default.
[10436:10436:0908/102846.988300:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0x268804a9db80: set chrome proxy config service to 0x2688018f6420
[10436:10436:0908/102846.989646:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[10436:10436:0908/102846.989721:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[10568:1:0908/102846.990163:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: renderer.
[10436:10436:0908/102846.991828:VERBOSE1:profile_manager.cc(1342)] RemoveKeepAlive(Default, kBrowserWindow). keep_alives=[kBrowserWindow (1)]
[10436:10466:0908/102846.997201:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave Local Data Updater
[10436:10580:0908/102847.028159:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
string "org.freedesktop.UPower"
[10436:10580:0908/102847.028359:VERBOSE1:bus.cc(687)] Filter function already exists: 1 with associated data: 0x2688013e4ee0
[10436:10580:0908/102847.028379:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[10436:10580:0908/102847.031593:VERBOSE1:bus.cc(709)] Requested to remove an unknown filter function: 1 with associated data: 0x268800fac620
[10436:10580:0908/102847.031617:VERBOSE1:bus.cc(709)] Requested to remove an unknown filter function: 1 with associated data: 0x268800fac540
[10436:10466:0908/102847.034758:VERBOSE1:component_installer.cc(428)] StartRegistration for Fanboy's Mobile Notifications
[10436:10466:0908/102847.036451:VERBOSE1:component_installer.cc(428)] StartRegistration for EasyList Cookie
[10436:10467:0908/102847.036492:VERBOSE1:component_installer.cc(428)] StartRegistration for EasyList Germany
[10436:10436:0908/102847.083010:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave Local Data Updater
[10436:10436:0908/102847.083047:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.441 in /home/schnucky/.config/BraveSoftware/Brave-Browser/afalakplffnnnlkncjhbmahjfjhmlkal/1.0.441
[10436:10436:0908/102847.085710:ERROR:network_service_instance_impl.cc(625)] Network service crashed, restarting service.
[10436:10436:0908/102847.103366:VERBOSE1:component_installer.cc(499)] FinishRegistration for Fanboy's Mobile Notifications
[10436:10436:0908/102847.104075:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.1026 in /home/schnucky/.config/BraveSoftware/Brave-Browser/bfpgedeaaibpoidldhjcknekahbikncb/1.0.1026
[10436:10436:0908/102847.104489:VERBOSE1:component_installer.cc(499)] FinishRegistration for EasyList Cookie
[10436:10436:0908/102847.104615:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.1111 in /home/schnucky/.config/BraveSoftware/Brave-Browser/cdbbhgbmjhfnhnmgeddbliobbofkgdhe/1.0.1111
[10436:10436:0908/102847.105058:VERBOSE1:component_installer.cc(499)] FinishRegistration for EasyList Germany
[10436:10436:0908/102847.105105:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.1126 in /home/schnucky/.config/BraveSoftware/Brave-Browser/lfmefmifdjlfneapckmpkinmlofjehbp/1.0.1126
[10436:10436:0908/102847.108028:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[10436:10436:0908/102847.108095:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[10589:10594:0908/102847.140386:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://variations.brave.com/seed?osname=linux&channel=stable&milestone=116
[10589:10594:0908/102847.147300:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10589:10594:0908/102847.148656:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10589:10594:0908/102847.149449:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10589:10594:0908/102847.149818:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10589:10594:0908/102847.154757:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10589:10594:0908/102847.155088:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10589:10594:0908/102847.155326:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10589:10594:0908/102847.155506:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10589:10594:0908/102847.155697:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10589:10594:0908/102847.155890:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10589:10594:0908/102847.184869:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10589:10594:0908/102847.185099:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10589:10594:0908/102847.185288:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10589:10594:0908/102847.185460:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[10436:10458:0908/102847.189793:VERBOSE1:content_verifier.cc(630)] OnFetchComplete eoceebklhjepohnakemchinmkdpbolgh success:1
[10436:10458:0908/102847.189896:VERBOSE1:content_verifier.cc(630)] OnFetchComplete bpkoijdaibakhfgahdfknbdcankhidoa success:1
[10436:10436:0908/102847.190131:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[10436:10458:0908/102847.196540:VERBOSE1:content_verifier.cc(630)] OnFetchComplete ldopphkgfhfchjcgfilekhkifaodmegm success:1
[10436:10458:0908/102847.196576:VERBOSE1:content_verifier.cc(630)] OnFetchComplete gajhkmnhhoadjcfchafgbekhgigglnkp success:1
[10436:10458:0908/102847.197956:VERBOSE1:content_verifier.cc(630)] OnFetchComplete jfnndgdcnclaikcihmjghocclbnnjlpb success:1
[10568:1:0908/102847.197780:VERBOSE1:script_context.cc(143)] Created context:
  extension id:           (none)
  frame:                  0x32cb001edbb0
  URL:
  context_type:           WEBUI
  effective extension id: (none)
  effective context type: WEBUI
[10568:1:0908/102847.201260:VERBOSE1:script_context.cc(143)] Created context:
  frame:                  (nil)
  URL:
  context_type:           UNSPECIFIED
  effective context type: UNSPECIFIED
[10568:1:0908/102847.202977:VERBOSE1:dispatcher.cc(455)] Num tracked contexts: 1
[10568:1:0908/102847.203240:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_MAIN
[10568:1:0908/102847.203517:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_MAIN
[10568:1:0908/102847.204314:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING
[10568:1:0908/102847.204403:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING
[10568:1:0908/102847.204468:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING_HOST
[10568:1:0908/102847.204536:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING_HOST
[10568:1:0908/102847.206216:VERBOSE1:script_context.cc(143)] Created context:
  URL:
  context_type:           WEBUI
[10568:1:0908/102847.206521:VERBOSE1:script_context.cc(143)] Created context:
  frame:                  (nil)
  URL:
[10568:1:0908/102847.207786:VERBOSE1:dispatcher.cc(455)] Num tracked contexts: 2
[10551:1:0908/102847.243952:VERBOSE1:script_context.cc(143)] Created context:
  extension id:           mnojpmjdmbbfmejpflffifhffcmidifd
  URL:
  context_type:           BLESSED_EXTENSION
  effective extension id: mnojpmjdmbbfmejpflffifhffcmidifd
  effective context type: BLESSED_EXTENSION
[10551:1:0908/102847.246377:VERBOSE1:script_context.cc(143)] Created context:
  frame:                  (nil)
  URL:
[10551:1:0908/102847.248985:VERBOSE1:dispatcher.cc(455)] Num tracked contexts: 1
[10551:1:0908/102847.249628:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_MAIN
[10551:1:0908/102847.251471:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_MAIN
[10551:1:0908/102847.251636:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING
[10551:1:0908/102847.251756:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING
[10551:1:0908/102847.251833:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING_HOST
[10551:1:0908/102847.251910:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING_HOST
[10551:1:0908/102847.254883:VERBOSE1:script_context.cc(143)] Created context:
  URL:
[10551:1:0908/102847.255735:VERBOSE1:script_context.cc(143)] Created context:
  frame:                  (nil)
  URL:
[10551:1:0908/102847.256192:VERBOSE1:dispatcher.cc(455)] Num tracked contexts: 2
[10436:10458:0908/102847.271148:VERBOSE1:content_verifier.cc(630)] OnFetchComplete eoceebklhjepohnakemchinmkdpbolgh success:1
[10436:10458:0908/102847.271390:VERBOSE1:content_verifier.cc(630)] OnFetchComplete galpopeppgfimpgpdbbkhemhcjgghmhl success:1
[10436:10458:0908/102847.271441:VERBOSE1:content_verifier.cc(630)] OnFetchComplete bpkoijdaibakhfgahdfknbdcankhidoa success:1
[10436:10458:0908/102847.273961:VERBOSE1:content_verifier.cc(630)] OnFetchComplete ficffphkednpmhjngkiljamkalhjmclj success:1
[10436:10458:0908/102847.274826:VERBOSE1:content_verifier.cc(630)] OnFetchComplete ldopphkgfhfchjcgfilekhkifaodmegm success:1
[10436:10458:0908/102847.280058:VERBOSE1:content_verifier.cc(630)] OnFetchComplete eoceebklhjepohnakemchinmkdpbolgh success:1
[10436:10458:0908/102847.281243:VERBOSE1:content_verifier.cc(630)] OnFetchComplete galpopeppgfimpgpdbbkhemhcjgghmhl success:1
[10436:10458:0908/102847.281303:VERBOSE1:content_verifier.cc(630)] OnFetchComplete bpkoijdaibakhfgahdfknbdcankhidoa success:1
[10436:10458:0908/102847.281935:VERBOSE1:content_verifier.cc(630)] OnFetchComplete gajhkmnhhoadjcfchafgbekhgigglnkp success:1
[10436:10458:0908/102847.281968:VERBOSE1:content_verifier.cc(630)] OnFetchComplete jfnndgdcnclaikcihmjghocclbnnjlpb success:1
[10436:10458:0908/102847.282752:VERBOSE1:content_verifier.cc(630)] OnFetchComplete ejoemlajhghppkakhhebjngamgbmepbj success:1
[10436:10458:0908/102847.286018:VERBOSE1:content_verifier.cc(630)] OnFetchComplete ficffphkednpmhjngkiljamkalhjmclj success:1
[10436:10458:0908/102847.286148:VERBOSE1:content_verifier.cc(630)] OnFetchComplete ldopphkgfhfchjcgfilekhkifaodmegm success:1
[10436:10458:0908/102847.286284:VERBOSE1:content_verifier.cc(630)] OnFetchComplete gajhkmnhhoadjcfchafgbekhgigglnkp success:1
[10436:10458:0908/102847.286655:VERBOSE1:content_verifier.cc(630)] OnFetchComplete jfnndgdcnclaikcihmjghocclbnnjlpb success:1
[10436:10458:0908/102847.286925:VERBOSE1:content_verifier.cc(630)] OnFetchComplete ejoemlajhghppkakhhebjngamgbmepbj success:1
[10436:10436:0908/102847.512773:WARNING:CONSOLE(1)] "Could not find style data in module named null", source: chrome://resources/polymer/v3_0/polymer/polymer_bundled.min.js (1)
[10436:10436:0908/102847.523836:WARNING:CONSOLE(1)] "Could not find style data in module named null", source: chrome://resources/polymer/v3_0/polymer/polymer_bundled.min.js (1)
[10436:10436:0908/102847.525886:WARNING:CONSOLE(1)] "Could not find style data in module named null", source: chrome://resources/polymer/v3_0/polymer/polymer_bundled.min.js (1)
[10436:10436:0908/102847.555048:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[10436:10436:0908/102847.555684:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[10436:10436:0908/102847.557673:ERROR:CONSOLE(2061)] "[Brave Settings Overrides] Appearance Page cannot find use default theme button template", source: chrome://settings/settings.js (2061)
[10436:10436:0908/102847.741658:VERBOSE1:CONSOLE(133)] "warning: fonts ready but string not set!", source: chrome://settings/shared.rollup.js (133)
[10568:1:0908/102847.822509:VERBOSE1:layout_shift_tracker.cc(363)] in "chrome://settings/getStarted", 0x32cb0012ea80:LayoutNGFlexibleBox DIV class='settings-box' moved from 621.375,362.828 1136.33x81.25 to 621.375,470.891 1136.33x81.25 (visible from 621,363 1137x81 to 621,471 1137x81)
[10568:1:0908/102847.822781:VERBOSE1:layout_shift_tracker.cc(363)] in "chrome://settings/getStarted", 0x32cb0012ed50:LayoutNGFlexibleBox DIV class='settings-box continuation' moved from 621.375,444.078 1136.33x321 to 621.375,552.141 1136.33x240.75 (visible from 621,444 1137x321 to 621,552 1137x241)
[10568:1:0908/102847.823234:VERBOSE1:layout_shift_tracker.cc(363)] in "chrome://settings/getStarted", 0x32cb0012f1e8:LayoutNGBlockFlow (relative positioned) DIV id='button' class='disc-wrapper' moved from 688.25,470.828 26.75x26.75 to 688.25,578.891 26.75x26.75 (visible from 688,471 27x27 to 688,579 27x27)
[10568:1:0908/102847.823333:VERBOSE1:layout_shift_tracker.cc(363)] in "chrome://settings/getStarted", 0x32cb0012f798:LayoutNGBlockFlow (relative positioned) DIV id='button' class='disc-wrapper' moved from 688.25,551.078 26.75x26.75 to 688.25,659.141 26.75x26.75 (visible from 688,551 27x27 to 688,659 27x27)
[10568:1:0908/102847.823412:VERBOSE1:layout_shift_tracker.cc(363)] in "chrome://settings/getStarted", 0x32cb0012fd48:LayoutNGBlockFlow (relative positioned) DIV id='button' class='disc-wrapper' moved from 688.25,631.328 26.75x26.75 to 688.25,739.391 26.75x26.75 (visible from 688,631 27x27 to 688,739 27x27)
[10568:1:0908/102847.823527:VERBOSE1:layout_shift_tracker.cc(555)] in "chrome://settings/getStarted", viewport was 30.0837% impacted with distance fraction 0.0562533 and subframe weighting factor 1
[10568:1:0908/102847.823577:VERBOSE1:layout_shift_tracker.cc(636)] in "chrome://settings/getStarted", layout shift of 0.0169231 excluded by recent input; cumulative score is 0
[10568:1:0908/102847.837978:VERBOSE1:layout_shift_tracker.cc(363)] in "chrome://settings/getStarted", 0x32cb00137ed0:LayoutNGBlockFlow DIV class='separator' moved from 1422.47,390.609 1x53.5 to 1393.06,390.609 1x53.5 (visible from 1422,391 1x53 to 1393,391 1x53)
[10568:1:0908/102847.838100:VERBOSE1:layout_shift_tracker.cc(363)] in "chrome://settings/getStarted", 0x32cb00137f98:LayoutNGFlexibleBox (relative positioned) CR-BUTTON moved from 1450.22,390.609 274.047x53.5 to 1420.81,390.609 303.453x53.5 (visible from 1450,391 274x53 to 1421,391 303x53)
[10568:1:0908/102847.838668:VERBOSE1:layout_shift_tracker.cc(555)] in "chrome://settings/getStarted", viewport was 0.991406% impacted with distance fraction 0.0153078 and subframe weighting factor 1
[10568:1:0908/102847.838978:VERBOSE1:layout_shift_tracker.cc(636)] in "chrome://settings/getStarted", layout shift of 0.000151762 excluded by recent input; cumulative score is 0
[10436:10436:0908/102848.945149:VERBOSE1:profile_manager.cc(1290)] AddKeepAlive(Default, kExtensionUpdater). keep_alives=[kBrowserWindow (1), kExtensionUpdater (1)]
[10436:10436:0908/102848.945298:VERBOSE1:profile_manager.cc(1342)] RemoveKeepAlive(Default, kExtensionUpdater). keep_alives=[kBrowserWindow (1)]
[10436:10453:0908/102848.972406:VERBOSE1:file_type_policies_component_installer.cc(45)] Reading Download File Types from file: /home/schnucky/.config/BraveSoftware/Brave-Browser/FileTypePolicies/62/download_file_types.pb
[10619:1:0908/102848.986161:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: utility.
[10620:1:0908/102848.989388:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: utility.
[10626:1:0908/102848.995574:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: utility.
[10632:1:0908/102848.999593:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: utility.
[10619:1:0908/102849.000291:VERBOSE1:statistics_recorder.cc(524)] Collections of all histograms
Histogram: ChildProcess.FieldTrials.CreateFromShmemSuccess recorded 1 samples, mean = 1.0 (flags = 0x1)
0  O        (0 = 0.0%)
1  -O        (1 = 100.0%) {0.0%}
2  O        (0 = 0.0%) {100.0%}
Histogram: HeapProfiling.InProcess.Enabled recorded 1 samples, mean = 0.0 (flags = 0x1)
0  -O        (1 = 100.0%)
1  ...
Histogram: HeapProfiling.InProcess.Enabled.Utility recorded 1 samples, mean = 0.0 (flags = 0x1)
0  -O        (1 = 100.0%)
1  ...
Histogram: Memory.PartitionAlloc.PartitionRoot.ExtrasSize recorded 1 samples, mean = 0.0 (flags = 0x1)
0  -O        (1 = 100.0%)
1  ...
Histogram: Mojo.Channel.WriteMessageLatency recorded 21 samples, mean = 0.0 (flags = 0x1)
0  ---------------------O                                                    (21 = 100.0%)
1  ...
Histogram: UMA.ChildProcess.Ping.SharedMemorySetUp recorded 1 samples, mean = 1.0 (flags = 0x41)
0  O        (0 = 0.0%)
2  ...
Histogram: UMA.LocalHistogram recorded 1 samples, mean = 1.0 (flags = 0x40)
0  O        (0 = 0.0%)
Histogram: UMA.PersistentAllocator.UtilityMetrics.Errors recorded 0 samples (flags = 0x41)
Histogram: UMA.PersistentAllocator.UtilityMetrics.UsedPct recorded 0 samples (flags = 0x41)
0 ...
Histogram: V8.Initializer.OpenV8File.Result recorded 1 samples, mean = 0.0 (flags = 0x1)
0  -O        (1 = 100.0%)
1  ...
Histogram: Variations.Limits.VariationKeySize.Default recorded 1 samples, mean = 0.0 (flags = 0x1)
0  -O        (1 = 100.0%)
1  ...
[10620:1:0908/102849.002846:VERBOSE1:statistics_recorder.cc(524)] Collections of all histograms
0  O        (0 = 0.0%)
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
1  ...
Histogram: Mojo.Channel.WriteReceiveMessageProcessType recorded 1 samples, mean = 11.0 (flags = 0x41)
0   ...
11  -O        (1 = 100.0%) {0.0%}
12  ...
0  O        (0 = 0.0%)
2  ...
0  O        (0 = 0.0%)
0 ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
[10636:1:0908/102849.003970:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: utility.
[10638:1:0908/102849.008408:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: utility.
[10626:1:0908/102849.013118:VERBOSE1:statistics_recorder.cc(524)] Collections of all histograms
0  O        (0 = 0.0%)
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
Histogram: Mojo.Channel.WriteMessageLatency recorded 20 samples, mean = 0.1 (flags = 0x1)
0  -------------------O                                                      (19 = 95.0%)
1  -O        (1 = 5.0%) {95.0%}
2  ...
Histogram: Mojo.Channel.WriteQueuePendingMessages recorded 1 samples, mean = 4.0 (flags = 0x41)
0  ...
4  -O        (1 = 100.0%) {0.0%}
5  ...
0  O        (0 = 0.0%)
2  ...
0  O        (0 = 0.0%)
0 ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
[10645:1:0908/102849.011090:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: utility.
[10645:1:0908/102849.030645:VERBOSE1:statistics_recorder.cc(524)] Collections of all histograms
0  O        (0 = 0.0%)
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
1  ...
0  O        (0 = 0.0%)
2  ...
0  O        (0 = 0.0%)
0 ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
[10655:1:0908/102849.034133:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: utility.
[10638:1:0908/102849.039259:VERBOSE1:statistics_recorder.cc(524)] Collections of all histograms
0  O        (0 = 0.0%)
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
Histogram: Mojo.Channel.WriteMessageLatency recorded 20 samples, mean = 0.0 (flags = 0x1)
0  --------------------O                                                     (20 = 100.0%)
1  ...
0  O        (0 = 0.0%)
2  ...
0  O        (0 = 0.0%)
0 ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
[10632:1:0908/102849.075050:VERBOSE1:statistics_recorder.cc(524)] Collections of all histograms
0  O        (0 = 0.0%)
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
1  ...
Histogram: Mojo.Channel.WriteQueuePendingMessages recorded 4 samples, mean = 1.0 (flags = 0x41)
0  O        (0 = 0.0%)
1  ----O        (4 = 100.0%) {0.0%}
2  ...
0  O        (0 = 0.0%)
2  ...
0  O        (0 = 0.0%)
0 ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
[10655:1:0908/102849.075300:VERBOSE1:statistics_recorder.cc(524)] Collections of all histograms
0  O        (0 = 0.0%)
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
Histogram: Mojo.Channel.WriteMessageLatency recorded 23 samples, mean = 0.0 (flags = 0x1)
0  -----------------------O                                                  (23 = 100.0%)
1  ...
0  O        (0 = 0.0%)
2  ...
0  O        (0 = 0.0%)
0 ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
[10436:10436:0908/102849.085895:VERBOSE1:device_event_log_impl.cc(224)] [10:28:49.085] USB: USER: usb_service_linux.cc:294 USB device added: path=/dev/bus/usb/001/006 vendor=6940 "Corsair", product=2639 "CORSAIR HS70 Pro Wireless Gaming Headset", serial="", guid=2cb10bc0-27eb-4768-bd56-f04a26d3dd85
[10436:10436:0908/102849.087009:VERBOSE1:device_event_log_impl.cc(224)] [10:28:49.087] USB: USER: usb_service_linux.cc:294 USB device added: path=/dev/bus/usb/001/007 vendor=1133 "Logitech", product=50475 "USB Receiver", serial="", guid=ab9fee54-49b6-47d2-913c-5ebf69a377db
[10436:10436:0908/102849.088420:VERBOSE1:device_event_log_impl.cc(224)] [10:28:49.088] USB: USER: usb_service_linux.cc:294 USB device added: path=/dev/bus/usb/001/008 vendor=1133 "Logitech", product=50504 "USB Receiver", serial="", guid=1ea67e76-ee7e-4ad2-9564-2cab2326b385
[10436:10436:0908/102849.091364:VERBOSE1:device_event_log_impl.cc(224)] [10:28:49.091] USB: USER: usb_service_linux.cc:294 USB device added: path=/dev/bus/usb/001/005 vendor=1054 "Creative Technology Ltd", product=12511 "SB X-Fi Surround 5.1 Pro", serial="000000d7", guid=dd825113-d92a-4e62-b1ca-86bd0dd9a14d
[10436:10453:0908/102849.129223:VERBOSE1:wallet_data_files_installer.cc(103)] Can't parse dapp lists.
[10636:1:0908/102849.133456:VERBOSE1:statistics_recorder.cc(524)] Collections of all histograms
0  O        (0 = 0.0%)
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
1  O        (0 = 0.0%) {95.0%}
2  -O        (1 = 5.0%) {95.0%}
3  ...
Histogram: Mojo.Channel.WriteQueuePendingMessages recorded 6 samples, mean = 1.0 (flags = 0x41)
0  O        (0 = 0.0%)
1  ------O        (6 = 100.0%) {0.0%}
2  ...
0  O        (0 = 0.0%)
2  ...
0  O        (0 = 0.0%)
0 ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
[10436:10436:0908/102854.732964:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10436:10436:0908/102854.734063:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10436:10436:0908/102854.735182:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10436:10436:0908/102854.735288:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
[10436:10436:0908/102854.736460:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10436:10436:0908/102854.736798:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
[10436:10436:0908/102854.738017:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10589:10594:0908/102854.738280:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://componentupdater.brave.com/service/update2/json
[10436:10436:0908/102854.738497:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
[10436:10436:0908/102854.738972:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
[10436:10436:0908/102854.739302:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
[10436:10436:0908/102854.780600:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10436:10436:0908/102854.781327:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
[10436:10436:0908/102854.782455:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10436:10436:0908/102854.783344:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
[10436:10436:0908/102854.783962:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10436:10436:0908/102854.785241:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10436:10436:0908/102854.785741:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
[10436:10436:0908/102854.786610:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10436:10436:0908/102854.787734:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10436:10436:0908/102854.787843:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
[10589:10594:0908/102854.788506:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://componentupdater.brave.com/service/update2/json
[10436:10436:0908/102854.788856:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10436:10436:0908/102854.789465:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
[10436:10436:0908/102854.790172:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
[10436:10436:0908/102854.790387:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
[10436:10436:0908/102857.449775:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10436:10436:0908/102857.450481:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
[10436:10436:0908/102857.456873:VERBOSE1:request_sender.cc(181)] Request completed from url: https://go-updater.brave.com/extensions
[10436:10436:0908/102857.457614:VERBOSE1:component_updater_service.cc(449)] Update completed with error 0
You’re welcome! But don’t thank me just yet, since I can’t help anymore. I don’t use Chrome or Chromium or something Chromium-based, so I wouldn’t know.
So my help is officially over. I don’t know anything more. Sorry!
:sob:
Thx anyway, maybe someone else has some more insight.
Couldn’t find anything out of the ordinary myself in the log.
Looks like
messes up your chromium launch. Takes 15s and fails.
You could try this:
chromium --disable-gpu --disable-software-rasterizer
If that doesn’t work then try this:
rm -r ~/.config/chromium
rm -r ~/.cache/chromium
▶ chromium --disable-gpu --disable-software-rasterizer
[33747:33747:0908/170832.428493:ERROR:chrome_browser_cloud_management_controller.cc(163)] Cloud management controller initialization aborted as CBCM is not enabled.
[33747:33747:0908/170832.515248:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
[33747:33747:0908/170832.687876:ERROR:network_service_instance_impl.cc(625)] Network service crashed, restarting service.
/etc
▶ brave --disable-gpu --disable-software-rasterizer
[33936:33936:0908/170919.658555:ERROR:chrome_browser_cloud_management_controller.cc(163)] Cloud management controller initialization aborted as CBCM is not enabled.
[33936:33936:0908/170919.876302:ERROR:network_service_instance_impl.cc(625)] Network service crashed, restarting service.
[33936:33936:0908/170920.318317:ERROR:CONSOLE(2061)] "[Brave Settings Overrides] Appearance Page cannot find use default theme button template", source: chrome://settings/settings.js (2061)
The next one is after I deleted
▶ time brave --disable-gpu --disable-software-rasterizer
[34631:34631:0908/171234.458238:ERROR:chrome_browser_cloud_management_controller.cc(163)] Cloud management controller initialization aborted as CBCM is not enabled.
[34631:34631:0908/171234.646979:ERROR:star_randomness_meta.cc(266)] StarRandomnessMeta: no response body for randomness server info request, net error: ERR_FAILED
[34631:34631:0908/171234.648751:ERROR:network_service_instance_impl.cc(625)] Network service crashed, restarting service.
brave --disable-gpu --disable-software-rasterizer  0,97s user 0,61s system 5% cpu 27,347 total
▶ rm -r .cache/BraveSoftware
▶ rm -r .cache/chromium
▶ time chromium --disable-gpu --disable-software-rasterizer
[34896:34896:0908/171433.171352:ERROR:chrome_browser_cloud_management_controller.cc(163)] Cloud management controller initialization aborted as CBCM is not enabled.
[34896:34896:0908/171433.213856:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
[34896:34896:0908/171433.227772:ERROR:network_service_instance_impl.cc(625)] Network service crashed, restarting service.
chromium --disable-gpu --disable-software-rasterizer  0,60s user 0,63s system 4% cpu 28,754 total
and chromium startup with verbose logging
▶ time chromium --disable-gpu --disable-software-rasterizer --enable-logging=stderr --v=1
[35216:35216:0908/171636.814668:WARNING:chrome_main_delegate.cc(596)] This is Chrome version 116.0.5845.179 (not a warning)
[35216:35216:0908/171636.814760:VERBOSE1:chrome_crash_reporter_client.cc(190)] GetCollectStatsConsent(): is_official_chrome_build is false so returning false
[35216:35216:0908/171636.825010:VERBOSE1:chrome_crash_reporter_client.cc(190)] GetCollectStatsConsent(): is_official_chrome_build is false so returning false
[1:1:0908/171636.889288:VERBOSE1:cdm_registration.cc(208)] Widevine enabled but no library found
[1:1:0908/171636.889369:INFO:cpu_info.cc(53)] Available number of cores: 4
[1:1:0908/171636.889585:VERBOSE1:zygote_main_linux.cc(201)] ZygoteMain: initializing 0 fork delegates
[35224:35224:0908/171636.893367:VERBOSE1:cdm_registration.cc(208)] Widevine enabled but no library found
[35224:35224:0908/171636.893507:INFO:cpu_info.cc(53)] Available number of cores: 4
[35224:35224:0908/171636.893751:VERBOSE1:zygote_main_linux.cc(201)] ZygoteMain: initializing 0 fork delegates
[35216:35216:0908/171636.895017:WARNING:chrome_browser_cloud_management_controller.cc(88)] Could not create policy manager as CBCM is not enabled.
[35216:35216:0908/171636.898402:VERBOSE1:variations_field_trial_creator.cc(87)] VariationsSeedUsage:2
[35216:35216:0908/171636.898515:VERBOSE1:variations_field_trial_creator.cc(336)] VariationsSetupComplete
[35216:35235:0908/171636.902126:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[35216:35216:0908/171637.028487:VERBOSE1:webrtc_event_log_manager.cc(97)] WebRTC remote-bound event logging enabled.
[35216:35216:0908/171637.028646:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0xf8800249a00: set chrome proxy config service to 0xf8800095860
[35216:35216:0908/171637.033151:VERBOSE1:cdm_registration.cc(208)] Widevine enabled but no library found
[35216:35235:0908/171637.034620:VERBOSE1:select_file_dialog_linux_portal.cc(280)] File chooser portal available: no
[35216:35235:0908/171637.036106:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
string "org.freedesktop.portal.Desktop"
[35216:35236:0908/171637.036370:VERBOSE1:media_stream_manager.cc(1450)] MSM::InitializeMaybeAsync([this=0xf8800159d80])
[35216:35236:0908/171637.036399:VERBOSE1:media_stream_manager.cc(1450)] MDM::MediaDevicesManager()
[35216:35236:0908/171637.036434:VERBOSE1:media_stream_manager.cc(1450)] MSM::MediaStreamManager([this=0xf8800159d80]))
[35216:35216:0908/171637.038373:VERBOSE1:key_storage_util_linux.cc(50)] Password storage detected desktop environment: XFCE
[35216:35216:0908/171637.038415:VERBOSE1:key_storage_linux.cc(118)] Selected backend for OSCrypt: GNOME_LIBSECRET
[35249:35249:0908/171637.045560:WARNING:vaapi_wrapper.cc(806)] VAAPI video acceleration not available for disabled
[35249:35249:0908/171637.046250:WARNING:sandbox_linux.cc(393)] InitializeSandbox() called with multiple threads in process gpu-process.
[35251:35251:0908/171652.105120:INFO:child_thread_impl.cc(927)] ChildThreadImpl::EnsureConnected()
[35216:35216:0908/171702.073836:WARNING:key_storage_linux.cc(168)] OSCrypt tried Libsecret but couldn't initialise.
[35216:35216:0908/171702.073943:VERBOSE1:key_storage_linux.cc(137)] OSCrypt did not initialize a backend.
[35216:35216:0908/171702.074672:ERROR:chrome_browser_cloud_management_controller.cc(163)] Cloud management controller initialization aborted as CBCM is not enabled.
[35216:35216:0908/171702.080660:WARNING:account_consistency_mode_manager.cc(73)] Desktop Identity Consistency cannot be enabled as no OAuth client ID and client secret have been configured.
[35216:35216:0908/171702.080685:VERBOSE1:account_consistency_mode_manager.cc(207)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[35216:35216:0908/171702.083969:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0xf880024a300: set chrome proxy config service to 0xf8800f40920
[35216:35216:0908/171702.085686:VERBOSE1:device_event_log_impl.cc(224)] [17:17:02.085] Bluetooth: EVENT: bluetooth_api.cc:82 BluetoothAPI: 0xf88005d4000
[35216:35216:0908/171702.085912:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0xf880024b200: set chrome proxy config service to 0xf8800f44540
[35216:35216:0908/171702.085980:VERBOSE1:account_consistency_mode_manager.cc(207)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[35216:35216:0908/171702.086162:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(217)] MutablePO2TS::MutablePO2TS
[35216:35216:0908/171702.086264:VERBOSE1:gaia_auth_util.cc(48)] Canonicalized @gmail.com to @gmail.com
[35216:35216:0908/171702.086272:VERBOSE1:gaia_auth_util.cc(48)] Canonicalized @gmail.com to @gmail.com
[35216:35216:0908/171702.087177:VERBOSE1:gaia_auth_util.cc(48)] Canonicalized @gmail.com to @gmail.com
[35216:35216:0908/171702.087206:VERBOSE1:gaia_auth_util.cc(48)] Canonicalized @gmail.com to @gmail.com
[35216:35216:0908/171702.087331:VERBOSE1:account_consistency_mode_manager.cc(207)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[35216:35216:0908/171702.087364:VERBOSE1:account_consistency_mode_manager.cc(207)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[35216:35216:0908/171702.087388:VERBOSE1:account_consistency_mode_manager.cc(207)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[35216:35216:0908/171702.087410:VERBOSE1:account_reconcilor.cc(167)] AccountReconcilor::AccountReconcilor
[35216:35216:0908/171702.087427:VERBOSE1:account_reconcilor.cc(197)] AccountReconcilor::Initialize
[35216:35235:0908/171702.088915:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[35216:35235:0908/171702.089189:VERBOSE1:bus.cc(687)] Filter function already exists: 1 with associated data: 0xf880055be80
[35216:35235:0908/171702.089299:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[35216:35235:0908/171702.089444:VERBOSE1:bus.cc(687)] Filter function already exists: 1 with associated data: 0xf880055be80
[35216:35235:0908/171702.089493:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[35216:35216:0908/171702.090539:VERBOSE1:bluetooth_low_energy_event_router.cc(276)] Initializing BluetoothLowEnergyEventRouter.
[35216:35216:0908/171702.092064:VERBOSE1:service_discovery_device_lister.cc(36)] DeviceListerStart: service_type: _googlecast._tcp.local
[35216:35216:0908/171702.092084:VERBOSE1:service_discovery_device_lister.cc(42)] DiscoverNewDevices: service_type: _googlecast._tcp.local
[35216:35216:0908/171702.093346:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Web Store
[35216:35216:0908/171702.093661:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Chromium PDF Viewer
[35216:35216:0908/171702.093870:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Google Hangouts
[35216:35216:0908/171702.094466:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[35216:35216:0908/171702.094629:VERBOSE1:profile_manager.cc(1922)] ForceSigninCheck: 0, 0, 1
[35216:35216:0908/171702.094980:VERBOSE1:on_device_head_suggest_component_installer.cc(58)] On Device Head Component will fetch model for locale: DE500000
[35216:35287:0908/171702.094992:VERBOSE1:component_installer.cc(428)] StartRegistration for Widevine Content Decryption Module
[35216:35290:0908/171702.095035:VERBOSE1:component_installer.cc(428)] StartRegistration for OnDeviceHeadSuggest
[35216:35291:0908/171702.094990:VERBOSE1:component_installer.cc(428)] StartRegistration for Subresource Filter Rules
[35216:35216:0908/171702.095137:VERBOSE1:first_party_sets_component_installer.cc(214)] Registering First-Party Sets component.
[35216:35216:0908/171702.095214:VERBOSE1:file_type_policies_component_installer.cc(131)] Registering File Type Policies component.
[35216:35292:0908/171702.095245:VERBOSE1:component_installer.cc(428)] StartRegistration for Optimization Hints
[35216:35216:0908/171702.095353:VERBOSE1:hyphenation_component_installer.cc(150)] Registering Hyphenation component.
[35216:35287:0908/171702.098553:VERBOSE1:component_installer.cc(428)] StartRegistration for Certificate Error Assistant
[35216:35290:0908/171702.098621:VERBOSE1:component_installer.cc(428)] StartRegistration for File Type Policies
[35216:35287:0908/171702.098651:VERBOSE1:component_installer.cc(428)] StartRegistration for CRLSet
[35216:35292:0908/171702.099046:VERBOSE1:component_installer.cc(428)] StartRegistration for Hyphenation
[35216:35287:0908/171702.099119:VERBOSE1:component_installer.cc(428)] StartRegistration for Zxcvbn Data Dictionaries
[35216:35288:0908/171702.098693:VERBOSE1:component_installer.cc(428)] StartRegistration for Origin Trials
[35284:1:0908/171702.089800:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: utility.
[35216:35285:0908/171702.098848:VERBOSE1:component_installer.cc(428)] StartRegistration for MEI Preload
[35216:35290:0908/171702.099285:VERBOSE1:component_installer.cc(428)] StartRegistration for Autofill States Data
[35216:35285:0908/171702.099334:VERBOSE1:component_installer.cc(428)] StartRegistration for Client Side Phishing Detection
[35216:35282:0908/171702.098894:VERBOSE1:component_installer.cc(428)] StartRegistration for PKI Metadata
[35216:35286:0908/171702.098928:VERBOSE1:component_installer.cc(428)] StartRegistration for Safety Tips
[35216:35245:0908/171702.098966:VERBOSE1:component_installer.cc(428)] StartRegistration for Crowd Deny
[35216:35216:0908/171702.099234:VERBOSE1:cached_result_provider.cc(80)] CachedResultProvider loaded prefs with results from previous session: PredictionResult: timestamp: 0 for segmentation key search_user
[35216:35216:0908/171702.099568:VERBOSE1:cached_result_provider.cc(80)] CachedResultProvider loaded prefs with results from previous session: PredictionResult: timestamp: 0 for segmentation key password_manager_user
[35216:35216:0908/171702.102288:VERBOSE1:profile_manager.cc(1290)] AddKeepAlive(Default, kBrowserWindow). keep_alives=[kWaitingForFirstBrowserWindow (1), kBrowserWindow (1)]
[35216:35216:0908/171702.102642:VERBOSE1:profile_manager.cc(1363)] ClearFirstBrowserWindowKeepAlive(Default). keep_alives=[kBrowserWindow (1)]
[35216:35235:0908/171702.106869:VERBOSE1:token_service_table.cc(148)] Loaded tokens: result = 3 ; number of tokens loaded = 0
[35216:35235:0908/171702.114497:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[35299:1:0908/171702.176052:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: renderer.
[35300:1:0908/171702.179285:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: renderer.
[35216:35216:0908/171702.186524:WARNING:bluez_dbus_manager.cc(247)] Floss manager not present, cannot set Floss enable/disable.
[35216:35216:0908/171702.190018:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
[35216:35216:0908/171702.197650:VERBOSE1:component_installer.cc(499)] FinishRegistration for Widevine Content Decryption Module
[35216:35216:0908/171702.197736:VERBOSE1:component_updater_service.cc(151)] CrxUpdateService starting up. First update attempt will take place in 60 s seconds. Next update attempt will take place in 18000 s seconds.
[35216:35216:0908/171702.197846:VERBOSE1:component_installer.cc(499)] FinishRegistration for OnDeviceHeadSuggest
[35216:35216:0908/171702.197911:VERBOSE1:component_installer.cc(499)] FinishRegistration for Certificate Error Assistant
[35216:35216:0908/171702.198127:VERBOSE1:component_installer.cc(499)] FinishRegistration for Optimization Hints
[35216:35216:0908/171702.198202:VERBOSE1:component_installer.cc(499)] FinishRegistration for CRLSet
[35216:35216:0908/171702.198344:VERBOSE1:component_installer.cc(499)] FinishRegistration for Subresource Filter Rules
[35216:35216:0908/171702.198545:VERBOSE1:component_installer.cc(499)] FinishRegistration for File Type Policies
[35216:35216:0908/171702.198644:VERBOSE1:component_installer.cc(499)] FinishRegistration for MEI Preload
[35216:35216:0908/171702.198713:VERBOSE1:component_installer.cc(499)] FinishRegistration for Autofill States Data
[35216:35216:0908/171702.198791:VERBOSE1:component_installer.cc(499)] FinishRegistration for Client Side Phishing Detection
[35216:35216:0908/171702.198855:VERBOSE1:component_installer.cc(499)] FinishRegistration for Crowd Deny
[35216:35216:0908/171702.199364:VERBOSE1:component_installer.cc(499)] FinishRegistration for Origin Trials
[35216:35216:0908/171702.199454:VERBOSE1:component_installer.cc(499)] FinishRegistration for PKI Metadata
[35216:35216:0908/171702.199528:VERBOSE1:component_installer.cc(499)] FinishRegistration for Safety Tips
[35216:35216:0908/171702.199595:VERBOSE1:component_installer.cc(499)] FinishRegistration for Zxcvbn Data Dictionaries
[35216:35216:0908/171702.199794:VERBOSE1:component_installer.cc(499)] FinishRegistration for Hyphenation
[35216:35216:0908/171702.201554:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(368)] MutablePO2TS::OnWebDataServiceRequestDone. Result type: 5
[35216:35216:0908/171702.201674:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(424)] MutablePO2TS::LoadAllCredentialsIntoMemory; 0 redential(s).
[35216:35216:0908/171702.201784:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[35216:35216:0908/171702.202101:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[35216:35322:0908/171702.231588:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
interface: org.freedesktop.DBus
member: GetNameOwner
signature: s
[35216:35322:0908/171702.232235:VERBOSE1:bus.cc(687)] Filter function already exists: 1 with associated data: 0xf8801885f40
[35216:35322:0908/171702.232259:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[35216:35322:0908/171702.234754:VERBOSE1:bus.cc(709)] Requested to remove an unknown filter function: 1 with associated data: 0xf8801885e00
[35216:35322:0908/171702.234777:VERBOSE1:bus.cc(709)] Requested to remove an unknown filter function: 1 with associated data: 0xf8801885cc0
[35216:35216:0908/171702.254035:ERROR:network_service_instance_impl.cc(625)] Network service crashed, restarting service.
[35216:35216:0908/171702.273965:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[35216:35216:0908/171702.273990:VERBOSE1:account_consistency_mode_manager.cc(207)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[35216:35216:0908/171702.324742:VERBOSE1:gaia_cookie_manager_service.cc(1078)] GaiaCookieManagerService::ListAccounts
[35323:35328:0908/171702.327040:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://manjaro.org/
[35323:35328:0908/171702.327663:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://accounts.google.com/ListAccounts?gpsia=1&source=ChromiumBrowser&json=standard
[35216:35216:0908/171702.670374:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[35216:35216:0908/171702.670592:VERBOSE1:back_forward_cache_impl.cc(693)] BackForwardCacheImpl::GetFutureBackForwardCacheEligibilityPotential:  : No: HTTP status is not OK, scheme is not HTTP or HTTPS, main RenderFrameHost doesn't have response headers set, probably due not having successfully committed a navigation.
[35323:35328:0908/171702.678741:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://cdnjs.cloudflare.com/ajax/libs/font-awesome/6.1.1/css/all.min.css
[35216:35216:0908/171702.679171:VERBOSE1:back_forward_cache_impl.cc(693)] BackForwardCacheImpl::GetCurrentBackForwardCacheEligibility:  : No: HTTP status is not OK, scheme is not HTTP or HTTPS, main RenderFrameHost doesn't have response headers set, probably due not having successfully committed a navigation.
[35323:35328:0908/171702.680385:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://manjaro.org/static/css/styles.9b54975c8755.css
[35300:1:0908/171702.688427:VERBOSE1:script_context.cc(143)] Created context:
  frame:                  0x1fc9001f5040
  URL:
  context_type:           WEB_PAGE
  effective context type: WEB_PAGE
[35300:1:0908/171702.689789:VERBOSE1:script_context.cc(143)] Created context:
  frame:                  (nil)
  URL:
[35300:1:0908/171702.690013:VERBOSE1:dispatcher.cc(455)] Num tracked contexts: 1
[35323:35328:0908/171702.701312:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://unpkg.com/@popperjs/core@2
[35216:35216:0908/171704.419972:VERBOSE1:profile_manager.cc(1290)] AddKeepAlive(Default, kSessionDataDeleter). keep_alives=[kBrowserWindow (1), kSessionDataDeleter (1)]
[35216:35235:0908/171704.420194:VERBOSE1:bus.cc(709)] Requested to remove an unknown filter function: 1 with associated data: 0xf880055abc0
[35216:35216:0908/171704.423784:VERBOSE1:account_reconcilor.cc(231)] AccountReconcilor::Shutdown
[35216:35216:0908/171704.423818:VERBOSE1:account_reconcilor.cc(663)] AccountReconcilor::AbortReconcile: try again later
[35216:35216:0908/171704.423846:VERBOSE1:account_reconcilor.cc(772)] AccountReconcilor::CalculateIfMultiloginReconcileIsDone: Error was
[35216:35216:0908/171704.423868:VERBOSE1:account_reconcilor.cc(274)] AccountReconcilor::UnregisterWithIdentityManager
[35216:35216:0908/171704.423885:VERBOSE1:account_reconcilor.cc(253)] AccountReconcilor::UnregisterWithContentSettings
[35216:35216:0908/171704.424124:VERBOSE1:gaia_cookie_manager_service.cc(719)] GaiaCookieManagerService::CancelAll
[35216:35216:0908/171704.424300:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(683)] MutablePO2TS::Shutdown
[35216:35216:0908/171704.424346:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(227)] MutablePO2TS::~MutablePO2TS
[35216:35216:0908/171704.424555:VERBOSE1:device_event_log_impl.cc(224)] [17:17:04.424] Bluetooth: EVENT: bluetooth_api.cc:109 BluetoothAPI: Shutdown
[35216:35216:0908/171704.425750:VERBOSE1:account_reconcilor.cc(174)] AccountReconcilor::~AccountReconcilor
[35216:35216:0908/171704.426108:VERBOSE1:device_event_log_impl.cc(224)] [17:17:04.426] Bluetooth: EVENT: bluetooth_api.cc:95 ~BluetoothAPI: 0xf88005d4000
[35323:35323:0908/171704.431633:VERBOSE1:statistics_recorder.cc(524)] Collections of all histograms
Histogram: API.StorageAccess.AllowedRequests2 recorded 10 samples, mean = 1.0 (flags = 0x41)
0  O        (0 = 0.0%)
1  ----------O                                                               (10 = 100.0%) {0.0%}
2  ...
0  O        (0 = 0.0%)
chromium --disable-gpu --disable-software-rasterizer --enable-logging=stderr   0,59s user 0,46s system 3% cpu 27,722 total
The same problem persists.
I see that you deleted cache. But did you delete config directory?
And you don’t have to use --disable-gpu --disable-software-rasterizer flags after removing the mentioned dirs.
I deleted them both before, but for good measure I did it again.
▶ cd .cache
~/.cache
▶ rm -r chromium
~/.cache
▶ cd .config
~/.config
▶ rm -r chromium
~/.config
▶ rm -r BraveSoftware
~/.config
▶ time chromium --enable-logging=stderr --v=1
[38979:38979:0908/183303.970005:WARNING:chrome_main_delegate.cc(596)] This is Chrome version 116.0.5845.179 (not a warning)
[38979:38979:0908/183303.970137:VERBOSE1:chrome_crash_reporter_client.cc(190)] GetCollectStatsConsent(): is_official_chrome_build is false so returning false
[38979:38979:0908/183303.978068:VERBOSE1:chrome_crash_reporter_client.cc(190)] GetCollectStatsConsent(): is_official_chrome_build is false so returning false
[38987:38987:0908/183304.036427:VERBOSE1:cdm_registration.cc(208)] Widevine enabled but no library found
[38987:38987:0908/183304.036531:INFO:cpu_info.cc(53)] Available number of cores: 4
[38987:38987:0908/183304.036748:VERBOSE1:zygote_main_linux.cc(201)] ZygoteMain: initializing 0 fork delegates
[1:1:0908/183304.050017:VERBOSE1:cdm_registration.cc(208)] Widevine enabled but no library found
[1:1:0908/183304.050110:INFO:cpu_info.cc(53)] Available number of cores: 4
[1:1:0908/183304.050327:VERBOSE1:zygote_main_linux.cc(201)] ZygoteMain: initializing 0 fork delegates
[38979:38979:0908/183304.054356:WARNING:chrome_browser_cloud_management_controller.cc(88)] Could not create policy manager as CBCM is not enabled.
[38979:38979:0908/183304.056241:VERBOSE1:variations_field_trial_creator.cc(87)] VariationsSeedUsage:2
[38979:38979:0908/183304.056327:VERBOSE1:variations_field_trial_creator.cc(336)] VariationsSetupComplete
[38979:38979:0908/183304.162658:VERBOSE1:webrtc_event_log_manager.cc(97)] WebRTC remote-bound event logging enabled.
[38979:38979:0908/183304.162896:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0x116000249a00: set chrome proxy config service to 0x116000099ba0
[38979:38979:0908/183304.166019:VERBOSE1:cdm_registration.cc(208)] Widevine enabled but no library found
[38979:38998:0908/183304.168815:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
string "org.freedesktop.login1"
[38979:38998:0908/183304.172254:VERBOSE1:select_file_dialog_linux_portal.cc(280)] File chooser portal available: no
[38979:38999:0908/183304.172419:VERBOSE1:media_stream_manager.cc(1450)] MSM::InitializeMaybeAsync([this=0x11600004e300])
[38979:38999:0908/183304.172450:VERBOSE1:media_stream_manager.cc(1450)] MDM::MediaDevicesManager()
[38979:38999:0908/183304.172461:VERBOSE1:media_stream_manager.cc(1450)] MSM::MediaStreamManager([this=0x11600004e300]))
[38979:38979:0908/183304.173510:VERBOSE1:key_storage_util_linux.cc(50)] Password storage detected desktop environment: XFCE
[38979:38979:0908/183304.173585:VERBOSE1:key_storage_linux.cc(118)] Selected backend for OSCrypt: GNOME_LIBSECRET
[38979:38998:0908/183304.174002:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[39014:39014:0908/183304.335888:WARNING:sandbox_linux.cc(393)] InitializeSandbox() called with multiple threads in process gpu-process.
[39016:39016:0908/183319.257065:INFO:child_thread_impl.cc(927)] ChildThreadImpl::EnsureConnected()
[38979:38979:0908/183329.228372:WARNING:key_storage_linux.cc(168)] OSCrypt tried Libsecret but couldn't initialise.
[38979:38979:0908/183329.228453:VERBOSE1:key_storage_linux.cc(137)] OSCrypt did not initialize a backend.
[38979:38979:0908/183329.229133:ERROR:chrome_browser_cloud_management_controller.cc(163)] Cloud management controller initialization aborted as CBCM is not enabled.
[38979:38979:0908/183329.239018:WARNING:account_consistency_mode_manager.cc(73)] Desktop Identity Consistency cannot be enabled as no OAuth client ID and client secret have been configured.
[38979:38979:0908/183329.239067:VERBOSE1:account_consistency_mode_manager.cc(207)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[38979:38979:0908/183329.243204:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0x11600024a600: set chrome proxy config service to 0x116000f39140
[38979:38994:0908/183329.245460:VERBOSE1:simple_index_file.cc(600)] Simple Cache Index is being restored from disk.
[38979:38994:0908/183329.245606:VERBOSE1:simple_index_file.cc(600)] Simple Cache Index is being restored from disk.
[38979:38979:0908/183329.246867:VERBOSE1:device_event_log_impl.cc(224)] [18:33:29.246] Bluetooth: EVENT: bluetooth_api.cc:82 BluetoothAPI: 0x1160005efa80
[38979:38998:0908/183329.247172:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
string "org.freedesktop.Notifications"
[38979:38998:0908/183329.247506:VERBOSE1:bus.cc(687)] Filter function already exists: 1 with associated data: 0x116000577480
[38979:38979:0908/183329.247614:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0x11600024af00: set chrome proxy config service to 0x116000f3cd60
[38979:38979:0908/183329.247749:VERBOSE1:account_consistency_mode_manager.cc(207)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[38979:38998:0908/183329.247657:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[38979:38979:0908/183329.248039:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(217)] MutablePO2TS::MutablePO2TS
[38979:38998:0908/183329.248324:VERBOSE1:bus.cc(687)] Filter function already exists: 1 with associated data: 0x116000577480
[38979:38998:0908/183329.248376:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[39065:1:0908/183329.249005:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: utility.
[38979:38979:0908/183329.250100:VERBOSE1:gaia_auth_util.cc(48)] Canonicalized @gmail.com to @gmail.com
[38979:38979:0908/183329.250136:VERBOSE1:gaia_auth_util.cc(48)] Canonicalized @gmail.com to @gmail.com
[38979:38979:0908/183329.250250:VERBOSE1:account_consistency_mode_manager.cc(207)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[38979:38979:0908/183329.250268:VERBOSE1:account_consistency_mode_manager.cc(207)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[38979:38979:0908/183329.250280:VERBOSE1:account_consistency_mode_manager.cc(207)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[38979:38979:0908/183329.250333:VERBOSE1:account_reconcilor.cc(167)] AccountReconcilor::AccountReconcilor
[38979:38979:0908/183329.250355:VERBOSE1:account_reconcilor.cc(197)] AccountReconcilor::Initialize
[38979:38979:0908/183329.253935:VERBOSE1:bluetooth_low_energy_event_router.cc(276)] Initializing BluetoothLowEnergyEventRouter.
[38979:38979:0908/183329.256656:VERBOSE1:service_discovery_device_lister.cc(36)] DeviceListerStart: service_type: _googlecast._tcp.local
[38979:38979:0908/183329.256680:VERBOSE1:service_discovery_device_lister.cc(42)] DiscoverNewDevices: service_type: _googlecast._tcp.local
[38979:38979:0908/183329.259219:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Web Store
[38979:38979:0908/183329.259242:VERBOSE1:extension_service.cc(1548)] Component extension Web Store (ahfgeienlihckogmohjhadlkjgocpleb) installing/upgrading from '' to 0.2
[38979:38979:0908/183329.260147:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Chromium PDF Viewer
[38979:38979:0908/183329.260168:VERBOSE1:extension_service.cc(1548)] Component extension Chromium PDF Viewer (mhjfbmdgcfjbbpaeojofohoefgiehjai) installing/upgrading from '' to 1
[38979:38979:0908/183329.260750:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Google Hangouts
[38979:38979:0908/183329.260762:VERBOSE1:extension_service.cc(1548)] Component extension Google Hangouts (nkeimhogjdpnpccoofpliimaahmaaome) installing/upgrading from '' to 1.3.21
[38979:38979:0908/183329.261764:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[38979:38979:0908/183329.262709:VERBOSE1:on_device_head_suggest_component_installer.cc(58)] On Device Head Component will fetch model for locale: DE500000
[38979:39009:0908/183329.262727:VERBOSE1:component_installer.cc(428)] StartRegistration for Subresource Filter Rules
[38979:38979:0908/183329.262744:VERBOSE1:first_party_sets_component_installer.cc(214)] Registering First-Party Sets component.
[38979:39068:0908/183329.262707:VERBOSE1:component_installer.cc(428)] StartRegistration for Widevine Content Decryption Module
[38979:39073:0908/183329.262868:VERBOSE1:component_installer.cc(428)] StartRegistration for OnDeviceHeadSuggest
[38979:38979:0908/183329.263233:VERBOSE1:file_type_policies_component_installer.cc(131)] Registering File Type Policies component.
[38979:39068:0908/183329.263452:VERBOSE1:component_installer.cc(428)] StartRegistration for File Type Policies
[38979:39009:0908/183329.263255:VERBOSE1:component_installer.cc(428)] StartRegistration for Certificate Error Assistant
[38979:39074:0908/183329.263496:VERBOSE1:component_installer.cc(428)] StartRegistration for CRLSet
[38979:39009:0908/183329.263580:VERBOSE1:component_installer.cc(428)] StartRegistration for Origin Trials
[38979:39068:0908/183329.263735:VERBOSE1:component_installer.cc(428)] StartRegistration for MEI Preload
[38979:39074:0908/183329.263755:VERBOSE1:component_installer.cc(428)] StartRegistration for PKI Metadata
[38979:39076:0908/183329.263838:VERBOSE1:component_installer.cc(428)] StartRegistration for Safety Tips
[38979:39071:0908/183329.262993:VERBOSE1:component_installer.cc(428)] StartRegistration for Optimization Hints
[38979:39009:0908/183329.263884:VERBOSE1:component_installer.cc(428)] StartRegistration for Crowd Deny
[38979:38979:0908/183329.263886:VERBOSE1:hyphenation_component_installer.cc(150)] Registering Hyphenation component.
[38979:39072:0908/183329.264470:VERBOSE1:component_installer.cc(428)] StartRegistration for Hyphenation
[38979:39072:0908/183329.265165:VERBOSE1:component_installer.cc(428)] StartRegistration for Zxcvbn Data Dictionaries
[38979:39009:0908/183329.265435:VERBOSE1:component_installer.cc(428)] StartRegistration for Autofill States Data
[38979:39009:0908/183329.265584:VERBOSE1:component_installer.cc(428)] StartRegistration for Client Side Phishing Detection
[38979:38979:0908/183329.265932:VERBOSE1:cached_result_provider.cc(80)] CachedResultProvider loaded prefs with results from previous session: PredictionResult: timestamp: 0 for segmentation key search_user
[38979:38979:0908/183329.265978:VERBOSE1:cached_result_provider.cc(80)] CachedResultProvider loaded prefs with results from previous session: PredictionResult: timestamp: 0 for segmentation key password_manager_user
[38979:38979:0908/183329.266951:WARNING:bluez_dbus_manager.cc(247)] Floss manager not present, cannot set Floss enable/disable.
[38979:38979:0908/183329.267509:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
[38979:38998:0908/183329.273329:VERBOSE1:token_service_table.cc(148)] Loaded tokens: result = 3 ; number of tokens loaded = 0
[38979:38979:0908/183329.276521:VERBOSE1:component_installer.cc(499)] FinishRegistration for Subresource Filter Rules
[38979:38979:0908/183329.276569:VERBOSE1:component_updater_service.cc(151)] CrxUpdateService starting up. First update attempt will take place in 60 s seconds. Next update attempt will take place in 18000 s seconds.
[38979:38979:0908/183329.276627:VERBOSE1:component_installer.cc(499)] FinishRegistration for Widevine Content Decryption Module
[38979:38979:0908/183329.276678:VERBOSE1:component_installer.cc(499)] FinishRegistration for Certificate Error Assistant
[38979:38979:0908/183329.276736:VERBOSE1:component_installer.cc(499)] FinishRegistration for File Type Policies
[38979:38979:0908/183329.276803:VERBOSE1:component_installer.cc(499)] FinishRegistration for CRLSet
[38979:38979:0908/183329.276849:VERBOSE1:component_installer.cc(499)] FinishRegistration for Origin Trials
[38979:38979:0908/183329.276910:VERBOSE1:component_installer.cc(499)] FinishRegistration for PKI Metadata
[38979:38979:0908/183329.276957:VERBOSE1:component_installer.cc(499)] FinishRegistration for Safety Tips
[38979:38979:0908/183329.277020:VERBOSE1:component_installer.cc(499)] FinishRegistration for MEI Preload
[38979:38979:0908/183329.277079:VERBOSE1:component_installer.cc(499)] FinishRegistration for Optimization Hints
[38979:38979:0908/183329.277121:VERBOSE1:component_installer.cc(499)] FinishRegistration for OnDeviceHeadSuggest
[38979:38979:0908/183329.277192:VERBOSE1:component_installer.cc(499)] FinishRegistration for Crowd Deny
[38979:38979:0908/183329.277242:VERBOSE1:component_installer.cc(499)] FinishRegistration for Hyphenation
[38979:38979:0908/183329.277301:VERBOSE1:component_installer.cc(499)] FinishRegistration for Zxcvbn Data Dictionaries
[38979:38979:0908/183329.277359:VERBOSE1:component_installer.cc(499)] FinishRegistration for Autofill States Data
[38979:38979:0908/183329.277495:VERBOSE1:component_installer.cc(499)] FinishRegistration for Client Side Phishing Detection
[38979:39079:0908/183329.279325:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
string "org.freedesktop.UPower"
[38979:39079:0908/183329.279686:VERBOSE1:bus.cc(687)] Filter function already exists: 1 with associated data: 0x116001216e40
[38979:39079:0908/183329.279719:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[38979:38979:0908/183329.280738:ERROR:network_service_instance_impl.cc(625)] Network service crashed, restarting service.
[38979:39079:0908/183329.285858:VERBOSE1:bus.cc(709)] Requested to remove an unknown filter function: 1 with associated data: 0x116001216d00
[38979:39079:0908/183329.285889:VERBOSE1:bus.cc(709)] Requested to remove an unknown filter function: 1 with associated data: 0x116001216bc0
[38979:38979:0908/183329.289582:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(368)] MutablePO2TS::OnWebDataServiceRequestDone. Result type: 5
[38979:38979:0908/183329.289601:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(424)] MutablePO2TS::LoadAllCredentialsIntoMemory; 0 redential(s).
[38979:38979:0908/183329.289700:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[38979:38979:0908/183329.289907:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[39082:1:0908/183329.323656:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: renderer.
[38979:38979:0908/183329.336067:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[38979:38979:0908/183329.336091:VERBOSE1:account_consistency_mode_manager.cc(207)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[39083:1:0908/183329.337017:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: renderer.
[38979:38979:0908/183329.361977:VERBOSE1:gaia_cookie_manager_service.cc(1078)] GaiaCookieManagerService::ListAccounts
[39080:39105:0908/183329.362696:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://accounts.google.com/ListAccounts?gpsia=1&source=ChromiumBrowser&json=standard
[38979:38979:0908/183329.362853:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[38979:38979:0908/183329.367627:VERBOSE1:profile_manager.cc(1290)] AddKeepAlive(Default, kBrowserWindow). keep_alives=[kWaitingForFirstBrowserWindow (1), kBrowserWindow (1)]
[38979:38979:0908/183329.367653:VERBOSE1:profile_manager.cc(1363)] ClearFirstBrowserWindowKeepAlive(Default). keep_alives=[kBrowserWindow (1)]
[39081:39081:0908/183329.367970:VERBOSE1:statistics_recorder.cc(524)] Collections of all histograms
0  O        (0 = 0.0%)
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
0  -O        (1 = 100.0%)
1  ...
1  ...
0  O        (0 = 0.0%)
2  ...
0  O        (0 = 0.0%)
0 ...
0  -O        (1 = 100.0%)
1  ...
[39083:1:0908/183329.369276:VERBOSE1:script_context.cc(143)] Created context:
  extension id:           nkeimhogjdpnpccoofpliimaahmaaome
  frame:                  0x370b001edba0
  URL:
  effective extension id: nkeimhogjdpnpccoofpliimaahmaaome
[39083:1:0908/183329.369983:VERBOSE1:script_context.cc(143)] Created context:
  frame:                  (nil)
  URL:
[39083:1:0908/183329.371749:VERBOSE1:dispatcher.cc(455)] Num tracked contexts: 1
[39080:39104:0908/183329.373702:VERBOSE1:simple_index_file.cc(600)] Simple Cache Index is being restored from disk.
[38979:38998:0908/183329.380746:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
string "com.canonical.AppMenu.Registrar"
[38979:38979:0908/183329.425143:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[38979:38979:0908/183329.425176:VERBOSE1:account_consistency_mode_manager.cc(207)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[39080:39105:0908/183329.426286:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://manjaro.org/
[39115:1:0908/183329.429441:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: renderer.
[38979:38979:0908/183330.381884:VERBOSE1:profile_manager.cc(1290)] AddKeepAlive(Default, kSessionDataDeleter). keep_alives=[kBrowserWindow (1), kSessionDataDeleter (1)]
[38979:38998:0908/183330.382248:VERBOSE1:bus.cc(709)] Requested to remove an unknown filter function: 1 with associated data: 0x116000577340
[38979:38979:0908/183330.388332:VERBOSE1:account_reconcilor.cc(231)] AccountReconcilor::Shutdown
[38979:38979:0908/183330.388356:VERBOSE1:account_reconcilor.cc(663)] AccountReconcilor::AbortReconcile: try again later
[38979:38979:0908/183330.388363:VERBOSE1:account_reconcilor.cc(772)] AccountReconcilor::CalculateIfMultiloginReconcileIsDone: Error was
[38979:38979:0908/183330.388377:VERBOSE1:account_reconcilor.cc(274)] AccountReconcilor::UnregisterWithIdentityManager
[38979:38979:0908/183330.388385:VERBOSE1:account_reconcilor.cc(253)] AccountReconcilor::UnregisterWithContentSettings
[38979:38979:0908/183330.388589:VERBOSE1:gaia_cookie_manager_service.cc(719)] GaiaCookieManagerService::CancelAll
[38979:38979:0908/183330.388698:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(683)] MutablePO2TS::Shutdown
[38979:38979:0908/183330.388735:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(227)] MutablePO2TS::~MutablePO2TS
[38979:38979:0908/183330.388944:VERBOSE1:device_event_log_impl.cc(224)] [18:33:30.388] Bluetooth: EVENT: bluetooth_api.cc:109 BluetoothAPI: Shutdown
[38979:38979:0908/183330.390080:VERBOSE1:account_reconcilor.cc(174)] AccountReconcilor::~AccountReconcilor
[38979:38979:0908/183330.390645:VERBOSE1:device_event_log_impl.cc(224)] [18:33:30.390] Bluetooth: EVENT: bluetooth_api.cc:95 ~BluetoothAPI: 0x1160005efa80
[39080:39080:0908/183330.397259:VERBOSE1:statistics_recorder.cc(524)] Collections of all histograms
chromium --enable-logging=stderr --v=1  0,53s user 0,36s system 3% cpu 26,529 total
now with Brave
▶ time brave --enable-logging=stderr --v=1
[39208:39208:0908/183527.040024:WARNING:chrome_main_delegate.cc(596)] This is Chrome version 116.1.57.62 (not a warning)
[39208:39208:0908/183527.040143:VERBOSE1:chrome_crash_reporter_client.cc(195)] GetCollectStatsConsent(): settings_consent: 0 so returning that
[39208:39208:0908/183527.046066:VERBOSE1:chrome_crash_reporter_client.cc(195)] GetCollectStatsConsent(): settings_consent: 0 so returning that
[39218:39218:0908/183527.076213:VERBOSE1:cdm_registration.cc(208)] Widevine enabled but no library found
[1:1:0908/183527.076221:VERBOSE1:cdm_registration.cc(208)] Widevine enabled but no library found
[39218:39218:0908/183527.076276:INFO:cpu_info.cc(53)] Available number of cores: 4
[1:1:0908/183527.076276:INFO:cpu_info.cc(53)] Available number of cores: 4
[1:1:0908/183527.076451:VERBOSE1:zygote_main_linux.cc(201)] ZygoteMain: initializing 0 fork delegates
[39218:39218:0908/183527.076434:VERBOSE1:zygote_main_linux.cc(201)] ZygoteMain: initializing 0 fork delegates
[39208:39208:0908/183527.078800:WARNING:chrome_browser_cloud_management_controller.cc(88)] Could not create policy manager as CBCM is not enabled.
[39208:39208:0908/183527.080010:VERBOSE1:variations_field_trial_creator.cc(87)] VariationsSeedUsage:2
[39208:39208:0908/183527.080045:VERBOSE1:variations_field_trial_creator.cc(336)] VariationsSetupComplete
[39208:39228:0908/183527.082634:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[39208:39208:0908/183527.187973:VERBOSE1:webrtc_event_log_manager.cc(97)] WebRTC remote-bound event logging enabled.
[39208:39208:0908/183527.188158:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0x3a9800095540: set chrome proxy config service to 0x3a98000c9480
[39208:39208:0908/183527.188264:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_MAIN
[39208:39208:0908/183527.188275:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_MAIN
[39208:39208:0908/183527.188281:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING
[39208:39208:0908/183527.188286:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING
[39208:39208:0908/183527.188291:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING_HOST
[39208:39208:0908/183527.188298:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING_HOST
[39208:39208:0908/183527.192670:VERBOSE1:cdm_registration.cc(208)] Widevine enabled but no library found
[39208:39228:0908/183527.195254:VERBOSE1:select_file_dialog_linux_portal.cc(280)] File chooser portal available: no
[39208:39230:0908/183527.196367:VERBOSE1:media_stream_manager.cc(1450)] MSM::InitializeMaybeAsync([this=0x3a980061c800])
[39208:39230:0908/183527.196454:VERBOSE1:media_stream_manager.cc(1450)] MDM::MediaDevicesManager()
[39208:39230:0908/183527.196486:VERBOSE1:media_stream_manager.cc(1450)] MSM::MediaStreamManager([this=0x3a980061c800]))
[39208:39208:0908/183527.201101:VERBOSE1:key_storage_util_linux.cc(50)] Password storage detected desktop environment: XFCE
[39208:39208:0908/183527.201125:VERBOSE1:key_storage_linux.cc(117)] Selected backend for OSCrypt: GNOME_LIBSECRET
[39245:39245:0908/183527.311663:WARNING:sandbox_linux.cc(393)] InitializeSandbox() called with multiple threads in process gpu-process.
[39246:39246:0908/183542.233103:INFO:child_thread_impl.cc(927)] ChildThreadImpl::EnsureConnected()
[39208:39208:0908/183552.212497:WARNING:key_storage_linux.cc(167)] OSCrypt tried Libsecret but couldn't initialise.
[39208:39208:0908/183552.212540:VERBOSE1:key_storage_linux.cc(136)] OSCrypt did not initialize a backend.
[39208:39208:0908/183552.213129:ERROR:chrome_browser_cloud_management_controller.cc(163)] Cloud management controller initialization aborted as CBCM is not enabled.
[39208:39208:0908/183552.222059:VERBOSE1:ntp_utils.cc(48)] Migrating hide widget pref...
[39208:39208:0908/183552.222080:VERBOSE1:ntp_utils.cc(59)] Setting: brave.new_tab_page.show_rewards, was off? 0
[39208:39208:0908/183552.222097:VERBOSE1:ntp_utils.cc(78)] Done migrating hide widget pref: 0
[39208:39208:0908/183552.223744:VERBOSE1:brave_shields_p3a.cc(225)] BraveShieldsP3A: Starting initial report for profile
[39208:39208:0908/183552.223781:VERBOSE1:brave_shields_p3a.cc(237)] BraveShieldsP3A: Domain FP counts: allow=0 standard=0 agg=0
[39208:39208:0908/183552.223789:VERBOSE1:brave_shields_p3a.cc(240)] BraveShieldsP3A: Domain Ad counts: allow=0 standard=0 agg=0
[39208:39208:0908/183552.223813:VERBOSE1:brave_shields_p3a.cc(181)] BraveShieldsP3A: Recording counts: is_fp=0 above=0 below=0
[39208:39208:0908/183552.223852:VERBOSE1:brave_shields_p3a.cc(181)] BraveShieldsP3A: Recording counts: is_fp=1 above=0 below=0
[39208:39239:0908/183552.224295:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave Ad Block List Catalog
[39208:39229:0908/183552.224317:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave Ad Block Updater
[39208:39226:0908/183552.224272:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave Ad Block Resources Library
[39208:39238:0908/183552.224328:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave Ad Block First Party Filters
[39208:39208:0908/183552.224742:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0x3a9800096b40: set chrome proxy config service to 0x3a98000c8780
[39208:39208:0908/183552.228364:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0x3a9800097640: set chrome proxy config service to 0x3a9800f86b40
[39297:1:0908/183552.228805:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: utility.
[39208:39208:0908/183552.230258:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[39208:39208:0908/183552.230282:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[39208:39208:0908/183552.230495:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(217)] MutablePO2TS::MutablePO2TS
[39208:39303:0908/183552.230503:VERBOSE1:simple_index_file.cc(600)] Simple Cache Index is being restored from disk.
[39208:39208:0908/183552.230568:VERBOSE1:gaia_auth_util.cc(48)] Canonicalized @gmail.com to @gmail.com
[39208:39208:0908/183552.230576:VERBOSE1:gaia_auth_util.cc(48)] Canonicalized @gmail.com to @gmail.com
[39208:39208:0908/183552.230614:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[39208:39208:0908/183552.230620:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[39208:39208:0908/183552.230630:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[39208:39208:0908/183552.230644:VERBOSE1:account_reconcilor.cc(167)] AccountReconcilor::AccountReconcilor
[39208:39208:0908/183552.230650:VERBOSE1:account_reconcilor.cc(197)] AccountReconcilor::Initialize
[39208:39303:0908/183552.230672:VERBOSE1:simple_index_file.cc(600)] Simple Cache Index is being restored from disk.
[39208:39208:0908/183552.230709:VERBOSE1:brave_sync_auth_manager.cc(36)] DeriveSigningKeys
[39208:39208:0908/183552.232136:VERBOSE1:device_event_log_impl.cc(224)] [18:35:52.232] Bluetooth: EVENT: bluetooth_api.cc:82 BluetoothAPI: 0x3a98001bc600
[39208:39208:0908/183552.232731:VERBOSE1:bluetooth_low_energy_event_router.cc(276)] Initializing BluetoothLowEnergyEventRouter.
[39208:39225:0908/183552.238641:VERBOSE1:component_installer.cc(428)] StartRegistration for NTP Background Images
[39208:39239:0908/183552.238649:VERBOSE1:component_installer.cc(428)] StartRegistration for NTP Sponsored Images (DE)
[39208:39208:0908/183552.239108:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Webshop
[39208:39208:0908/183552.239122:VERBOSE1:extension_service.cc(1548)] Component extension Webshop (ahfgeienlihckogmohjhadlkjgocpleb) installing/upgrading from '' to 0.2
[39208:39208:0908/183552.240155:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Chrome PDF Viewer
[39208:39208:0908/183552.240174:VERBOSE1:extension_service.cc(1548)] Component extension Chrome PDF Viewer (mhjfbmdgcfjbbpaeojofohoefgiehjai) installing/upgrading from '' to 1
[39208:39208:0908/183552.240611:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Google Hangouts
[39208:39208:0908/183552.240623:VERBOSE1:extension_service.cc(1548)] Component extension Google Hangouts (nkeimhogjdpnpccoofpliimaahmaaome) installing/upgrading from '' to 1.3.21
[39208:39208:0908/183552.241137:VERBOSE1:extension_service.cc(1546)] AddComponentExtension Brave
[39208:39208:0908/183552.241153:VERBOSE1:extension_service.cc(1548)] Component extension Brave (mnojpmjdmbbfmejpflffifhffcmidifd) installing/upgrading from '' to 1.0.0
[39208:39208:0908/183552.242252:WARNING:external_provider_impl.cc(513)] Malformed extension dictionary for extension: odbfpeeihdkbihmopkbjmoonfanlbfcl.  Key external_update_url has value "", which is not a valid URL.
[39208:39208:0908/183552.243163:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[39208:39208:0908/183552.243611:VERBOSE1:brave_wallet_p3a.cc(121)] Wallet P3A: starting report
[39208:39208:0908/183552.243881:VERBOSE1:brave_news_p3a.cc(132)] NewsP3A: total card views update: total = 0 count delta = 0
[39208:39208:0908/183552.243903:VERBOSE1:brave_news_controller.cc(667)] STOPPING TIMERS
[39208:39208:0908/183552.243910:VERBOSE1:brave_news_controller.cc(671)] REMOVING DATA FROM MEMORY
[39208:39208:0908/183552.245799:VERBOSE1:component_installer.cc(53)] Skipping registration of Brave-unsupported component gcmjkmgdlgnkkcocmoeiminaijmmjnii.
[39208:39208:0908/183552.245827:VERBOSE1:on_device_head_suggest_component_installer.cc(58)] On Device Head Component will fetch model for locale: DE500000
[39208:39208:0908/183552.245841:VERBOSE1:first_party_sets_component_installer.cc(214)] Registering First-Party Sets component.
[39208:39208:0908/183552.245852:VERBOSE1:component_installer.cc(53)] Skipping registration of Brave-unsupported component gonpemdgkjcecdgbnaabipppbmgfggbe.
[39208:39239:0908/183552.245857:VERBOSE1:component_installer.cc(428)] StartRegistration for OnDeviceHeadSuggest
[39208:39303:0908/183552.245917:VERBOSE1:component_installer.cc(428)] StartRegistration for Certificate Error Assistant
[39208:39304:0908/183552.245976:VERBOSE1:component_installer.cc(428)] StartRegistration for File Type Policies
[39208:39208:0908/183552.246012:VERBOSE1:component_installer.cc(53)] Skipping registration of Brave-unsupported component llkgjffcdpffmhiakmfcdcblohccpfmo.
[39208:39305:0908/183552.246044:VERBOSE1:component_installer.cc(428)] StartRegistration for CRLSet
[39208:39239:0908/183552.246197:VERBOSE1:component_installer.cc(428)] StartRegistration for MEI Preload
[39208:39303:0908/183552.246273:VERBOSE1:component_installer.cc(428)] StartRegistration for Safety Tips
[39208:39307:0908/183552.246248:VERBOSE1:component_installer.cc(428)] StartRegistration for PKI Metadata
[39208:39239:0908/183552.246296:VERBOSE1:component_installer.cc(273)] Preinstalled component found for MEI Preload at /usr/lib/brave-browser/MEIPreload with version 1.0.7.1652906823.
[39208:39208:0908/183552.246578:VERBOSE1:hyphenation_component_installer.cc(150)] Registering Hyphenation component.
[39208:39208:0908/183552.246612:VERBOSE1:component_installer.cc(53)] Skipping registration of Brave-unsupported component ojhpjlocmbogdgmfpkhlaaeamibhnphh.
[39208:39208:0908/183552.246630:VERBOSE1:component_installer.cc(53)] Skipping registration of Brave-unsupported component eeigpngbgcognadeebkilcpcaedhellh.
[39208:39208:0908/183552.246646:VERBOSE1:component_installer.cc(53)] Skipping registration of Brave-unsupported component imefjhfbkmcmebodilednhmaccmincoa.
[39208:39239:0908/183552.246719:VERBOSE1:component_installer.cc(428)] StartRegistration for Hyphenation
[39208:39309:0908/183552.246713:VERBOSE1:component_installer.cc(428)] StartRegistration for Crowd Deny
[39208:39303:0908/183552.246765:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave Wallet data files
[39208:39309:0908/183552.246852:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave HTTPS Everywhere Updater
[39208:39208:0908/183552.247509:VERBOSE1:profile_manager.cc(1290)] AddKeepAlive(Default, kBrowserWindow). keep_alives=[kWaitingForFirstBrowserWindow (1), kBrowserWindow (1)]
[39208:39208:0908/183552.247523:VERBOSE1:profile_manager.cc(1363)] ClearFirstBrowserWindowKeepAlive(Default). keep_alives=[kBrowserWindow (1)]
[39208:39230:0908/183552.248496:VERBOSE1:content_verifier.cc(630)] OnFetchComplete ahfgeienlihckogmohjhadlkjgocpleb success:0
[39208:39230:0908/183552.248556:VERBOSE1:content_verifier.cc(630)] OnFetchComplete mhjfbmdgcfjbbpaeojofohoefgiehjai success:0
[39208:39230:0908/183552.248652:VERBOSE1:content_verifier.cc(630)] OnFetchComplete nkeimhogjdpnpccoofpliimaahmaaome success:0
[39208:39230:0908/183552.248723:VERBOSE1:content_verifier.cc(630)] OnFetchComplete mnojpmjdmbbfmejpflffifhffcmidifd success:0
[39208:39228:0908/183552.252615:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[39208:39228:0908/183552.252828:VERBOSE1:bus.cc(687)] Filter function already exists: 1 with associated data: 0x3a9801448d20
[39208:39228:0908/183552.252844:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[39208:39228:0908/183552.252932:VERBOSE1:bus.cc(687)] Filter function already exists: 1 with associated data: 0x3a9801448d20
[39208:39228:0908/183552.252944:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[39208:39228:0908/183552.262815:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[39208:39208:0908/183552.290322:VERBOSE1:sidebar_service.cc(138)] Not migrating built-in items, pref is still default.
[39208:39208:0908/183552.301616:VERBOSE1:pref_proxy_config_tracker_impl.cc(191)] 0x3a980009dec0: set chrome proxy config service to 0x3a98016f2320
[39313:1:0908/183552.302483:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: renderer.
[39208:39208:0908/183552.303606:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[39311:1:0908/183552.303559:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: renderer.
[39208:39208:0908/183552.303678:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[39208:39238:0908/183552.316151:VERBOSE1:component_installer.cc(428)] StartRegistration for Brave Local Data Updater
[39208:39208:0908/183552.317413:WARNING:bluez_dbus_manager.cc(247)] Floss manager not present, cannot set Floss enable/disable.
[39208:39225:0908/183552.319762:VERBOSE1:shell_integration_linux.cc(522)] Looking for desktop file in /home/schnucky/.local/share/applications
[39208:39225:0908/183552.319785:VERBOSE1:shell_integration_linux.cc(522)] Looking for desktop file in /usr/local/share/applications
[39208:39225:0908/183552.319794:VERBOSE1:shell_integration_linux.cc(522)] Looking for desktop file in /usr/share/applications
[39208:39225:0908/183552.319801:VERBOSE1:shell_integration_linux.cc(524)] Found desktop file at /usr/share/applications
[39208:39208:0908/183552.320690:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave Ad Block List Catalog
[39208:39208:0908/183552.320724:VERBOSE1:component_updater_service.cc(151)] CrxUpdateService starting up. First update attempt will take place in 60 s seconds. Next update attempt will take place in 18000 s seconds.
[39208:39208:0908/183552.320871:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave Ad Block Updater
[39208:39208:0908/183552.320916:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave Ad Block First Party Filters
[39208:39208:0908/183552.320974:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave Ad Block Resources Library
[39208:39208:0908/183552.325635:VERBOSE1:component_installer.cc(499)] FinishRegistration for NTP Background Images
[39208:39208:0908/183552.325755:VERBOSE1:component_installer.cc(499)] FinishRegistration for NTP Sponsored Images (DE)
[39208:39208:0908/183552.332544:VERBOSE1:component_installer.cc(499)] FinishRegistration for OnDeviceHeadSuggest
[39208:39208:0908/183552.332622:VERBOSE1:component_installer.cc(499)] FinishRegistration for Certificate Error Assistant
[39208:39208:0908/183552.332679:VERBOSE1:component_installer.cc(499)] FinishRegistration for File Type Policies
[39208:39208:0908/183552.332745:VERBOSE1:component_installer.cc(499)] FinishRegistration for PKI Metadata
[39208:39208:0908/183552.332811:VERBOSE1:component_installer.cc(499)] FinishRegistration for MEI Preload
[39208:39208:0908/183552.332836:VERBOSE1:component_installer.cc(536)] Component ready, version 1.0.7.1652906823 in /usr/lib/brave-browser/MEIPreload
[39208:39208:0908/183552.332884:VERBOSE1:component_installer.cc(499)] FinishRegistration for Safety Tips
[39208:39208:0908/183552.332956:VERBOSE1:component_installer.cc(499)] FinishRegistration for CRLSet
[39208:39208:0908/183552.333045:VERBOSE1:component_installer.cc(499)] FinishRegistration for Crowd Deny
[39208:39208:0908/183552.333086:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave Wallet data files
[39208:39208:0908/183552.333133:VERBOSE1:component_installer.cc(499)] FinishRegistration for Hyphenation
[39208:39208:0908/183552.333184:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave HTTPS Everywhere Updater
[39332:1:0908/183552.342164:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: renderer.
[39208:39208:0908/183552.365151:VERBOSE1:component_installer.cc(499)] FinishRegistration for Brave Local Data Updater
[39208:39341:0908/183552.367995:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[39208:39341:0908/183552.368215:VERBOSE1:bus.cc(687)] Filter function already exists: 1 with associated data: 0x3a98014480e0
[39208:39341:0908/183552.368241:VERBOSE1:bus.cc(890)] Method call: message_type: MESSAGE_METHOD_CALL
signature: s
[39208:39341:0908/183552.371812:VERBOSE1:bus.cc(709)] Requested to remove an unknown filter function: 1 with associated data: 0x3a9801449b20
[39208:39341:0908/183552.371836:VERBOSE1:bus.cc(709)] Requested to remove an unknown filter function: 1 with associated data: 0x3a9801449a40
[39342:1:0908/183552.381625:VERBOSE1:sandbox_linux.cc(78)] Activated seccomp-bpf sandbox for process type: renderer.
[39208:39208:0908/183552.384398:ERROR:network_service_instance_impl.cc(625)] Network service crashed, restarting service.
[39208:39208:0908/183552.389697:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[39208:39208:0908/183552.389747:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[39208:39208:0908/183552.400646:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[39208:39208:0908/183552.400690:VERBOSE1:account_consistency_mode_manager.cc(208)] Desktop Identity Consistency disabled as sign-in to Chrome is not allowed
[39350:39356:0908/183552.423007:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[39350:39356:0908/183552.423376:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[39350:39356:0908/183552.423560:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[39350:39356:0908/183552.423754:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[39350:39356:0908/183552.423988:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[39350:39356:0908/183552.424212:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[39350:39356:0908/183552.424360:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[39350:39356:0908/183552.424688:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[39350:39356:0908/183552.426042:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[39350:39356:0908/183552.426374:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[39208:39208:0908/183552.426384:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(273)] MutablePO2TS::RefreshTokenIsAvailable
[39350:39356:0908/183552.426585:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://go-updater.brave.com/extensions
[39350:39356:0908/183552.426743:VERBOSE1:network_delegate.cc(35)] NetworkDelegate::NotifyBeforeURLRequest: https://variations.brave.com/seed?osname=linux&channel=stable&milestone=116
[39313:1:0908/183552.432229:VERBOSE1:script_context.cc(143)] Created context:
  extension id:           (none)
  frame:                  0x18cf001edbb0
  URL:
  context_type:           WEBUI
  effective extension id: (none)
  effective context type: WEBUI
[39313:1:0908/183552.432794:VERBOSE1:script_context.cc(143)] Created context:
  frame:                  (nil)
  URL:
  context_type:           UNSPECIFIED
  effective context type: UNSPECIFIED
[39313:1:0908/183552.433324:VERBOSE1:dispatcher.cc(455)] Num tracked contexts: 1
[39313:1:0908/183552.433422:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_MAIN
[39313:1:0908/183552.433471:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_MAIN
[39313:1:0908/183552.433539:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING
[39313:1:0908/183552.433608:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING
[39313:1:0908/183552.433675:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING_HOST
[39313:1:0908/183552.433746:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING_HOST
[39313:1:0908/183552.435278:VERBOSE1:script_context.cc(143)] Created context:
  URL:
  context_type:           WEBUI
[39313:1:0908/183552.435473:VERBOSE1:script_context.cc(143)] Created context:
  frame:                  (nil)
  URL:
[39313:1:0908/183552.435670:VERBOSE1:dispatcher.cc(455)] Num tracked contexts: 2
[39332:1:0908/183552.449752:VERBOSE1:script_context.cc(143)] Created context:
  extension id:           mnojpmjdmbbfmejpflffifhffcmidifd
  URL:
  context_type:           BLESSED_EXTENSION
  effective extension id: mnojpmjdmbbfmejpflffifhffcmidifd
  effective context type: BLESSED_EXTENSION
[39332:1:0908/183552.450279:VERBOSE1:script_context.cc(143)] Created context:
  frame:                  (nil)
  URL:
[39332:1:0908/183552.451206:VERBOSE1:dispatcher.cc(455)] Num tracked contexts: 1
[39332:1:0908/183552.451386:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_MAIN
[39332:1:0908/183552.451458:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_MAIN
[39332:1:0908/183552.451533:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING
[39332:1:0908/183552.451614:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING
[39332:1:0908/183552.451677:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING_HOST
[39332:1:0908/183552.451823:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING_HOST
[39332:1:0908/183552.453225:VERBOSE1:script_context.cc(143)] Created context:
  URL:
[39332:1:0908/183552.453617:VERBOSE1:script_context.cc(143)] Created context:
  frame:                  (nil)
  URL:
[39332:1:0908/183552.453998:VERBOSE1:dispatcher.cc(455)] Num tracked contexts: 2
[39342:1:0908/183552.453822:VERBOSE1:script_context.cc(143)] Created context:
  URL:
[39342:1:0908/183552.454689:VERBOSE1:script_context.cc(143)] Created context:
  frame:                  (nil)
  URL:
[39342:1:0908/183552.455625:VERBOSE1:dispatcher.cc(455)] Num tracked contexts: 1
[39342:1:0908/183552.455734:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_MAIN
[39342:1:0908/183552.455805:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_MAIN
[39342:1:0908/183552.455866:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING
[39342:1:0908/183552.455924:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING
[39342:1:0908/183552.455987:VERBOSE1:google_api_keys.cc(316)] Using default value "575648666095-16mil6hahc0o91757beimmv4uqkk3pqk.apps.googleusercontent.com" for API key GOOGLE_CLIENT_ID_REMOTING_HOST
[39342:1:0908/183552.456046:VERBOSE1:google_api_keys.cc(316)] Using default value "p14G9be_gU1nk0N6kbIXtB89" for API key GOOGLE_CLIENT_SECRET_REMOTING_HOST
[39342:1:0908/183552.457550:VERBOSE1:script_context.cc(143)] Created context:
  URL:
[39342:1:0908/183552.457716:VERBOSE1:script_context.cc(143)] Created context:
  frame:                  (nil)
  URL:
[39342:1:0908/183552.457854:VERBOSE1:dispatcher.cc(455)] Num tracked contexts: 2
[39208:39208:0908/183552.474165:WARNING:CONSOLE(5)] "crbug/1173575, non-JS module files deprecated.", source: chrome://resources/js/load_time_data_deprecated.js (5)
[39313:1:0908/183553.881019:VERBOSE1:layout_shift_tracker.cc(363)] in "chrome://welcome/", 0x18cf00124c68:LayoutNGFlexibleBox (relative positioned) DIV class='Box--10fc1xg bWINfg' moved from 204.25,95.9219 1337.5x691.141 to 204.25,76.7031 1337.5x729.594 (visible from 204,96 1338x691 to 204,77 1338x729)
[39313:1:0908/183553.881359:VERBOSE1:layout_shift_tracker.cc(555)] in "chrome://welcome/", viewport was 63.2672% impacted with distance fraction 0.0110073 and subframe weighting factor 1
[39313:1:0908/183553.881477:VERBOSE1:layout_shift_tracker.cc(636)] in "chrome://welcome/", layout shift of 0.00696401 reported; cumulative score is 0.00696401
[39208:39208:0908/183554.094040:VERBOSE1:profile_manager.cc(1290)] AddKeepAlive(Default, kSessionDataDeleter). keep_alives=[kBrowserWindow (1), kSessionDataDeleter (1)]
[39208:39208:0908/183554.094142:VERBOSE1:profile_manager.cc(1342)] RemoveKeepAlive(Default, kSessionDataDeleter). keep_alives=[kBrowserWindow (1)]
[39208:39228:0908/183554.094239:VERBOSE1:bus.cc(709)] Requested to remove an unknown filter function: 1 with associated data: 0x3a9801448e00
[39208:39208:0908/183554.102714:VERBOSE1:account_reconcilor.cc(231)] AccountReconcilor::Shutdown
[39208:39208:0908/183554.102728:VERBOSE1:account_reconcilor.cc(663)] AccountReconcilor::AbortReconcile: try again later
[39208:39208:0908/183554.102734:VERBOSE1:account_reconcilor.cc(772)] AccountReconcilor::CalculateIfMultiloginReconcileIsDone: Error was
[39208:39208:0908/183554.102743:VERBOSE1:account_reconcilor.cc(274)] AccountReconcilor::UnregisterWithIdentityManager
[39208:39208:0908/183554.102750:VERBOSE1:account_reconcilor.cc(253)] AccountReconcilor::UnregisterWithContentSettings
[39208:39208:0908/183554.102832:VERBOSE1:gaia_cookie_manager_service.cc(719)] GaiaCookieManagerService::CancelAll
[39208:39208:0908/183554.102841:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(683)] MutablePO2TS::Shutdown
[39208:39208:0908/183554.102848:VERBOSE1:mutable_profile_oauth2_token_service_delegate.cc(227)] MutablePO2TS::~MutablePO2TS
[39208:39208:0908/183554.102944:VERBOSE1:device_event_log_impl.cc(224)] [18:35:54.102] Bluetooth: EVENT: bluetooth_api.cc:109 BluetoothAPI: Shutdown
[39208:39208:0908/183554.103935:VERBOSE1:account_reconcilor.cc(174)] AccountReconcilor::~AccountReconcilor
[39208:39208:0908/183554.104271:VERBOSE1:device_event_log_impl.cc(224)] [18:35:54.104] Bluetooth: EVENT: bluetooth_api.cc:95 ~BluetoothAPI: 0x3a98001bc600
[39350:39350:0908/183554.109810:VERBOSE1:statistics_recorder.cc(524)] Collections of all histograms
brave --enable-logging=stderr --v=1  0,49s user 0,45s system 3% cpu 27,147 total
Yes, the problem persists. Any ideas?
Could you boot live-iso, install chromium and check if the problem is there or not?
Will not have physical access to the machine till Christmas. Hope I can fix it then.
Thank you for your help and effort!
