I have two monitors, one on a DisplayPort and another on the HDMI, xrandr -q
shows this :
Screen 0: minimum 320 x 200, current 3360 x 1080, maximum 16384 x 16384
DisplayPort-0 connected primary 1920x1080+1440+0 (normal left inverted right x axis y axis) 521mm x 293mm
1920x1080 143.85 + 165.00* 120.00 119.88 119.88 60.00 50.00 59.94
1680x1050 59.95
1280x1024 75.02 60.02
1440x900 59.89
1280x960 60.00
1280x800 59.81
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 connected 1440x900+0+0 (normal left inverted right x axis y axis) 410mm x 256mm
1440x900 59.89*+
1280x960 60.00
1280x800 59.89
1152x864 75.00
1280x720 60.00
1024x768 75.03 60.00
832x624 74.55
800x600 75.00 60.32
640x480 75.00 59.94
720x400 70.08
It says that the DP is the primary display but GNOME says the HDMI one is display #1 while DP is #2.
How do I change that?
