Change LANG temporarily
For example, when posting something like this, I think most people find it annoying to see something other than English.
What should I do if I want to temporarily start up in English?
Is there a way to do it with minimal effort?
It takes less than 1 minute.
I feel little sad.
Hi @ehhen,
All environment variables can be set for that running app as prefix to the command-line. So, the following is all temporary:
Just prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Hope this helps!
LC_ALL=C manjaro-settings-manager
I replaced the screenshot.
thanks.
not LANG=C. :grinning:
Nope, this one was added for debug purposes, if I recall correct. Exact for use like this…:point_up:
@Mirdarthos
LC_ALL=C
I just checked $HISTFILE.
during the past 10 years
It looks like I’m using a little over 400.
In my case, I use it with a pipe.
LC_ALL=C sort
The result of sort is different.
Sort speed is faster.
https://unix.stackexchange.com/questions/564303/sort-lc-all-c-vs-lc-all-c-utf8
There’s no pipe in that command? Or am I missing something? That’s also a distinct possibility…
parallel cd {} '&&' bash -c 'find . -type f -exec md5sum {} + | LC_ALL=C sort | md5sum | perl -lpE "s#^.*/##" ' ::: */
