Ceph fails to build on stable
Trying to build ceph-libs on stable:
[user@manjaro-kde ~]$ pamac build ceph-libs
To build (1):
  ceph-libs              16.2.10-1              (15.2.17-1)   AUR
In member function ‘btree::internal::btree_node<Params>* btree::internal::btree_node<Params>::child(int) const [with Params = btree::internal::map_params<pg_t, ceph_le<unsigned int>*, std::less<pg_t>, std::allocator<std::pair<const pg_t, ceph_le<unsigned int>*> >, 256, false>]’,
    inlined from ‘void btree::internal::btree_node<Params>::swap(btree::internal::btree_node<Params>*, allocator_type*) [with Params = btree::internal::map_params<pg_t, ceph_le<unsigned int>*, std::less<pg_t>, std::allocator<std::pair<const pg_t, ceph_le<unsigned int>*> >, 256, false>]’ at /var/tmp/pamac-build-user/ceph/src/ceph-16.2.10/src/include/cpp-btree/btree.h:1703:36,
    inlined from ‘btree::internal::btree<Params>::iterator btree::internal::btree<Params>::internal_emplace(iterator, Args&& ...) [with Args = {const std::pair<const pg_t, ceph_le<unsigned int>*>&}; Params = btree::internal::map_params<pg_t, ceph_le<unsigned int>*, std::less<pg_t>, std::allocator<std::pair<const pg_t, ceph_le<unsigned int>*> >, 256, false>]’ at /var/tmp/pamac-build-user/ceph/src/ceph-16.2.10/src/include/cpp-btree/btree.h:2418:22:
/var/tmp/pamac-build-user/ceph/src/ceph-16.2.10/src/include/cpp-btree/btree.h:514:83: warning: array subscript 32 is outside array bounds of ‘btree::internal::AlignedAlloc<8, std::allocator<std::pair<const pg_t, ceph_le<unsigned int>*> > >::M [32]’ [-Warray-bounds]
  514 |   btree_node* child(int i) const { return GetField<&internal_fields::children>()[i]; }
In member function ‘_Tp* std::__new_allocator<_Tp>::allocate(size_type, const void*) [with _Tp = btree::internal::AlignedAlloc<8, std::allocator<std::pair<const pg_t, ceph_le<unsigned int>*> > >::M]’,
    inlined from ‘static _Tp* std::allocator_traits<std::allocator<_CharT> >::allocate(allocator_type&, size_type) [with _Tp = btree::internal::AlignedAlloc<8, std::allocator<std::pair<const pg_t, ceph_le<unsigned int>*> > >::M]’ at /usr/include/c++/12.2.0/bits/alloc_traits.h:464:28,
    inlined from ‘static void* btree::internal::AlignedAlloc<Alignment, Alloc>::allocate(Alloc*, size_t) [with long unsigned int Alignment = 8; Alloc = std::allocator<std::pair<const pg_t, ceph_le<unsigned int>*> >]’ at /var/tmp/pamac-build-user/ceph/src/ceph-16.2.10/src/include/cpp-btree/btree.h:879:33,
    inlined from ‘btree::internal::btree<Params>::node_type* btree::internal::btree<Params>::allocate(size_type) [with Params = btree::internal::map_params<pg_t, ceph_le<unsigned int>*, std::less<pg_t>, std::allocator<std::pair<const pg_t, ceph_le<unsigned int>*> >, 256, false>]’ at /var/tmp/pamac-build-user/ceph/src/ceph-16.2.10/src/include/cpp-btree/btree.h:1289:32,
    inlined from ‘btree::internal::btree<Params>::node_type* btree::internal::btree<Params>::new_leaf_root_node(int) [with Params = btree::internal::map_params<pg_t, ceph_le<unsigned int>*, std::less<pg_t>, std::allocator<std::pair<const pg_t, ceph_le<unsigned int>*> >, 256, false>]’ at /var/tmp/pamac-build-user/ceph/src/ceph-16.2.10/src/include/cpp-btree/btree.h:1302:28,
    inlined from ‘btree::internal::btree<Params>::iterator btree::internal::btree<Params>::internal_emplace(iterator, Args&& ...) [with Args = {const std::pair<const pg_t, ceph_le<unsigned int>*>&}; Params = btree::internal::map_params<pg_t, ceph_le<unsigned int>*, std::less<pg_t>, std::allocator<std::pair<const pg_t, ceph_le<unsigned int>*> >, 256, false>]’ at /var/tmp/pamac-build-user/ceph/src/ceph-16.2.10/src/include/cpp-btree/btree.h:2417:29:
/usr/include/c++/12.2.0/bits/new_allocator.h:137:55: note: at offset 256 into object of size [64, 256] allocated by ‘operator new’
  137 |         return static_cast<_Tp*>(_GLIBCXX_OPERATOR_NEW(__n * sizeof(_Tp)));
[ 80%] Linking CXX static library ../../lib/libosd.a
cd /var/tmp/pamac-build-user/ceph/src/ceph-16.2.10/build/src/osd && /usr/bin/cmake -P CMakeFiles/osd.dir/cmake_clean_target.cmake
cd /var/tmp/pamac-build-user/ceph/src/ceph-16.2.10/build/src/osd && /usr/bin/cmake -E cmake_link_script CMakeFiles/osd.dir/link.txt --verbose=1
/usr/bin/ar qc ../../lib/libosd.a CMakeFiles/osd.dir/OSD.cc.o CMakeFiles/osd.dir/pg_scrubber.cc.o CMakeFiles/osd.dir/scrub_machine.cc.o CMakeFiles/osd.dir/PrimaryLogScrub.cc.o CMakeFiles/osd.dir/Watch.cc.o CMakeFiles/osd.dir/ClassHandler.cc.o CMakeFiles/osd.dir/PG.cc.o CMakeFiles/osd.dir/PGLog.cc.o CMakeFiles/osd.dir/PrimaryLogPG.cc.o CMakeFiles/osd.dir/ReplicatedBackend.cc.o CMakeFiles/osd.dir/ECBackend.cc.o CMakeFiles/osd.dir/ECTransaction.cc.o CMakeFiles/osd.dir/PGBackend.cc.o CMakeFiles/osd.dir/OSDCap.cc.o CMakeFiles/osd.dir/Session.cc.o CMakeFiles/osd.dir/SnapMapper.cc.o CMakeFiles/osd.dir/ScrubStore.cc.o CMakeFiles/osd.dir/osd_types.cc.o CMakeFiles/osd.dir/ECUtil.cc.o CMakeFiles/osd.dir/ExtentCache.cc.o CMakeFiles/osd.dir/scheduler/OpScheduler.cc.o CMakeFiles/osd.dir/scheduler/OpSchedulerItem.cc.o CMakeFiles/osd.dir/scheduler/mClockScheduler.cc.o CMakeFiles/osd.dir/PeeringState.cc.o CMakeFiles/osd.dir/PGStateUtils.cc.o CMakeFiles/osd.dir/recovery_types.cc.o CMakeFiles/osd.dir/MissingLoc.cc.o CMakeFiles/osd.dir/osd_perf_counters.cc.o CMakeFiles/osd.dir/__/common/TrackedOp.cc.o CMakeFiles/osd.dir/__/mgr/OSDPerfMetricTypes.cc.o CMakeFiles/osd.dir/__/osdc/Objecter.cc.o CMakeFiles/osd.dir/__/osdc/Striper.cc.o
/usr/bin/ranlib ../../lib/libosd.a
make[2]: Leaving directory '/var/tmp/pamac-build-user/ceph/src/ceph-16.2.10/build'
[ 80%] Built target osd
make[1]: Leaving directory '/var/tmp/pamac-build-user/ceph/src/ceph-16.2.10/build'
make: *** [Makefile:149: all] Error 2
make: Leaving directory '/var/tmp/pamac-build-user/ceph/src/ceph-16.2.10/build'
==> ERROR: A failure occurred in build().
    Aborting...
…a little search
It’s moved to AUR but still doesn’t compile on stable.
ceph-libs were dropped and are basically dead meat… you should remove them, together with the other ceph packages mentioned in the stable thread if you have them
Builds fine in unstable.
