Capture Card Continually disconnects (Aver Media LGHD2 GC570)
Hi there. I’ve gotten the my capture card to work before. But it will continually disconnect and reconnect and has been giving me grief ever since install. The card should not need drivers as it acts as a USB Webcam.
Occasionally the card will work, but for the most part it just flickers in and out of existence.
Is there any information I should include?
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. The output of:
    journalctl --system --boot=0 --priority=3 | tail --lines=35
    ASAP after the card starts flickering would be helpful as well. (E.G Insert it and then run the above)
:+1:
inxi output:
  Kernel: 5.13.1-3-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=e5334836-7220-4604-863b-3231f1ab6582 rw quiet apparmor=1
  security=apparmor resume=UUID=5839106a-edcd-4121-9be5-51c4b8c0fed5
  udev.log_priority=3
  Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: MSI model: Z87-G45 GAMING (MS-7821) v: 1.0
  serial: <filter> UEFI: American Megatrends v: 1.9 date: 07/21/2014
  RAM: total: 23.43 GiB used: 9.47 GiB (40.4%)
  Info: Quad Core model: Intel Core i7-4770K bits: 64 type: MT MCP
  arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
  L2: 8 MiB bogomips: 56022
  Speed: 3700 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 3700 2: 3700
  3: 3700 4: 3700 5: 3700 6: 3700 7: 3700 8: 3700
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
  clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
  dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
  ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
  movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb
  pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep
  smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
  tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology
  xtpr
  Type: l1tf
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
  vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 01:00.0
  chip-ID: 1002:67df class-ID: 0300
  Device-2: AVerMedia AVerMedia USB Device type: USB
  driver: snd-usb-audio,uvcvideo bus-ID: 6-1:47 chip-ID: 07ca:1570
  class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
  display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4486x1050 s-dpi: 96 s-size: 1181x276mm (46.5x10.9")
  s-diag: 1213mm (47.7")
  Monitor-1: HDMI-A-0 res: 1366x768 hz: 60 dpi: 101
  size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
  Monitor-2: HDMI-A-1 res: 1440x900 hz: 60 dpi: 81
  size: 453x255mm (17.8x10.0") diag: 520mm (20.5")
  Monitor-3: DVI-D-0 res: 1680x1050 hz: 60 dpi: 90
  size: 473x296mm (18.6x11.7") diag: 558mm (22")
  OpenGL: renderer: AMD Radeon RX 480 Graphics (POLARIS10 DRM 3.41.0
  5.13.1-3-MANJARO LLVM 12.0.0)
  v: 4.6 Mesa 21.1.4 direct render: Yes
  Device-1: Intel 8 Series/C220 Series High Definition Audio
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  chip-ID: 8086:8c20 class-ID: 0403
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  chip-ID: 1002:aaf0 class-ID: 0403
  Device-3: Blue Microphones Yeti Stereo Microphone type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-9:4 chip-ID: b58e:9e84
  class-ID: 0300 serial: <filter>
  Device-4: AVerMedia AVerMedia USB Device type: USB
  Sound Server-1: ALSA v: k5.13.1-3-MANJARO running: yes
  Sound Server-2: JACK v: 1.9.18 running: no
  Sound Server-3: PulseAudio v: 14.2 running: no
  Sound Server-4: PipeWire v: 0.3.31 running: yes
  Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet
  vendor: Micro-Star MSI driver: alx v: kernel port: d000 bus-ID: 03:00.0
  chip-ID: 1969:e091 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Permissions: Unable to run lvs. Root privileges required.
  Local Storage: total: 1.82 TiB used: 761.09 GiB (40.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA100
  rotation: 7200 rpm serial: <filter> rev: A750 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-08WN4A0
  rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
  ID-1: / raw-size: 905.44 GiB size: 890.16 GiB (98.31%)
  used: 256.58 GiB (28.8%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
  uuid: e5334836-7220-4604-863b-3231f1ab6582
  used: 296 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
  uuid: 19B7-59FB
  ID-3: /media/data raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
  used: 493.68 GiB (53.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
  label: still not porn uuid: f4adb40c-4e2b-4683-a01b-4bae74279d0e
  ID-4: /run/user/1000/keybase/kbfs raw-size: N/A size: 250 GiB
  used: 10.83 GiB (4.3%) fs: fuse dev: /dev/fuse label: N/A uuid: N/A
  ID-1: swap-1 type: partition size: 25.77 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sdb3 maj-min: 8:19 label: N/A
  uuid: 5839106a-edcd-4121-9be5-51c4b8c0fed5
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8008 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
  Device-1: 3-1:2 info: Razer USA Mamba 2018 (Wired) type: Mouse,Keyboard
  driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
  power: 500mA chip-ID: 1532:0073 class-ID: 0301 serial: <filter>
  Device-2: 3-2:3 info: Razer USA Ornata Chroma type: Keyboard,Mouse
  power: 500mA chip-ID: 1532:021e class-ID: 0300
  Device-3: 3-9:4 info: Blue Microphones Yeti Stereo Microphone
  type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
  rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: b58e:9e84 class-ID: 0300
  serial: <filter>
  Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  Hub-7: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-8: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  Device-1: 6-1:47 info: AVerMedia AVerMedia USB Device type: Video,Audio
  driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 3.0 speed: 5 Gb/s
  power: 600mA chip-ID: 07ca:1570 class-ID: 0102 serial: <filter>
  System Temperatures: cpu: 72.0 C mobo: 27.8 C gpu: amdgpu temp: 55.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1290
  Processes: 315 Uptime: 4h 0m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1607 pacman: 1597 lib: 397
  flatpak: 4 snap: 6 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.05
journal output
-- Journal begins at Wed 2021-07-21 13:48:59 EDT, ends at Wed 2021-07-21 16:56:08 EDT. --
Jul 21 13:58:23 aliza kernel: Trying to vfree() nonexistent vm area (00000000846838ae)
Jul 21 14:11:25 aliza kernel: Trying to vfree() nonexistent vm area (0000000070c72aa7)
Jul 21 14:19:11 aliza kernel: Trying to vfree() nonexistent vm area (00000000e9cfcee1)
Jul 21 14:21:39 aliza kernel: Trying to vfree() nonexistent vm area (000000006a24c19c)
Jul 21 14:26:50 aliza kernel: Trying to vfree() nonexistent vm area (000000002947863c)
Jul 21 14:29:30 aliza kernel: Trying to vfree() nonexistent vm area (00000000042a0c03)
Jul 21 14:32:04 aliza kernel: Trying to vfree() nonexistent vm area (00000000042a0c03)
Jul 21 14:34:26 aliza kernel: Trying to vfree() nonexistent vm area (000000002947863c)
Jul 21 14:39:19 aliza kernel: Trying to vfree() nonexistent vm area (00000000d7db4c8f)
Jul 21 14:41:53 aliza kernel: Trying to vfree() nonexistent vm area (00000000fae7750c)
Jul 21 14:44:28 aliza kernel: Trying to vfree() nonexistent vm area (00000000fae7750c)
Jul 21 14:46:53 aliza kernel: Trying to vfree() nonexistent vm area (0000000088361ff4)
Jul 21 14:51:55 aliza kernel: Trying to vfree() nonexistent vm area (0000000088361ff4)
Jul 21 14:51:58 aliza kernel: Trying to vfree() nonexistent vm area (000000002830b20f)
Jul 21 14:57:06 aliza kernel: Trying to vfree() nonexistent vm area (0000000088361ff4)
Jul 21 15:04:51 aliza kernel: Trying to vfree() nonexistent vm area (00000000484427ca)
Jul 21 15:09:50 aliza kernel: Trying to vfree() nonexistent vm area (00000000299b52c7)
Jul 21 15:12:16 aliza kernel: Trying to vfree() nonexistent vm area (00000000299b52c7)
Jul 21 15:14:38 aliza kernel: Trying to vfree() nonexistent vm area (0000000067438d60)
Jul 21 15:30:05 aliza kernel: Trying to vfree() nonexistent vm area (00000000d5da2c8d)
Jul 21 15:44:42 aliza kernel: Trying to vfree() nonexistent vm area (00000000dca2fd9f)
Jul 21 15:47:13 aliza kernel: Trying to vfree() nonexistent vm area (00000000de0364e7)
Jul 21 16:00:00 aliza kernel: Trying to vfree() nonexistent vm area (00000000ac9a32f5)
Jul 21 16:02:34 aliza kernel: Trying to vfree() nonexistent vm area (0000000017895a98)
Jul 21 16:53:08 aliza kernel: usb 6-1: Failed to query (GET_DEF) UVC control 2 on unit 3: -19 (exp. 2).
Jul 21 16:53:08 aliza kernel: uvcvideo 6-1:1.1: Failed to set UVC probe control : -19 (exp. 26).
Jul 21 16:53:35 aliza kernel: usb 6-1: Failed to query (GET_DEF) UVC control 2 on unit 3: -19 (exp. 2).
Jul 21 16:53:35 aliza kernel: uvcvideo 6-1:1.1: Failed to set UVC probe control : -19 (exp. 26).
Have you tried the latest LTS kernel yet? (5.10)
You’ve got it to work before? Because it doesn’t get recognized as a specific capture card under 5.13. Is it one of these?
Some program is polluting your journal file: I need the last 35 lines without any of these:
:man_shrugging:
Check the tlp settings for it or disable tlp
I had the same issue on Debian and what helped me was to disable USB autosuspend. I suspected the kernel did not know what to do with the capture card if it was not used by some recording software as pointed out in a couple of Reddit threads.
Aug  2 18:01:37 engumi kernel: [   33.280591] usb 6-1: new SuperSpeed Gen 1 USB device number 6 using xhci_hcd
Aug  2 18:01:37 engumi kernel: [   33.311196] usb 6-1: New USB device found, idVendor=07ca, idProduct=1570, bcdDevice= 1.00
Aug  2 18:01:37 engumi kernel: [   33.313989] usb 6-1: New USB device strings: Mfr=6, Product=7, SerialNumber=3
Aug  2 18:01:37 engumi kernel: [   33.316287] usb 6-1: Product: AVerMedia USB Device
Aug  2 18:01:37 engumi kernel: [   33.316937] usb 6-1: Manufacturer: AVerMedia
Aug  2 18:01:37 engumi kernel: [   33.317529] usb 6-1: SerialNumber: 13117576004380
Aug  2 18:01:37 engumi kernel: [   33.319569] uvcvideo: Found UVC 1.00 device AVerMedia USB Device (07ca:1570)
Aug  2 18:01:37 engumi kernel: [   33.337840] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
Aug  2 18:01:37 engumi kernel: [   36.056069] usb 6-1: USB disconnect, device number 6
I also found a question on[ StackExchange](unix.stackexchange com/questions/91027/how-to-disable-usb-autosuspend-on-kernel-3-7-10-or-above) which helped me disable USB autosuspend on Debian but there are generic instructions too.
From StackExchange:
For Ubuntu and Debian, usbcore is compiled in to the kernel, so creating entries in /etc/modprobe.d will NOT work. Instead, we need to change the kernel boot parameters.
Edit the /etc/default/grub file and change the GRUB_CMDLINE_LINUX_DEFAULT line to add the usbcore.autosuspend=-1 option:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash usbcore.autosuspend=-1"
Note that quiet splash were already present options. So keep other options you have too.
After saving the file, update grub:
sudo update-grub
And reboot.
Please let me know if this was helpful.
