Can't wake up after suspending: journalctl output
Hi folks,
Not sure what to make of this but I thought I’ll give it ago. Laptop won’t wake up after suspending. Have to reboot through power button.
dec 14 12:26:19 Space kernel: ACPI Error: Method parse/execution failed \_SB.PCI0.SPI1.FPNT._CRS, AE_AML_>
dec 14 12:26:19 Space kernel: ACPI Error: Method execution failed \_SB.PCI0.SPI1.FPNT._CRS, AE_AML_INVALI>
dec 14 12:26:19 Space kernel: ACPI Error: Method parse/execution failed \_SB.PCI0.SPI2.FPNT._CRS, AE_AML_>
dec 14 12:26:19 Space kernel: ACPI Error: Method execution failed \_SB.PCI0.SPI2.FPNT._CRS, AE_AML_INVALI>
dec 14 12:26:21 Space systemd-udevd[273]: eth0: Failed to rename network interface 2 from 'eth0' to 'enp3>
dec 14 12:26:21 Space kernel: iTCO_wdt iTCO_wdt: can't request region for resource [mem 0x00c5fffc-0x00c5>
dec 14 12:26:23 Space kernel: iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
dec 14 12:28:39 Space gdm-password][249136]: gkr-pam: unable to locate daemon control file
dec 14 13:01:24 Space kernel: NVRM: Xid (PCI:0000:01:00): 79, pid=9690, GPU has fallen off the bus.
dec 14 13:15:23 Space kernel: pci_pm_suspend(): nv_pmops_suspend+0x0/0x30 [nvidia] returns -5
dec 14 13:15:23 Space kernel: dpm_run_callback(): pci_pm_suspend+0x0/0x130 returns -5
dec 14 13:15:23 Space kernel: PM: Device 0000:01:00.0 failed to suspend async: error -5
dec 14 13:15:23 Space kernel: PM: Some devices failed to suspend, or early wake event detected
dec 14 13:15:23 Space kernel: iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
dec 14 16:17:24 Space kernel: pci_pm_suspend(): nv_pmops_suspend+0x0/0x30 [nvidia] returns -5
dec 14 16:17:24 Space kernel: dpm_run_callback(): pci_pm_suspend+0x0/0x130 returns -5
dec 14 16:17:24 Space kernel: PM: Device 0000:01:00.0 failed to suspend async: error -5
dec 14 16:17:24 Space kernel: PM: Some devices failed to suspend, or early wake event detected
dec 14 16:17:24 Space kernel: iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
dec 14 16:17:24 Space kernel: snd_hda_codec_hdmi hdaudioC1D0: Unable to sync register 0x7f0100. -5
dec 14 16:17:24 Space gdm[6426]: GLib: Source ID 802 was not found when attempting to remove it
dec 14 16:17:26 Space kernel: pci_pm_suspend(): nv_pmops_suspend+0x0/0x30 [nvidia] returns -5
dec 14 16:17:26 Space kernel: dpm_run_callback(): pci_pm_suspend+0x0/0x130 returns -5
dec 14 16:17:26 Space kernel: PM: Device 0000:01:00.0 failed to suspend async: error -5
dec 14 16:17:26 Space kernel: PM: Some devices failed to suspend, or early wake event detected
dec 14 16:17:26 Space kernel: iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
dec 14 16:17:26 Space kernel: snd_hda_codec_hdmi hdaudioC1D0: Unable to sync register 0x7f0100. -5
dec 14 16:17:26 Space systemd-sleep[298094]: Failed to suspend system. System resumed again: Input/output>
dec 14 16:17:26 Space systemd[1]: Failed to start Suspend.
System information:
  Kernel: 4.19.160-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64
  root=UUID=62481d69-1bcc-4f3a-bb98-f2b96994ca9d rw
  UUID=b51ddf27-7094-44ee-9b19-81f806f2b347
  Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
  Distro: Manjaro Linux
  Type: Laptop System: Dell product: G3 3579 v: N/A serial: <filter> Chassis:
  type: 10 serial: <filter>
  Mobo: Dell model: 05K0D2 v: A00 serial: <filter> UEFI: Dell v: 1.8.1
  date: 03/06/2019
  ID-1: BAT0 charge: 42.2 Wh condition: 42.2/56.0 Wh (75%) volts: 17.3/15.2
  model: BYD DELL 7FHHV94 type: Li-ion serial: <filter> status: Full
  Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
  arch: Kaby Lake family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
  L2 cache: 8192 KiB
  bogomips: 36864
  Speed: 900 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 900 2: 896 3: 900
  4: 897 5: 900 6: 900 7: 897 8: 900
  Type: l1tf
  Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:3e9b
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] driver: nvidia v: 430.64
  bus ID: 01:00.0 chip ID: 10de:1c8d
  Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo
  bus ID: 1-5:2 chip ID: 1bcf:28c1
  Display: x11 server: X.org 1.20.10 compositor: gnome-shell
  driver: modesetting unloaded: intel alternate: fbdev,vesa
  resolution: <xdpyinfo missing>
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.3
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
  v: kernel bus ID: 00:1f.3 chip ID: 8086:a348
  Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
  v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
  Sound Server: ALSA v: k4.19.160-1-MANJARO
  Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
  port: 5000 bus ID: 00:14.3 chip ID: 8086:a370
  vendor: Dell driver: r8168 v: 8.048.03-NAPI port: 3000 bus ID: 03:00.0
  chip ID: 10ec:8168
  IF: eth0 state: down mac: <filter>
  Local Storage: total: 238.47 GiB used: 67.49 GiB (28.3%)
  ID-1: /dev/nvme0n1 model: PC SN520 NVMe WDC 256GB size: 238.47 GiB
  block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2
  serial: <filter> rev: 20200012 scheme: GPT
  ID-1: / raw size: 96.07 GiB size: 94.06 GiB (97.91%) used: 67.42 GiB (71.7%)
  fs: ext4 dev: /dev/nvme0n1p7
  ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%) priority: 9
  dev: /dev/nvme0n1p8
  System Temperatures: cpu: 45.0 C mobo: N/A
  Processes: 246 Uptime: 17m Memory: 7.65 GiB used: 1.41 GiB (18.4%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages:
  pacman: 1610 lib: 427 flatpak: 0 Shell: Bash v: 5.0.18
  running in: gnome-terminal inxi: 3.1.08
Does this mean the issue is with a specific kernel?
Also please see this: [HowTo] Provide System Information
(particularly the first part about system info)
My mistake - fixed both counts!
So, uhh, I am upgraded my kernel to linux54 and the probleem seems to have been resolved…
Learning…
It’s happening again unfortunately…
dec 14 21:27:53 Space kernel: PM: pci_pm_suspend(): nv_pmops_suspend+0x0/0x20 [nvidia] returns -5
dec 14 21:27:53 Space kernel: PM: dpm_run_callback(): pci_pm_suspend+0x0/0x130 returns -5
dec 14 21:27:53 Space kernel: PM: Device 0000:01:00.0 failed to suspend async: error -5
dec 14 21:27:53 Space kernel: PM: Some devices failed to suspend, or early wake event detected
dec 14 21:27:53 Space kernel: iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
dec 14 21:27:53 Space kernel: snd_hda_codec_hdmi hdaudioC1D0: Unable to sync register 0x7f0100. -5
dec 14 21:27:54 Space gdm[1590]: GLib: Source ID 90 was not found when attempting to remove it
dec 14 21:27:55 Space kernel: PM: pci_pm_suspend(): nv_pmops_suspend+0x0/0x20 [nvidia] returns -5
dec 14 21:27:55 Space kernel: PM: dpm_run_callback(): pci_pm_suspend+0x0/0x130 returns -5
dec 14 21:27:55 Space kernel: PM: Device 0000:01:00.0 failed to suspend async: error -5
dec 14 21:27:55 Space kernel: PM: Some devices failed to suspend, or early wake event detected
dec 14 21:27:55 Space kernel: iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
dec 14 21:27:55 Space kernel: snd_hda_codec_hdmi hdaudioC1D0: Unable to sync register 0x7f0100. -5
dec 14 21:27:55 Space systemd-sleep[18479]: Failed to suspend system. System resumed again: Input/output error
dec 14 21:27:55 Space systemd[1]: Failed to start Suspend.
Issue finally resolved using this solution (USB Restart Service).
