Hello people!
After being two stable updates behind, I’ve tried to upgrade my current version of Manjaro, but the terminal keeps telling me this:
resolving dependencies...
:: installing nvidia-utils (460.80-1) breaks dependency 'nvidia-utils=460.73.01' required by linux59-nvidia
Digging for a bit, I’m now aware that the kernel that I’m currently using (5.9.16-1) is EOL, so I should have switched to a more recent one. Problem is, I cannot install a new one because it tells me to update the system first:
sudo mhwd-kernel -i linux510
core 165,3 KiB 1559 KiB/s 00:00 [---------------------------------------------] 100%
extra 1910,3 KiB 4,18 MiB/s 00:00 [---------------------------------------------] 100%
community 6,5 MiB 5,92 MiB/s 00:01 [---------------------------------------------] 100%
multilib 178,1 KiB 13,4 MiB/s 00:00 [---------------------------------------------] 100%
The following packages are out of date, please update your system first: adwaita-icon-theme alsa-card-profiles android-tools android-udev aom at-spi2-core attica baloo bash bashrc-manjaro bluedevil bluez-qt botan breeze breeze-icons btrfs-progs bubblewrap device-mapper faudio ffmpeg file firefox flac frameworkintegration fwupd game-devices-udev gegl gimp glslang gnome-desktop gnustep-base gst-plugins-bad gst-plugins-bad-libs gtk-update-icon-cache gvfs gvfs-afc gvfs-gphoto2 gvfs-mtp gvfs-nfs gvfs-smb harfbuzz harfbuzz-icu hdparm imagemagick iproute2 iputils js78 kactivities kactivities-stats kactivitymanagerd karchive kauth kbookmarks kcmutils kcodecs kcompletion kconfig kconfigwidgets kcontacts kcoreaddons kcrash kdbusaddons kde-cli-tools kde-gtk-config kdeclarative kdecoration kded kdelibs4support kdeplasma-addons kdesu kdnssd kdoctools kemoticons kfilemetadata kgamma5 kglobalaccel kguiaddons kholidays khotkeys khtml ki18n kiconthemes kidletime kimageformats kinfocenter kinit kio kio-extras kirigami2 kitemmodels kitemviews kjobwidgets kjs kmenuedit knewstuff knotifications knotifyconfig konsole kpackage kparts kpeople kpty kquickcharts krunner kscreen kscreenlocker kservice ksshaskpass ksysguard ktexteditor ktextwidgets kunitconversion kwallet kwallet-pam kwayland kwayland-integration kwayland-server kwidgetsaddons kwin kwindowsystem kwrited kxmlgui less lib32-at-spi2-core lib32-faudio lib32-glib-networking lib32-gtk3 lib32-harfbuzz lib32-libepoxy lib32-libglvnd lib32-librsvg lib32-libva-mesa-driver lib32-libxcrypt lib32-libxkbcommon lib32-mesa lib32-mpg123 lib32-nvidia-utils lib32-readline lib32-systemd lib32-vulkan-icd-loader libass libepoxy libfdk-aac libglvnd libheif libimagequant libinput libkscreen libksysguard libldap libmanette libmicrohttpd libnm libplacebo libreoffice-still librsvg libsidplayfp libtool libupnp libva-mesa-driver libwacom libxcrypt libxkbcommon libxkbcommon-x11 linux-firmware lvm2 mailcap manjaro-release md4c mesa mhwd-nvidia milou mjpegtools modemmanager-qt mpfr mpg123 nano ncurses networkmanager networkmanager-openconnect networkmanager-pptp networkmanager-qt nvidia-utils oath-toolkit openexr oxygen oxygen-icons pavucontrol-qt perl-libwww pipewire plasma-desktop plasma-framework plasma-integration plasma-nm plasma-pa plasma-workspace plasma-workspace-wallpapers polkit-kde-agent poppler poppler-glib poppler-qt5 powerdevil ppp prison protobuf purpose python python-chardet python-pep517 python-pillow python-pulsectl python-reportlab python-setuptools python-six qpdf qqc2-desktop-style qt5-base qt5-webengine readline samba sddm sddm-kcm shaderc smbclient snapd solid sonnet spirv-tools srt svt-av1 syntax-highlighting systemd systemd-libs systemd-sysvcompat systemsettings threadweaver ttf-liberation unarchiver vi vlc vte-common vte3 vulkan-icd-loader wayland-protocols webkit2gtk wine-staging wpebackend-fdo xdg-desktop-portal xdg-desktop-portal-kde xorgproto yay zsh-completions
Do you want to continue anyway? [y/N]
Saying yes (I presume I should have not), it tells me the same as before:
Here is my inxi output:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=92df1057-74e1-4d7e-b9b7-18efcc00c590 rw quiet apparmor=1
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: MSI model: B150M MORTAR (MS-7972) v: 2.0
serial: <filter> UEFI: American Megatrends v: C.90 date: 11/03/2016
RAM: total: 7.72 GiB used: 2.37 GiB (30.6%)
Info: Quad Core model: Intel Core i5-7500 bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 9E (158) stepping: 9 microcode: DE cache: L2: 6 MiB
bogomips: 27208
Speed: 2862 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 2862 2: 3172
3: 3103 4: 3071
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ASUSTeK driver: nvidia
v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 3840x1080 s-dpi: 101 s-size: 966x272mm (38.0x10.7")
s-diag: 1004mm (39.5")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-3: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:2 chip-ID: 0d8c:0005
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.02 TiB used: 216.28 GiB (20.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-21WN4A0
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SV300S37A120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: BBF0 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD1 rev: LE00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 29.3 GiB size: 28.71 GiB (98.00%) used: 17.47 GiB (60.8%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 92df1057-74e1-4d7e-b9b7-18efcc00c590
ID-2: /boot/efi raw-size: 511 MiB size: 510 MiB (99.80%)
used: 320 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 03C4-58A3
ID-3: /home raw-size: 550.84 GiB size: 541.19 GiB (98.25%)
used: 198.81 GiB (36.7%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: c9b8a5d8-d00d-4e6c-b5ce-2a5ad660faea
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 22100c29-09a2-46a6-aecd-ca613b8a8957
ID-1: /dev/sda4 maj-min: 8:4 size: 346.97 GiB fs: ntfs label: N/A
uuid: 0CEC4D7D3AA0FDF6
ID-2: /dev/sdb1 maj-min: 8:17 size: 529 MiB fs: ntfs
label: Recuperaci\xc3\xb3n uuid: CA763F4C763F3891
ID-3: /dev/sdb2 maj-min: 8:18 size: 100 MiB fs: vfat label: N/A
uuid: F43F-F792
ID-4: /dev/sdb3 maj-min: 8:19 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-5: /dev/sdb4 maj-min: 8:20 size: 111.16 GiB fs: ntfs label: N/A
uuid: 96026018025FFF9B
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-4:2 info: C-Media Blue Snowball type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0005 class-ID: 0300
serial: <filter>
Device-2: 1-9:3 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID
power: 100mA chip-ID: 258a:0001 class-ID: 0300
Device-3: 1-10:4 info: Trust GXT 144 Gaming Mouse type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 256mA chip-ID: 145f:026d class-ID: 0301
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 44.0 C mobo: 29.8 C gpu: nvidia temp: 52 C
Processes: 173 Uptime: 36m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 1368 lib: 429 flatpak: 0
Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.04
How should I proceed so I can use a new kernel and update my system?
