I was upgrading my system with pacman -Syu and it gave me this error. I tried changing pacman mirrors and pacman -Syyu but with same result.
warning: gnome-initial-setup: local (40.0-1) is newer than community (3.38.4-2)
warning: pamac-cli: local (10.1.2-0.1) is newer than extra (10.0.6-2)
warning: pamac-common: local (10.1.2-0.1) is newer than extra (10.0.6-2)
warning: pamac-flatpak-plugin: local (10.1.2-0.1) is newer than extra (10.0.6-2)
warning: pamac-gnome-integration: local (10.1.2-0.1) is newer than extra (10.0.6-2)
warning: pamac-gtk: local (10.1.2-0.1) is newer than extra (10.0.6-2)
warning: pamac-snap-plugin: local (10.1.2-0.1) is newer than extra (10.0.6-2)
resolving dependencies...
:: installing nvidia-utils (460.80-1) breaks dependency 'nvidia-utils=460.73.01' required by linux59-nvidia`
Then I came to know that kernel 5.9 is no longer supported. So I run pacman -S linux512 and I tried to remove linux 5.9 kernel with pacman -Rs linux59. But it showed me this
checking dependencies...
:: removing linux59 breaks dependency 'linux59' required by linux59-nvidia
After that I ran pacman -Syu anyway but got the same error. How can I fix this?
linux59 has been EOL for a while and no longer exists in the repo.
Please change kernel to latest LTS or supported kernel, before you update.
Thatās because you still have kernel modules installed that needs the old kernel. Which is all handled by Manjaro Settings Managerās Kernel management. So use that.
I removed the older kernel by using sudo mhwd-kernel -r linux59. But it seem to have removed linux59-nvidia also. Do I need to do anything else? Should I install linux512-nvidia?
I had linux 59 and I installed the latest update with 460.80⦠resulting in the system not bootable, can you please tell me what commands (in terminal)to use to start the system. I am new to Manjaro
Hi,
Iām trying to do this as well and Iām confused. Iām in the GUI, and itās showing me that 5.9 is running and installed. So I try hitting install on the LTS 5.10.36-2. itās saying changes were made successfully, but this is in the details
The following packages will be installed:
linux510
linux510-nvidia
Starting
resolving dependenciesā¦
looking for conflicting packagesā¦
:: installing nvidia-utils (460.80-1) breaks dependency ānvidia-utils=460.73.01ā required by linux59-nvidia
Done ā¦
I tried restarting my computer but 5.9 is still installed. What am I doing wrong?
You havenāt switched to 5.10, only installed it.
When your computer is booting, press Esc, until you see your GRUB menu. You can choose the newer kernel under advanced options.
Hi,
So I actually went through and uninstalled 5.9 and then installed 5.10. Now I broke my system. When I go to boot after I select Manjaro on the grub menu I just get stuck in my splash screen. I tried the advanced screen but my only option is Kernel 5.10.36. Any idea how I can get it working?
Did the Nvidia drivers install without errors this time? And by āmy splash screenā, do you mean the desktop environment or UEFI/BIOS one?
If latter, youāll likely need to reinstall the Nvidia drivers through a live environment.
I didnāt run the system update before restarting my machine. I used the GUI to remove the old kernel and install the new one, then restarted.
By splash screen, I mean the manufacturer logo splash screen. (AlienWare).
I run a dual boot with windows and manjaro. The PC boots to the grub menu, and when I try to go to manjaro from there it just gets stuck in the splash screen.
So, Iām not sure how to reinstall Nvidia drivers through a live environment. I am going to do some resarch on that now, but if you donāt mind helping me understand that a little more Iād be super grateful. Iām hoping to avoid doing a fresh install.
Not through a bootable USB right? I tried that once but it didnāt seem like the operating system on that USB knew about the operating system on my hard drive.
Quite the opposite, you need a bootable USB. Using chroot while in the live environment: GRUB/Restore the GRUB Bootloader - Manjaro
After a successful chroot, you wanna perform a full system upgrade.
Thank you for all your help, itās really appreciated. I got a bootable usb and got into chroot and then did a full system upgrade as well as grub. However, I still have the same problem. I went back into the live environment and chrooted again, and it says my system is up to date. Any idea where I should go from here? Is there any information I need to post?
