I tried updating my system, using sudo pcaman -Syyu, but it fails with the following:
I tried looking around, but couldn’t get any of the proposed solutions to work.
sudo pacman -Syyu
error: could not register 'sublime-text' database (database already registered)
core 168.6 KiB 694 KiB/s 00:00 [#######################################################################################] 100%
extra 1923.9 KiB 1673 KiB/s 00:01 [#######################################################################################] 100%
community 6.6 MiB 2.64 MiB/s 00:02 [#######################################################################################] 100%
multilib 177.4 KiB 5.25 MiB/s 00:00 [#######################################################################################] 100%
sublime-text 1831.0 B 0.00 B/s 00:00 [#######################################################################################] 100%
sublime-text.sig 543.0 B 0.00 B/s 00:00 [#######################################################################################] 100%
:: Some packages should be upgraded first...
resolving dependencies...
Packages (2) archlinux-keyring-20210616-1 manjaro-keyring-20210622-1
Total Installed Size: 1.49 MiB
Net Upgrade Size: 0.01 MiB
(2/2) checking keys in keyring [#######################################################################################] 100%
downloading required keys...
:: Import PGP key 428F7ECC7117F726, "Helmut Stult <helmut@manjaro.org>"? [Y/n]
error: key "428F7ECC7117F726" could not be looked up remotely
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
:: Replace adobe-source-sans-pro-fonts with extra/adobe-source-sans-fonts? [Y/n]
:: Replace lib32-libcanberra-pulse with multilib/lib32-libcanberra? [Y/n]
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n]
:: Replace pamac-common with extra/libpamac? [Y/n]
:: Replace pamac-flatpak-plugin with extra/libpamac-flatpak-plugin? [Y/n]
:: Replace pamac-snap-plugin with extra/libpamac-snap-plugin? [Y/n]
:: Replace qca with extra/qca-qt5? [Y/n]
:: installing libcanberra (0.30+2+gc0620e4-5) breaks dependency 'libcanberra=0.30+2+gc0620e4-3' required by libcanberra-gstreamer
