I’ve been trying to run League of Legends on my Manjaro system using Lutris but I keep running into a problem.
The Riot launcher installs correctly, and the game seems to install properly too, however when I click play to start the game, the splash screen appears briefly, and then nothing happens. The launcher acts as if the game has started and then stopped.
If you need a any logs please tell me how to obtain them and I will provide them.
Found a solution here (under “How to install League of Legends”), here and here.
tl;dr I was trying to use Vulkan with an AMD Radeon HD 7770. To enable Vulkan, use any text editor to edit /etc/default/grub to add the boot parameters
