when updating this friday, I was told that this package was interrupting with the upgrade (did not record the message) and I, stupidly, removed it:
sudo pacman -R nvidia-519
Now I can’t boot into graphical environment (i3).
I tried
sudo pacman -S nvidia-519
but that just says:
error: target not found: nvidia-519
I tried downgrading the kernel to the LTS 515, but that still did not help
sudo mhwd -a pci nonfree 0300
which just says:
skipping already installed config 'video-nvidia' for device
So I’ve tried googling and searching the forums but I couldn’t find anything I could use (or, that I could understand, probably)
I can get to a terminal, and output these that might help:
output of inxi -Fza
Kernel: 5.15.89-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=f61cf363-eb5f-4a1e-86cc-e0379407767b
rw quiet apparmor=1 security=apparmor udev.log_priority=3
Console: tty 2 DM: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: LENOVO product: 30BYS2N000 v: ThinkStation P520c
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: LENOVO model: 1036 v: SDK0Q40104 WIN 3305667182328 serial: <superuser required>
UEFI: LENOVO v: S03KT21A date: 10/26/2018
Info: model: Intel Xeon W-2135 bits: 64 type: MT MCP arch: Skylake level: v4 note: check
process: Intel 14nm family: 6 model-id: 0x55 (85) stepping: 4 microcode: 0x2006E05
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB L3: 8.2 MiB desc: 1x8.2 MiB
Speed (MHz): avg: 1200 high: 1201 min/max: 1200/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 1201 6: 1200 7: 1200 8: 1200
9: 1200 10: 1200 11: 1200 12: 1200 bogomips: 88824
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA GP107GL [Quadro P1000] driver: N/A alternate: nouveau non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 65:00.0
chip-ID: 10de:1cb1 class-ID: 0300
Display: server: X.org v: 1.21.1.6 driver: N/A tty: 215x45
API: OpenGL Message: GL data unavailable in console. Try -G --display
Device-1: Intel 200 Series PCH HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 65:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Sound API: ALSA v: k5.15.89-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.64 running: no
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 476.94 GiB used: 198.57 GiB (41.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD9SB8W512G1001 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4001
scheme: GPT
ID-1: / raw-size: 268.55 GiB size: 263.28 GiB (98.04%) used: 198.57 GiB (75.4%) fs: ext4
dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 427.3 MiB size: 426.5 MiB (99.80%) used: 300 KiB (0.1%) fs: vfat
dev: /dev/sda7 maj-min: 8:7
ID-1: swap-1 type: partition size: 37.11 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda6
maj-min: 8:6
System Temperatures: cpu: 31.0 C mobo: N/A
Processes: 197 Uptime: 12m wakeups: 0 Memory: 31.01 GiB used: 656.1 MiB (2.1%) Init: systemd
v: 252 default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages:
pm: pacman pkgs: 1870 libs: 375 tools: pamac,yay Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: tty 2 inxi: 3.3.24
output of sudo mhwd-kernel -li
e[32mCurrently running:e[0m 5.15.89-1-MANJARO (linux515)
* linux515
* linux519
* linux61
