I have a realtek wifi and bluetooth adapter and only able to use blutooth and can’t get wifi to work wifi also i’m quite new at manjaro and linux c820 Realtek Semiconductor Corp. 802.11ac NIC
I have used Linux mint and Ubantu forums to try to fix this problem, The adapter is being recognized by Linux. I have used wine, but have only gone as far as reboot computer, but it is in wine, and i have not gotten farther than that.
lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 003: ID 0bda:c820 Realtek Semiconductor Corp. 802.11ac NIC
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 062a:5918 MosArt Semiconductor Corp. 2.4G Keyboard Mouse
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
can this adapter really work, or should i get a panda wireless adapter thanks
i got this, i tried without the brackets, but it did not work so i tried it with and got this:
** (pamac:3279): WARNING **: 04:59:20.923: database.vala:1054: Error while compiling regular expression [link] at char 37: range out of order in character class
** (pamac:3279): WARNING **: 04:59:20.954: database.vala:1054: Error while compiling regular expression [link] at char 37: range out of order in character class
** (pamac:3279): WARNING **: 04:59:21.057: database.vala:1054: Error while compiling regular expression [link] at char 37: range out of order in character class
** (pamac:3279): WARNING **: 04:59:21.347: database.vala:1054: Error while compiling regular expression [link] at char 37: range out of order in character class
** (pamac:3279): WARNING **: 04:59:21.359: database.vala:1054: Error while compiling regular expression [link] at char 37: range out of order in character class
In whatever package manager you are using e.g Pamac, Octopi search for linux59-headers or whatever headers for the kernel you seek. It might be a good idea to read the Manjaro wiki:
