Can't get past booting from usb to installation
Everytime I try to install Manjaro on my new surface laptop 4 the Ryzen 5 edition on with 16g ram I get stuck at the part right after I select the drivers
I’ve disabled ***Secure Boot (off) and I can see this to be true when I pull up msinfo32
I’m new to all this but really wanted this new laptop to be my everyday windows/Linux dual boot machine
Any help would be appreciated
Edit: some more details
Summary
		Operating System
			Windows 11 Home 64-bit
		CPU
			AMD Ryzen 5	33 °C
			Renoir 7nm Technology
		RAM
			15.0GB Dual-Channel DDR4 @ 2122MHz (40-39-45-90)
		Motherboard
			Microsoft Corporation Surface Laptop 4 (FP6)
		Graphics
			LQ135P1JX51 (2256x1504@60Hz)
			512MB ATI AMD Radeon Graphics (Microsoft)
		Storage
			238GB Hitachi HFM256GDGTNI-82A0A (Unknown (SSD))
			14GB USB DISK 2.0 USB Device (USB )
		Optical Drives
			No optical disk drives detected
		Audio
			Realtek High Definition Audio
Operating System
	Computer type: Virtual
	Installation Date: 31/08/2022 3:20:37 PM
		Windows Security Center
			User Account Control (UAC)	Enabled
			Notify level	2 - Default
			Firewall	Enabled
		Windows Update
			AutoUpdate	Not configured
		Windows Defender
			Windows Defender	Enabled
		Antivirus
			Antivirus	Enabled
			Display Name	Windows Defender
			Virus Signature Database	Up to date
		.NET Frameworks installed
			v4.8 Full
			v4.8 Client
		Internet Explorer
			Version	11.1.22000.0
		PowerShell
			Version	5.1.22000.1
		Environment Variables
			USERPROFILE	C:\Users\iberk
			SystemRoot	C:\windows
				User Variables
					OneDrive	C:\Users\iberk\OneDrive
					OneDriveConsumer	C:\Users\iberk\OneDrive
					Path	C:\Users\iberk\AppData\Local\Microsoft\WindowsApps
					TEMP	C:\Users\iberk\AppData\Local\Temp
					TMP	C:\Users\iberk\AppData\Local\Temp
				Machine Variables
					ComSpec	C:\windows\system32\cmd.exe
					DriverData	C:\Windows\System32\Drivers\DriverData
					NUMBER_OF_PROCESSORS	12
					OS	Windows_NT
					Path	C:\windows\system32
					C:\windows
					C:\windows\System32\Wbem
					C:\windows\System32\WindowsPowerShell\v1.0\
					C:\windows\System32\OpenSSH\
					PATHEXT	.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
					PROCESSOR_ARCHITECTURE	AMD64
					PROCESSOR_IDENTIFIER	AMD64 Family 23 Model 96 Stepping 1, AuthenticAMD
					PROCESSOR_LEVEL	23
					PROCESSOR_REVISION	6001
					PSModulePath	%ProgramFiles%\WindowsPowerShell\Modules
					C:\windows\system32\WindowsPowerShell\v1.0\Modules
					TEMP	C:\windows\TEMP
					TMP	C:\windows\TEMP
					USERNAME	SYSTEM
					windir	C:\windows
Also tried selecting both the open source and proprietary drivers options
After selecting the driver option and the install starts I see a line saying:
cp:can not create directory :‘/run/initramfs/’ no such file or directory
This happens with both the minimal and full editions of gnome
Let me know if there is other info I can provide that could help
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
    (Wisdom lies in reading :wink: )
TIP: enable UEFI
You have to disable Secure Boot.
Thank you, I’ve used speccy to help provide some additional info in an edit
I’ve gone through this and applied the what was possible from the appropriate checklists but I still can’t get past the USB boot and selecting the drivers to use.
I’m left staring at and installation terminal which runs for a couple of seconds then stops/freezes
I never end up getting to the graphical installer
