Hi, I just installed Manjaro and I’m struggling to get my main monitor to work at 1440p 144hz. Here’s my xrandr -q
output:
$ xrandr -q
Screen 0: minimum 8 x 8, current 4480 x 1440, maximum 32767 x 32767
DVI-D-0 connected primary 2560x1440+1920+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95*+
1920x1080 60.00
1680x1050 59.95
1440x900 59.89
1280x1024 75.02 60.02
1280x960 60.00
1280x800 59.81
1280x720 60.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
640x480 75.00 72.81 59.94
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 476mm x 268mm
1920x1080 60.00*+
1680x1050 59.95
1440x900 59.89
1280x960 60.00
1280x800 59.81
1280x720 60.00
1152x864 75.00
640x480 75.00 59.94
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
2560x1440_144.00_gtf (0x22d) 807.690MHz -HSync +VSync
h: width 2560 start 2784 end 3072 total 3584 skew 0 clock 225.36KHz
v: height 1440 start 1441 end 1444 total 1565 clock 144.00Hz
2560x1440_144.00_cvt (0x22e) 808.750MHz -HSync +VSync
h: width 2560 start 2792 end 3072 total 3584 skew 0 clock 225.66KHz
v: height 1440 start 1443 end 1448 total 1568 clock 143.91Hz
As you can see, I tried to create custom resolutions using gtf
and cvt
but adding either of them using xrandr
results in this error:
$ xrandr --addmode DVI-D-0 "2560x1440_144.00_gtf"
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 18 (RRAddOutputMode)
Serial number of failed request: 45
Current serial number in output stream: 46
inxi -SGx
$ inxi -SGx
System: Host: xxxx Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.21.4
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 460.73.01 bus-ID: 20:00.0
Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia resolution: 1: 2560x1440~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01 direct render: Yes
Current xorg.conf:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 460.73.01
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Acer XF270HU"
HorizSync 31.0 - 90.0
VertRefresh 56.0 - 76.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 1060 6GB"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-0"
Option "metamodes" "DVI-D-0: 2560x1440 +1920+0, DP-2: nvidia-auto-select +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
I also found this line in /var/log/Xorg.0.log:
[ 4396.038] (--) NVIDIA(GPU-0): Ancor Communications Inc ASUS VS228 (DFP-4): 1440.0 MHz maximum pixel clock
The monitor it mentions here is actually my 60hz 1080p monitor, I don’t know if this contributes to the problem. The “corresponding” line for the 1440p144hz monitor looks like this:
[ 4302.028] (--) NVIDIA(GPU-0): Acer XF270HU (DFP-0): 330.0 MHz maximum pixel clock
I did some research already but I couldn’t find anything that fixed my issue, maybe some of you know what’s wrong… Thanks in advance!
