I can’t get my Manjaro to update using Pacman
I get this error
What am I doing wrong?
I get this error
Hello,
Make a habit to read the announcements, otherwise is nothing wrong on what you do, but sometimes is required a manual intervention or a workaround:
This seemed to fix it. thank you for the tip AND the solution
