Hi, I’m writing my thesis in latex with texstudio. I had also to install the compiler that is TexLive but I can’t find it in the application menu. I’d like to install an additional package and I had to do it with TexLive.
Do u know how can I do to start it?
Hi. You have to install TexLive first, because TexStudio is just an editor. You have two options:
- Install package
texlive-core
from the repositories and probably some additionaltexlive-...
packages you need. - Install TexLive from TUG site. See TeX Live - TeX Users Group. You also can install
texlive-installer
from the AUR and use it to install TexLive.
I already installed texlive. I just can’t find it.
There is not a single application called texlive. TeX Live provides multiple programs. Most programs don’t have a GUI. Simply open a Terminal (in KDE Konsole) and start the program you need.
If you are looking for tlmgr
, check out the arch wiki.
Thank you , I didn’t know it wasn’t a single application
