I wanted to move my linux install to a new drive, so I installed Manjaro on that drive then copied my file system overwriting the installed one. When I installed the new one, I chose a swap with hibernate abilities when my old one I had no swap. Something interesting to me is without any setup, it was using the swap partition and allowed hibernation but didn’t resume correctly, just starting as if it was off. I decided to try to set up hibernation. Nothing I have tried has worked though so far.
I added the partition UUID to grub. Two places just to make sure.
I have made sure to sudo mkinitcpio -P and sudo update-grub each time. Nothing has worked so far, grub just does it’s normal menu then I boot normally.
I recently got a new ROG motherboard, so I don’t know if that affects things. I don’t know much about BIOS stuff, but I can say I have secure boot on and CSM off if that affects things
I have tried different things with these, but this is what they currently are.
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=3fbbd881-cb4a-4e22-a443-ecdbd1d324dc / ext4 noatime 0 1
UUID=F614-0982 /boot/efi vfat umask=0077 0 2
UUID=ff28484c-6ab7-41ad-9276-d8107ce46f7b none swap defaults 0 0
tmpfs /tmp tmpfs noatime,mode=1777 0 0
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash udev.log_priority=3 resume=UUID=ff28484c-6ab7-41ad-9276-d8107ce46f7b"
GRUB_CMDLINE_LINUX="resume=UUID=ff28484c-6ab7-41ad-9276-d8107ce46f7b"
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
GRUB_DISABLE_OS_PROBER=false
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
The old/current file system did not say it had any updates available when I made the new installation, and currently doesn’t and hasn’t since. I don’t know what the update status of the new installation was, but I downloaded a minimal image right before making it, which I used. I replaced the root partition, but not the efi boot one. I just used the boot one the new installation created.
I never actually booted the fresh install. I completely overwrote it’s partition with my existing manjaro root partition, which was up-to-date, then edited the fstab and I think also updated grub.
…and what happened to files in ~/.gnupg~/.kde4~/.local~/.ssr for example? Or do you mean everything including Home folder data? If you overworte everything I would try to update and the to restore the boot loader.
I used GParted in a bootable media and just copied the whole old root partition into the new one, supposedly completely overwriting it. I expected it to not work, that’s why I still have the original installation on the old drive, but it seems to be working fine for me right now.
Then double check the UUID of the / partition. Probably it’s not matching with your /etc/fstab entry. Afterwards, I still would recommend to restore the boot loader.
I’ve tried restoring the boot loader, and the system seems up-to-date. I found an option about some sort of fast boot and disabled it; that didnt seem to work. idk what the UEFI stuff is, but it seems like it has always been in it I’m guessing? Seems I’m using the right boot entry.
I may just delete the swap partition; I don’t need hibernate too badly.
