I´m trying to use Google Meet and can not enable video device on Chromium…v4l2 recognizes it when i run v4l2-ctl --list-devices, it shows my video device, which is a Dazzle Pinacle…
I use this device with OBS without troubles…
CPU: AMD Athlon 3000G with Radeon Vega Graphics
GPU: AMD® Radeon™ vega 3 graphics
Thanks
Welcome to Manjaro!
Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… -
An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command) -
Does it work on Firefox?
Hi!!! Sorry by my delay on answer you, expected that the system notifies me about an answer…by email …then…sorry again:
Kernel: 5.4.101-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=3e56f450-cdc8-415b-bb53-88599061b419 ro quiet splash apparmor=1
Desktop: GNOME 3.38.3 tk: GTK 3.24.26 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Desktop System: TSINGHUA TONGFANG product: H81-M1 v: N/A
serial: <filter> Chassis: type: 3 serial: <filter>
Mobo: PEGATRON model: H81-M1 v: 1.02 serial: <filter>
UEFI: American Megatrends v: P014AP0M date: 01/03/2014
RAM: total: 7.61 GiB used: 4.82 GiB (63.4%)
Info: Quad Core model: Intel Core i5-4440 bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 L2 cache: 6 MiB
bogomips: 24753
Speed: 3093 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 3093 2: 3093
3: 3093 4: 3093
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Pegatron driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0412
class ID: 0300
Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: i915 note: n/a (using device driver) - try sudo/root display ID: 0
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Pegatron driver: snd_hda_intel v: kernel bus ID: 00:03.0
chip ID: 8086:0c0c class ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Pegatron
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
class ID: 0403
Device-3: C-Media Audio Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-7:3 chip ID: 0d8c:000c
class ID: 0300
Device-4: Pinnacle Systems Dazzle DVC100 Audio Device type: USB
driver: em28xx,snd-usb-audio bus ID: 2-10:5 chip ID: 2304:021a
class ID: 0102
Sound Server: ALSA v: k5.4.101-1-MANJARO
vendor: Pegatron driver: r8169 v: kernel port: e000 bus ID: 03:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Message: No Bluetooth data was found.
Local Storage: total: 2.73 TiB used: 761.93 GiB (27.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1CH162
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC47 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1ER162
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC45 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: Expansion
serial: <filter> rev: 060E scheme: MBR
ID-1: / raw size: 60 GiB size: 58.81 GiB (98.01%) used: 17.03 GiB (29.0%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 3e56f450-cdc8-415b-bb53-88599061b419
ID-2: /boot/efi raw size: 570 MiB size: 568.8 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 6407-0824
ID-3: /home raw size: 30 GiB size: 29.4 GiB (98.01%) used: 2.49 GiB (8.5%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 3c41e050-f993-4d02-8b46-1a5374b6b235
ID-4: /mnt/Cosas raw size: 498.76 GiB size: 498.76 GiB (100.00%)
used: 246.38 GiB (49.4%) fs: ntfs dev: /dev/sdb6 maj-min: 8:22 label: Cosas
uuid: 5B88BB3935ED0CB9
ID-5: /mnt/Trabajo1 raw size: 220.23 GiB size: 220.23 GiB (100.00%)
used: 134.55 GiB (61.1%) fs: ntfs dev: /dev/sdb5 maj-min: 8:21
label: Trabajo1 uuid: 74F37E206086A289
ID-6: /mnt/Trabajo2 raw size: 156.25 GiB size: 156.25 GiB (100.00%)
used: 83.04 GiB (53.1%) fs: ntfs dev: /dev/sdb7 maj-min: 8:23
label: Trabajo2 uuid: 045DFFE75DF35099
ID-7: /mnt/Trabajo3 raw size: 832.85 GiB size: 818.78 GiB (98.31%)
used: 76 MiB (0.0%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: Trabajo3
uuid: a1f55991-2e81-4153-82a6-fc2adb53f56a
ID-8: /run/media/boris/HDOcio raw size: 585.94 GiB size: 575.74 GiB (98.26%)
used: 199.77 GiB (34.7%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: HDOcio
uuid: be156cef-32af-4df8-90c0-17b770979205
ID-9: /run/media/boris/HDWork raw size: 345.58 GiB size: 339.15 GiB (98.14%)
used: 78.59 GiB (23.2%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: HDWork
uuid: c539c530-6430-4817-bbc0-30f936f900f4
ID-1: /dev/sda1 maj-min: 8:1 size: 8.1 GiB fs: swap label: N/A
uuid: 1dd8f952-9877-40ac-aca2-00c9c38d1ecd
ID-2: /dev/sdb3 maj-min: 8:19 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8008 class ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0
Device-1: 2-5:2 info: Realtek RTS5182 Card Reader type: Mass Storage
driver: ums-realtek interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 0bda:0184 class ID: 0806 serial: <filter>
Device-2: 2-7:3 info: C-Media Audio Adapter type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s chip ID: 0d8c:000c class ID: 0300
Device-3: 2-9:4
info: Seagate RSS LLC USB 3.0 bridge [Portable Expansion Drive]
type: Mass Storage driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s
chip ID: 0bc2:2320 class ID: 0806 serial: <filter>
Device-4: 2-10:5 info: Pinnacle Systems Dazzle DVC100 Audio Device
type: Audio driver: em28xx,snd-usb-audio interfaces: 3 rev: 2.0
speed: 480 Mb/s chip ID: 2304:021a class ID: 0102
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 8087:8000 class ID: 0900
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003 class ID: 0900
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 232 Uptime: 1h 37m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1233 lib: 276 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.3.01
Sorry, i have my Dazzle unplugged when i run inxi… please note that i have a Dazzle Pinnacle to capture video input…and i´m using it with OBS…all rigth with OBS…and this is the output of v4l2-ctl --list-devices…
Pinnacle Dazzle DVC 90/100/101/ (usb-0000:00:14.0-10):
/dev/video0
Thanks, hope now my question is well formatted
Please edit your original reply by pressing the three dots and then the pencil below that post and including a full inxi with the camera hooked up.
Then please delete this comment and
this one so get a notification that I can delete this comment just like I deleted the other one of mine and have a brand new look at your full hardware config.
I cannot edit, nor delete my original question…
what can i do???
Not after 5 days you cannot…
Just post another answer instead.
Hi @Fabby , thanks, then…my problem is that i have my camera connected trough a Dazzle Pinacle USB device, and i canot use it with Chromium or Chrome…here is my inxi --admin --verbosity=7 --filter --no-host --width output, a curious note , i see the device only on Audio section…:
Kernel: 5.10.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=3c26c08a-7441-4c54-8fa4-6171113c87c6 ro quiet splash apparmor=1
security=apparmor resume=UUID=46a8c828-bcc5-4a9d-9536-feb3aeb98ef4
udev.log_priority=3
Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 5222 date: 10/14/2019
RAM: total: 7.64 GiB used: 4.94 GiB (64.7%)
Info: Dual Core model: AMD Athlon 3000G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108109 L2 cache: 1024 KiB bogomips: 27959
Speed: 1660 MHz min/max: 1600/3500 MHz boost: enabled Core speeds (MHz):
1: 1660 2: 1513 3: 1647 4: 1533
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
Device-1: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus ID: 07:00.0 chip ID: 1002:15d8 class ID: 0300
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa display ID: 0
OpenGL: renderer: AMD Radeon Vega 3 Graphics (RAVEN2 DRM 3.40.0
5.10.19-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 07:00.1 chip ID: 1002:15de
class ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 07:00.6 chip ID: 1022:15e3 class ID: 0403
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-4:2 chip ID: 0d8c:000c
class ID: 0300
driver: em28xx,snd-usb-audio bus ID: 1-9:2 chip ID: 2304:021a class ID: 0102
Sound Server: ALSA v: k5.10.19-1-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 05:00.0
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.83 TiB used: 419.91 GiB (22.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
rotation: 7200 rpm serial: <filter> rev: CC43 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: Expansion
ID-3: /dev/sdc maj-min: 8:32 type: USB model: General size: 14.65 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 5.00
ID-1: / raw size: 97.66 GiB size: 95.62 GiB (97.92%) used: 17.33 GiB (18.1%)
uuid: 3c26c08a-7441-4c54-8fa4-6171113c87c6
ID-2: /boot/efi raw size: 513 MiB size: 512 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 5DE1-65FE
ID-3: /home raw size: 44.11 GiB size: 43.16 GiB (97.86%)
used: 3.7 GiB (8.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 6d5aa671-71f0-458f-996d-3b770a22ba11
ID-4: /mnt/Cosas raw size: 332.03 GiB size: 325.82 GiB (98.13%)
used: 42.35 GiB (13.0%) fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: Cosas
uuid: 57f3100d-f02c-48c2-823b-08a240ec7b66
ID-5: /mnt/Trabajo1 raw size: 224.61 GiB size: 220.08 GiB (97.99%)
used: 68.13 GiB (31.0%) fs: ext4 dev: /dev/sda5 maj-min: 8:5
label: Trabajo 1 uuid: 0b0c5b85-76d6-4585-8ff0-53a350075d24
ID-6: /mnt/Trabajo2 raw size: 224.61 GiB size: 220.08 GiB (97.99%)
used: 4.29 GiB (1.9%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: Trabajo 2
uuid: bc3fda77-9216-4ec2-a9bd-203b12474b76
ID-7: /run/media/boris/B-Video_16G raw size: 14.65 GiB
size: 14.65 GiB (100.00%) used: 5.39 GiB (36.8%) fs: ntfs dev: /dev/sdc
maj-min: 8:32 label: B-Video_16G uuid: 124BCEDB7F3FB408
used: 200.11 GiB (34.8%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: HDOcio
used: 78.62 GiB (23.2%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: HDWork
ID-1: /dev/sda1 maj-min: 8:1 size: 8 GiB fs: swap label: N/A
uuid: 46a8c828-bcc5-4a9d-9536-feb3aeb98ef4
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Device-1: 1-3:5 info: LogiLink UDisk flash drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: abcd:1234 class ID: 0806 serial: <filter>
Device-2: 1-9:2 info: Pinnacle Systems Dazzle DVC100 Audio Device
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 3-4:2 info: C-Media Audio Adapter type: Audio,HID
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 4-3:2
type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 32.5 C mobo: N/A gpu: amdgpu temp: 32.0 C
Processes: 297 Uptime: 5h 26m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 1246 lib: 287 flatpak: 0 Shell: Zsh v: 5.8
The Dazzle doesn’t show from a Kernel POV up and you didn’t specify a specific hardware model, and a few of them are not supported under Linux:
