I have 2 gpus and I want to have all monitors connected to them have their own x screens, or at least 1 X screen per gpu. Now I haven’t necessarily done this before so I’m not sure of the practicality of it but at the very least I want the 2 gpus to be independent with their own screens. I read Arch multi-head wiki and it seems like it can be done, but every time I try and assign monitors to separate screens, on reboot it will just get rid of all of them but Screen0. I even tried just assigning the monitors on the 2nd gpu to its own X screen and that’s it, and it will just reboot to all black screens. Curiously enough though I noticed with the nvidia_drm.modeset=1 kernel parameter set it will login, but it will enable the only the monitors on the first gpu as “Prime Offloading” displays, which is a kind of behavior I saw happening when messing around with it in other ways, where the 2nd x screen will always get disabled and the monitors on the other gpu will only be able to be set from the KDE display manager as Prime Displays, and will do the same when using xrandr --auto
I’m sure I’m missing something or my config is off but at this point I can’t tell whats wrong. nvidia_drm.modeset=1 at least makes all the monitors work simultaneously but not in the way I really want to. I just have it enabled right now so I at least don’t get blank screens when I try and log in. It doesn’t really seem to make any other difference otherwise.
heres the nvidia.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 515.65.01
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 3840 1080
Screen 1 "Screen1" RightOf "Screen0"
Screen 2 "Screen2" Above "Screen1"
Screen 3 "Screen3" Above "Screen0"
Screen 4 "Screen4" LeftOf "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "LG Electronics LG HDR 4K"
HorizSync 30.0 - 135.0
VertRefresh 56.0 - 61.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "DELL ST2421L"
HorizSync 30.0 - 83.0
VertRefresh 56.0 - 76.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor2"
ModelName "Ancor Communications Inc VH203"
HorizSync 29.0 - 83.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor3"
ModelName "HP 27xw"
HorizSync 30.0 - 80.0
VertRefresh 50.0 - 60.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor4"
ModelName "Acer CB281HK"
HorizSync 160.0 - 160.0
VertRefresh 40.0 - 60.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce RTX 2070 SUPER"
BusID "PCI:10:0:0"
Screen 0
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BoardName "NVIDIA GeForce GTX 1060 3GB"
BusID "PCI:6:0:0"
Screen 0
EndSection
Section "Device"
Identifier "Device2"
Driver "nvidia"
BusID "PCI:6:0:0"
Screen 1
EndSection
Section "Device"
Identifier "Device3"
Driver "nvidia"
BusID "PCI:10:0:0"
Screen 1
EndSection
Section "Device"
Identifier "Device4"
Driver "nvidia"
BusID "PCI:10:0:0"
Screen 2
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "DP-1-4: 3840x2160_60 +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "HDMI-0: 1920x1080_60 +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On, AllowGSYNC=Off}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen2"
Device "Device2"
Monitor "Monitor2"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "DP-0: 1600x900_60 +0+0 {AllowGSYNC=Off}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen3"
Device "Device3"
Monitor "Monitor3"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "DP-1-3: 1920x1080_60 +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On, AllowGSYNC=Off}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen4"
Device "Device4"
Monitor "Monitor4"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "DP-1-0: 3840x2160_60 +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On, AllowGSYNC=Off}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
And heres some system info
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=80ae6d56-ecf7-41cd-952a-770354c83fc6 rw quiet
udev.log_priority=3 nvidia_drm.modeset=1
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: B450 AORUS PRO WIFI v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450 AORUS PRO WIFI-CF v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F62b
date: 09/06/2021
RAM: total: 31.29 GiB used: 3.35 GiB (10.7%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
stepping: 0 microcode: 0xA201016
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3157 high: 3599 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3564 2: 3593
3: 2878 4: 3057 5: 2874 6: 2876 7: 3599 8: 3594 9: 3597 10: 2992 11: 2591
12: 2679 bogomips: 88831
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
prctl and seccomp
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: PNY driver: nvidia
v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-07) arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21
pcie: gen: 1 speed: 2.5 GT/s lanes: 2 link-max: gen: 2 speed: 5 GT/s
lanes: 16 ports: active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3,DVI-D-1
bus-ID: 06:00.0 chip-ID: 10de:1c02 class-ID: 0300
Device-2: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Gigabyte
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-4,DP-5,DP-6
empty: HDMI-A-2 bus-ID: 0a:00.0 chip-ID: 10de:1e84 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: N/A unloaded: nvidia gpu: nvidia,nvidia-nvswitch note: X driver n/a
display-ID: :0 screens: 1
Screen-1: 0 s-res: 5440x2160 s-dpi: 161 s-size: 858x340mm (33.78x13.39")
s-diag: 923mm (36.34")
Monitor-1: DP-1-0 pos: right res: 1600x900 hz: 60 dpi: 92
size: 443x249mm (17.44x9.8") diag: 508mm (20.01") modes: N/A
Monitor-2: DP-4 pos: primary,left res: 3840x2160 hz: 60 dpi: 163
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: PNY
driver: snd_hda_intel v: kernel bus-ID: 5-2:3 chip-ID: 1235:8006 pcie:
gen: 1 class-ID: fe01 speed: 2.5 GT/s lanes: 2 link-max: gen: 2
speed: 5 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1
chip-ID: 10de:10f8 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Focusrite-Novation Focusrite Scarlett 2i2 type: USB
driver: snd-usb-audio
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0
chip-ID: 8086:24fb class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-5:4 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 6.45 TiB used: 9.73 GiB (0.1%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO Plus
500GB size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: HP model: SSD EX920 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 42A0S63C temp: 32.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10EZEX-60M2NA0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM006-2DM164
type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 043 scheme: GPT
ID-7: /dev/sde maj-min: 8:64 type: USB vendor: Lexar model: USB Flash
Drive size: 59.62 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 9.73 GiB (1.0%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2 label: N/A
uuid: 80ae6d56-ecf7-41cd-952a-770354c83fc6
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: NO_LABEL
uuid: B65D-E8FD
ID-1: /dev/nvme0n1p1 maj-min: 259:4 size: 529 MiB fs: ntfs label: Recovery
uuid: 02CCCCA0CCCC8F7B
ID-2: /dev/nvme0n1p2 maj-min: 259:5 size: 99 MiB fs: vfat label: N/A
uuid: 48CC-E1B4
ID-3: /dev/nvme0n1p3 maj-min: 259:6 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme0n1p4 maj-min: 259:7 size: 465.13 GiB fs: ntfs label: SSD
uuid: FCF4CDC3F4CD7FFE
ID-5: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
ID-6: /dev/sda2 maj-min: 8:2 size: 931.39 GiB fs: ntfs label: Disk 1
uuid: 007838D57838CAE4
ID-7: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-8: /dev/sdb2 maj-min: 8:18 size: 1.82 TiB fs: ntfs label: SSD2
uuid: 448644D88644CC5C
ID-9: /dev/sdc1 maj-min: 8:33 size: 128 MiB fs: <superuser required>
ID-10: /dev/sdc2 maj-min: 8:34 size: 1.82 TiB fs: ntfs label: Disk 2
uuid: 247457EB7457BE6C
ID-11: /dev/sdd1 maj-min: 8:49 size: 100 MiB fs: vfat label: N/A
uuid: FC86-705F
ID-12: /dev/sdd2 maj-min: 8:50 size: 16 MiB fs: <superuser required>
ID-13: /dev/sdd3 maj-min: 8:51 size: 465.13 GiB fs: ntfs label: SSD4
uuid: 4E28F78728F76BF9
ID-14: /dev/sdd4 maj-min: 8:52 size: 530 MiB fs: ntfs label: N/A
uuid: 7A7219017218C433
ID-15: /dev/sde1 maj-min: 8:65 size: 3.32 GiB fs: iso9660
ID-16: /dev/sde2 maj-min: 8:66 size: 4 MiB fs: vfat label: MISO_EFI
uuid: C80E-8B3F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-3:2 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID
power: 100mA chip-ID: 258a:0001 class-ID: 0300
Device-2: 1-4:3 info: Microsoft XBOX ACC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
Device-3: 1-5:4 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Device-4: 1-7:5 info: Lexar Media LJDTT16G [JumpDrive 16GB]
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 200mA chip-ID: 05dc:a81d class-ID: 0806
serial: <filter>
Device-5: 1-8:6 info: Corsair M65 RGB Gaming Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 300mA chip-ID: 1b1c:1b12 class-ID: 0300 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: Corsair K95 RGB Platinum Keyboard [RGP0056]
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b2d class-ID: 0300
serial: <filter>
Device-2: 5-2:3 info: Focusrite-Novation Focusrite Scarlett 2i2
type: Audio driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 1235:8006 class-ID: fe01
Device-3: 5-3:4 info: Corsair SCIMITAR RGB ELITE Gaming Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 1b1c:1b8b class-ID: 0300
serial: <filter>
Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 48 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
Processes: 348 Uptime: 9m wakeups: 0 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1166
lib: 314 flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.20
If theres anything else I should run and post just let me know
