I installed manjaro to my laptop today. It is lenovo ideapad gaming 3. At first I could connect the wifi without problem. Then suddenly it started to not connect and when it connects, internet is very slow. I can see the wifi networks from gui still. I tried to update kernel, but it did not solve my problem. From settings->hardware configuration I can see that manjaro cant detect my network device, it says unknown device name (Mediatek Corp.). How can I solve this?
This is my first linux experience.
inxi output:
Kernel: 6.2.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.2-x86_64
root=UUID=4fc9aacf-f5c9-4c30-ab82-2db024214daf rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Type: Laptop System: LENOVO product: 82K2 v: IdeaPad Gaming 3 15ACH6
serial: <filter> Chassis: type: 10 v: IdeaPad Gaming 3 15ACH6
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter> UEFI: LENOVO
v: H3CN31WW(V2.01) date: 11/18/2021
ID-1: BAT1 charge: 15.4 Wh (35.6%) condition: 43.3/45.0 Wh (96.2%)
volts: 11.2 min: 11.5 model: 0x53 0x4D 0x50 0x00 0x32 0x30 0 0x4C 0x32 0x30
0x4D 0x33 0x50 0 type: Li-ion serial: <filter> status: discharging
cycles: 22
RAM: total: 13.51 GiB used: 2.92 GiB (21.6%)
Array-1: capacity: 64 GiB slots: 2 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M471A1G44AB0-CWE
serial: <filter>
Device-2: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
serial: <filter>
Info: model: AMD Ryzen 7 5800H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1575 high: 3200 min/max: 1200/4462 boost: enabled
base/boost: 3200/4450 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3200 2: 1200 3: 1200 4: 1200
5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200 11: 3200 12: 3200 13: 1200
14: 1200 15: 1200 16: 1200 bogomips: 102250
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f9d class-ID: 0302
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 44.0 C
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 13d3:56ff class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0a81 built: 2021
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.1 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.2.8-1-MANJARO) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.2.8-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.67 status: off with: wireplumber status: off
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active (root, process)
tools: pacat,pactl
vendor: Lenovo driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel modules: wl pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter type: USB
driver: btusb v: 0.8 bus-ID: 1-4:4 chip-ID: 0489:e0cd class-ID: e001
serial: <filter>
Local Storage: total: 476.94 GiB used: 12.81 GiB (2.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDHBA512QFD
lanes: 4 type: SSD serial: <filter> rev: 0011P6LN temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 22d 11h cycles: 227
read-units: 4,136,332 [2.11 TB] written-units: 4,202,277 [2.15 TB]
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 12.81 GiB (2.7%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 4fc9aacf-f5c9-4c30-ab82-2db024214daf
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 61C0-4CAD
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-2:2 info: ASUSTek TUF GAMING M5 type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 0b05:1898 class-ID: 0300
Device-2: 1-3:3 info: IMC Networks Integrated Camera type: Video
Device-3: 1-4:4 info: Foxconn / Hon Hai MediaTek Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Hub-2: 2-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 2-3:2 info: Integrated Express ITE Device(8176) type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 048d:c966 class-ID: 0301
Device-2: 2-4:3 info: Integrated Express ITE Device(8295)
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:c963 class-ID: 0300
Hub-3: 3-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 52.0 C mobo: N/A gpu: amdgpu temp: 46.0 C
Processes: 302 Uptime: 1h 1m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1069 libs: 317 tools: pamac Shell: Zsh (sudo)
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
