Hey, guys.
I had finally gotten Samba working on my old laptop so that I could access the shared drive plugged into my router, but that laptop died, so I installed Manjaro on a partition on my other laptop.
I’ve installed the Samba settings package, and edited the smb.conf file to change the min client protocol to NT1, but I currently can’t see the folder on the router. Last weekend when I was fooling with it, I did get it to where it was able to see it, but it gave me an error message dealing with password, even though I’m certain the username and password I was using were both correct. Windows 10 on the other partition connects with no issues.
This laptop is updated to current versions of everything.
Thanks for any help,
Adrian
Fabby
May 17, 2021, 10:29am
#2
Welcome to Manjaro!
Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text .
The output to smbclient --list=m.n.o.p --no-pass
would be helpful as well.
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Thank you. It’ll be the weekend at least before I can get back to it, but I’ll do that. Really appreciate your time.
Adrian
Here’s the output of those commands:
Kernel: 5.6.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64
root=UUID=542e065c-33d0-4824-b30a-2292f87317f5 rw quiet apparmor=1
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 23426QU v: ThinkPad T430
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 23426QU v: Win8 Pro DPK TPG serial: <filter>
UEFI-[Legacy]: LENOVO v: G1ET93WW (2.53 ) date: 03/08/2013
ID-1: BAT0 charge: 55.4 Wh (67.7%) condition: 81.8/71.3 Wh (114.7%)
volts: 11.2 min: 10.8 model: SANYO 45N1001 type: Li-ion serial: <filter>
status: Discharging
RAM: total: 7.48 GiB used: 4.55 GiB (60.8%)
Info: Dual Core model: Intel Core i5-3230M bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 3 MiB bogomips: 20760
Speed: 1327 MHz min/max: 1200/3200 MHz Core speeds (MHz): 1: 1327 2: 1377
3: 1348 4: 1447
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms
est f16c flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sep
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-1.6:4
chip-ID: 5986:02d5 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 21.0.3 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound Server-1: ALSA v: k5.6.11-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: 3.2.6-k port: 5080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Wireless-N 2200 driver: iwlwifi v: kernel
port: efa0 bus-ID: 03:00.0 chip-ID: 8086:0891 class-ID: 0280
Local Storage: total: 223.57 GiB used: 17.52 GiB (7.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 240GB
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 04RL scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GT80N rev: LT20
dev-links: cdrom
ID-1: / raw-size: 58.59 GiB size: 57.42 GiB (98.00%) used: 17.52 GiB (30.5%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 542e065c-33d0-4824-b30a-2292f87317f5
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 627.1 MiB fs: ntfs label: System Reserved
uuid: 01D6A421B20275B0
ID-2: /dev/sda2 maj-min: 8:2 size: 163.6 GiB fs: ntfs label: N/A
uuid: 01D6A4230B550460
ID-3: /dev/sda3 maj-min: 8:3 size: 1 KiB fs: <superuser required> label: N/A
uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 784.7 MiB fs: ntfs label: N/A
uuid: 01D6A42316F824A0
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.2:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-1.6:4 info: Acer Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 200mA chip-ID: 5986:02d5
class-ID: 0e02
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-6: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
System Temperatures: cpu: 47.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 2586
Processes: 287 Uptime: 15h 57m wakeups: 3 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: 1334 pacman: 1329 lib: 423
flatpak: 0 snap: 5 Shell: Bash v: 5.1.4 running-in: yakuake inxi: 3.3.04
The result of the smbclient command is:
do_connect: Connection to m.n.o.p failed (Error NT_STATUS_UNSUCCESSFUL)
Appreciate any direction from here.
Thanks,
Adrian
winnie
May 30, 2021, 4:00pm
#5
Have you tried with Smb4K? It’s a user-friendly all-in-one GUI made specifically for KDE for managing and connecting to SMB network shares. You can specify the SMB protocol version and authentication mode.
pamac install smb4k
It gives you a lot of control.
However, version 3.1 was recently released and is likely to be included in the next batch of stable KDE updates in Manjaro. Version 3.1 is a complete re-haul on custom mount options and other settings, so you’ll have to re-configure your settings again after Smb4K updates to version 3.1.
Fabby
May 30, 2021, 4:28pm
#6
That means the router is doing something different than NT1. Can you log into a console and provide both the router’s smb.conf
and your local machine’s?
