Can't connect to my 5ghz network (kicks randomly)
Hey everyone,
I’ve seen some people having the same problems, but I can’t find the solution. My wifi Adapter It’s clearly not working as it should (It worked fine on Windows), and I don’t know where to find the adecuate drivers for it (It’s a WavLink AC 600 Dual Band).
In detail, the problem I’m currently having is that I can’t connect to my 5ghz network (I can see it though). Sometimes I can connect fine, sometimes it shows “Limited connectivity”, and sometimes I can’t even connect to it.
I suppose It has to do with drivers (The adapter’s light it’s not on, I don’t know if that means something). It’s not being hard or soft blocked ( I checked), and I also tried changing region to where I am but nothing.
Here’s the output of iinxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.11.6-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
  root=UUID=da24dd6f-145b-403e-8f17-1fa27d5e7149 rw quiet apparmor=1
  security=apparmor resume=UUID=a4e79c30-d8e7-492a-9c68-1750bfde6d3f
  udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
  Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter> Chassis:
  type: 3 serial: <filter>
  Mobo: Gigabyte model: H61M-S1 v: x.x serial: <filter>
  UEFI: American Megatrends v: F9 date: 04/17/2013
  RAM: total: 15.6 GiB used: 7.95 GiB (51.0%)
  Info: Quad Core model: Intel Core i7-3770 bits: 64 type: MT MCP
  arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
  cache: L2: 8 MiB bogomips: 54297
  Speed: 2432 MHz min/max: 1600/3900 MHz Core speeds (MHz): 1: 2432 2: 2629
  3: 2505 4: 2536 5: 2687 6: 2408 7: 2549 8: 2314
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
  constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
  erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
  lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
  pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
  rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
  syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
  xsave xsaveopt xtopology xtpr
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
  driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
  loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
  display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 96
  size: 510x290mm (20.1x11.4") diag: 587mm (23.1")
  OpenGL: renderer: AMD Radeon RX 480 Graphics (POLARIS10 DRM 3.40.0
  5.11.6-1-MANJARO LLVM 11.1.0)
  v: 4.6 Mesa 20.3.4 direct render: Yes
  vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  chip-ID: 8086:1c20 class-ID: 0403
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
  driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 1002:aaf0
  class-ID: 0403
  Sound Server-1: ALSA v: k5.11.6-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.23 running: yes
  vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
  Device-2: MediaTek WiFi type: USB driver: mt76x0u bus-ID: 1-1.1:3
  chip-ID: 0e8d:7610 class-ID: 0000 serial: <filter>
  IF: wlp0s26u1u1 state: up mac: <filter>
  Message: No Bluetooth data was found.
  Message: No LVM data was found.
  Local Storage: total: 946.42 GiB used: 218.37 GiB (23.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-00BN5A0
  size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
  speed: <unknown> rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Edge
  size: 14.91 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1.26 scheme: MBR
  ID-1: / raw-size: 914.06 GiB size: 898.63 GiB (98.31%)
  used: 211.94 GiB (23.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: da24dd6f-145b-403e-8f17-1fa27d5e7149
  used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
  uuid: 8A79-575F
  ID-3: /run/media/sebas/8437-BF0D raw-size: 14.91 GiB
  size: 14.89 GiB (99.90%) used: 6.02 GiB (40.4%) fs: vfat dev: /dev/sdb1
  maj-min: 8:17 label: N/A uuid: 8437-BF0D
  ID-1: swap-1 type: partition size: 17.16 GiB used: 414.8 MiB (2.4%)
  priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: a4e79c30-d8e7-492a-9c68-1750bfde6d3f
  Message: No Unmounted partitions found.
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.1:3 info: MediaTek WiFi type: Network driver: mt76x0u
  interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 160mA chip-ID: 0e8d:7610
  Device-2: 1-1.2:4 info: Logitech G Pro Gaming Mouse type: Mouse,HID
  power: 300mA chip-ID: 046d:c085 class-ID: 0300 serial: <filter>
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.5:3 info: SanDisk Cruzer Edge type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
  chip-ID: 0781:556b class-ID: 0806 serial: <filter>
  Device-2: 2-1.6:6 info: Microdia USB Keyboard type: Keyboard
  driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
  power: 300mA chip-ID: 0c45:7603 class-ID: 0301
  System Temperatures: cpu: 51.0 C mobo: 27.8 C gpu: amdgpu temp: 54.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 913
  Processes: 384 Uptime: 1d 1h 24m wakeups: 0 Init: systemd v: 247
  tool: systemctl Compilers: gcc: 10.2.0 Packages: 1382 pacman: 1364 lib: 401
  flatpak: 5 snap: 13 Shell: Bash v: 5.1.0 running-in: yakuake inxi: 3.3.03
And here’s for iw list just in case:
Wiphy phy0
        wiphy index: 0
        max # scan SSIDs: 4
        max scan IEs length: 2243 bytes
        max # sched scan SSIDs: 0
        max # match sets: 0
        Retry short limit: 7
        Retry long limit: 4
        Coverage class: 0 (up to 0m)
        Device supports RSN-IBSS.
        Device supports AP-side u-APSD.
        Device supports T-DLS.
        Supported Ciphers:
                * WEP40 (00-0f-ac:1)
                * WEP104 (00-0f-ac:5)
                * TKIP (00-0f-ac:2)
                * CCMP-128 (00-0f-ac:4)
                * CCMP-256 (00-0f-ac:10)
                * GCMP-128 (00-0f-ac:8)
                * GCMP-256 (00-0f-ac:9)
                * CMAC (00-0f-ac:6)
                * CMAC-256 (00-0f-ac:13)
                * GMAC-128 (00-0f-ac:11)
                * GMAC-256 (00-0f-ac:12)
        Available Antennas: TX 0x1 RX 0x1
        Configured Antennas: TX 0x1 RX 0x1
        Supported interface modes:
                 * IBSS
                 * managed
                 * AP
                 * AP/VLAN
                 * monitor
                 * mesh point
                 * P2P-client
                 * P2P-GO
        Band 1:
                Capabilities: 0x17e
                        HT20/HT40
                        SM Power Save disabled
                        RX Greenfield
                        RX HT20 SGI
                        RX HT40 SGI
                        RX STBC 1-stream
                        Max AMSDU length: 3839 bytes
                        No DSSS/CCK HT40
                Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
                Minimum RX AMPDU time spacing: No restriction (0x00)
                HT TX/RX MCS rate indexes supported: 0-7
                Bitrates (non-HT):
                        * 1.0 Mbps (short preamble supported)
                        * 2.0 Mbps (short preamble supported)
                        * 5.5 Mbps (short preamble supported)
                        * 11.0 Mbps (short preamble supported)
                        * 6.0 Mbps
                        * 9.0 Mbps
                        * 12.0 Mbps
                        * 18.0 Mbps
                        * 24.0 Mbps
                        * 36.0 Mbps
                        * 48.0 Mbps
                        * 54.0 Mbps
                Frequencies:
                        * 2412 MHz [1] (14.0 dBm)
                        * 2417 MHz [2] (14.0 dBm)
                        * 2422 MHz [3] (14.0 dBm)
                        * 2427 MHz [4] (14.0 dBm)
                        * 2432 MHz [5] (14.0 dBm)
                        * 2437 MHz [6] (14.0 dBm)
                        * 2442 MHz [7] (14.0 dBm)
                        * 2447 MHz [8] (14.0 dBm)
                        * 2452 MHz [9] (14.0 dBm)
                        * 2457 MHz [10] (14.0 dBm)
                        * 2462 MHz [11] (14.0 dBm)
                        * 2467 MHz [12] (14.0 dBm)
                        * 2472 MHz [13] (14.0 dBm)
                        * 2484 MHz [14] (disabled)
        Band 2:
                Capabilities: 0x17e
                        HT20/HT40
                        RX Greenfield
                        RX HT20 SGI
                        RX HT40 SGI
                        RX STBC 1-stream
                        No DSSS/CCK HT40
                VHT Capabilities (0x31800120):
                        Max MPDU length: 3895
                        Supported Channel Width: neither 160 nor 80+80
                        short GI (80 MHz)
                        RX antenna pattern consistency
                        TX antenna pattern consistency
                VHT RX MCS set:
                        1 streams: MCS 0-9
                        2 streams: not supported
                        3 streams: not supported
                        4 streams: not supported
                        5 streams: not supported
                        6 streams: not supported
                        7 streams: not supported
                        8 streams: not supported
                VHT RX highest supported: 0 Mbps
                VHT TX MCS set:
                        1 streams: MCS 0-9
                VHT TX highest supported: 0 Mbps
                Bitrates (non-HT):
                        * 6.0 Mbps
                        * 9.0 Mbps
                        * 12.0 Mbps
                        * 18.0 Mbps
                        * 24.0 Mbps
                        * 36.0 Mbps
                        * 48.0 Mbps
                        * 54.0 Mbps
                Frequencies:
                        * 5180 MHz [36] (16.0 dBm)
                        * 5200 MHz [40] (16.0 dBm)
                        * 5220 MHz [44] (16.0 dBm)
                        * 5240 MHz [48] (16.0 dBm)
                        * 5260 MHz [52] (16.0 dBm) (radar detection)
                        * 5280 MHz [56] (16.0 dBm) (radar detection)
                        * 5300 MHz [60] (16.0 dBm) (radar detection)
                        * 5320 MHz [64] (16.0 dBm) (radar detection)
                        * 5500 MHz [100] (16.0 dBm) (radar detection)
                        * 5520 MHz [104] (16.0 dBm) (radar detection)
                        * 5540 MHz [108] (16.0 dBm) (radar detection)
                        * 5560 MHz [112] (16.0 dBm) (radar detection)
                        * 5580 MHz [116] (16.0 dBm) (radar detection)
                        * 5600 MHz [120] (16.0 dBm) (radar detection)
                        * 5620 MHz [124] (16.0 dBm) (radar detection)
                        * 5640 MHz [128] (16.0 dBm) (radar detection)
                        * 5660 MHz [132] (16.0 dBm) (radar detection)
                        * 5680 MHz [136] (16.0 dBm) (radar detection)
                        * 5700 MHz [140] (16.0 dBm) (radar detection)
                        * 5720 MHz [144] (16.0 dBm) (radar detection)
                        * 5745 MHz [149] (16.0 dBm)
                        * 5765 MHz [153] (16.0 dBm)
                        * 5785 MHz [157] (16.0 dBm)
                        * 5805 MHz [161] (16.0 dBm)
                        * 5825 MHz [165] (16.0 dBm)
                        * 5845 MHz [169] (disabled)
                        * 5865 MHz [173] (disabled)
        Supported commands:
                 * new_interface
                 * set_interface
                 * new_key
                 * start_ap
                 * new_station
                 * new_mpath
                 * set_mesh_config
                 * set_bss
                 * authenticate
                 * associate
                 * deauthenticate
                 * disassociate
                 * join_ibss
                 * join_mesh
                 * remain_on_channel
                 * set_tx_bitrate_mask
                 * frame
                 * frame_wait_cancel
                 * set_wiphy_netns
                 * set_channel
                 * tdls_mgmt
                 * tdls_oper
                 * probe_client
                 * set_noack_map
                 * register_beacons
                 * start_p2p_device
                 * set_mcast_rate
                 * connect
                 * disconnect
                 * channel_switch
                 * set_qos_map
                 * set_multicast_to_unicast
        software interface modes (can always be added):
                 * AP/VLAN
                 * monitor
        valid interface combinations:
                 * #{ IBSS } <= 1, #{ managed, AP, mesh point, P2P-client, P2P-GO } <= 2,
                   total <= 2, #channels <= 1, STA/AP BI must match
        HT Capability overrides:
                 * MCS: ff ff ff ff ff ff ff ff ff ff
                 * maximum A-MSDU length
                 * supported channel width
                 * short GI for 40 MHz
                 * max A-MPDU length exponent
                 * min MPDU start spacing
        Device supports TX status socket option.
        Device supports HT-IBSS.
        Device supports SAE with AUTHENTICATE command
        Device supports low priority scan.
        Device supports scan flush.
        Device supports AP scan.
        Device supports per-vif TX power setting
        Driver supports full state transitions for AP/GO clients
        Driver supports a userspace MPM
        Device supports active monitor (which will ACK incoming frames)
        Device supports configuring vdev MAC-addr on create.
        max # scan plans: 1
        max scan plan interval: -1
        max scan plan iterations: 0
        Supported TX frame types:
                 * IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
                 * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
        Supported RX frame types:
                 * IBSS: 0x40 0xb0 0xc0 0xd0
                 * managed: 0x40 0xb0 0xd0
                 * AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
                 * AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
                 * mesh point: 0xb0 0xc0 0xd0
                 * P2P-client: 0x40 0xd0
                 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
                 * P2P-device: 0x40 0xd0
        Supported extended features:
                * [ VHT_IBSS ]: VHT-IBSS
                * [ RRM ]: RRM
                * [ FILS_STA ]: STA FILS (Fast Initial Link Setup)
                * [ CQM_RSSI_LIST ]: multiple CQM_RSSI_THOLD records
                * [ CONTROL_PORT_OVER_NL80211 ]: control port over nl80211
                * [ TXQS ]: FQ-CoDel-enabled intermediate TXQs
                * [ AIRTIME_FAIRNESS ]: airtime fairness scheduling
                * [ AQL ]: Airtime Queue Limits (AQL)
                * [ SCAN_RANDOM_SN ]: use random sequence numbers in scans
                * [ SCAN_MIN_PREQ_CONTENT ]: use probe request with only rate IEs in scans
                * [ CONTROL_PORT_NO_PREAUTH ]: disable pre-auth over nl80211 control port support
                * [ DEL_IBSS_STA ]: deletion of IBSS station support
                * [ SCAN_FREQ_KHZ ]: scan on kHz frequency support
                * [ CONTROL_PORT_OVER_NL80211_TX_STATUS ]: tx status for nl80211 control port support
What should I do? Thanks in advance
Hi Squishy,
I don’t see that device on the resource I normally use as a rough guide for supported devices:- https://help.ubuntu.com/community/WifiDocs/WirelessCardsSupported
If it helps, I use a TP-Link TL-WN822N and happy to report it is affordable and works even better than in WIN$ollars
Good luck and I hope this helps!
Hi @Squoshy,
Welcome to the forum!!
Could you please read the following post in order to see whether you could solve the wifi problem?
Problem with wifi driver
Hope this help, regards
Hi @j8a
Thank you for the link! I’ve read it (And also the links they refer to) and it seems that I need to change / update my wifi driver (mt76x0u), but I don’t know where should I find new drivers (maybe from MediaTek | Broadband Wi-Fi 5 / 4 ??) or how to check if the driver being downloaded is compatible with my adapter (yeah, i’m pretty new with linux :sweat_smile:). If you or someone could guide me on that, I would be very thankful!
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
Hi @Squoshy,
I think this is the one for you:
https://www.mediatek.com/products/broadbandWifi/mt7610u
Also, in the post @anon89812132 quoted another driver you can find in the AUR.
The following link is in the post I recommended to you.
https://aur.archlinux.org/packages/mt7601u-ap-dkms/
Regards,
Thank you! I’m sorry for being an annoyance, but I don’t really know how to install a driver, any driver. I’ve been looking for the answer the last days but I can not find it. I looked up videos and forums (even the arch wiki).
I’ve downloaded the compatible wifi driver (mt7610u), but I don’t know what to do with it. I’ve tried with Sudo make and sudo make install inside the folder, but it ends with error 1 and 2 saying that
Can't efectuate "stat" on 'mt7650u_sta.ko' there is not such file or directory
and
there is no rule for building the objective "modules"
I would paste the error, but it’s in spanish
Appart from that, I don’t know where to find the driver i’m currently using in case something woes wrong.
Thank you for helping me on this
Hi @Squoshy ,
I speak spanich, it is my native language. Perhaps you could post the output here.
I could not found the drivers that @anon89812132 suggested, but I found the following ones
AUR (en) - mt7601u-dkms-git
GitHub - jeremyb31/mt7601u-5.3
http://aur.archlinux.org/packages/mt7610u_wifi_sta
'GitHub - Myria-de/mt7610u_wifi_sta_v3002_dpo_20130916: Modified usb wifi driver for TP_link TL-WDN5200
How to build the packages is simple enough:
sudo pacman -U ‘the name of the package from the AUR’
Also check if rt2800usb module isn’t blacklisted in /etc/modprobe.d/blacklist.conf
Regards,
