I’ve been using gnome for well over a year but have recently run into problems at reboots with “timed out waiting for device” along with “dependency failed.” Usually I’d have to force another reboot and it would then start.
Except now it won’t! Can anyone help me learn to solve this issue? I’m just not sure where to start and searches haven’t gotten me very far.
I can boot from live usb, for all the good it does me because I’m not quite sure what to do from there!
Have a look at /etc/fstab First thought would be that the UUID changed somehow and therefore it can’t find the partition. That happens when you resize a partition for example or the a partition is not there anymore or the SSD/HDD died…
Open a terminal and type manjaro-chroot -a when on a live session. Then please post these outputs:
I don’t know if this is helpful, but here’s some information I see just before I entered those commands:
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme0n1p2]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
-> mount: [/mnt/home]
mount: /mnt/home: special device /dev/disk/by-uuid/a4fdf2f3-223b-46c0-989b-6a996557f19d does not exist.
@Kelltech If there was another partition on /dev/nvme0n1 for home then it is not there anymore… Maybe it it is now on nvme0n1p2 ? In this case you can comment out the line with /home in fstab or just delete the line.
@megavolt I was able to edit that line out and booted right up to the login screen. After entering my password it just refreshes the login screen though.
If I knew why I’d certainly say so
The best I can think of is because I had a lot of trouble getting things running with Nvidia/Intel graphics and getting set up with a secondary hdd. That was more than a year ago now and the good man that helped me through that was all on the former Manjaro board.
Right, but I’m trying to log in to my system. I can boot to my login screen but entering the password shows me the splash screen and back to the login. Quite strange.
Ah, sorry I misunderstood, but have now booted from live once more and have the output. What I have is a 256gb SSD and a 1tb HDD where I keep files, apps, installed programs, etc.
Edit: If I’m not mistaken, I don’t even see that 1tb hdd represented here.
[manjaro-gnome /]# sudo parted -l
Model: USB Driver (scsi)
Disk /dev/sda: 4008MB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 2816MB 2820MB 4194kB primary esp
Model: WDC WDS256G1X0C-00ENX0 (nvme)
Disk /dev/nvme0n1: 256GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 2097kB 317MB 315MB fat32 boot, esp
2 317MB 238GB 237GB ext4
3 238GB 256GB 18.4GB linux-swap(v1) swap
Sadly I will agree it has died. I opened up and checked, all connections seem good.
Perhaps a question for a new thread, or else I can search tomorrow, can I create a new /home on the existing SSD, or do I need to wipe it and start fresh?
