I don’t know if I got everything with sudo dmesg with how long it was
sudo dmesg
[ 0.077038] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.092155] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2e09ef82697, max_idle_ns: 440795310854 ns
[ 0.092160] Calibrating delay loop (skipped), value calculated using timer frequency.. 6390.04 BogoMIPS (lpj=10646473)
[ 0.092162] pid_max: default: 32768 minimum: 301
[ 0.095514] LSM: Security Framework initializing
[ 0.095522] landlock: Up and running.
[ 0.095522] Yama: becoming mindful.
[ 0.095540] AppArmor: AppArmor initialized
[ 0.095559] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.095571] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.095723] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.095731] LVT offset 1 assigned for vector 0xf9
[ 0.095739] LVT offset 2 assigned for vector 0xf4
[ 0.095741] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[ 0.095742] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[ 0.095745] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.095747] Spectre V2 : Mitigation: Full AMD retpoline
[ 0.095747] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.095748] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.095749] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.095750] Spectre V2 : User space: Mitigation: STIBP always-on protection
[ 0.095751] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.100851] Freeing SMP alternatives memory: 36K
[ 0.208354] smpboot: CPU0: AMD Ryzen 7 5800H with Radeon Graphics (family: 0x19, model: 0x50, stepping: 0x0)
[ 0.208457] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[ 0.208461] ... version: 0
[ 0.208461] ... bit width: 48
[ 0.208462] ... generic registers: 6
[ 0.208463] ... value mask: 0000ffffffffffff
[ 0.208463] ... max period: 00007fffffffffff
[ 0.208464] ... fixed-purpose events: 0
[ 0.208464] ... event mask: 000000000000003f
[ 0.208512] rcu: Hierarchical SRCU implementation.
[ 0.208824] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.208824] smp: Bringing up secondary CPUs ...
[ 0.208824] x86: Booting SMP configuration:
[ 0.208824] .... node #0, CPUs: #1
[ 0.208824] TSC synchronization [CPU#0 -> CPU#1]:
[ 0.208824] Measured 3191407834 cycles TSC warp between CPUs, turning off TSC clock.
[ 0.208824] tsc: Marking TSC unstable due to check_tsc_sync_source failed
[ 0.208824] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[ 0.208824] #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15
[ 0.212386] smp: Brought up 1 node, 16 CPUs
[ 0.212386] smpboot: Max logical packages: 1
[ 0.212386] smpboot: Total of 16 processors activated (102247.73 BogoMIPS)
[ 0.213390] devtmpfs: initialized
[ 0.213390] x86/mm: Memory block size: 128MB
[ 0.213390] ACPI: PM: Registering ACPI NVS region [mem 0x09f00000-0x09f0efff] (61440 bytes)
[ 0.213390] ACPI: PM: Registering ACPI NVS region [mem 0xcdf7f000-0xcef7efff] (16777216 bytes)
[ 0.213390] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.213390] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.213390] pinctrl core: initialized pinctrl subsystem
[ 0.213390] PM: RTC time: 17:45:25, date: 2021-12-21
[ 0.213390] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.213390] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.213390] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.213390] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.213390] audit: initializing netlink subsys (disabled)
[ 0.213390] audit: type=2000 audit(1640108725.136:1): state=initialized audit_enabled=0 res=1
[ 0.213390] thermal_sys: Registered thermal governor 'fair_share'
[ 0.213390] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.213390] thermal_sys: Registered thermal governor 'step_wise'
[ 0.213390] thermal_sys: Registered thermal governor 'user_space'
[ 0.213390] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.213390] cpuidle: using governor ladder
[ 0.213390] cpuidle: using governor menu
[ 0.215515] Simple Boot Flag at 0x44 set to 0x1
[ 0.215525] HugeTLB: can free 4094 vmemmap pages for hugepages-1048576kB
[ 0.215527] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.215564] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.215569] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.215576] PCI: Using configuration type 1 for base access
[ 0.216361] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.216365] HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
[ 0.216365] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.216365] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.216365] ACPI: Added _OSI(Module Device)
[ 0.216365] ACPI: Added _OSI(Processor Device)
[ 0.216365] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.216365] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.216365] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.216365] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.216365] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.230576] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.PB2], AE_NOT_FOUND (20210930/dswload2-162)
[ 0.230580] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210930/psobject-220)
[ 0.230581] ACPI: Skipping parse of AML opcode: Scope (0x0010)
[ 0.231517] ACPI: 16 ACPI AML tables successfully acquired and loaded
[ 0.232879] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.234383] ACPI: EC: EC started
[ 0.234384] ACPI: EC: interrupt blocked
[ 0.238651] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.238653] ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC used to handle transactions
[ 0.238653] ACPI: Interpreter enabled
[ 0.238665] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.238665] ACPI: Using IOAPIC for interrupt routing
[ 0.238789] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.239133] ACPI: Enabled 5 GPEs in block 00 to 1F
[ 0.239732] ACPI: PM: Power Resource [PG00]
[ 0.261871] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.261876] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.261934] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
[ 0.262033] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.262042] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.262267] PCI host bridge to bus 0000:00
[ 0.262268] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.262269] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.262270] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.262271] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000cffff window]
[ 0.262272] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000effff window]
[ 0.262272] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xf7ffffff window]
[ 0.262273] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfeafffff window]
[ 0.262273] pci_bus 0000:00: root bus resource [mem 0xfed45000-0xfed811ff window]
[ 0.262274] pci_bus 0000:00: root bus resource [mem 0xfed81900-0xfed81fff window]
[ 0.262275] pci_bus 0000:00: root bus resource [mem 0xfedc0000-0xfedc0fff window]
[ 0.262275] pci_bus 0000:00: root bus resource [mem 0xfedc6000-0xfedc6fff window]
[ 0.262276] pci_bus 0000:00: root bus resource [mem 0x450200000-0xfcffffffff window]
[ 0.262277] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.262285] pci 0000:00:00.0: [1022:1630] type 00 class 0x060000
[ 0.262341] pci 0000:00:00.2: [1022:1631] type 00 class 0x080600
[ 0.262401] pci 0000:00:01.0: [1022:1632] type 00 class 0x060000
[ 0.262451] pci 0000:00:01.1: [1022:1633] type 01 class 0x060400
[ 0.262497] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 0.262550] pci 0000:00:01.2: [1022:1634] type 01 class 0x060400
[ 0.262597] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 0.262654] pci 0000:00:02.0: [1022:1632] type 00 class 0x060000
[ 0.262703] pci 0000:00:02.1: [1022:1634] type 01 class 0x060400
[ 0.262749] pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
[ 0.262798] pci 0000:00:02.2: [1022:1634] type 01 class 0x060400
[ 0.262844] pci 0000:00:02.2: PME# supported from D0 D3hot D3cold
[ 0.262904] pci 0000:00:08.0: [1022:1632] type 00 class 0x060000
[ 0.262953] pci 0000:00:08.1: [1022:1635] type 01 class 0x060400
[ 0.262971] pci 0000:00:08.1: enabling Extended Tags
[ 0.262997] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 0.263047] pci 0000:00:08.2: [1022:1635] type 01 class 0x060400
[ 0.263065] pci 0000:00:08.2: enabling Extended Tags
[ 0.263091] pci 0000:00:08.2: PME# supported from D0 D3hot D3cold
[ 0.263159] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 0.263253] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 0.263353] pci 0000:00:18.0: [1022:166a] type 00 class 0x060000
[ 0.263379] pci 0000:00:18.1: [1022:166b] type 00 class 0x060000
[ 0.263405] pci 0000:00:18.2: [1022:166c] type 00 class 0x060000
[ 0.263431] pci 0000:00:18.3: [1022:166d] type 00 class 0x060000
[ 0.263463] pci 0000:00:18.4: [1022:166e] type 00 class 0x060000
[ 0.263490] pci 0000:00:18.5: [1022:166f] type 00 class 0x060000
[ 0.263517] pci 0000:00:18.6: [1022:1670] type 00 class 0x060000
[ 0.263543] pci 0000:00:18.7: [1022:1671] type 00 class 0x060000
[ 0.263622] pci 0000:01:00.0: [10de:2560] type 00 class 0x030000
[ 0.263631] pci 0000:01:00.0: reg 0x10: [mem 0xd0000000-0xd0ffffff]
[ 0.263640] pci 0000:01:00.0: reg 0x14: [mem 0xfa00000000-0xfbffffffff 64bit pref]
[ 0.263648] pci 0000:01:00.0: reg 0x1c: [mem 0xfc00000000-0xfc01ffffff 64bit pref]
[ 0.263653] pci 0000:01:00.0: reg 0x24: [io 0x3000-0x307f]
[ 0.263658] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[ 0.263671] pci 0000:01:00.0: BAR 1: assigned to efifb
[ 0.263706] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 0.263772] pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:01.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.263935] pci 0000:01:00.1: [10de:228e] type 00 class 0x040300
[ 0.263943] pci 0000:01:00.1: reg 0x10: [mem 0xd1000000-0xd1003fff]
[ 0.264040] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.264043] pci 0000:00:01.1: bridge window [io 0x3000-0x3fff]
[ 0.264044] pci 0000:00:01.1: bridge window [mem 0xd0000000-0xd10fffff]
[ 0.264046] pci 0000:00:01.1: bridge window [mem 0xfa00000000-0xfc01ffffff 64bit pref]
[ 0.264135] pci 0000:02:00.0: [1c5c:174a] type 00 class 0x010802
[ 0.264149] pci 0000:02:00.0: reg 0x10: [mem 0xd1800000-0xd1803fff 64bit]
[ 0.264156] pci 0000:02:00.0: reg 0x18: [mem 0xd1805000-0xd1805fff]
[ 0.264162] pci 0000:02:00.0: reg 0x1c: [mem 0xd1804000-0xd1804fff]
[ 0.264339] pci 0000:00:01.2: PCI bridge to [bus 02]
[ 0.264342] pci 0000:00:01.2: bridge window [mem 0xd1800000-0xd18fffff]
[ 0.264386] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
[ 0.264402] pci 0000:03:00.0: reg 0x10: [io 0x2000-0x20ff]
[ 0.264423] pci 0000:03:00.0: reg 0x18: [mem 0xd1704000-0xd1704fff 64bit]
[ 0.264437] pci 0000:03:00.0: reg 0x20: [mem 0xd1700000-0xd1703fff 64bit]
[ 0.264520] pci 0000:03:00.0: supports D1 D2
[ 0.264521] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.264638] pci 0000:00:02.1: PCI bridge to [bus 03]
[ 0.264640] pci 0000:00:02.1: bridge window [io 0x2000-0x2fff]
[ 0.264642] pci 0000:00:02.1: bridge window [mem 0xd1700000-0xd17fffff]
[ 0.264687] pci 0000:04:00.0: [10ec:8852] type 00 class 0x028000
[ 0.264705] pci 0000:04:00.0: reg 0x10: [io 0x1000-0x10ff]
[ 0.264727] pci 0000:04:00.0: reg 0x18: [mem 0xd1600000-0xd16fffff 64bit]
[ 0.264838] pci 0000:04:00.0: supports D1 D2
[ 0.264839] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.264965] pci 0000:00:02.2: PCI bridge to [bus 04]
[ 0.264967] pci 0000:00:02.2: bridge window [io 0x1000-0x1fff]
[ 0.264969] pci 0000:00:02.2: bridge window [mem 0xd1600000-0xd16fffff]
[ 0.265021] pci 0000:05:00.0: [1022:145a] type 00 class 0x130000
[ 0.265044] pci 0000:05:00.0: enabling Extended Tags
[ 0.265108] pci 0000:05:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:08.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.265140] pci 0000:05:00.2: [1022:15df] type 00 class 0x108000
[ 0.265153] pci 0000:05:00.2: reg 0x18: [mem 0xd1400000-0xd14fffff]
[ 0.265161] pci 0000:05:00.2: reg 0x24: [mem 0xd1508000-0xd1509fff]
[ 0.265167] pci 0000:05:00.2: enabling Extended Tags
[ 0.265232] pci 0000:05:00.3: [1022:1639] type 00 class 0x0c0330
[ 0.265242] pci 0000:05:00.3: reg 0x10: [mem 0xd1200000-0xd12fffff 64bit]
[ 0.265263] pci 0000:05:00.3: enabling Extended Tags
[ 0.265289] pci 0000:05:00.3: PME# supported from D0 D3hot D3cold
[ 0.265327] pci 0000:05:00.4: [1022:1639] type 00 class 0x0c0330
[ 0.265337] pci 0000:05:00.4: reg 0x10: [mem 0xd1300000-0xd13fffff 64bit]
[ 0.265358] pci 0000:05:00.4: enabling Extended Tags
[ 0.265384] pci 0000:05:00.4: PME# supported from D0 D3hot D3cold
[ 0.265425] pci 0000:05:00.6: [1022:15e3] type 00 class 0x040300
[ 0.265431] pci 0000:05:00.6: reg 0x10: [mem 0xd1500000-0xd1507fff]
[ 0.265449] pci 0000:05:00.6: enabling Extended Tags
[ 0.265474] pci 0000:05:00.6: PME# supported from D0 D3hot D3cold
[ 0.265525] pci 0000:00:08.1: PCI bridge to [bus 05]
[ 0.265528] pci 0000:00:08.1: bridge window [mem 0xd1200000-0xd15fffff]
[ 0.265562] pci 0000:06:00.0: [1022:7901] type 00 class 0x010601
[ 0.265587] pci 0000:06:00.0: reg 0x24: [mem 0xd1101000-0xd11017ff]
[ 0.265595] pci 0000:06:00.0: enabling Extended Tags
[ 0.265650] pci 0000:06:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:08.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 0.265679] pci 0000:06:00.1: [1022:7901] type 00 class 0x010601
[ 0.265704] pci 0000:06:00.1: reg 0x24: [mem 0xd1100000-0xd11007ff]
[ 0.265712] pci 0000:06:00.1: enabling Extended Tags
[ 0.265780] pci 0000:00:08.2: PCI bridge to [bus 06]
[ 0.265783] pci 0000:00:08.2: bridge window [mem 0xd1100000-0xd11fffff]
[ 0.266329] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.266330] ACPI: PCI: Interrupt link LNKA disabled
[ 0.266380] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 0.266381] ACPI: PCI: Interrupt link LNKB disabled
[ 0.266419] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.266419] ACPI: PCI: Interrupt link LNKC disabled
[ 0.266468] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.266468] ACPI: PCI: Interrupt link LNKD disabled
[ 0.266514] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.266514] ACPI: PCI: Interrupt link LNKE disabled
[ 0.266550] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.266550] ACPI: PCI: Interrupt link LNKF disabled
[ 0.266585] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.266586] ACPI: PCI: Interrupt link LNKG disabled
[ 0.266621] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.266621] ACPI: PCI: Interrupt link LNKH disabled
[ 0.268569] ACPI: EC: interrupt unblocked
[ 0.268570] ACPI: EC: event unblocked
[ 0.268575] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.268576] ACPI: EC: GPE=0x3
[ 0.268576] ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC initialization complete
[ 0.268577] ACPI: \_SB_.PCI0.LPC0.EC0_: EC: Used to handle transactions and events
[ 0.268595] iommu: Default domain type: Translated
[ 0.268595] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.268595] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.268595] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.268595] pci 0000:01:00.0: vgaarb: setting as boot device
[ 0.268595] vgaarb: loaded
[ 0.268595] SCSI subsystem initialized
[ 0.268595] libata version 3.00 loaded.
[ 0.268595] ACPI: bus type USB registered
[ 0.268595] usbcore: registered new interface driver usbfs
[ 0.268595] usbcore: registered new interface driver hub
[ 0.268825] usbcore: registered new device driver usb
[ 0.274249] pps_core: LinuxPPS API ver. 1 registered
[ 0.274250] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.274252] PTP clock support registered
[ 0.274256] EDAC MC: Ver: 3.0.0
[ 0.274347] Registered efivars operations
[ 0.274347] NetLabel: Initializing
[ 0.274347] NetLabel: domain hash size = 128
[ 0.274347] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.274347] NetLabel: unlabeled traffic allowed by default
[ 0.274347] PCI: Using ACPI for IRQ routing
[ 0.276455] PCI: pci_cache_line_size set to 64 bytes
[ 0.276498] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 0.276499] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.276500] e820: reserve RAM buffer [mem 0x09a00000-0x0bffffff]
[ 0.276501] e820: reserve RAM buffer [mem 0x09f00000-0x0bffffff]
[ 0.276502] e820: reserve RAM buffer [mem 0xb63cf000-0xb7ffffff]
[ 0.276502] e820: reserve RAM buffer [mem 0xb641b000-0xb7ffffff]
[ 0.276503] e820: reserve RAM buffer [mem 0xbbb69000-0xbbffffff]
[ 0.276503] e820: reserve RAM buffer [mem 0xcaf7f000-0xcbffffff]
[ 0.276504] e820: reserve RAM buffer [mem 0xcf000000-0xcfffffff]
[ 0.276504] e820: reserve RAM buffer [mem 0x42e340000-0x42fffffff]
[ 0.276508] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.276508] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.279143] clocksource: Switched to clocksource hpet
[ 0.283477] VFS: Disk quotas dquot_6.6.0
[ 0.283487] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.283545] AppArmor: AppArmor Filesystem Enabled
[ 0.283563] pnp: PnP ACPI init
[ 0.283652] system 00:00: [mem 0xfec00000-0xfec01fff] could not be reserved
[ 0.283655] system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.283656] system 00:00: [mem 0xfde00000-0xfdefffff] has been reserved
[ 0.283799] system 00:03: [io 0x0400-0x04cf] could not be reserved
[ 0.283801] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 0.283801] system 00:03: [io 0x04d6] has been reserved
[ 0.283802] system 00:03: [io 0x0c00-0x0c01] has been reserved
[ 0.283803] system 00:03: [io 0x0c14] has been reserved
[ 0.283803] system 00:03: [io 0x0c50-0x0c52] has been reserved
[ 0.283804] system 00:03: [io 0x0c6c] has been reserved
[ 0.283805] system 00:03: [io 0x0c6f] has been reserved
[ 0.283805] system 00:03: [io 0x0cd0-0x0cdb] has been reserved
[ 0.283842] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[ 0.284628] pnp: PnP ACPI: found 5 devices
[ 0.290734] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.290792] NET: Registered PF_INET protocol family
[ 0.290995] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.292250] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.292400] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.292523] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.292569] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.292626] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.292657] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.292690] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.292817] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.292821] NET: Registered PF_XDP protocol family
[ 0.292823] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[ 0.292830] pci 0000:01:00.0: BAR 6: assigned [mem 0xd1080000-0xd10fffff pref]
[ 0.292832] pci 0000:00:01.1: PCI bridge to [bus 01]
[ 0.292833] pci 0000:00:01.1: bridge window [io 0x3000-0x3fff]
[ 0.292835] pci 0000:00:01.1: bridge window [mem 0xd0000000-0xd10fffff]
[ 0.292837] pci 0000:00:01.1: bridge window [mem 0xfa00000000-0xfc01ffffff 64bit pref]
[ 0.292840] pci 0000:00:01.2: PCI bridge to [bus 02]
[ 0.292842] pci 0000:00:01.2: bridge window [mem 0xd1800000-0xd18fffff]
[ 0.292846] pci 0000:00:02.1: PCI bridge to [bus 03]
[ 0.292847] pci 0000:00:02.1: bridge window [io 0x2000-0x2fff]
[ 0.292849] pci 0000:00:02.1: bridge window [mem 0xd1700000-0xd17fffff]
[ 0.292852] pci 0000:00:02.2: PCI bridge to [bus 04]
[ 0.292853] pci 0000:00:02.2: bridge window [io 0x1000-0x1fff]
[ 0.292855] pci 0000:00:02.2: bridge window [mem 0xd1600000-0xd16fffff]
[ 0.292859] pci 0000:00:08.1: PCI bridge to [bus 05]
[ 0.292861] pci 0000:00:08.1: bridge window [mem 0xd1200000-0xd15fffff]
[ 0.292864] pci 0000:00:08.2: PCI bridge to [bus 06]
[ 0.292866] pci 0000:00:08.2: bridge window [mem 0xd1100000-0xd11fffff]
[ 0.292869] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.292870] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.292871] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.292872] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000cffff window]
[ 0.292872] pci_bus 0000:00: resource 8 [mem 0x000d0000-0x000effff window]
[ 0.292873] pci_bus 0000:00: resource 9 [mem 0xd0000000-0xf7ffffff window]
[ 0.292873] pci_bus 0000:00: resource 10 [mem 0xfc000000-0xfeafffff window]
[ 0.292874] pci_bus 0000:00: resource 11 [mem 0xfed45000-0xfed811ff window]
[ 0.292875] pci_bus 0000:00: resource 12 [mem 0xfed81900-0xfed81fff window]
[ 0.292875] pci_bus 0000:00: resource 13 [mem 0xfedc0000-0xfedc0fff window]
[ 0.292876] pci_bus 0000:00: resource 14 [mem 0xfedc6000-0xfedc6fff window]
[ 0.292876] pci_bus 0000:00: resource 15 [mem 0x450200000-0xfcffffffff window]
[ 0.292877] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.292878] pci_bus 0000:01: resource 1 [mem 0xd0000000-0xd10fffff]
[ 0.292878] pci_bus 0000:01: resource 2 [mem 0xfa00000000-0xfc01ffffff 64bit pref]
[ 0.292879] pci_bus 0000:02: resource 1 [mem 0xd1800000-0xd18fffff]
[ 0.292880] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 0.292880] pci_bus 0000:03: resource 1 [mem 0xd1700000-0xd17fffff]
[ 0.292881] pci_bus 0000:04: resource 0 [io 0x1000-0x1fff]
[ 0.292881] pci_bus 0000:04: resource 1 [mem 0xd1600000-0xd16fffff]
[ 0.292882] pci_bus 0000:05: resource 1 [mem 0xd1200000-0xd15fffff]
[ 0.292883] pci_bus 0000:06: resource 1 [mem 0xd1100000-0xd11fffff]
[ 0.292963] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.293004] pci 0000:05:00.3: extending delay after power-on from D3hot to 20 msec
[ 0.336525] pci 0000:05:00.3: quirk_usb_early_handoff+0x0/0x750 took 42495 usecs
[ 0.336532] pci 0000:05:00.4: extending delay after power-on from D3hot to 20 msec
[ 0.350189] pci 0000:05:00.4: quirk_usb_early_handoff+0x0/0x750 took 13334 usecs
[ 0.350197] PCI: CLS 64 bytes, default 64
[ 0.350206] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 0.350239] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 0.350240] pci 0000:00:00.2: PCI INT A: not connected
[ 0.350246] Trying to unpack rootfs image as initramfs...
[ 0.350253] pci 0000:00:01.0: Adding to iommu group 0
[ 0.350259] pci 0000:00:01.1: Adding to iommu group 1
[ 0.350263] pci 0000:00:01.2: Adding to iommu group 2
[ 0.350271] pci 0000:00:02.0: Adding to iommu group 3
[ 0.350276] pci 0000:00:02.1: Adding to iommu group 4
[ 0.350281] pci 0000:00:02.2: Adding to iommu group 5
[ 0.350289] pci 0000:00:08.0: Adding to iommu group 6
[ 0.350293] pci 0000:00:08.1: Adding to iommu group 6
[ 0.350296] pci 0000:00:08.2: Adding to iommu group 6
[ 0.350304] pci 0000:00:14.0: Adding to iommu group 7
[ 0.350308] pci 0000:00:14.3: Adding to iommu group 7
[ 0.350323] pci 0000:00:18.0: Adding to iommu group 8
[ 0.350327] pci 0000:00:18.1: Adding to iommu group 8
[ 0.350332] pci 0000:00:18.2: Adding to iommu group 8
[ 0.350336] pci 0000:00:18.3: Adding to iommu group 8
[ 0.350341] pci 0000:00:18.4: Adding to iommu group 8
[ 0.350345] pci 0000:00:18.5: Adding to iommu group 8
[ 0.350349] pci 0000:00:18.6: Adding to iommu group 8
[ 0.350353] pci 0000:00:18.7: Adding to iommu group 8
[ 0.350361] pci 0000:01:00.0: Adding to iommu group 9
[ 0.350366] pci 0000:01:00.1: Adding to iommu group 9
[ 0.350371] pci 0000:02:00.0: Adding to iommu group 10
[ 0.350377] pci 0000:03:00.0: Adding to iommu group 11
[ 0.350383] pci 0000:04:00.0: Adding to iommu group 12
[ 0.350393] pci 0000:05:00.0: Adding to iommu group 6
[ 0.350395] pci 0000:05:00.2: Adding to iommu group 6
[ 0.350398] pci 0000:05:00.3: Adding to iommu group 6
[ 0.350401] pci 0000:05:00.4: Adding to iommu group 6
[ 0.350403] pci 0000:05:00.6: Adding to iommu group 6
[ 0.350407] pci 0000:06:00.0: Adding to iommu group 6
[ 0.350409] pci 0000:06:00.1: Adding to iommu group 6
[ 0.351615] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.351616] AMD-Vi: Extended features (0x206d73ef22254ade): PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 0.351620] AMD-Vi: Interrupt remapping enabled
[ 0.351620] AMD-Vi: Virtual APIC enabled
[ 0.351620] AMD-Vi: X2APIC enabled
[ 0.351712] software IO TLB: tearing down default memory pool
[ 0.352151] LVT offset 0 assigned for vector 0x400
[ 0.359489] perf: AMD IBS detected (0x000003ff)
[ 0.359493] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 0.361218] Initialise system trusted keyrings
[ 0.361225] Key type blacklist registered
[ 0.361265] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.361770] zbud: loaded
[ 0.364403] Key type asymmetric registered
[ 0.364404] Asymmetric key parser 'x509' registered
[ 0.364420] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.364477] io scheduler mq-deadline registered
[ 0.364477] io scheduler kyber registered
[ 0.364492] io scheduler bfq registered
[ 0.364895] pcieport 0000:00:01.1: PME: Signaling with IRQ 26
[ 0.364986] pcieport 0000:00:01.2: PME: Signaling with IRQ 27
[ 0.365073] pcieport 0000:00:02.1: PME: Signaling with IRQ 28
[ 0.365158] pcieport 0000:00:02.2: PME: Signaling with IRQ 29
[ 0.365239] pcieport 0000:00:08.1: PME: Signaling with IRQ 30
[ 0.365377] pcieport 0000:00:08.2: PME: Signaling with IRQ 31
[ 0.365434] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.366780] ACPI: AC: AC Adapter [ADP0] (on-line)
[ 0.366812] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.366823] ACPI: button: Power Button [PWRB]
[ 0.366839] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[ 0.366846] ACPI: button: Lid Switch [LID0]
[ 0.366858] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.366883] ACPI: button: Power Button [PWRF]
[ 0.366922] Monitor-Mwait will be used to enter C-1 state
[ 0.366931] ACPI: \_SB_.PLTF.C000: Found 3 idle states
[ 0.367026] ACPI: \_SB_.PLTF.C001: Found 3 idle states
[ 0.367095] ACPI: \_SB_.PLTF.C002: Found 3 idle states
[ 0.367172] ACPI: \_SB_.PLTF.C003: Found 3 idle states
[ 0.367234] ACPI: \_SB_.PLTF.C004: Found 3 idle states
[ 0.367320] ACPI: \_SB_.PLTF.C005: Found 3 idle states
[ 0.367366] ACPI: \_SB_.PLTF.C006: Found 3 idle states
[ 0.367449] ACPI: \_SB_.PLTF.C007: Found 3 idle states
[ 0.367537] ACPI: \_SB_.PLTF.C008: Found 3 idle states
[ 0.367624] ACPI: \_SB_.PLTF.C009: Found 3 idle states
[ 0.367712] ACPI: \_SB_.PLTF.C00A: Found 3 idle states
[ 0.367799] ACPI: \_SB_.PLTF.C00B: Found 3 idle states
[ 0.367886] ACPI: \_SB_.PLTF.C00C: Found 3 idle states
[ 0.367965] ACPI: \_SB_.PLTF.C00D: Found 3 idle states
[ 0.368045] ACPI: \_SB_.PLTF.C00E: Found 3 idle states
[ 0.368122] ACPI: \_SB_.PLTF.C00F: Found 3 idle states
[ 0.368274] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.369210] Non-volatile memory driver v1.3
[ 0.369211] Linux agpgart interface v0.103
[ 0.369240] AMD-Vi: AMD IOMMUv2 loaded and initialized
[ 0.369309] ACPI: bus type drm_connector registered
[ 0.369984] nvme nvme0: pci function 0000:02:00.0
[ 0.370007] ahci 0000:06:00.0: version 3.0
[ 0.370116] ahci 0000:06:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.370118] ahci 0000:06:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.370226] scsi host0: ahci
[ 0.370259] ata1: SATA max UDMA/133 abar m2048@0xd1101000 port 0xd1101100 irq 33
[ 0.370346] ahci 0000:06:00.1: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[ 0.370347] ahci 0000:06:00.1: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[ 0.370448] scsi host1: ahci
[ 0.370475] ata2: SATA max UDMA/133 abar m2048@0xd1100000 port 0xd1100100 irq 37
[ 0.370537] libphy: Fixed MDIO Bus: probed
[ 0.370543] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.370546] ehci-pci: EHCI PCI platform driver
[ 0.370552] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.370556] ohci-pci: OHCI PCI platform driver
[ 0.370560] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.370580] usbcore: registered new interface driver usbserial_generic
[ 0.370583] usbserial: USB Serial support registered for generic
[ 0.370676] rtc_cmos 00:01: RTC can wake from S4
[ 0.370856] rtc_cmos 00:01: registered as rtc0
[ 0.370901] rtc_cmos 00:01: setting system clock to 2021-12-21T17:45:25 UTC (1640108725)
[ 0.370910] rtc_cmos 00:01: alarms up to one month, 114 bytes nvram, hpet irqs
[ 0.371118] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.371214] efifb: probing for efifb
[ 0.371224] efifb: showing boot graphics
[ 0.374122] efifb: framebuffer at 0xfa00000000, using 25600k, total 25600k
[ 0.374123] efifb: mode is 2560x1600x32, linelength=16384, pages=1
[ 0.374124] efifb: scrolling: redraw
[ 0.374124] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.374158] fbcon: Deferring console take-over
[ 0.374158] fb0: EFI VGA frame buffer device
[ 0.374174] hid: raw HID events driver (C) Jiri Kosina
[ 0.374217] ashmem: initialized
[ 0.374250] drop_monitor: Initializing network drop monitor service
[ 0.374288] Initializing XFRM netlink socket
[ 0.374329] NET: Registered PF_INET6 protocol family
[ 0.412447] Freeing initrd memory: 8256K
[ 0.415734] Segment Routing with IPv6
[ 0.415736] RPL Segment Routing with IPv6
[ 0.415743] In-situ OAM (IOAM) with IPv6
[ 0.415761] NET: Registered PF_PACKET protocol family
[ 0.416515] microcode: CPU0: patch_level=0x0a50000b
[ 0.416523] microcode: CPU1: patch_level=0x0a50000b
[ 0.416539] microcode: CPU2: patch_level=0x0a50000b
[ 0.416549] microcode: CPU3: patch_level=0x0a50000b
[ 0.416550] microcode: CPU4: patch_level=0x0a50000b
[ 0.416559] microcode: CPU5: patch_level=0x0a50000b
[ 0.416576] microcode: CPU6: patch_level=0x0a50000b
[ 0.416586] microcode: CPU7: patch_level=0x0a50000b
[ 0.416596] microcode: CPU8: patch_level=0x0a50000b
[ 0.416603] microcode: CPU9: patch_level=0x0a50000b
[ 0.416618] microcode: CPU10: patch_level=0x0a50000b
[ 0.416626] microcode: CPU11: patch_level=0x0a50000b
[ 0.416644] microcode: CPU12: patch_level=0x0a50000b
[ 0.416653] microcode: CPU13: patch_level=0x0a50000b
[ 0.416670] microcode: CPU14: patch_level=0x0a50000b
[ 0.416680] microcode: CPU15: patch_level=0x0a50000b
[ 0.416682] microcode: Microcode Update Driver: v2.2.
[ 0.416956] resctrl: L3 allocation detected
[ 0.416956] resctrl: MB allocation detected
[ 0.416957] resctrl: L3 monitoring detected
[ 0.416961] IPI shorthand broadcast: enabled
[ 0.417148] registered taskstats version 1
[ 0.417675] Loading compiled-in X.509 certificates
[ 0.419413] Loaded X.509 cert 'Build time autogenerated kernel key: 7078f0a32a383ec4a603f069fe96235ac9a6fb14'
[ 0.422108] zswap: loaded using pool zstd/z3fold
[ 0.422631] Key type ._fscrypt registered
[ 0.422632] Key type .fscrypt registered
[ 0.422632] Key type fscrypt-provisioning registered
[ 0.422658] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.424130] PM: Magic number: 1:655:795
[ 0.424166] platform MSFT0101:00: hash matches
[ 0.424174] acpi MSFT0101:00: hash matches
[ 0.424289] RAS: Correctable Errors collector initialized.
[ 0.424301] Unstable clock detected, switching default tracing clock to "global"
If you want to keep using the local clock, then add:
"trace_clock=local"
on the kernel command line
[ 0.451203] nvme nvme0: 16/0/0 default/read/poll queues
[ 0.457698] nvme0n1: p1 p2
[ 0.459104] ACPI: battery: Slot [BAT0] (battery present)
[ 0.682977] ata1: SATA link down (SStatus 0 SControl 300)
[ 0.682975] ata2: SATA link down (SStatus 0 SControl 300)
[ 0.684525] Freeing unused decrypted memory: 2036K
[ 0.684807] Freeing unused kernel image (initmem) memory: 1800K
[ 0.684810] Write protecting the kernel read-only data: 30720k
[ 0.685268] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 0.685544] Freeing unused kernel image (rodata/data gap) memory: 1228K
[ 0.707060] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.707066] rodata_test: all tests were successful
[ 0.707072] Run /init as init process
[ 0.707073] with arguments:
[ 0.707074] /init
[ 0.707075] with environment:
[ 0.707075] HOME=/
[ 0.707076] TERM=linux
[ 0.707076] BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
[ 0.772373] xhci_hcd 0000:05:00.3: xHCI Host Controller
[ 0.772379] xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 1
[ 0.772490] xhci_hcd 0000:05:00.3: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
[ 0.772606] i8042: PNP: PS/2 Controller [PNP0303:KBC0] at 0x60,0x64 irq 1
[ 0.772608] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.772764] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16
[ 0.772766] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.772767] usb usb1: Product: xHCI Host Controller
[ 0.772768] usb usb1: Manufacturer: Linux 5.16.0-1-MANJARO xhci-hcd
[ 0.772769] usb usb1: SerialNumber: 0000:05:00.3
[ 0.772856] hub 1-0:1.0: USB hub found
[ 0.772861] hub 1-0:1.0: 4 ports detected
[ 0.773011] xhci_hcd 0000:05:00.3: xHCI Host Controller
[ 0.773013] xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 2
[ 0.773014] xhci_hcd 0000:05:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.773023] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.773033] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.16
[ 0.773034] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.773034] usb usb2: Product: xHCI Host Controller
[ 0.773035] usb usb2: Manufacturer: Linux 5.16.0-1-MANJARO xhci-hcd
[ 0.773035] usb usb2: SerialNumber: 0000:05:00.3
[ 0.773079] hub 2-0:1.0: USB hub found
[ 0.773083] hub 2-0:1.0: 2 ports detected
[ 0.773189] xhci_hcd 0000:05:00.4: xHCI Host Controller
[ 0.773192] xhci_hcd 0000:05:00.4: new USB bus registered, assigned bus number 3
[ 0.773283] xhci_hcd 0000:05:00.4: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000020000000410
[ 0.773521] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.16
[ 0.773522] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.773523] usb usb3: Product: xHCI Host Controller
[ 0.773523] usb usb3: Manufacturer: Linux 5.16.0-1-MANJARO xhci-hcd
[ 0.773524] usb usb3: SerialNumber: 0000:05:00.4
[ 0.773557] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.773569] hub 3-0:1.0: USB hub found
[ 0.773573] hub 3-0:1.0: 4 ports detected
[ 0.773737] xhci_hcd 0000:05:00.4: xHCI Host Controller
[ 0.773738] xhci_hcd 0000:05:00.4: new USB bus registered, assigned bus number 4
[ 0.773739] xhci_hcd 0000:05:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[ 0.773748] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 0.773758] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.16
[ 0.773759] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.773759] usb usb4: Product: xHCI Host Controller
[ 0.773760] usb usb4: Manufacturer: Linux 5.16.0-1-MANJARO xhci-hcd
[ 0.773760] usb usb4: SerialNumber: 0000:05:00.4
[ 0.773802] hub 4-0:1.0: USB hub found
[ 0.773805] hub 4-0:1.0: 2 ports detected
[ 0.792863] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.815690] fbcon: Taking over console
[ 0.815796] Console: switching to colour frame buffer device 160x50
[ 0.828358] random: fast init done
[ 1.025532] usb 3-4: new full-speed USB device number 2 using xhci_hcd
[ 1.025544] usb 1-2: new high-speed USB device number 2 using xhci_hcd
[ 1.098321] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.152711] systemd[1]: systemd 249.7-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 1.169031] systemd[1]: Detected architecture x86-64.
[ 1.169885] systemd[1]: Hostname set to <pr1mal-lenovo>.
[ 1.171313] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=71.00
[ 1.171316] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.171318] usb 1-2: Product: USB2.1 Hub
[ 1.171319] usb 1-2: Manufacturer: GenesysLogic
[ 1.185808] usb 3-4: New USB device found, idVendor=0bda, idProduct=4852, bcdDevice= 0.00
[ 1.185810] usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.185812] usb 3-4: Product: Bluetooth Radio
[ 1.185813] usb 3-4: Manufacturer: Realtek
[ 1.185813] usb 3-4: SerialNumber: 00e04c000001
[ 1.221339] hub 1-2:1.0: USB hub found
[ 1.221940] hub 1-2:1.0: 3 ports detected
[ 1.244125] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 1.283445] systemd[1]: Queued start job for default target Graphical Interface.
[ 1.284515] systemd[1]: Created slice Slice /system/getty.
[ 1.284662] systemd[1]: Created slice Slice /system/modprobe.
[ 1.284798] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 1.284892] systemd[1]: Created slice User and Session Slice.
[ 1.284933] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 1.284964] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.285040] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.285068] systemd[1]: Reached target Local Encrypted Volumes.
[ 1.285085] systemd[1]: Reached target Login Prompts.
[ 1.285109] systemd[1]: Reached target Remote File Systems.
[ 1.285122] systemd[1]: Reached target Slice Units.
[ 1.285140] systemd[1]: Reached target Swaps.
[ 1.285157] systemd[1]: Reached target Local Verity Protected Volumes.
[ 1.285198] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 1.285344] systemd[1]: Listening on LVM2 poll daemon socket.
[ 1.285849] systemd[1]: Listening on Process Core Dump Socket.
[ 1.285925] systemd[1]: Listening on Journal Audit Socket.
[ 1.285978] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1.286036] systemd[1]: Listening on Journal Socket.
[ 1.286449] systemd[1]: Listening on udev Control Socket.
[ 1.286503] systemd[1]: Listening on udev Kernel Socket.
[ 1.286873] systemd[1]: Mounting Huge Pages File System...
[ 1.287191] systemd[1]: Mounting POSIX Message Queue File System...
[ 1.287535] systemd[1]: Mounting Kernel Debug File System...
[ 1.287879] systemd[1]: Mounting Kernel Trace File System...
[ 1.288638] systemd[1]: Mounting Temporary Directory /tmp...
[ 1.288948] usb 2-2: new SuperSpeed USB device number 2 using xhci_hcd
[ 1.289019] systemd[1]: Starting Load AppArmor profiles...
[ 1.289406] systemd[1]: Starting Create List of Static Device Nodes...
[ 1.289756] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 1.290113] systemd[1]: Starting Load Kernel Module configfs...
[ 1.290459] systemd[1]: Starting Load Kernel Module drm...
[ 1.290807] systemd[1]: Starting Load Kernel Module fuse...
[ 1.291388] systemd[1]: Starting Set Up Additional Binary Formats...
[ 1.291419] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 1.291468] random: lvm: uninitialized urandom read (4 bytes read)
[ 1.292003] systemd[1]: Starting Load Kernel Modules...
[ 1.292401] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 1.292442] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 1.292801] systemd[1]: Starting Coldplug All udev Devices...
[ 1.293574] systemd[1]: Mounted Huge Pages File System.
[ 1.293628] systemd[1]: Mounted POSIX Message Queue File System.
[ 1.293681] systemd[1]: Mounted Kernel Debug File System.
[ 1.293725] systemd[1]: Mounted Kernel Trace File System.
[ 1.293770] systemd[1]: Mounted Temporary Directory /tmp.
[ 1.293944] systemd[1]: Finished Create List of Static Device Nodes.
[ 1.294093] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 1.294215] systemd[1]: Finished Load Kernel Module configfs.
[ 1.294335] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 1.294450] systemd[1]: Finished Load Kernel Module drm.
[ 1.294586] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 339 (systemd-binfmt)
[ 1.294994] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 1.295401] systemd[1]: Mounting Kernel Configuration File System...
[ 1.295455] EXT4-fs (nvme0n1p2): re-mounted. Opts: (null). Quota mode: none.
[ 1.296207] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 1.296438] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 1.296514] systemd[1]: Mounted Kernel Configuration File System.
[ 1.296582] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 1.296795] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 1.297159] systemd[1]: Starting Load/Save Random Seed...
[ 1.297192] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 1.297560] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 1.298053] systemd[1]: Finished Set Up Additional Binary Formats.
[ 1.302006] fuse: init (API version 7.35)
[ 1.302356] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 1.302504] systemd[1]: Finished Load Kernel Module fuse.
[ 1.302962] systemd[1]: Mounting FUSE Control File System...
[ 1.304008] systemd[1]: Mounted FUSE Control File System.
[ 1.307981] IPMI message handler: version 39.2
[ 1.308269] usb 2-2: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=71.00
[ 1.308272] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.308274] usb 2-2: Product: USB3.2 Hub
[ 1.308275] usb 2-2: Manufacturer: GenesysLogic
[ 1.310463] ipmi device interface
[ 1.315391] ipmi_si: IPMI System Interface driver
[ 1.315437] ipmi_si: Unable to find any System Interface(s)
[ 1.316230] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 1.316328] systemd[1]: Condition check resulted in Entropy Daemon based on the HAVEGE algorithm being skipped.
[ 1.317525] systemd[1]: Starting Journal Service...
[ 1.318325] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 1.333202] systemd[1]: Finished Coldplug All udev Devices.
[ 1.333235] hub 2-2:1.0: USB hub found
[ 1.333246] audit: type=1130 audit(1640108726.459:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.333524] hub 2-2:1.0: 3 ports detected
[ 1.333883] usb: port power management may be unreliable
[ 1.347706] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 1.347773] audit: type=1130 audit(1640108726.473:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.348933] audit: type=1400 audit(1640108726.476:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=355 comm="apparmor_parser"
[ 1.349324] systemd[1]: Started Journal Service.
[ 1.349404] audit: type=1130 audit(1640108726.476:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.354923] systemd-journald[362]: Received client request to flush runtime journal.
[ 1.359827] systemd-journald[362]: File /var/log/journal/fa1d4b1475324d638f2f7fd68a5716fc/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 1.360691] audit: type=1400 audit(1640108726.486:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=356 comm="apparmor_parser"
[ 1.360848] audit: type=1400 audit(1640108726.486:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=358 comm="apparmor_parser"
[ 1.361407] audit: type=1400 audit(1640108726.486:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=356 comm="apparmor_parser"
[ 1.367044] audit: type=1130 audit(1640108726.493:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1.370770] audit: type=1400 audit(1640108726.496:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=357 comm="apparmor_parser"
[ 1.396788] ACPI: video: [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 1.396847] ACPI: video: Video Device [PEGP] (multi-head: yes rom: no post: no)
[ 1.397632] acpi device:01: registered as cooling_device16
[ 1.398117] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input4
[ 1.399183] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 1.399238] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP17.VGA.LCD._BCM.AFN7], AE_NOT_FOUND (20210930/psargs-330)
[ 1.399245] ACPI Error: Aborting method \_SB.PCI0.GP17.VGA.LCD._BCM due to previous error (AE_NOT_FOUND) (20210930/psparse-529)
[ 1.399425] ACPI: \_SB_.PCI0.GP17.VGA_.LCD_: _BCM evaluation failed
[ 1.399766] random: tlp-readconfs: uninitialized urandom read (4 bytes read)
[ 1.399938] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input5
[ 1.420831] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.421031] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.421211] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 1.421350] loop: module loaded
[ 1.428846] usb 1-4: new full-speed USB device number 3 using xhci_hcd
[ 1.442674] loop0: detected capacity change from 0 to 88616
[ 1.442724] loop1: detected capacity change from 0 to 113640
[ 1.442802] loop2: detected capacity change from 0 to 264984
[ 1.442887] loop3: detected capacity change from 0 to 44392
[ 1.443851] loop4: detected capacity change from 0 to 126784
[ 1.455620] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 1.455626] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 1.478240] input: MSFT0001:00 04F3:31AD Mouse as /devices/platform/AMDI0010:01/i2c-0/i2c-MSFT0001:00/0018:04F3:31AD.0001/input/input6
[ 1.478293] input: MSFT0001:00 04F3:31AD Touchpad as /devices/platform/AMDI0010:01/i2c-0/i2c-MSFT0001:00/0018:04F3:31AD.0001/input/input8
[ 1.478337] hid-generic 0018:04F3:31AD.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:00 04F3:31AD] on i2c-MSFT0001:00
[ 1.500318] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.503510] cryptd: max_cpu_qlen set to 1000
[ 1.527046] libphy: r8169: probed
[ 1.527183] r8169 0000:03:00.0 eth0: RTL8168h/8111h, 38:f3:ab:9a:71:9a, XID 541, IRQ 74
[ 1.527185] r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 1.566448] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xff00, revision 15
[ 1.566457] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 1.566555] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xff20
[ 1.573755] nvidia: loading out-of-tree module taints kernel.
[ 1.573763] nvidia: module license 'NVIDIA' taints kernel.
[ 1.573764] Disabling lock debugging due to kernel taint
[ 1.604218] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 1.605161] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:14.3/PNP0C09:00/VPC2004:00/input/input9
[ 1.605275] ideapad_acpi VPC2004:00: Keyboard backlight control not available
[ 1.606421] AVX2 version of gcm_enc/dec engaged.
[ 1.606450] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 1.606535] AES CTR mode by8 optimization enabled
[ 1.606648] sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
[ 1.606730] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 1.612966] ideapad_acpi VPC2004:00: DYTC interface is not available
[ 1.613068] usb 1-4: New USB device found, idVendor=048d, idProduct=c101, bcdDevice= 7.00
[ 1.613074] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.613076] usb 1-4: Product: ITE Device(8910)
[ 1.613077] usb 1-4: Manufacturer: ITE Tech. Inc.
[ 1.632212] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.633378] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
[ 1.640209] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 1.640867] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.683574] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 495.44 Fri Oct 22 06:13:12 UTC 2021
[ 1.725119] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 495.44 Fri Oct 22 06:05:22 UTC 2021
[ 1.748034] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 1.748039] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 1.845159] ccp 0000:05:00.2: enabling device (0000 -> 0002)
[ 1.845352] ccp 0000:05:00.2: ccp: unable to access the device: you might be running a broken BIOS.
[ 1.851754] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 1.851856] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 1.851862] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 1.851945] snd_hda_intel 0000:05:00.6: enabling device (0000 -> 0002)
[ 1.855506] ccp 0000:05:00.2: tee enabled
[ 1.855508] ccp 0000:05:00.2: psp enabled
[ 1.863398] r8169 0000:03:00.0 eno1: renamed from eth0
[ 1.926719] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input10
[ 1.926755] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 1.933749] SVM: TSC scaling supported
[ 1.933751] kvm: Nested Virtualization enabled
[ 1.933753] SVM: kvm: Nested Paging enabled
[ 1.933765] SVM: Virtual VMLOAD VMSAVE supported
[ 1.933765] SVM: Virtual GIF supported
[ 1.933766] SVM: LBR virtualization supported
[ 1.935844] nvidia-uvm: Loaded the UVM driver, major device number 507.
[ 1.945318] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC287: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 1.945324] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 1.945326] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 1.945328] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 1.945329] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 1.945330] snd_hda_codec_realtek hdaudioC1D0: Mic=0x19
[ 1.945332] snd_hda_codec_realtek hdaudioC1D0: Internal Mic=0x12
[ 1.956223] MCE: In-kernel MCE decoding enabled.
[ 1.961561] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input11
[ 1.961609] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input12
[ 1.961647] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input13
[ 1.961683] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input14
[ 1.961717] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input15
[ 1.971396] input: MSFT0001:00 04F3:31AD Mouse as /devices/platform/AMDI0010:01/i2c-0/i2c-MSFT0001:00/0018:04F3:31AD.0001/input/input16
[ 1.971455] input: MSFT0001:00 04F3:31AD Touchpad as /devices/platform/AMDI0010:01/i2c-0/i2c-MSFT0001:00/0018:04F3:31AD.0001/input/input18
[ 1.971501] hid-multitouch 0018:04F3:31AD.0001: input,hidraw0: I2C HID v1.00 Mouse [MSFT0001:00 04F3:31AD] on i2c-MSFT0001:00
[ 2.016749] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:05:00.6/sound/card1/input19
[ 2.016791] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:05:00.6/sound/card1/input20
[ 2.017403] mousedev: PS/2 mouse device common for all mice
[ 2.017931] rtw89_pci 0000:04:00.0: enabling device (0000 -> 0003)
[ 2.020413] rtw89_pci 0000:04:00.0: Firmware version 0.13.30.0, cmd version 0, type 1
[ 2.020418] rtw89_pci 0000:04:00.0: Firmware version 0.13.30.0, cmd version 0, type 3
[ 2.036548] rtw89_pci 0000:04:00.0: chip rfe_type is 1
[ 2.043831] loop5: detected capacity change from 0 to 8
[ 2.092262] Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[ 2.131151] NET: Registered PF_QIPCRTR protocol family
[ 2.138050] intel_rapl_common: Found RAPL domain package
[ 2.138052] intel_rapl_common: Found RAPL domain core
[ 2.163156] ACPI Warning: \_SB.PCI0.GPP0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210930/nsarguments-61)
[ 2.163531] ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210930/nsarguments-61)
[ 2.299428] r8169 0000:03:00.0 eno1: Link is Down
[ 2.299925] rtw89_pci 0000:04:00.0 wlp4s0: renamed from wlan0
[ 2.558328] NVRM: nv_acpi_dsm_method: DSM data invalid!
[ 2.708851] random: crng init done
[ 2.708852] random: 7 urandom warning(s) missed due to ratelimiting
[ 3.091257] input: ITE Tech. Inc. ITE Device(8910) Keyboard as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-4/1-4:1.0/0003:048D:C101.0002/input/input21
[ 3.103277] Bluetooth: Core ver 2.22
[ 3.103290] NET: Registered PF_BLUETOOTH protocol family
[ 3.103291] Bluetooth: HCI device and connection manager initialized
[ 3.103293] Bluetooth: HCI socket layer initialized
[ 3.103294] Bluetooth: L2CAP socket layer initialized
[ 3.103297] Bluetooth: SCO socket layer initialized
[ 3.145994] input: ITE Tech. Inc. ITE Device(8910) Wireless Radio Control as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-4/1-4:1.0/0003:048D:C101.0002/input/input22
[ 3.146148] hid-generic 0003:048D:C101.0002: input,hiddev96,hidraw1: USB HID v1.10 Keyboard [ITE Tech. Inc. ITE Device(8910)] on usb-0000:05:00.3-4/input0
[ 3.146171] usbcore: registered new interface driver usbhid
[ 3.146172] usbhid: USB HID core driver
[ 3.200248] usbcore: registered new interface driver btusb
[ 3.201793] Bluetooth: hci0: RTL: examining hci_ver=0b hci_rev=000a lmp_ver=0b lmp_subver=8852
[ 3.203787] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 3.203789] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852au_fw.bin
[ 3.204087] Bluetooth: hci0: RTL: loading rtl_bt/rtl8852au_config.bin
[ 3.204196] Bluetooth: hci0: RTL: cfg_sz 6, total sz 46195
[ 3.273468] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.273471] Bluetooth: BNEP filters: protocol multicast
[ 3.273474] Bluetooth: BNEP socket layer initialized
[ 3.593836] Bluetooth: hci0: RTL: fw version 0xd9a91d69
[ 3.733892] Bluetooth: hci0: Failed to read codec capabilities (-22)
[ 3.768819] NET: Registered PF_ALG protocol family
[ 6.260292] kauditd_printk_skb: 71 callbacks suppressed
[ 6.260294] audit: type=1100 audit(1640108731.386:61): pid=1027 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 6.260298] audit: type=1101 audit(1640108731.386:62): pid=1027 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 6.260649] audit: type=1103 audit(1640108731.386:63): pid=1027 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 6.269431] audit: type=1130 audit(1640108731.396:64): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.274557] audit: type=1101 audit(1640108731.399:65): pid=1029 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.274577] audit: type=1103 audit(1640108731.399:66): pid=1029 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 6.274604] audit: type=1006 audit(1640108731.399:67): pid=1029 uid=0 subj==unconfined old-auid=4294967295 auid=963 tty=(none) old-ses=4294967295 ses=1 res=1
[ 6.274605] audit: type=1300 audit(1640108731.399:67): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffd47790900 a2=3 a3=3c3 items=0 ppid=1 pid=1029 auid=963 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
[ 6.274607] audit: type=1327 audit(1640108731.399:67): proctitle="(systemd)"
[ 6.275794] audit: type=1105 audit(1640108731.403:68): pid=1029 uid=0 auid=963 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.147014] nvidia-modeset: ERROR: GPU:0: Failed to set variable refresh rate with invalid minimum frame time (16684000 ns) or maximum frame time (1000 ns)
[ 12.020067] kauditd_printk_skb: 10 callbacks suppressed
[ 12.020071] audit: type=1131 audit(1640108737.146:77): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.564013] audit: type=1100 audit(1640108737.689:78): pid=1078 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="buiterma" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 12.564849] audit: type=1101 audit(1640108737.689:79): pid=1078 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="buiterma" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 12.565127] audit: type=1103 audit(1640108737.689:80): pid=1078 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="buiterma" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 12.565174] audit: type=1006 audit(1640108737.689:81): pid=1078 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 12.565177] audit: type=1300 audit(1640108737.689:81): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7fff76b7b680 a2=4 a3=3e8 items=0 ppid=689 pid=1078 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null)
[ 12.565180] audit: type=1327 audit(1640108737.689:81): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746836383561383863392D396236362D343637362D383166352D656534393034386339353731002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
[ 12.583003] audit: type=1130 audit(1640108737.709:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.592865] audit: type=1101 audit(1640108737.719:83): pid=1080 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="buiterma" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.592887] audit: type=1103 audit(1640108737.719:84): pid=1080 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="buiterma" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 12.631786] systemd-journald[362]: File /var/log/journal/fa1d4b1475324d638f2f7fd68a5716fc/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 13.663790] Bluetooth: hci0: Failed to read codec capabilities (-22)
[ 13.679295] Bluetooth: RFCOMM TTY layer initialized
[ 13.679308] Bluetooth: RFCOMM socket layer initialized
[ 13.679312] Bluetooth: RFCOMM ver 1.11
[ 19.360078] wlp4s0: authenticate with d8:47:32:f9:52:4b
[ 19.590205] wlp4s0: send auth to d8:47:32:f9:52:4b (try 1/3)
[ 19.590818] wlp4s0: authenticated
[ 19.592188] wlp4s0: associate with d8:47:32:f9:52:4b (try 1/3)
[ 19.593381] wlp4s0: RX AssocResp from d8:47:32:f9:52:4b (capab=0x411 status=0 aid=3)
[ 19.702403] wlp4s0: associated
[ 19.772284] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
[ 19.989662] kauditd_printk_skb: 19 callbacks suppressed
[ 19.989664] audit: type=1130 audit(1640108745.116:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.920669] audit: type=1131 audit(1640108748.046:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.925485] audit: type=1131 audit(1640108748.049:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 30.011117] audit: type=1131 audit(1640108755.136:101): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.173440] audit: type=1131 audit(1640108757.299:102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 32.219133] audit: type=1334 audit(1640108757.346:103): prog-id=0 op=UNLOAD
[ 32.219151] audit: type=1334 audit(1640108757.346:104): prog-id=0 op=UNLOAD
[ 32.219157] audit: type=1334 audit(1640108757.346:105): prog-id=0 op=UNLOAD
[ 35.057902] audit: type=1334 audit(1640108760.183:106): prog-id=22 op=LOAD
[ 35.058064] audit: type=1334 audit(1640108760.183:107): prog-id=23 op=LOAD
[ 35.058145] audit: type=1334 audit(1640108760.183:108): prog-id=24 op=LOAD
[ 35.091425] audit: type=1130 audit(1640108760.216:109): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.571240] audit: type=1131 audit(1640108770.696:110): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 45.679022] audit: type=1334 audit(1640108770.806:111): prog-id=0 op=UNLOAD
[ 45.679028] audit: type=1334 audit(1640108770.806:112): prog-id=0 op=UNLOAD
[ 45.679031] audit: type=1334 audit(1640108770.806:113): prog-id=0 op=UNLOAD
[ 65.109352] audit: type=1131 audit(1640108790.236:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 65.139023] audit: type=1334 audit(1640108790.266:115): prog-id=0 op=UNLOAD
[ 65.139033] audit: type=1334 audit(1640108790.266:116): prog-id=0 op=UNLOAD
[ 65.139039] audit: type=1334 audit(1640108790.266:117): prog-id=0 op=UNLOAD
[ 212.222932] input: MX Master 3 Keyboard as /devices/virtual/misc/uhid/0005:046D:B023.0003/input/input23
[ 212.223113] input: MX Master 3 Mouse as /devices/virtual/misc/uhid/0005:046D:B023.0003/input/input24
[ 212.223419] hid-generic 0005:046D:B023.0003: input,hidraw2: BLUETOOTH HID v0.15 Keyboard [MX Master 3] on 74:4c:a1:da:b0:f8
[ 217.512187] logitech-hidpp-device 0005:046D:B023.0003: Device not connected
[ 304.442199] usb 1-2.1: new high-speed USB device number 4 using xhci_hcd
[ 306.895157] usb 1-2.1: New USB device found, idVendor=046d, idProduct=082d, bcdDevice= 0.11
[ 306.895169] usb 1-2.1: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[ 306.895174] usb 1-2.1: Product: HD Pro Webcam C920
[ 306.895177] usb 1-2.1: SerialNumber: 5CFFDA3F
[ 307.524033] mc: Linux media interface: v0.10
[ 307.543697] videodev: Linux video capture interface: v2.00
[ 307.890445] usbcore: registered new interface driver snd-usb-audio
[ 307.890497] usb 1-2.1: Found UVC 1.00 device HD Pro Webcam C920 (046d:082d)
[ 307.897964] input: HD Pro Webcam C920 as /devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-2/1-2.1/1-2.1:1.0/input/input26
[ 307.898042] usbcore: registered new interface driver uvcvideo
[ 317.157176] usb 1-2.1: reset high-speed USB device number 4 using xhci_hcd
[ 335.074433] audit: type=1334 audit(1640109060.198:118): prog-id=25 op=LOAD
[ 335.074582] audit: type=1334 audit(1640109060.198:119): prog-id=26 op=LOAD
[ 335.074664] audit: type=1334 audit(1640109060.198:120): prog-id=27 op=LOAD
[ 335.107982] audit: type=1130 audit(1640109060.231:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 365.137401] audit: type=1131 audit(1640109090.261:122): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 365.176810] audit: type=1334 audit(1640109090.301:123): prog-id=0 op=UNLOAD
[ 365.176821] audit: type=1334 audit(1640109090.301:124): prog-id=0 op=UNLOAD
[ 365.176825] audit: type=1334 audit(1640109090.301:125): prog-id=0 op=UNLOAD
[ 367.110617] usb 1-2.1: USB disconnect, device number 4
[ 367.113492] uvcvideo 1-2.1:1.1: Failed to resubmit video URB (-19).
[ 367.117491] uvcvideo 1-2.1:1.1: Failed to resubmit video URB (-19).
[ 367.121489] uvcvideo 1-2.1:1.1: Failed to resubmit video URB (-19).
[ 367.125488] uvcvideo 1-2.1:1.1: Failed to resubmit video URB (-19).
[ 367.129490] uvcvideo 1-2.1:1.1: Failed to resubmit video URB (-19).
[ 571.104910] audit: type=1100 audit(1640109296.230:126): pid=3201 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="buiterma" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 571.105875] audit: type=1101 audit(1640109296.233:127): pid=3201 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="buiterma" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 571.106465] audit: type=1110 audit(1640109296.233:128): pid=3201 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 571.108849] audit: type=1105 audit(1640109296.236:129): pid=3201 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 571.127814] audit: type=1106 audit(1640109296.253:130): pid=3201 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 571.127881] audit: type=1104 audit(1640109296.253:131): pid=3201 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 604.716595] audit: type=1101 audit(1640109329.843:132): pid=3213 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="buiterma" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 604.716926] audit: type=1110 audit(1640109329.843:133): pid=3213 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 604.718105] audit: type=1105 audit(1640109329.843:134): pid=3213 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
glxinfo
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_libglvnd,
GLX_EXT_stereo_tree, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_NV_copy_image, GLX_NV_delay_before_swap, GLX_NV_float_buffer,
GLX_NV_multigpu_context, GLX_NV_robustness_video_memory_purge,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_swap_control,
GLX_SGI_video_sync
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_stereo_tree, GLX_EXT_swap_control,
GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_NV_copy_buffer,
GLX_NV_multigpu_context, GLX_NV_multisample_coverage,
GLX_NV_robustness_video_memory_purge, GLX_NV_swap_group,
GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_stereo_tree,
GLX_SGI_video_sync
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 6144 MB
Total available memory: 6144 MB
Currently available dedicated video memory: 5201 MB
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 495.44
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_AMD_multi_draw_indirect, GL_AMD_seamless_cubemap_per_texture,
GL_AMD_vertex_shader_layer, GL_AMD_vertex_shader_viewport_index,
GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility,
GL_ARB_ES3_2_compatibility, GL_ARB_ES3_compatibility,
GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_bindless_texture,
GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
GL_ARB_clear_buffer_object, GL_ARB_clear_texture, GL_ARB_clip_control,
GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_compute_shader, GL_ARB_compute_variable_group_size,
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
GL_ARB_depth_texture, GL_ARB_derivative_control,
GL_ARB_direct_state_access, GL_ARB_draw_buffers,
GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_fragment_shader_interlock,
GL_ARB_framebuffer_no_attachments, GL_ARB_framebuffer_object,
GL_ARB_framebuffer_sRGB, GL_ARB_geometry_shader4,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image, GL_ARB_gl_spirv,
GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_gpu_shader_int64,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex, GL_ARB_imaging,
GL_ARB_indirect_parameters, GL_ARB_instanced_arrays,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_occlusion_query2, GL_ARB_parallel_shader_compile,
GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
GL_ARB_post_depth_coverage, GL_ARB_program_interface_query,
GL_ARB_provoking_vertex, GL_ARB_query_buffer_object,
GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
GL_ARB_sample_locations, GL_ARB_sample_shading, GL_ARB_sampler_objects,
GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture,
GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counter_ops,
GL_ARB_shader_atomic_counters, GL_ARB_shader_ballot,
GL_ARB_shader_bit_encoding, GL_ARB_shader_clock,
GL_ARB_shader_draw_parameters, GL_ARB_shader_group_vote,
GL_ARB_shader_image_load_store, GL_ARB_shader_image_size,
GL_ARB_shader_objects, GL_ARB_shader_precision,
GL_ARB_shader_storage_buffer_object, GL_ARB_shader_subroutine,
GL_ARB_shader_texture_image_samples, GL_ARB_shader_texture_lod,
GL_ARB_shader_viewport_layer_array, GL_ARB_shading_language_100,
GL_ARB_shading_language_420pack, GL_ARB_shading_language_include,
GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_sparse_buffer,
GL_ARB_sparse_texture, GL_ARB_sparse_texture2,
GL_ARB_sparse_texture_clamp, GL_ARB_spirv_extensions,
GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_tessellation_shader,
GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
GL_ARB_texture_buffer_range, GL_ARB_texture_compression,
GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_cube_map, GL_ARB_texture_cube_map_array,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_filter_anisotropic, GL_ARB_texture_filter_minmax,
GL_ARB_texture_float, GL_ARB_texture_gather,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
GL_ARB_texture_stencil8, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_64bit,
GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ARB_viewport_array, GL_ARB_window_pos, GL_ATI_draw_buffers,
GL_ATI_texture_float, GL_ATI_texture_mirror_once,
GL_EXTX_framebuffer_mixed_formats, GL_EXT_Cg_shader, GL_EXT_abgr,
GL_EXT_bgra, GL_EXT_bindable_uniform, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
GL_EXT_depth_bounds_test, GL_EXT_direct_state_access,
GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
GL_EXT_framebuffer_sRGB, GL_EXT_geometry_shader4,
GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4,
GL_EXT_import_sync_object, GL_EXT_memory_object, GL_EXT_memory_object_fd,
GL_EXT_multi_draw_arrays, GL_EXT_multiview_texture_multisample,
GL_EXT_multiview_timer_query, GL_EXT_packed_depth_stencil,
GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_polygon_offset_clamp,
GL_EXT_post_depth_coverage, GL_EXT_provoking_vertex,
GL_EXT_raster_multisample, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_semaphore, GL_EXT_semaphore_fd, GL_EXT_separate_shader_objects,
GL_EXT_separate_specular_color, GL_EXT_shader_image_load_formatted,
GL_EXT_shader_image_load_store, GL_EXT_shader_integer_mix,
GL_EXT_shadow_funcs, GL_EXT_sparse_texture2, GL_EXT_stencil_two_side,
GL_EXT_stencil_wrap, GL_EXT_texture3D, GL_EXT_texture_array,
GL_EXT_texture_buffer_object, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_filter_minmax,
GL_EXT_texture_integer, GL_EXT_texture_lod, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_sRGB,
GL_EXT_texture_sRGB_R8, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_shadow_lod, GL_EXT_texture_shared_exponent,
GL_EXT_texture_storage, GL_EXT_texture_swizzle, GL_EXT_timer_query,
GL_EXT_transform_feedback2, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_EXT_vertex_attrib_64bit, GL_EXT_window_rectangles,
GL_EXT_x11_sync_object, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_KHR_blend_equation_advanced,
GL_KHR_blend_equation_advanced_coherent, GL_KHR_context_flush_control,
GL_KHR_debug, GL_KHR_no_error, GL_KHR_parallel_shader_compile,
GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness,
GL_KHR_shader_subgroup, GL_KTX_buffer_region,
GL_NVX_blend_equation_advanced_multi_draw_buffers,
GL_NVX_conditional_render, GL_NVX_gpu_memory_info, GL_NVX_nvenc_interop,
GL_NVX_progress_fence, GL_NV_ES1_1_compatibility,
GL_NV_ES3_1_compatibility, GL_NV_alpha_to_coverage_dither_control,
GL_NV_bindless_multi_draw_indirect,
GL_NV_bindless_multi_draw_indirect_count, GL_NV_bindless_texture,
GL_NV_blend_equation_advanced, GL_NV_blend_equation_advanced_coherent,
GL_NV_blend_minmax_factor, GL_NV_blend_square, GL_NV_clip_space_w_scaling,
GL_NV_command_list, GL_NV_compute_program5,
GL_NV_compute_shader_derivatives, GL_NV_conditional_render,
GL_NV_conservative_raster, GL_NV_conservative_raster_dilate,
GL_NV_conservative_raster_pre_snap,
GL_NV_conservative_raster_pre_snap_triangles,
GL_NV_conservative_raster_underestimation, GL_NV_copy_depth_to_color,
GL_NV_copy_image, GL_NV_depth_buffer_float, GL_NV_depth_clamp,
GL_NV_draw_texture, GL_NV_draw_vulkan_image, GL_NV_explicit_multisample,
GL_NV_feature_query, GL_NV_fence, GL_NV_fill_rectangle,
GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragment_coverage_to_color,
GL_NV_fragment_program, GL_NV_fragment_program2,
GL_NV_fragment_program_option, GL_NV_fragment_shader_barycentric,
GL_NV_fragment_shader_interlock, GL_NV_framebuffer_mixed_samples,
GL_NV_framebuffer_multisample_coverage, GL_NV_geometry_shader4,
GL_NV_geometry_shader_passthrough, GL_NV_gpu_multicast,
GL_NV_gpu_program4, GL_NV_gpu_program4_1, GL_NV_gpu_program5,
GL_NV_gpu_program5_mem_extended, GL_NV_gpu_program_fp64,
GL_NV_gpu_shader5, GL_NV_half_float, GL_NV_internalformat_sample_query,
GL_NV_light_max_exponent, GL_NV_memory_attachment,
GL_NV_memory_object_sparse, GL_NV_mesh_shader, GL_NV_multisample_coverage,
GL_NV_multisample_filter_hint, GL_NV_occlusion_query,
GL_NV_packed_depth_stencil, GL_NV_parameter_buffer_object,
GL_NV_parameter_buffer_object2, GL_NV_path_rendering,
GL_NV_path_rendering_shared_edge, GL_NV_pixel_data_range,
GL_NV_point_sprite, GL_NV_primitive_restart, GL_NV_primitive_shading_rate,
GL_NV_query_resource, GL_NV_query_resource_tag, GL_NV_register_combiners,
GL_NV_register_combiners2, GL_NV_representative_fragment_test,
GL_NV_robustness_video_memory_purge, GL_NV_sample_locations,
GL_NV_sample_mask_override_coverage, GL_NV_scissor_exclusive,
GL_NV_shader_atomic_counters, GL_NV_shader_atomic_float,
GL_NV_shader_atomic_float64, GL_NV_shader_atomic_fp16_vector,
GL_NV_shader_atomic_int64, GL_NV_shader_buffer_load,
GL_NV_shader_storage_buffer_object, GL_NV_shader_subgroup_partitioned,
GL_NV_shader_texture_footprint, GL_NV_shader_thread_group,
GL_NV_shader_thread_shuffle, GL_NV_shading_rate_image,
GL_NV_stereo_view_rendering, GL_NV_texgen_reflection,
GL_NV_texture_barrier, GL_NV_texture_compression_vtc,
GL_NV_texture_dirty_tile_map, GL_NV_texture_env_combine4,
GL_NV_texture_multisample, GL_NV_texture_rectangle,
GL_NV_texture_rectangle_compressed, GL_NV_texture_shader,
GL_NV_texture_shader2, GL_NV_texture_shader3, GL_NV_timeline_semaphore,
GL_NV_transform_feedback, GL_NV_transform_feedback2,
GL_NV_uniform_buffer_unified_memory, GL_NV_vdpau_interop,
GL_NV_vdpau_interop2, GL_NV_vertex_array_range, GL_NV_vertex_array_range2,
GL_NV_vertex_attrib_integer_64bit, GL_NV_vertex_buffer_unified_memory,
GL_NV_vertex_program, GL_NV_vertex_program1_1, GL_NV_vertex_program2,
GL_NV_vertex_program2_option, GL_NV_vertex_program3,
GL_NV_viewport_array2, GL_NV_viewport_swizzle, GL_OVR_multiview,
GL_OVR_multiview2, GL_S3_s3tc, GL_SGIS_generate_mipmap,
GL_SGIS_texture_lod, GL_SGIX_depth_texture, GL_SGIX_shadow,
GL_SUN_slice_accum
OpenGL version string: 4.6.0 NVIDIA 495.44
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
GL_ARB_color_buffer_float, GL_ARB_compatibility,
GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
GL_ARB_compute_variable_group_size, GL_ARB_conditional_render_inverted,
GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_derivative_control,
GL_SUN_slice_accum
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 495.44
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
GL_ANDROID_extension_pack_es31a, GL_EXT_EGL_image_external_wrap_modes,
GL_EXT_base_instance, GL_EXT_blend_func_extended, GL_EXT_blend_minmax,
GL_EXT_buffer_storage, GL_EXT_clear_texture, GL_EXT_clip_control,
GL_EXT_clip_cull_distance, GL_EXT_color_buffer_float,
GL_EXT_color_buffer_half_float, GL_EXT_compressed_ETC1_RGB8_sub_texture,
GL_EXT_conservative_depth, GL_EXT_copy_image, GL_EXT_debug_label,
GL_EXT_depth_clamp, GL_EXT_discard_framebuffer,
GL_EXT_disjoint_timer_query, GL_EXT_draw_buffers_indexed,
GL_EXT_draw_elements_base_vertex, GL_EXT_draw_transform_feedback,
GL_EXT_float_blend, GL_EXT_frag_depth, GL_EXT_geometry_point_size,
GL_EXT_geometry_shader, GL_EXT_gpu_shader5, GL_EXT_map_buffer_range,
GL_EXT_memory_object, GL_EXT_memory_object_fd, GL_EXT_multi_draw_indirect,
GL_EXT_multisample_compatibility, GL_EXT_multisampled_render_to_texture,
GL_EXT_multisampled_render_to_texture2,
GL_EXT_multiview_texture_multisample, GL_EXT_multiview_timer_query,
GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp,
GL_EXT_post_depth_coverage, GL_EXT_primitive_bounding_box,
GL_EXT_raster_multisample, GL_EXT_render_snorm, GL_EXT_robustness,
GL_EXT_sRGB, GL_EXT_sRGB_write_control, GL_EXT_semaphore,
GL_EXT_shader_group_vote, GL_EXT_shader_implicit_conversions,
GL_EXT_shader_integer_mix, GL_EXT_shader_io_blocks,
GL_EXT_shader_non_constant_global_initializers, GL_EXT_shader_texture_lod,
GL_EXT_shadow_samplers, GL_EXT_sparse_texture, GL_EXT_sparse_texture2,
GL_EXT_tessellation_point_size, GL_EXT_tessellation_shader,
GL_EXT_texture_border_clamp, GL_EXT_texture_buffer,
GL_EXT_texture_compression_bptc, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_cube_map_array, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_filter_minmax, GL_EXT_texture_format_BGRA8888,
GL_EXT_texture_mirror_clamp_to_edge, GL_EXT_texture_norm16,
GL_EXT_texture_query_lod, GL_EXT_texture_rg, GL_EXT_texture_sRGB_R8,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_shadow_lod,
GL_EXT_texture_storage, GL_EXT_texture_view, GL_EXT_unpack_subimage,
GL_EXT_window_rectangles, GL_KHR_blend_equation_advanced,
GL_KHR_shader_subgroup, GL_KHR_texture_compression_astc_hdr,
GL_KHR_texture_compression_astc_ldr,
GL_KHR_texture_compression_astc_sliced_3d,
GL_NVX_blend_equation_advanced_multi_draw_buffers, GL_NV_bgr,
GL_NV_bindless_texture, GL_NV_blend_equation_advanced,
GL_NV_blend_equation_advanced_coherent, GL_NV_blend_minmax_factor,
GL_NV_clip_space_w_scaling, GL_NV_compute_shader_derivatives,
GL_NV_conditional_render, GL_NV_conservative_raster,
GL_NV_conservative_raster_pre_snap_triangles, GL_NV_copy_buffer,
GL_NV_copy_image, GL_NV_draw_buffers, GL_NV_draw_instanced,
GL_NV_explicit_attrib_location, GL_NV_fbo_color_attachments,
GL_NV_fill_rectangle, GL_NV_fragment_coverage_to_color,
GL_NV_fragment_shader_barycentric, GL_NV_fragment_shader_interlock,
GL_NV_framebuffer_blit, GL_NV_framebuffer_mixed_samples,
GL_NV_framebuffer_multisample, GL_NV_generate_mipmap_sRGB,
GL_NV_geometry_shader_passthrough, GL_NV_gpu_shader5, GL_NV_image_formats,
GL_NV_instanced_arrays, GL_NV_internalformat_sample_query,
GL_NV_memory_attachment, GL_NV_memory_object_sparse, GL_NV_mesh_shader,
GL_NV_non_square_matrices, GL_NV_occlusion_query_samples,
GL_NV_pack_subimage, GL_NV_packed_float, GL_NV_packed_float_linear,
GL_NV_path_rendering, GL_NV_path_rendering_shared_edge,
GL_NV_pixel_buffer_object, GL_NV_polygon_mode,
GL_NV_primitive_shading_rate, GL_NV_read_buffer, GL_NV_read_depth,
GL_NV_read_depth_stencil, GL_NV_read_stencil,
GL_NV_representative_fragment_test, GL_NV_sRGB_formats,
GL_NV_sample_locations, GL_NV_sample_mask_override_coverage,
GL_NV_scissor_exclusive, GL_NV_shader_atomic_fp16_vector,
GL_NV_shader_noperspective_interpolation,
GL_NV_shader_subgroup_partitioned, GL_NV_shader_texture_footprint,
GL_NV_shading_rate_image, GL_NV_shadow_samplers_array,
GL_NV_shadow_samplers_cube, GL_NV_stereo_view_rendering,
GL_NV_texture_array, GL_NV_texture_barrier, GL_NV_texture_border_clamp,
GL_NV_texture_compression_latc, GL_NV_texture_compression_s3tc,
GL_NV_texture_compression_s3tc_update, GL_NV_texture_dirty_tile_map,
GL_NV_timeline_semaphore, GL_NV_timer_query, GL_NV_viewport_array,
GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image, GL_OES_depth24,
GL_OES_depth32, GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
GL_OES_geometry_point_size, GL_OES_geometry_shader,
GL_OES_get_program_binary, GL_OES_gpu_shader5, GL_OES_mapbuffer,
GL_OES_packed_depth_stencil, GL_OES_primitive_bounding_box,
GL_OES_rgb8_rgba8, GL_OES_sample_shading, GL_OES_sample_variables,
GL_OES_shader_image_atomic, GL_OES_shader_io_blocks,
GL_OES_shader_multisample_interpolation, GL_OES_standard_derivatives,
GL_OES_tessellation_point_size, GL_OES_tessellation_shader,
GL_OES_texture_border_clamp, GL_OES_texture_buffer,
GL_OES_texture_cube_map_array, GL_OES_texture_float,
GL_OES_texture_float_linear, GL_OES_texture_half_float,
GL_OES_texture_half_float_linear, GL_OES_texture_npot,
GL_OES_texture_stencil8, GL_OES_texture_storage_multisample_2d_array,
GL_OES_texture_view, GL_OES_vertex_array_object, GL_OES_vertex_half_float,
GL_OES_viewport_array, GL_OVR_multiview, GL_OVR_multiview2,
GL_OVR_multiview_multisampled_render_to_texture
132 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x021 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x022 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x024 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x025 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x026 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x027 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x028 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x029 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x02a 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x02b 24 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x02c 24 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x02d 24 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x02e 24 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x02f 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x030 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x031 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x032 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x033 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x034 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x035 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x036 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x037 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x038 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x039 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x03a 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x03b 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x03c 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x03d 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x03e 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x03f 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x040 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x041 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x042 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x043 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x044 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x045 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x046 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x047 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x048 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x049 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x04a 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x04b 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x04c 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x04d 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x04e 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x04f 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x050 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x051 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x052 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x053 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x054 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x055 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x056 24 dc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x057 24 dc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x058 24 dc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x059 24 dc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x05a 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x05b 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x05c 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x05d 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x05e 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x05f 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x060 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x061 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x062 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x063 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x064 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x065 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x066 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x067 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x068 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x069 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x06a 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x06b 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x06c 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x06d 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x06e 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x06f 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x070 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x071 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x072 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x073 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x074 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x075 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x076 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x077 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x078 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x079 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x023 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x07a 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x07b 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x07c 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x07d 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x07e 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x07f 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x080 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x081 32 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x082 32 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x083 32 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x084 32 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x085 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x086 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x087 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x088 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x089 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x08a 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x08b 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x08c 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x08d 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x08e 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x08f 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x090 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x091 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x092 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x093 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x094 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x095 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x096 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x097 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x098 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x099 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x09a 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x09b 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x09c 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x09d 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x09e 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x09f 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0a0 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0a1 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0a2 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0a3 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0a4 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
215 GLXFBConfigs:
0x0a5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0a6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0a7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0a8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0a9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0aa 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0ab 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0ac 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0ad 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0ae 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0af 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b1 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0b2 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0b3 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b4 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0b6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0b7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0b8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0b9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0ba 24 dc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0bb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0bc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0bd 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x0be 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x0bf 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x0c0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x0c1 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x0c2 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x0c3 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x0c4 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x0c5 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x0c6 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x0c7 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x0c8 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x0c9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x0ca 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x0cb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x0cc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x0cd 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x0ce 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x0cf 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x0d0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x0d1 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x0d2 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x0d3 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x0d4 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x0d5 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x0d6 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x0d7 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x0d8 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x0d9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x0da 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x0db 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x0dc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x0dd 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x0de 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x0df 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x0e0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x0e1 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x0e2 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x0e3 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x0e4 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x0e5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x0e6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x0e7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x0e8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x0e9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x0ea 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x0eb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x0ec 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x0ed 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0ee 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0ef 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0f0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0f1 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0f2 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0f3 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0f4 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0f5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0f6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0f7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0f8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0f9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0fa 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0fb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0fc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0fd 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0fe 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0ff 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x100 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x101 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x102 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x103 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x104 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x105 32 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x106 32 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x107 32 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x108 32 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x109 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x10a 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x10b 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x10c 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x10d 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x10e 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x10f 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x110 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x111 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x112 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x113 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x114 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x115 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x116 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x117 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x118 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x119 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x11a 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x11b 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x11c 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x11d 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x11e 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x11f 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x120 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x121 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x122 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x123 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x124 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x125 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x126 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x127 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x128 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x129 0 sg 0 16 0 r y . 5 6 5 0 . . 4 16 0 16 16 16 16 0 0 None
0x12a 0 sg 0 16 0 r . . 5 6 5 0 . . 4 16 0 16 16 16 16 0 0 None
0x12b 0 sg 0 16 0 r y . 5 6 5 0 . . 4 24 0 16 16 16 16 0 0 None
0x12c 0 sg 0 16 0 r . . 5 6 5 0 . . 4 24 0 16 16 16 16 0 0 None
0x12d 0 sg 0 16 0 r y . 5 6 5 0 . . 4 24 8 16 16 16 16 0 0 None
0x12e 0 sg 0 16 0 r . . 5 6 5 0 . . 4 24 8 16 16 16 16 0 0 None
0x12f 0 sg 0 16 0 r y . 5 6 5 0 . . 4 0 0 16 16 16 16 0 0 None
0x130 0 sg 0 16 0 r . . 5 6 5 0 . . 4 0 0 16 16 16 16 0 0 None
0x131 0 sg 0 0 0 r . . 0 0 0 0 . . 4 16 0 16 16 16 16 0 0 None
0x132 0 sg 0 0 0 r . . 0 0 0 0 . . 4 24 0 16 16 16 16 0 0 None
0x133 0 sg 0 0 0 r . . 0 0 0 0 . . 4 24 8 16 16 16 16 0 0 None
0x134 0 sg 0 32 0 r . . 16 16 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x135 0 sg 0 32 0 . . 16 16 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x136 0 sg 0 32 0 r y . 16 16 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x137 0 sg 0 32 0 y . 16 16 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x138 0 sg 0 32 0 r . . 32 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x139 0 sg 0 32 0 . . 32 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x13a 0 sg 0 32 0 r y . 32 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x13b 0 sg 0 32 0 y . 32 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x13c 0 sg 0 64 0 r . . 16 16 16 16 f . 4 0 0 16 16 16 16 0 0 None
0x13d 0 sg 0 64 0 . . 16 16 16 16 f . 4 0 0 16 16 16 16 0 0 None
0x13e 0 sg 0 64 0 r y . 16 16 16 16 f . 4 0 0 16 16 16 16 0 0 None
0x13f 0 sg 0 64 0 y . 16 16 16 16 f . 4 0 0 16 16 16 16 0 0 None
0x140 0 sg 0 128 0 r . . 32 32 32 32 f . 4 0 0 16 16 16 16 0 0 None
0x141 0 sg 0 128 0 . . 32 32 32 32 f . 4 0 0 16 16 16 16 0 0 None
0x142 0 sg 0 128 0 r y . 32 32 32 32 f . 4 0 0 16 16 16 16 0 0 None
0x143 0 sg 0 128 0 y . 32 32 32 32 f . 4 0 0 16 16 16 16 0 0 None
0x144 0 sg 0 32 0 r . . 16 16 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x145 0 sg 0 32 0 . . 16 16 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x146 0 sg 0 32 0 r y . 16 16 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x147 0 sg 0 32 0 y . 16 16 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x148 0 sg 0 32 0 r . . 16 16 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x149 0 sg 0 32 0 . . 16 16 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x14a 0 sg 0 32 0 r y . 16 16 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x14b 0 sg 0 32 0 y . 16 16 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x14c 0 sg 0 32 0 r . . 32 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x14d 0 sg 0 32 0 . . 32 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x14e 0 sg 0 32 0 r y . 32 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x14f 0 sg 0 32 0 y . 32 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x150 0 sg 0 32 0 r . . 32 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x151 0 sg 0 32 0 . . 32 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x152 0 sg 0 32 0 r y . 32 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x153 0 sg 0 32 0 y . 32 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x154 0 sg 0 64 0 r . . 16 16 16 16 f . 4 24 0 16 16 16 16 0 0 None
0x155 0 sg 0 64 0 . . 16 16 16 16 f . 4 24 0 16 16 16 16 0 0 None
0x156 0 sg 0 64 0 r y . 16 16 16 16 f . 4 24 0 16 16 16 16 0 0 None
0x157 0 sg 0 64 0 y . 16 16 16 16 f . 4 24 0 16 16 16 16 0 0 None
0x158 0 sg 0 64 0 r . . 16 16 16 16 f . 4 24 8 16 16 16 16 0 0 None
0x159 0 sg 0 64 0 . . 16 16 16 16 f . 4 24 8 16 16 16 16 0 0 None
0x15a 0 sg 0 64 0 r y . 16 16 16 16 f . 4 24 8 16 16 16 16 0 0 None
0x15b 0 sg 0 64 0 y . 16 16 16 16 f . 4 24 8 16 16 16 16 0 0 None
0x15c 0 sg 0 128 0 r . . 32 32 32 32 f . 4 24 0 16 16 16 16 0 0 None
0x15d 0 sg 0 128 0 . . 32 32 32 32 f . 4 24 0 16 16 16 16 0 0 None
0x15e 0 sg 0 128 0 r y . 32 32 32 32 f . 4 24 0 16 16 16 16 0 0 None
0x15f 0 sg 0 128 0 y . 32 32 32 32 f . 4 24 0 16 16 16 16 0 0 None
0x160 0 sg 0 128 0 r . . 32 32 32 32 f . 4 24 8 16 16 16 16 0 0 None
0x161 0 sg 0 128 0 . . 32 32 32 32 f . 4 24 8 16 16 16 16 0 0 None
0x162 0 sg 0 128 0 r y . 32 32 32 32 f . 4 24 8 16 16 16 16 0 0 None
0x163 0 sg 0 128 0 y . 32 32 32 32 f . 4 24 8 16 16 16 16 0 0 None
0x164 0 sg 0 16 0 r . . 16 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x165 0 sg 0 16 0 . . 16 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x166 0 sg 0 16 0 r y . 16 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x167 0 sg 0 16 0 y . 16 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x168 0 sg 0 64 0 r . . 32 32 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x169 0 sg 0 64 0 . . 32 32 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x16a 0 sg 0 64 0 r y . 32 32 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x16b 0 sg 0 64 0 y . 32 32 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x16c 0 sg 0 16 0 r . . 16 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x16d 0 sg 0 16 0 . . 16 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x16e 0 sg 0 16 0 r y . 16 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x16f 0 sg 0 16 0 y . 16 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x170 0 sg 0 16 0 r . . 16 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x171 0 sg 0 16 0 . . 16 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x172 0 sg 0 16 0 r y . 16 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x173 0 sg 0 16 0 y . 16 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x174 0 sg 0 64 0 r . . 32 32 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x175 0 sg 0 64 0 . . 32 32 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x176 0 sg 0 64 0 r y . 32 32 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x177 0 sg 0 64 0 y . 32 32 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x178 0 sg 0 64 0 r . . 32 32 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x179 0 sg 0 64 0 . . 32 32 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x17a 0 sg 0 64 0 r y . 32 32 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x17b 0 sg 0 64 0 y . 32 32 0 0 f . 4 24 8 16 16 16 16 0 0 None
